Attention is currently required from: Marshall Dawson. Felix Held has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/59968 )
Change subject: soc/amd/stoneyridge: use common fch_spi_early_init ......................................................................
All SPI interface setup related functionality that Stoneyridge implemented in its southbridge code is already present in the common AMD SoC code, so use that code instead.
The common fch_spi_early_init function requires the SPI controller's base address to be set, so call lpc_set_spibase(SPI_BASE_ADDRESS) right before it. fch_spi_early_init then calls lpc_enable_spi_rom and lpc_enable_spi_prefetch which can be removed from the board code now. Next it calls fch_spi_configure_4dw_burst which does the same as the now removed sb_disable_4dw_burst function when SOC_AMD_COMMON_BLOCK_SPI_4DW_BURST is set to n which is the default. This option can also only be set to y for SoCs that aren't Stoneyridge. Finally fch_spi_early_init calls fch_spi_config_modes which configures the SPI mode and speed settings according to the Kconfig settings and the settings in the amdfw part. On Kahlee this was done by calls to sb_read_mode and sb_set_spi100 before. The previous patch added the remaining Kconfig settings, so the resulting register values don't change in the non-EM100 case. In the EM100 case the TPM speed is changed from 64 to 16 MHz.
TEST=Both the non-EM100 mode with a real SPI flash and the EM100 mode with a first-generation EM100 results in Google/Barla reaching the payload and the show_spi_speeds_and_modes call in bootblock prints the expected settings:
relevant bootblock console output in non-EM100 case:
SPI normal read speed: 33.33 MHz SPI fast read speed: 66.66 Mhz SPI alt read speed: 66.66 Mhz SPI TPM read speed: 66.66 Mhz SPI100: Enabled SPI Read Mode: Dual IO (1-2-2)
relevant bootblock console output in EM100 case:
SPI normal read speed: 16.66 MHz SPI fast read speed: 16.66 MHz SPI alt read speed: 16.66 MHz SPI TPM read speed: 16.66 MHz SPI100: Enabled SPI Read Mode: Normal Read (up to 33M)
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I8f37a3b040808d6a5a8e07d39b6d4a1e1981355c --- M src/mainboard/google/kahlee/bootblock/bootblock.c M src/soc/amd/stoneyridge/include/soc/southbridge.h M src/soc/amd/stoneyridge/southbridge.c 3 files changed, 3 insertions(+), 95 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/59968/1
diff --git a/src/mainboard/google/kahlee/bootblock/bootblock.c b/src/mainboard/google/kahlee/bootblock/bootblock.c index 9b456c8..0ee9b58 100644 --- a/src/mainboard/google/kahlee/bootblock/bootblock.c +++ b/src/mainboard/google/kahlee/bootblock/bootblock.c @@ -25,32 +25,6 @@
void bootblock_mainboard_init(void) { - if (CONFIG(EM100)) { - /* - * We should be able to rely on defaults, but it seems safer - * to explicitly set up these registers. - */ - sb_read_mode(SPI_READ_MODE_NOM); - sb_set_spi100(SPI_SPEED_16M, /* Normal */ - SPI_SPEED_16M, /* Fast */ - SPI_SPEED_16M, /* AltIO */ - SPI_SPEED_66M); /* TPM */ - } else { - /* - * W25Q128FW Setup - * Normal Read 40MHz - * Fast Read 104MHz - * Dual Read IO (1-2-2) - */ - sb_read_mode(SPI_READ_MODE_DUAL122); - - /* Set SPI speeds before verstage. Needed for TPM */ - sb_set_spi100(SPI_SPEED_33M, /* Normal */ - SPI_SPEED_66M, /* Fast */ - SPI_SPEED_66M, /* AltIO */ - SPI_SPEED_66M); /* TPM */ - } - /* Setup TPM decode before verstage */ lpc_tpm_decode_spi(); } diff --git a/src/soc/amd/stoneyridge/include/soc/southbridge.h b/src/soc/amd/stoneyridge/include/soc/southbridge.h index 74e9498..2773751 100644 --- a/src/soc/amd/stoneyridge/include/soc/southbridge.h +++ b/src/soc/amd/stoneyridge/include/soc/southbridge.h @@ -142,41 +142,6 @@ #define SATA_CAPABILITIES_REG 0xfc #define SATA_CAPABILITY_SPM BIT(12)
