Naresh Solanki (naresh.solanki@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16610
commit 188c75051a65dc4d784767ccec4e4be578a75501 Author: Naresh G Solanki naresh.solanki@intel.com Date: Thu Sep 15 18:14:28 2016 +0530
driver/intel/fsp1_1: Utilise soc/intel/common for adding vbt.bin
Remove fsp1.1 driver code that adds vbt.bin & use soc/intel/common instead to add vbt.bin in cbfs.
Change-Id: I08f2556a34f83a0ea2b67b003e51dcace994361b Signed-off-by: Naresh G Solanki naresh.solanki@intel.com --- src/drivers/intel/fsp1_1/Kconfig | 6 +----- src/drivers/intel/fsp1_1/Makefile.inc | 7 ------- src/drivers/intel/fsp1_1/fsp_gop.c | 2 +- 3 files changed, 2 insertions(+), 13 deletions(-)
diff --git a/src/drivers/intel/fsp1_1/Kconfig b/src/drivers/intel/fsp1_1/Kconfig index 59b4797..17a5caf 100644 --- a/src/drivers/intel/fsp1_1/Kconfig +++ b/src/drivers/intel/fsp1_1/Kconfig @@ -98,6 +98,7 @@ config FSP_USES_UPD config GOP_SUPPORT bool "Enable GOP support" default n + select ADD_VBT_DATA_FILE
config USE_GENERIC_FSP_CAR_INC bool @@ -106,11 +107,6 @@ config USE_GENERIC_FSP_CAR_INC The chipset can select this to use a generic cache_as_ram.inc file that should be good for all FSP based platforms.
-config VBT_FILE - string "GOP Video BIOS table binary path" - depends on GOP_SUPPORT - default "3rdparty/blobs/mainboard/$(MAINBOARDDIR)/vbt.bin" - config CHECKLIST_DATA_FILE_LOCATION string default "src/vendorcode/intel/fsp/fsp1_1/checklist" diff --git a/src/drivers/intel/fsp1_1/Makefile.inc b/src/drivers/intel/fsp1_1/Makefile.inc index 3820a5d..4ea23f3 100644 --- a/src/drivers/intel/fsp1_1/Makefile.inc +++ b/src/drivers/intel/fsp1_1/Makefile.inc @@ -44,13 +44,6 @@ CPPFLAGS_common += -Isrc/drivers/intel/fsp1_1/include
cpu_incs-$(CONFIG_USE_GENERIC_FSP_CAR_INC) += $(src)/drivers/intel/fsp1_1/cache_as_ram.inc
- -# Add the GOP Video BIOS Table to the cbfs image -cbfs-files-$(CONFIG_GOP_SUPPORT) += vbt.bin -vbt.bin-file := $(call strip_quotes,$(CONFIG_VBT_FILE)) -vbt.bin-type := optionrom - - # Add the FSP binary to the cbfs image ifeq ($(CONFIG_HAVE_FSP_BIN),y) cbfs-files-y += fsp.bin diff --git a/src/drivers/intel/fsp1_1/fsp_gop.c b/src/drivers/intel/fsp1_1/fsp_gop.c index f531d76..78e80cd 100644 --- a/src/drivers/intel/fsp1_1/fsp_gop.c +++ b/src/drivers/intel/fsp1_1/fsp_gop.c @@ -29,7 +29,7 @@ const optionrom_vbt_t *fsp_get_vbt(uint32_t *vbt_len) } vbt;
/* Locate the vbt file in cbfs */ - vbt.data = cbfs_boot_map_with_leak("vbt.bin", CBFS_TYPE_OPTIONROM, + vbt.data = cbfs_boot_map_with_leak("vbt.bin", CBFS_TYPE_RAW, &vbt_size); if (!vbt.data) { printk(BIOS_INFO,
