Attention is currently required from: Bora Guvendik, Caveh Jalali, Selma Bensaid, Maulik V Vaghela, Subrata Banik, Nick Vaccaro, Patrick Rudolph, Karthik Ramasubramanian. Hello Bora Guvendik, build bot (Jenkins), Caveh Jalali, Selma Bensaid, Maulik V Vaghela, Tim Wawrzynczak, Subrata Banik, Patrick Rudolph, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/58351
Change subject: soc/intel/common: add generic gpio lock mechanism ......................................................................
For added security, there are some gpios that an SoC will want to lock once initially configured, such as gpios attached to non-host (x86) controllers, so that they can't be recofigured at a later point in time by rogue code.
Likewise, a mainboard may have some gpios connected to secure busses and/or devices that they want to protect from being changed post initial configuration.
This change adds a generic gpio locking mechanism that allows the SoC to export a list of GPIOs to be locked down and allows the mainboard to export a list of GPIOs that it wants locked down once initialization is complete.
Use the SOC_INTEL_COMMON_BLOCK_SMM_LOCK_GPIO_PADS Kconfig option to enable this feature.
BUG=b:201430600 TEST='emerge-brya coreboot chromeos-bootimage', flash and verify brya0 boots successfully to kernel.
Signed-off-by: Nick Vaccaro nvaccaro@google.com Change-Id: I42979fb89567d8bcd9392da4fb8c4113ef427b14 --- M src/soc/intel/common/block/gpio/gpio.c M src/soc/intel/common/block/include/intelblocks/gpio.h M src/soc/intel/common/block/smm/Kconfig M src/soc/intel/common/block/smm/smihandler.c 4 files changed, 156 insertions(+), 40 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/51/58351/11
