Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/40465 )
Change subject: mb/gigabyte: Add GA-D510UD ......................................................................
Booted fine on the first try. Most things work properly, but I haven't tested them thoroughly. Native raminit chokes with a DIMM in the second slot, but the first slot works properly.
Change-Id: I2126c7d31e0d8a8f80df69fdcdcd202b87f219a4 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/40465 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Arthur Heymans arthur@aheymans.xyz --- A src/mainboard/gigabyte/ga-d510ud/Kconfig A src/mainboard/gigabyte/ga-d510ud/Kconfig.name A src/mainboard/gigabyte/ga-d510ud/Makefile.inc A src/mainboard/gigabyte/ga-d510ud/acpi/ec.asl A src/mainboard/gigabyte/ga-d510ud/acpi/ich7_pci_irqs.asl A src/mainboard/gigabyte/ga-d510ud/acpi/superio.asl A src/mainboard/gigabyte/ga-d510ud/board_info.txt A src/mainboard/gigabyte/ga-d510ud/cmos.default A src/mainboard/gigabyte/ga-d510ud/cmos.layout A src/mainboard/gigabyte/ga-d510ud/cstates.c A src/mainboard/gigabyte/ga-d510ud/data.vbt A src/mainboard/gigabyte/ga-d510ud/devicetree.cb A src/mainboard/gigabyte/ga-d510ud/dsdt.asl A src/mainboard/gigabyte/ga-d510ud/early_init.c A src/mainboard/gigabyte/ga-d510ud/gpio.c A src/mainboard/gigabyte/ga-d510ud/hda_verb.c 16 files changed, 469 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Arthur Heymans: Looks good to me, approved
diff --git a/src/mainboard/gigabyte/ga-d510ud/Kconfig b/src/mainboard/gigabyte/ga-d510ud/Kconfig new file mode 100644 index 0000000..71fe981 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/Kconfig @@ -0,0 +1,27 @@ +## SPDX-License-Identifier: GPL-2.0-only + +if BOARD_GIGABYTE_GA_D510UD + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select BOARD_ROMSIZE_KB_512 + select CPU_INTEL_SOCKET_FCBGA559 + select HAVE_ACPI_RESUME + select HAVE_ACPI_TABLES + select HAVE_CMOS_DEFAULT + select HAVE_OPTION_TABLE + select INTEL_GMA_HAVE_VBT + select NORTHBRIDGE_INTEL_PINEVIEW + select REALTEK_8168_RESET + select SOUTHBRIDGE_INTEL_I82801GX + select SUPERIO_ITE_IT8720F + +config MAINBOARD_DIR + string + default "gigabyte/ga-d510ud" + +config MAINBOARD_PART_NUMBER + string + default "GA-D510UD" + +endif # BOARD_GIGABYTE_GA_D510UD diff --git a/src/mainboard/gigabyte/ga-d510ud/Kconfig.name b/src/mainboard/gigabyte/ga-d510ud/Kconfig.name new file mode 100644 index 0000000..68c6dc4 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_GIGABYTE_GA_D510UD + bool "GA-D510UD" diff --git a/src/mainboard/gigabyte/ga-d510ud/Makefile.inc b/src/mainboard/gigabyte/ga-d510ud/Makefile.inc new file mode 100644 index 0000000..e78c424e --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/Makefile.inc @@ -0,0 +1,8 @@ +## SPDX-License-Identifier: GPL-2.0-only + +bootblock-y += early_init.c + +romstage-y += early_init.c +romstage-y += gpio.c + +ramstage-y += cstates.c diff --git a/src/mainboard/gigabyte/ga-d510ud/acpi/ec.asl b/src/mainboard/gigabyte/ga-d510ud/acpi/ec.asl new file mode 100644 index 0000000..e69de29 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/acpi/ec.asl diff --git a/src/mainboard/gigabyte/ga-d510ud/acpi/ich7_pci_irqs.asl b/src/mainboard/gigabyte/ga-d510ud/acpi/ich7_pci_irqs.asl new file mode 100644 