-#define SPI_CNTRL0 0x00 -#define SPI_BUSY BIT(31) -#define SPI_READ_MODE_MASK (BIT(30) | BIT(29) | BIT(18)) -/* Nominal is 16.7MHz on older devices, 33MHz on newer */ -#define SPI_READ_MODE_NOM 0x00000000 -#define SPI_READ_MODE_DUAL112 ( BIT(29) ) -#define SPI_READ_MODE_QUAD114 ( BIT(29) | BIT(18)) -#define SPI_READ_MODE_DUAL122 (BIT(30) ) -#define SPI_READ_MODE_QUAD144 (BIT(30) | BIT(18)) -#define SPI_READ_MODE_NORMAL66 (BIT(30) | BIT(29) ) -#define SPI_READ_MODE_FAST (BIT(30) | BIT(29) | BIT(18)) -#define SPI_ACCESS_MAC_ROM_EN BIT(22) -#define SPI_FIFO_PTR_CLR BIT(20) -#define SPI_ARB_ENABLE BIT(19) -#define EXEC_OPCODE BIT(16) - -#define SPI100_ENABLE 0x20 -#define SPI_USE_SPI100 BIT(0) - -/* Use SPI_SPEED_16M-SPI_SPEED_66M below for the southbridge */ -#define SPI100_SPEED_CONFIG 0x22 -#define SPI_SPEED_66M (0x0) -#define SPI_SPEED_33M ( BIT(0)) -#define SPI_SPEED_22M ( BIT(1) ) -#define SPI_SPEED_16M ( BIT(1) | BIT(0)) -#define SPI_SPEED_100M (BIT(2) ) -#define SPI_SPEED_800K (BIT(2) | BIT(0)) -#define SPI_NORM_SPEED_NEW_SH 12 -#define SPI_FAST_SPEED_NEW_SH 8 -#define SPI_ALT_SPEED_NEW_SH 4 -#define SPI_TPM_SPEED_NEW_SH 0 - -#define SPI100_HOST_PREF_CONFIG 0x2c -#define SPI_RD4DW_EN_HOST BIT(15) - /* Platform Security Processor D8F0 */ void soc_enable_psp_early(void);
@@ -219,8 +184,6 @@
void enable_aoac_devices(void); void fch_clk_output_48Mhz(u32 osc); -void sb_read_mode(u32 mode); -void sb_set_spi100(u16 norm, u16 fast, u16 alt, u16 tpm);
/* * Call the mainboard to get the USB Over Current Map. The mainboard diff --git a/src/soc/amd/stoneyridge/southbridge.c b/src/soc/amd/stoneyridge/southbridge.c index 3b2cba6..2ffbc92 100644 --- a/src/soc/amd/stoneyridge/southbridge.c +++ b/src/soc/amd/stoneyridge/southbridge.c @@ -227,35 +227,6 @@ misc_write32(MISC_CLK_CNTL1, ctrl); }
-static void sb_init_spi_base(void) -{ - /* Make sure the base address is predictable */ - lpc_set_spibase(SPI_BASE_ADDRESS); - lpc_enable_spi_rom(SPI_ROM_ENABLE); -} - -void sb_set_spi100(u16 norm, u16 fast, u16 alt, u16 tpm) -{ - spi_write16(SPI100_SPEED_CONFIG, - (norm << SPI_NORM_SPEED_NEW_SH) | - (fast << SPI_FAST_SPEED_NEW_SH) | - (alt << SPI_ALT_SPEED_NEW_SH) | - (tpm << SPI_TPM_SPEED_NEW_SH)); - spi_write16(SPI100_ENABLE, SPI_USE_SPI100 | spi_read16(SPI100_ENABLE)); -} - -static void sb_disable_4dw_burst(void) -{ - spi_write16(SPI100_HOST_PREF_CONFIG, - spi_read16(SPI100_HOST_PREF_CONFIG) & ~SPI_RD4DW_EN_HOST); -} - -void sb_read_mode(u32 mode) -{ - spi_write32(SPI_CNTRL0, - (spi_read32(SPI_CNTRL0) & ~SPI_READ_MODE_MASK) | mode); -} - static void setup_spread_spectrum(int *reboot) { uint16_t rstcfg = pm_read16(PWR_RESET_CFG); @@ -334,9 +305,9 @@ sb_enable_lpc(); lpc_enable_port80(); sb_lpc_decode(); - lpc_enable_spi_prefetch(); - sb_init_spi_base(); - sb_disable_4dw_burst(); /* Must be disabled on CZ(ST) */ + /* Make sure the base address is predictable */ + lpc_set_spibase(SPI_BASE_ADDRESS); + fch_spi_early_init(); fch_smbus_init(); fch_enable_cf9_io(); setup_spread_spectrum(&reboot);
