Maxim Polyakov has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/41031 )
Change subject: intel/gpio: set trig to default if its not a param for GPI ......................................................................
If RX Level/Edge Configuration (RXEVCFG) isn't set in the macro using the parameter, then this should be the default value (2h = Drive '0').
Change-Id: I389435000d50af3e1815de5bc57025f85ab1cd38 Signed-off-by: Maxim Polyakov max.senia.poliak@gmail.com --- M src/soc/intel/common/block/include/intelblocks/gpio_defs.h 1 file changed, 17 insertions(+), 12 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/31/41031/1
diff --git a/src/soc/intel/common/block/include/intelblocks/gpio_defs.h b/src/soc/intel/common/block/include/intelblocks/gpio_defs.h index 4bb318b..d6c0287 100644 --- a/src/soc/intel/common/block/include/intelblocks/gpio_defs.h +++ b/src/soc/intel/common/block/include/intelblocks/gpio_defs.h @@ -289,24 +289,29 @@ * Host Software Pad Ownership to GPIO Driver mode. */ #define PAD_CFG_GPI_TRIG_OWN(pad, pull, rst, trig, own) \ - _PAD_CFG_STRUCT(pad, PAD_FUNC(GPIO) | PAD_RESET(rst) | \ + _PAD_CFG_STRUCT(pad, \ + PAD_FUNC(GPIO) | PAD_RESET(rst) | \ PAD_CFG0_TRIG_##trig | PAD_CFG0_RX_POL_NONE | PAD_BUF(TX_DISABLE), \ PAD_PULL(pull) | PAD_IOSSTATE(TxDRxE) | PAD_CFG_OWN_GPIO(own))
-#define PAD_CFG_GPI_GPIO_DRIVER(pad, pull, rst) \ - _PAD_CFG_STRUCT(pad, \ - PAD_FUNC(GPIO) | PAD_RESET(rst) | PAD_BUF(TX_DISABLE), \ - PAD_PULL(pull) | PAD_CFG_OWN_GPIO(DRIVER) | PAD_IOSSTATE(TxDRxE)) +#define PAD_CFG_GPI_GPIO_DRIVER(pad, pull, rst) \ + _PAD_CFG_STRUCT(pad, \ + PAD_FUNC(GPIO) | PAD_RESET(rst) | \ + PAD_CFG0_TRIG_OFF | PAD_BUF(TX_DISABLE), \ + PAD_PULL(pull) | PAD_CFG_OWN_GPIO(DRIVER) | \ + PAD_IOSSTATE(TxDRxE))
-#define PAD_CFG_GPIO_DRIVER_HI_Z(pad, pull, rst, iosstate, iosterm) \ - _PAD_CFG_STRUCT(pad, \ - PAD_FUNC(GPIO) | PAD_RESET(rst) | PAD_BUF(TX_RX_DISABLE), \ - PAD_PULL(pull) | PAD_CFG_OWN_GPIO(DRIVER) | \ +#define PAD_CFG_GPIO_DRIVER_HI_Z(pad, pull, rst, iosstate, iosterm) \ + _PAD_CFG_STRUCT(pad, \ + PAD_FUNC(GPIO) | PAD_RESET(rst) | \ + PAD_CFG0_RX_POL_NONE | PAD_BUF(TX_RX_DISABLE), \ + PAD_PULL(pull) | PAD_CFG_OWN_GPIO(DRIVER) | \ PAD_IOSSTATE(iosstate) | PAD_IOSTERM(iosterm))
-#define PAD_CFG_GPIO_HI_Z(pad, pull, rst, iosstate, iosterm) \ - _PAD_CFG_STRUCT(pad, \ - PAD_FUNC(GPIO) | PAD_RESET(rst) | PAD_BUF(TX_RX_DISABLE), \ +#define PAD_CFG_GPIO_HI_Z(pad, pull, rst, iosstate, iosterm) \ + _PAD_CFG_STRUCT(pad, \ + PAD_FUNC(GPIO) | PAD_RESET(rst) | \ + PAD_CFG0_TRIG_OFF | PAD_BUF(TX_RX_DISABLE), \ PAD_PULL(pull) | PAD_IOSSTATE(iosstate) | PAD_IOSTERM(iosterm))
/* GPIO Interrupt */
Maxim Polyakov has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41031 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/41031/1/src/soc/intel/common/block/... File src/soc/intel/common/block/include/intelblocks/gpio_defs.h:
https://review.coreboot.org/c/coreboot/+/41031/1/src/soc/intel/common/block/... PS1, Line 307: PAD_CFG0_RX_POL_NONE PAD_CFG0_TRIG_OFF
Maxim Polyakov has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/41031 )
Abandoned
There is no need for these changes.