index 0000000..d6e6bef --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/acpi/ich7_pci_irqs.asl @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +/* This is the IRQ routing for the 0:1e.0 PCI bridge of the NM10 */ + +If (PICM) { + Return (Package() { + Package() { 0x0000ffff, 0, 0, 0x15}, + Package() { 0x0000ffff, 1, 0, 0x16}, + Package() { 0x0000ffff, 2, 0, 0x17}, + Package() { 0x0000ffff, 3, 0, 0x14}, + Package() { 0x0001ffff, 0, 0, 0x13}, + }) +} Else { + Return (Package() { + Package() { 0x0000ffff, 0, _SB.PCI0.LPCB.LNKF, 0}, + Package() { 0x0000ffff, 1, _SB.PCI0.LPCB.LNKG, 0}, + Package() { 0x0000ffff, 2, _SB.PCI0.LPCB.LNKH, 0}, + Package() { 0x0000ffff, 3, _SB.PCI0.LPCB.LNKE, 0}, + Package() { 0x0001ffff, 0, _SB.PCI0.LPCB.LNKD, 0}, + }) +} diff --git a/src/mainboard/gigabyte/ga-d510ud/acpi/superio.asl b/src/mainboard/gigabyte/ga-d510ud/acpi/superio.asl new file mode 100644 index 0000000..c67e5d8 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/acpi/superio.asl @@ -0,0 +1,17 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#undef SUPERIO_DEV +#undef SUPERIO_PNP_BASE +#undef IT8720F_SHOW_SP1 +#undef IT8720F_SHOW_SP2 +#undef IT8720F_SHOW_EC +#undef IT8720F_SHOW_KBCK +#undef IT8720F_SHOW_KBCM +#define SUPERIO_DEV SIO0 +#define SUPERIO_PNP_BASE 0x2e +#define IT8720F_SHOW_SP1 +#define IT8720F_SHOW_SP2 +#define IT8720F_SHOW_EC +#define IT8720F_SHOW_KBCK +#define IT8720F_SHOW_KBCM +#include <superio/ite/it8720f/acpi/superio.asl> diff --git a/src/mainboard/gigabyte/ga-d510ud/board_info.txt b/src/mainboard/gigabyte/ga-d510ud/board_info.txt new file mode 100644 index 0000000..ad5afe1 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/board_info.txt @@ -0,0 +1,6 @@ +Category: mini +Board URL: https://www.gigabyte.com/Motherboard/GA-D510UD-rev-10 +ROM package: SOIC-8 +ROM protocol: SPI +ROM socketed: n +Flashrom support: y diff --git a/src/mainboard/gigabyte/ga-d510ud/cmos.default b/src/mainboard/gigabyte/ga-d510ud/cmos.default new file mode 100644 index 0000000..41098be --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/cmos.default @@ -0,0 +1,5 @@ +boot_option=Fallback +debug_level=Debug +power_on_after_fail=Disable +nmi=Enable +gfx_uma_size=8M diff --git a/src/mainboard/gigabyte/ga-d510ud/cmos.layout b/src/mainboard/gigabyte/ga-d510ud/cmos.layout new file mode 100644 index 0000000..1e08c1f --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/cmos.layout @@ -0,0 +1,67 @@ +## SPDX-License-Identifier: GPL-2.0-only + +# ----------------------------------------------------------------- +entries + +# ----------------------------------------------------------------- +0 120 r 0 reserved_memory + +# ----------------------------------------------------------------- +# RTC_BOOT_BYTE (coreboot hardcoded) +384 1 e 4 boot_option +388 4 h 0 reboot_counter + +# ----------------------------------------------------------------- +# coreboot config options: console +395 4 e 6 debug_level + +# coreboot config options: southbridge +408 1 e 1 nmi +409 2 e 7 power_on_after_fail + +# coreboot config options: bootloader +416 512 s 0 boot_devices + +# coreboot config options: cpu + +# coreboot config options: northbridge +952 3 e 11 gfx_uma_size + +# coreboot config options: check sums +984 16 h 0 check_sum + +# ----------------------------------------------------------------- + +enumerations + +#ID value text +1 0 Disable +1 1 Enable +2 0 Enable +2 1 Disable +4 0 Fallback +4 1 Normal +6 0 Emergency +6 1 Alert +6 2 Critical +6 3 Error +6 4 Warning +6 5 Notice +6 6 Info +6 7 Debug +6 8 Spew +7 0 Disable +7 1 Enable +7 2 Keep +11 0 8M +11 1 16M +11 2 32M +11 3 48M +11 4 64M +11 5 128M +11 6 256M + +# ----------------------------------------------------------------- +checksums + +checksum 392 983 984 diff --git a/src/mainboard/gigabyte/ga-d510ud/cstates.c b/src/mainboard/gigabyte/ga-d510ud/cstates.c new file mode 100644 index 0000000..21b18b9 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/cstates.c @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpigen.h> + +int get_cst_entries(acpi_cstate_t **entries) +{ + return 0; +} diff --git a/src/mainboard/gigabyte/ga-d510ud/data.vbt b/src/mainboard/gigabyte/ga-d510ud/data.vbt new file mode 100644 index 0000000..ae75a25 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/data.vbt Binary files differ diff --git a/src/mainboard/gigabyte/ga-d510ud/devicetree.cb b/src/mainboard/gigabyte/ga-d510ud/devicetree.cb new file mode 100644 index 0000000..9fb5ff5 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/devicetree.cb @@ -0,0 +1,80 @@ +## SPDX-License-Identifier: GPL-2.0-only + +chip northbridge/intel/pineview + register "use_crt" = "1" + + device cpu_cluster 0 on + chip cpu/intel/socket_FCBGA559 + device lapic 0 on end + end + end + device domain 0 on + subsystemid 0x105b 0x0d55 inherit + device pci 0.0 on end # Host Bridge + device pci 2.0 on end # iGPU + device pci 2.1 off end # iGPU 2 + + chip southbridge/intel/i82801gx + register "pirqa_routing" = "0x0b" + register "pirqb_routing" = "0x0b" + register "pirqc_routing" = "0x0b" + register "pirqd_routing" = "0x0b" + register "pirqe_routing" = "0x0b" + register "pirqf_routing" = "0x0b" + register "pirqg_routing" = "0x0b" + register "pirqh_routing" = "0x0b" + + register "sata_ports_implemented" = "0x3" + register "gpe0_en" = "0x441" + + register "gen1_dec" = "0x00040291" # Environment Controller + + device pci 1b.0 on end # HD Audio + device pci 1c.0 on end # PCIe 1: Realtek GbE NIC + device pci 1c.1 on end # PCIe 2: JMB363 SATA/IDE + device pci 1c.2 off end # PCIe 3 + device pci 1c.3 off end # PCIe 4 + device pci 1d.0 on end # UHCI + device pci 1d.1 on end # UHCI + device pci 1d.2 on end # UHCI + device pci 1d.3 on end # UHCI + device pci 1d.7 on end # EHCI + device pci 1e.0 on end # PCI bridge + device pci 1f.0 on # LPC bridge + chip superio/ite/it8720f + device pnp 2e.0 off end # Floppy + device pnp 2e.1 on # COM1 + io 0x60 = 0x3f8 + irq 0x70 = 4 + end + device pnp 2e.2 on # COM2 + io 0x60 = 0x2f8 + irq 0x70 = 3 + end + device pnp 2e.3 on # PP + io 0x60 = 0x378 + io 0x62 = 0 + irq 0x70 = 7 + end + device pnp 2e.4 on # EC + io 0x60 = 0x0290 + io 0x62 = 0 + irq 0x70 = 0 + end + device pnp 2e.5 on # PS/2 keyboard + io 0x60 = 0x60 + io 0x62 = 0x64 + irq 0x70 = 1 + end + device pnp 2e.6 on # PS/2 mouse + irq 0x70 = 12 + end + device pnp 2e.7 off end # GPIO + device pnp 2e.a off end # CIR + end + end + device pci 1f.2 on end # SATA + device pci 1f.3 on end # SMbus + end + end +end diff --git a/src/mainboard/gigabyte/ga-d510ud/dsdt.asl