Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/62625 )
Change subject: mb/google/brya/var/kinox: Modify the DPTF/Fan parameters ......................................................................
Follow the Thermal_paramters_list-0314.xlsx to modify DPTF/Fan parameters.
BUG=b:221180425, b:222020226, b:221182596 TEST=emerge-brask coreboot
Signed-off-by: Dtrain Hsu dtrain_hsu@compal.corp-partner.google.com Change-Id: I5f44120430029130d38b89d0eab6bbf205aca929 Reviewed-on: https://review.coreboot.org/c/coreboot/+/62625 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Sumeet R Pawnikar sumeet.r.pawnikar@intel.com Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/mainboard/google/brya/variants/kinox/overridetree.cb 1 file changed, 141 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Sumeet R Pawnikar: Looks good to me, but someone else must approve Tim Wawrzynczak: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/kinox/overridetree.cb b/src/mainboard/google/brya/variants/kinox/overridetree.cb index 4168c4f..a4050ee 100644 --- a/src/mainboard/google/brya/variants/kinox/overridetree.cb +++ b/src/mainboard/google/brya/variants/kinox/overridetree.cb @@ -46,6 +46,147 @@ }"
device domain 0 on + device ref dtt on + chip drivers/intel/dptf + ## sensor information + register "options.tsr[0].desc" = ""DRAM_SOC"" + register "options.tsr[1].desc" = ""Ambient"" + register "options.tsr[2].desc" = ""Charger"" + register "options.tsr[3].desc" = ""WWAN"" + + # TODO: below values are initial reference values only + ## Active Policy + register "policies.active" = "{ + [0] = { + .target = DPTF_CPU, + .thresholds = { + TEMP_PCT(80, 97), + TEMP_PCT(65, 93), + TEMP_PCT(58, 86), + TEMP_PCT(50, 80), + TEMP_PCT(45, 64), + TEMP_PCT(43, 52), + TEMP_PCT(40, 47), + TEMP_PCT(35, 40), + } + }, + [1] = { + .target = DPTF_TEMP_SENSOR_1, + .thresholds = { + TEMP_PCT(75, 97), + TEMP_PCT(70, 93), + TEMP_PCT(60, 86), + TEMP_PCT(52, 80), + TEMP_PCT(47, 64), + TEMP_PCT(43, 52), + TEMP_PCT(40, 47), + TEMP_PCT(35, 40), + } + }, + [2] = { + .target = DPTF_TEMP_SENSOR_2, + .thresholds = { + TEMP_PCT(75, 97), + TEMP_PCT(70, 93), + TEMP_PCT(60, 86), + TEMP_PCT(52, 80), + TEMP_PCT(47, 64), + TEMP_PCT(43, 52), + TEMP_PCT(40, 47), + TEMP_PCT(35, 40), + } + }, + [3] = { + .target = DPTF_TEMP_SENSOR_3, + .thresholds = { + TEMP_PCT(75, 97), + TEMP_PCT(70, 93), + TEMP_PCT(60, 86), + TEMP_PCT(52, 80), + TEMP_PCT(47, 64), + TEMP_PCT(43, 52), + TEMP_PCT(40, 47), + TEMP_PCT(35, 40), + } + }, + [4] = { + .target = DPTF_TEMP_SENSOR_4, + .thresholds = { + TEMP_PCT(75, 97), + TEMP_PCT(70, 93), + TEMP_PCT(60, 86), + TEMP_PCT(52, 80), + TEMP_PCT(47, 64), + TEMP_PCT(43, 52), + TEMP_PCT(40, 47), + TEMP_PCT(35, 40), + } + } + }" + + ## Passive Policy + register "policies.passive" = "{ + [0] = DPTF_PASSIVE(CPU, CPU, 90, 10000), + [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 90, 10000), + [2] = DPTF_PASSIVE(CPU, TEMP_SENSOR_1, 90, 10000), + [3] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_2, 90, 10000), + [4] = DPTF_PASSIVE(CPU, TEMP_SENSOR_3, 90, 10000), + }" + + ## Critical Policy + register "policies.critical" = "{ + [0] = DPTF_CRITICAL(CPU, 100, SHUTDOWN), + [1] = DPTF_CRITICAL(TEMP_SENSOR_0, 93, SHUTDOWN), + [2] = DPTF_CRITICAL(TEMP_SENSOR_1, 93, SHUTDOWN), + [3] = DPTF_CRITICAL(TEMP_SENSOR_2, 93, SHUTDOWN), + [4] = DPTF_CRITICAL(TEMP_SENSOR_3, 93, SHUTDOWN), + }" + + register "controls.power_limits" = "{ + .pl1 = { + .min_power = 15000, + .max_power = 17000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 28 * MSECS_PER_SEC, + .granularity = 500, + }, + .pl2 = { + .min_power = 39000, + .max_power = 39000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 1000, + } + }" + + ## Charger Performance Control (Control, mA) + register "controls.charger_perf" = "{ + [0] = { 255, 1700 }, + [1] = { 24, 1500 }, + [2] = { 16, 1000 }, + [3] = { 8, 500 } + }" + ## Fan Performance Control (Percent, Speed, Noise, Power) + register "controls.fan_perf" = "{ + [0] = { 90, 6700, 220, 2200, }, + [1] = { 80, 5800, 180, 1800, }, + [2] = { 70, 5000, 145, 1450, }, + [3] = { 60, 4900, 115, 1150, }, + [4] = { 50, 3838, 90, 900, }, + [5] = { 40, 2904, 55, 550, }, + [6] = { 30, 2337, 30, 300, }, + [7] = { 20, 1608, 15, 150, }, + [8] = { 10, 800, 10, 100, }, + [9] = { 0, 0, 0, 50, } + }" + + ## Fan options + register "options.fan.fine_grained_control" = "1" + register "options.fan.step_size" = "2" + + device generic 0 alias dptf_policy on end + end + end device ref pcie_rp7 on chip drivers/net register "customized_leds" = "0x05af"
