Ren Kuo has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31803
Change subject: mb/google/poppy/variant/nami: change the vbt bin loading for bard sku ......................................................................
remove the bard vbt bin in coreboot,and add it in cbfs(CL:990403) to fix the bugs
BUG=b:127552559 b:127611290 TEST= build the coreboot and firmware include CL:990403 to verify
Change-Id: I1202de5757a3e0703ebbe201e57be3ee7a47fa0d Signed-off-by: Ren Kuo ren.kuo@quanta.corp-partner.google.com --- M src/mainboard/google/poppy/variants/nami/Makefile.inc D src/mainboard/google/poppy/variants/nami/bard-data.vbt 2 files changed, 0 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/31803/1
diff --git a/src/mainboard/google/poppy/variants/nami/Makefile.inc b/src/mainboard/google/poppy/variants/nami/Makefile.inc index dc80357..7f86bb7 100644 --- a/src/mainboard/google/poppy/variants/nami/Makefile.inc +++ b/src/mainboard/google/poppy/variants/nami/Makefile.inc @@ -41,5 +41,3 @@ cbfs-files-y += oem.bin oem.bin-file := $(call strip_quotes,$(CONFIG_OEM_BIN_FILE)) oem.bin-type := raw - -$(call add_vbt_to_cbfs, vbt-bard.bin, bard-data.vbt) diff --git a/src/mainboard/google/poppy/variants/nami/bard-data.vbt b/src/mainboard/google/poppy/variants/nami/bard-data.vbt deleted file mode 100644 index cdaca6a..0000000 --- a/src/mainboard/google/poppy/variants/nami/bard-data.vbt +++ /dev/null Binary files differ
Ren Kuo has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31803 )
Patch Set 1: Code-Review+1
Hello Shelley Chen, build bot (Jenkins), Furquan Shaikh, Patrick Georgi, Martin Roth,
remove the bard vbt bin in coreboot,and add it in cbfs(CL:*990403) to fix the bugs
BUG=b:127552559 b:127611290 TEST= build the coreboot and firmware include CL:*990403 to verify
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/31803/2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31803 )
Patch Set 2:
(6 comments)
You should not score your on change-set.
https://review.coreboot.org/#/c/31803/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/#/c/31803/2//COMMIT_MSG@9 PS2, Line 9: coreboot,and Please add a space after the comma (,).
https://review.coreboot.org/#/c/31803/2//COMMIT_MSG@9 PS2, Line 9: cbfs(CL:*990403) Please add a space before the opening bracket (.
https://review.coreboot.org/#/c/31803/2//COMMIT_MSG@9 PS2, Line 9: vbt VBT
https://review.coreboot.org/#/c/31803/2//COMMIT_MSG@9 PS2, Line 9: remove Remove
https://review.coreboot.org/#/c/31803/2//COMMIT_MSG@10 PS2, Line 10: to fix the bugs Please elaborate, what bug is fixed. Not all reviewers have access to the bug report.
https://review.coreboot.org/#/c/31803/2//COMMIT_MSG@9 PS2, Line 9: remove the bard vbt bin in coreboot,and add it in cbfs(CL:*990403) : to fix the bugs Please add a dot/period at the end.
Change subject: mb/google/poppy/variant/nami: change the VBT loading for bard sku ......................................................................
Remove the bard VBT in coreboot, and add it in cbfs (CL:*990403) to fix the two bugs as following.
Bug 1: (b:127552559) Bard: System unable to show up the recovery mode screen and DEV mode screen
Bug 2: (b:127611290) Suspend stress FAIL by ERROR: Failed to clear screen
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/31803/3
Patch Set 3:
Patch Set 2:
(6 comments)
Modified the commit message.Please help to review it again.
Ren Kuo has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/31803 )
Abandoned
Furquan Shaikh furquan@google.com #8 Mar 9, 2019 02:21AM Ren, the issue is that this CL was never cherry-picked to nami branch. Can you please try only this CL cherry-picked to nami branch to see if it fixes the problem for you: https://chromium-review.googlesource.com/1392644
