Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5408
commit 95887069dd905c7aab4c451f508adc3c1c6f48ea Author: Aaron Durbin adurbin@chromium.org Date: Wed Mar 26 22:57:55 2014 -0500
cbfstool: provide structure to linux payload builder
This change started with tracking down a bug where the trampoline size was not being taken into account for sizing the output buffer leading to a heap corruption. I was having a hard time keeping track of what num_segments actually tracked as well as what parts were being placed in the output buffer. Here's my attempt at hopefully providing more clarity.
This change doesn't crash when adding a bzImage: $ dd if=/dev/zero of=bb.bin bs=64 count=1 $ ./cbfstool tmp.rom create -s 4M -B bb.bin -m x86 -a 64 $ ./cbfstool tmp.rom add-payload -f ~/Downloads/bzImage -C "1" -n "fallback"/payload
Change-Id: Ib1de1ddfec3c7102facffc5815c52b340fcdc628 Signed-off-by: Aaron Durbin adurbin@chromium.org --- util/cbfstool/cbfs-payload-linux.c | 311 +++++++++++++++++++++++-------------- util/cbfstool/common.h | 13 +- 2 files changed, 208 insertions(+), 116 deletions(-)
diff --git a/util/cbfstool/cbfs-payload-linux.c b/util/cbfstool/cbfs-payload-linux.c index c965e39..12fa238 100644 --- a/util/cbfstool/cbfs-payload-linux.c +++ b/util/cbfstool/cbfs-payload-linux.c @@ -25,6 +25,165 @@ #include "cbfs.h" #include "linux.h"
+/* trampoline */ +extern void *trampoline_start; +extern long trampoline_size; + +/* + * Current max number of segments include: + * + * 1. parameters + * 2. kernel + * 3. trampoline + * 4. optional cmdline + * 5. optional initrd + * 6. terminating entry segment + */ +#define MAX_NUM_SEGMENTS 6 + +struct bzpayload { + /* Input variables. */ + int num_segments; + struct cbfs_payload_segment segs[MAX_NUM_SEGMENTS]; + struct buffer parameters; + struct buffer kernel; + struct buffer trampoline; + struct buffer cmdline; + struct buffer initrd; + /* Output variables. */ + comp_algo algo; + comp_func_ptr compress; + struct buffer output; + size_t offset; + struct cbfs_payload_segment *out_seg; +}; + +static int bzp_init(struct bzpayload *bzp, comp_algo algo) +{ + memset(bzp, 0, sizeof(*bzp)); + + /* + * Need at least the terminating entry segment. + */ + bzp->num_segments = 1; + + buffer_init(&bzp->trampoline, NULL, trampoline_start, trampoline_size); + + bzp->algo = algo; + bzp->compress = compression_function(algo); + if (bzp->compress == NULL) { + ERROR("Invalid compression algorithm specified.\n"); + return -1; + } + + return 0; +} + +static int bzp_add_initrd(struct bzpayload *bzp, const char *fname) +{ + if (fname == NULL) + return 0; + + if (buffer_from_file(&bzp->initrd, fname)) { + ERROR("could not open initrd.\n"); + return -1; + } + + bzp->num_segments++; + + return 0; +} + +static void bzp_add_segment(struct bzpayload *bzp, struct buffer *b, void *data, + size_t size) +{ + buffer_init(b, NULL, data, size); + bzp->num_segments++; +} + + +static int bzp_add_cmdline(struct bzpayload *bzp, char *cmdline) +{ + if (cmdline == NULL) + return 0; + + bzp_add_segment(bzp, &bzp->cmdline, cmdline, strlen(cmdline) + 1); + + return 0; +} + +static int bzp_add_params(struct bzpayload *bzp, struct linux_params *params) +{ + bzp_add_segment(bzp, &bzp->parameters, params, sizeof(*params)); + + return 0; +} + +static int bzp_add_kernel(struct bzpayload *bzp, const struct buffer *in, + size_t setup_size) +{ + char *input = buffer_get(in); + size_t kern_sz = buffer_size(in) - setup_size; + + bzp_add_segment(bzp, &bzp->kernel, &input[setup_size], kern_sz); + + return 0; +} + +static int bzp_init_output(struct bzpayload *bzp, const char *name) +{ + size_t sz = 0; + + sz += buffer_size(&bzp->parameters); + sz += buffer_size(&bzp->kernel); + sz += buffer_size(&bzp->trampoline); + sz += buffer_size(&bzp->cmdline); + sz += buffer_size(&bzp->initrd); + + bzp->offset = bzp->num_segments * sizeof(struct cbfs_payload_segment); + sz += bzp->offset; + + if (buffer_create(&bzp->output, sz, name) != 0) + return -1; + + bzp->out_seg = &bzp->segs[0]; + + return 0; +} + +static void bzp_output_segment(struct bzpayload *bzp, struct buffer *b, + uint32_t type, uint64_t load_addr) +{ + struct buffer out; + struct cbfs_payload_segment *seg; + int len = 0; + + /* Don't process empty buffers. */ + if (b != NULL && buffer_size(b) == 0) + return; + + seg = bzp->out_seg; + seg->type = type; + seg->load_addr = load_addr; + bzp->out_seg++; + + /* No buffer associated with segment. */ + if (b == NULL) + return; + + /* Use a temp buffer for easier management. */ + buffer_splice(&out, &bzp->output, bzp->offset, buffer_size(b)); + + seg->mem_len = buffer_size(b); + seg->offset = bzp->offset; + bzp->compress(buffer_get(b), buffer_size(b), buffer_get(&out), &len); + seg->compression = bzp->algo; + seg->len = len; + + /* Update output offset. */ + bzp->offset += len; +} + /* TODO: * handle special arguments * mem= argument - only affects loading decisions (kernel + initrd), not e820 -> build time @@ -42,47 +201,20 @@ int parse_bzImage_to_payload(const struct buffer *input, struct buffer *output, const char *initrd_name, char *cmdline, comp_algo algo) { - int cur_len = 0; - int num_segments = 3; /* parameter block, real kernel, and trampoline */ + struct bzpayload bzp; + unsigned int initrd_base = 64*1024*1024; + struct linux_header *hdr = (struct linux_header *)input->data; + unsigned int setup_size = 4 * 512;
- comp_func_ptr compress = compression_function(algo); - if (!compress) + if (bzp_init(&bzp, algo) != 0) return -1;
- unsigned int initrd_base = 64*1024*1024; - unsigned int initrd_size = 0; - void *initrd_data = NULL; - if (initrd_name != NULL) { - /* TODO: load initrd, set initrd_size */ - num_segments++; - FILE *initrd_file = fopen(initrd_name, "rb"); - if (!initrd_file) { - ERROR("could not open initrd.\n"); - return -1; - } - fseek(initrd_file, 0, SEEK_END); - initrd_size = ftell(initrd_file); - fseek(initrd_file, 0, SEEK_SET); - initrd_data = malloc(initrd_size); - if (!initrd_data) { - ERROR("could not allocate memory for initrd.\n"); - return -1; - } - if (fread(initrd_data, initrd_size, 1, initrd_file) != 1) { - ERROR("could not load initrd.\n"); - return -1; - } - fclose(initrd_file); - } + if (bzp_add_initrd(&bzp, initrd_name) != 0) + return -1;
- unsigned int cmdline_size = 0; - if (cmdline != NULL) { - num_segments++; - cmdline_size = strlen(cmdline) + 1; - } + if (bzp_add_cmdline(&bzp, cmdline) != 0) + return -1;
- struct linux_header *hdr = (struct linux_header *)input->data; - unsigned int setup_size = 4 * 512; if (hdr->setup_sects != 0) { setup_size = (hdr->setup_sects + 1) * 512; } @@ -132,106 +264,59 @@ int parse_bzImage_to_payload(const struct buffer *input, * this information for its jump to real Linux. */ params.kernel_start = kernel_base;
- void *kernel_data = input->data + setup_size; - unsigned int kernel_size = input->size - setup_size; + if (bzp_add_kernel(&bzp, input, setup_size) != 0) + return -1;
- if (initrd_data != NULL) { + if (buffer_size(&bzp.initrd) != 0) { /* TODO: this is a bit of a hack. Linux recommends to store * initrd near to end-of-mem, but that's hard to do on build * time. It definitely fails to read the image if it's too * close to the kernel, so give it some room. */ - initrd_base = ALIGN(kernel_base + kernel_size, 16*1024*1024); + initrd_base = kernel_base + buffer_size(&bzp.kernel); + initrd_base = ALIGN(initrd_base, 16*1024*1024);
params.initrd_start = initrd_base; - params.initrd_size = initrd_size; + params.initrd_size = buffer_size(&bzp.initrd); }
- struct cbfs_payload_segment *segs; - unsigned long doffset = (num_segments + 1) * sizeof(*segs); - - /* Allocate a block of memory to store the data in */ - int isize = sizeof(params) + kernel_size + cmdline_size + initrd_size; - if (buffer_create(output, doffset + isize, input->name) != 0) + if (bzp_add_params(&bzp, ¶ms) != 0) return -1; - memset(output->data, 0, output->size);
- segs = calloc(num_segments, sizeof(*segs)); + if (bzp_init_output(&bzp, input->name) != 0) + return -1;
