Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/36092 )
Change subject: cpu/intel/common: Enable GetSec leafes for Intel TXT ......................................................................
Similar to VMX and SMX also enable all GetSec leafes for Intel TXT.
Change-Id: I89620c2a98cfceaa785b1a798fafbf35cc99a0b2 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/cpu/intel/common/common_init.c 1 file changed, 6 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/36092/1
diff --git a/src/cpu/intel/common/common_init.c b/src/cpu/intel/common/common_init.c index 2fff90c..93d324e 100644 --- a/src/cpu/intel/common/common_init.c +++ b/src/cpu/intel/common/common_init.c @@ -56,8 +56,13 @@
if (enable) { msr.lo |= (1 << 2); - if (feature_flag & CPUID_SMX) + if (feature_flag & CPUID_SMX) { msr.lo |= (1 << 1); + if (CONFIG(INTEL_TXT)) { + /* Enable GetSec and all GetSec leafes */ + msr.lo |= (0xff << 8); + } + } }
wrmsr(IA32_FEATURE_CONTROL, msr);
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36092 )
Patch Set 1:
(3 comments)
https://review.coreboot.org/c/coreboot/+/36092/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/36092/1//COMMIT_MSG@7 PS1, Line 7: leafes leaves?
https://review.coreboot.org/c/coreboot/+/36092/1//COMMIT_MSG@9 PS1, Line 9: leafes Ditto.
https://review.coreboot.org/c/coreboot/+/36092/1//COMMIT_MSG@10 PS1, Line 10: How can it be tested, that the leaves are enabled?
Philipp Deppenwiese has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36092 )
Patch Set 1: Code-Review+2
David Hendricks has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36092 )
Hello Patrick Rudolph, David Hendricks, Philipp Deppenwiese, build bot (Jenkins),
Change subject: cpu/intel/common: Enable GetSec leaves for Intel TXT ......................................................................
Similar to VMX and SMX also enable all GetSec leaves for Intel TXT.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/36092/2
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/36092/3
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36092 )
Patch Set 3:
(3 comments)
leaves?
Done
Ditto.
Done
Issue the corresponding GetSec instruction.
Patch Set 3: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/36092 )
Change-Id: I89620c2a98cfceaa785b1a798fafbf35cc99a0b2 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/36092 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Philipp Deppenwiese zaolin.daisuki@gmail.com --- M src/cpu/intel/common/common_init.c 1 file changed, 6 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Philipp Deppenwiese: Looks good to me, approved
diff --git a/src/cpu/intel/common/common_init.c b/src/cpu/intel/common/common_init.c index 2fff90c..9819ee7 100644 --- a/src/cpu/intel/common/common_init.c +++ b/src/cpu/intel/common/common_init.c @@ -56,8 +56,13 @@
if (enable) { msr.lo |= (1 << 2); - if (feature_flag & CPUID_SMX) + if (feature_flag & CPUID_SMX) { msr.lo |= (1 << 1); + if (CONFIG(INTEL_TXT)) { + /* Enable GetSec and all GetSec leaves */ + msr.lo |= (0xff << 8); + } + } }
