Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9337
commit 32a7a81c7e7a5ae51cdebf5fc02c51bc23b3f375 Author: Vadim Bendebury vbendeb@chromium.org Date: Tue Nov 11 20:14:47 2014 -0800
pistachio: modify memory layout
With the code now running on the FPGA board it makes sense to correct the memory layout definitions to match the actual hardware.
Note that the latest FPGA board firmware introduced support of the additional 128KB of SRAM (called GRAM) at base address of 0x9a000000.
These are still interim values, which will be tweaked when the actual bring up board is available.
BRANCH=none BUG=chrome-os-partner:31438 TEST=the code put into SPI NOR flash boots all the way to ramstage.
Change-Id: I00aa5bc3aabba50df2187bb208cf2fcd11b26b3d Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: a6378be5cd304744b40c57a34d7a276233d45779 Original-Change-Id: I50183c2d5f9017801d5c8a7a7addf08efa492b35 Original-Signed-off-by: Vadim Bendebury vbendeb@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/229203 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org --- src/soc/imgtec/pistachio/include/soc/memlayout.ld | 19 ++++++++++--------- 1 file changed, 10 insertions(+), 9 deletions(-)
diff --git a/src/soc/imgtec/pistachio/include/soc/memlayout.ld b/src/soc/imgtec/pistachio/include/soc/memlayout.ld index 21c3d73..554ebfc 100644 --- a/src/soc/imgtec/pistachio/include/soc/memlayout.ld +++ b/src/soc/imgtec/pistachio/include/soc/memlayout.ld @@ -21,18 +21,19 @@
#include <arch/header.ld>
-/* TODO: This should be revised by someone who understands the SoC better. */ - SECTIONS { - CBFS_CACHE(0x0, 0) /* TODO: fix this, it was already broken before!!! */ - DRAM_START(0x80000000) RAMSTAGE(0x80000000, 128K)
- /* TODO: Does this SoC use SRAM? Add SRAM_START() and SRAM_END(). */ - BOOTBLOCK(0x9B000000, 16K) - ROMSTAGE(0x9B004000, 40K) - STACK(0x9B00E000, 6K) - PRERAM_CBMEM_CONSOLE(0x9B00F800, 3K) + /* GRAM becomes the SRAM. */ + SRAM_START(0x9a000000) + BOOTBLOCK(0x9a000000, 16K) + ROMSTAGE(0x9a004000, 32K) + STACK(0x9a01c000, 8K) + PRERAM_CBMEM_CONSOLE(0x9a01e000, 8K) + SRAM_END(0x9a020000) + + /* Let's use SRAM for CBFS cache. */ + CBFS_CACHE(0x9b000000, 64K) }