/* parameter block */ - segs[0].type = PAYLOAD_SEGMENT_DATA; - segs[0].load_addr = LINUX_PARAM_LOC; - segs[0].mem_len = sizeof(params); - segs[0].offset = doffset; - - compress((void*)¶ms, sizeof(params), output->data + doffset, &cur_len); - segs[0].compression = algo; - segs[0].len = cur_len; - - doffset += cur_len; + bzp_output_segment(&bzp, &bzp.parameters, + PAYLOAD_SEGMENT_DATA, LINUX_PARAM_LOC);
/* code block */ - segs[1].type = PAYLOAD_SEGMENT_CODE; - segs[1].load_addr = kernel_base; - segs[1].mem_len = kernel_size; - segs[1].offset = doffset; - - compress(kernel_data, kernel_size, output->data + doffset, &cur_len); - segs[1].compression = algo; - segs[1].len = cur_len; - - doffset += cur_len; + bzp_output_segment(&bzp, &bzp.kernel, + PAYLOAD_SEGMENT_CODE, kernel_base);
/* trampoline */ - extern void *trampoline_start; - extern long trampoline_size; - - unsigned int entrypoint = 0x40000; /* TODO: any better place? */ - - segs[2].type = PAYLOAD_SEGMENT_CODE; - segs[2].load_addr = entrypoint; - segs[2].mem_len = trampoline_size; - segs[2].offset = doffset; - - compress(trampoline_start, trampoline_size, output->data + doffset, &cur_len); - segs[2].compression = algo; - segs[2].len = cur_len; + uint64_t entrypoint = 0x40000; /*TODO: any better place? */ + bzp_output_segment(&bzp, &bzp.trampoline, + PAYLOAD_SEGMENT_CODE, entrypoint);
- doffset += cur_len; + /* cmdline */ + bzp_output_segment(&bzp, &bzp.cmdline, + PAYLOAD_SEGMENT_DATA, COMMAND_LINE_LOC);
- if (cmdline_size > 0) { - /* command line block */ - segs[3].type = PAYLOAD_SEGMENT_DATA; - segs[3].load_addr = COMMAND_LINE_LOC; - segs[3].mem_len = cmdline_size; - segs[3].offset = doffset; + /* initrd */ + bzp_output_segment(&bzp, &bzp.initrd, + PAYLOAD_SEGMENT_DATA, initrd_base);
- compress(cmdline, cmdline_size, output->data + doffset, &cur_len); - segs[3].compression = algo; - segs[3].len = cur_len; + /* Terminating entry segment. */ + bzp_output_segment(&bzp, NULL, PAYLOAD_SEGMENT_ENTRY, entrypoint);
- doffset += cur_len; - } - - if (initrd_size > 0) { - /* setup block */ - segs[num_segments-1].type = PAYLOAD_SEGMENT_DATA; - segs[num_segments-1].load_addr = initrd_base; - segs[num_segments-1].mem_len = initrd_size; - segs[num_segments-1].offset = doffset; - - compress(initrd_data, initrd_size, output->data + doffset, &cur_len); - segs[num_segments-1].compression = algo; - segs[num_segments-1].len = cur_len; - - doffset += cur_len; - } + /* Set size of buffer taking into account potential compression. */ + buffer_set_size(&bzp.output, bzp.offset); + /* Make passed-in output buffer be valid. */ + buffer_clone(output, &bzp.output);
- /* prepare entry point segment */ - segs[num_segments].type = PAYLOAD_SEGMENT_ENTRY; - segs[num_segments].load_addr = entrypoint; - output->size = doffset; - xdr_segs(output, segs, num_segments); + /* Serialize the segments with the correct encoding. */ + xdr_segs(output, bzp.segs, bzp.num_segments); return 0; }
diff --git a/util/cbfstool/common.h b/util/cbfstool/common.h index 3cb94b6..b1f25d0 100644 --- a/util/cbfstool/common.h +++ b/util/cbfstool/common.h @@ -63,6 +63,15 @@ static inline void buffer_set_size(struct buffer *b, size_t size) b->size = size; }
+/* Initialize a buffer with the given constraints. */ +static inline void buffer_init(struct buffer *b, char *name, void *data, + size_t size) +{ + b->name = name; + b->data = data; + b->size = size; +} + /* * Splice a buffer into another buffer. If size is zero the entire buffer * is spliced while if size is non-zero the buffer is spliced starting at @@ -71,9 +80,7 @@ static inline void buffer_set_size(struct buffer *b, size_t size) static inline void buffer_splice(struct buffer *dest, const struct buffer *src, size_t offset, size_t size) { - dest->name = src->name; - dest->data = src->data; - dest->size = src->size; + buffer_init(dest, src->name, src->data, src->size); if (size != 0) { dest->data += offset; buffer_set_size(dest, size);