b/src/mainboard/gigabyte/ga-d510ud/dsdt.asl new file mode 100644 index 0000000..0e2fa7b --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/dsdt.asl @@ -0,0 +1,28 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <acpi/acpi.h> + +DefinitionBlock( + "dsdt.aml", + "DSDT", + ACPI_DSDT_REV_2, + OEM_ID, + ACPI_TABLE_CREATOR, + 0x20090419 +) +{ + #include <acpi/dsdt_top.asl> + + #include <southbridge/intel/common/acpi/platform.asl> + #include <southbridge/intel/i82801gx/acpi/globalnvs.asl> + + #include <cpu/intel/speedstep/acpi/cpu.asl> + + Device (_SB.PCI0) + { + #include <northbridge/intel/pineview/acpi/pineview.asl> + #include <southbridge/intel/i82801gx/acpi/ich7.asl> + } + + #include <southbridge/intel/common/acpi/sleepstates.asl> +} diff --git a/src/mainboard/gigabyte/ga-d510ud/early_init.c b/src/mainboard/gigabyte/ga-d510ud/early_init.c new file mode 100644 index 0000000..8fdf25d --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/early_init.c @@ -0,0 +1,61 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <bootblock_common.h> +#include <console/console.h> +#include <device/pnp_ops.h> +#include <northbridge/intel/pineview/pineview.h> +#include <southbridge/intel/i82801gx/i82801gx.h> +#include <superio/ite/common/ite.h> +#include <superio/ite/it8720f/it8720f.h> + +#define SERIAL_DEV PNP_DEV(0x2e, IT8720F_SP1) +#define GPIO_DEV PNP_DEV(0x2e, IT8720F_GPIO) +#define EC_DEV PNP_DEV(0x2e, IT8720F_EC) + +void bootblock_mainboard_early_init(void) +{ + /* Set default GPIOs on superio */ + pnp_enter_conf_state(GPIO_DEV); + + pnp_set_logical_device(GPIO_DEV); + pnp_write_config(GPIO_DEV, 0x25, 0x00); + pnp_write_config(GPIO_DEV, 0x26, 0x0c); + pnp_write_config(GPIO_DEV, 0x28, 0x41); + pnp_write_config(GPIO_DEV, 0x2c, 0x01); + pnp_write_config(GPIO_DEV, 0x62, 0x08); + pnp_write_config(GPIO_DEV, 0x72, 0x00); + pnp_write_config(GPIO_DEV, 0xb8, 0x00); + pnp_write_config(GPIO_DEV, 0xc0, 0x00); + pnp_write_config(GPIO_DEV, 0xc1, 0x0c); + pnp_write_config(GPIO_DEV, 0xc3, 0x41); + pnp_write_config(GPIO_DEV, 0xc8, 0x00); + pnp_write_config(GPIO_DEV, 0xcb, 0x00); + pnp_write_config(GPIO_DEV, 0xe9, 0x01); + pnp_write_config(GPIO_DEV, 0xfc, 0xa4); + + pnp_exit_conf_state(GPIO_DEV); + + ite_enable_serial(SERIAL_DEV, CONFIG_TTYS0_BASE); + + pnp_enter_conf_state(GPIO_DEV); + pnp_set_logical_device(GPIO_DEV); + + printk(BIOS_DEBUG, "ITE register 0xef: 0x%02x ", pnp_read_config(GPIO_DEV, 0xef)); + + /* Disable SIO reboot */ + pnp_write_config(GPIO_DEV, 0xef, 0x7e); + + printk(BIOS_DEBUG, "=> 0x%02x\n", pnp_read_config(GPIO_DEV, 0xef)); + + pnp_set_logical_device(EC_DEV); + pnp_write_config(EC_DEV, 0x70, 0x00); /* Don't use IRQ9 */ + pnp_write_config(EC_DEV, 0x30, 0x01); /* Enable */ + + pnp_exit_conf_state(GPIO_DEV); +} + +void get_mb_spd_addrmap(u8 *spd_addrmap) +{ + spd_addrmap[0] = 0x50; + spd_addrmap[1] = 0x51; +} diff --git a/src/mainboard/gigabyte/ga-d510ud/gpio.c b/src/mainboard/gigabyte/ga-d510ud/gpio.c new file mode 100644 index 0000000..5c756b9 --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/gpio.c @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <southbridge/intel/common/gpio.h> + +static const struct pch_gpio_set1 pch_gpio_set1_mode = { + .gpio0 = GPIO_MODE_NATIVE, + .gpio1 = GPIO_MODE_NATIVE, + .gpio2 = GPIO_MODE_NATIVE, + .gpio3 = GPIO_MODE_NATIVE, + .gpio4 = GPIO_MODE_NATIVE, + .gpio5 = GPIO_MODE_NATIVE, + .gpio6 = GPIO_MODE_GPIO, + .gpio7 = GPIO_MODE_GPIO, + .gpio8 = GPIO_MODE_GPIO, + .gpio9 = GPIO_MODE_GPIO, + .gpio10 = GPIO_MODE_GPIO, + .gpio11 = GPIO_MODE_GPIO, + .gpio12 = GPIO_MODE_GPIO, + .gpio13 = GPIO_MODE_GPIO, + .gpio14 = GPIO_MODE_GPIO, + .gpio15 = GPIO_MODE_GPIO, + .gpio16 = GPIO_MODE_NATIVE, + .gpio17 = GPIO_MODE_NATIVE, + .gpio18 = GPIO_MODE_NATIVE, + .gpio19 = GPIO_MODE_NATIVE, + .gpio20 = GPIO_MODE_GPIO, + .gpio21 = GPIO_MODE_NATIVE, + .gpio22 = GPIO_MODE_NATIVE, + .gpio23 = GPIO_MODE_NATIVE, + .gpio24 = GPIO_MODE_GPIO, + .gpio25 = GPIO_MODE_GPIO, + .gpio26 = GPIO_MODE_GPIO, + .gpio27 = GPIO_MODE_GPIO, + .gpio28 = GPIO_MODE_GPIO, + .gpio29 = GPIO_MODE_NATIVE, + .gpio30 = GPIO_MODE_NATIVE, + .gpio31 = GPIO_MODE_NATIVE, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_direction = { + .gpio6 = GPIO_DIR_INPUT, + .gpio7 = GPIO_DIR_INPUT, + .gpio8 = GPIO_DIR_INPUT, + .gpio9 = GPIO_DIR_INPUT, + .gpio10 = GPIO_DIR_INPUT, + .gpio11 = GPIO_DIR_INPUT, + .gpio12 = GPIO_DIR_INPUT, + .gpio13 = GPIO_DIR_INPUT, + .gpio14 = GPIO_DIR_INPUT, + .gpio15 = GPIO_DIR_INPUT, + .gpio20 = GPIO_DIR_OUTPUT, + .gpio24 = GPIO_DIR_OUTPUT, + .gpio25 = GPIO_DIR_INPUT, + .gpio26 = GPIO_DIR_OUTPUT, + .gpio27 = GPIO_DIR_OUTPUT, + .gpio28 = GPIO_DIR_OUTPUT, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_level = { + .gpio20 = GPIO_LEVEL_HIGH, + .gpio24 = GPIO_LEVEL_LOW, + .gpio26 = GPIO_LEVEL_LOW, + .gpio27 = GPIO_LEVEL_LOW, + .gpio28 = GPIO_LEVEL_LOW, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_invert = { + .gpio6 = GPIO_INVERT, + .gpio7 = GPIO_INVERT, + .gpio8 = GPIO_INVERT, + .gpio11 = GPIO_INVERT, + .gpio12 = GPIO_INVERT, + .gpio13 = GPIO_INVERT, +}; + +static const struct pch_gpio_set2 pch_gpio_set2_mode = { + .gpio32 = GPIO_MODE_NATIVE, + .gpio33 = GPIO_MODE_GPIO, + .gpio34 = GPIO_MODE_GPIO, + .gpio35 = GPIO_MODE_NATIVE, + .gpio36 = GPIO_MODE_NATIVE, + .gpio37 = GPIO_MODE_NATIVE, + .gpio38 = GPIO_MODE_GPIO, + .gpio39 = GPIO_MODE_GPIO, +}; + +static const struct pch_gpio_set2 pch_gpio_set2_direction = { + .gpio33 = GPIO_DIR_OUTPUT, + .gpio34 = GPIO_DIR_OUTPUT, + .gpio38 = GPIO_DIR_INPUT, + .gpio39 = GPIO_DIR_INPUT, +}; + +static const struct pch_gpio_set2 pch_gpio_set2_level = { + .gpio33 = GPIO_LEVEL_HIGH, + .gpio34 = GPIO_LEVEL_LOW, + .gpio38 = GPIO_LEVEL_HIGH, + .gpio39 = GPIO_LEVEL_HIGH, +}; + +const struct pch_gpio_map mainboard_gpio_map = { + .set1 = { + .mode = &pch_gpio_set1_mode, + .direction = &pch_gpio_set1_direction, + .level = &pch_gpio_set1_level, + .invert = &pch_gpio_set1_invert, + }, + .set2 = { + .mode = &pch_gpio_set2_mode, + .direction = &pch_gpio_set2_direction, + .level = &pch_gpio_set2_level, + }, +}; diff --git a/src/mainboard/gigabyte/ga-d510ud/hda_verb.c b/src/mainboard/gigabyte/ga-d510ud/hda_verb.c new file mode 100644 index 0000000..f36d48c --- /dev/null +++ b/src/mainboard/gigabyte/ga-d510ud/hda_verb.c @@ -0,0 +1,26 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* coreboot specific header */ + 0x10ec0662, + 0x105b0d55, /* Subsystem ID */ + 10, /* Number of entries */ + + /* Pin Widget Verb Table */ + AZALIA_PIN_CFG(0, 0x14, 0x01014c10), + AZALIA_PIN_CFG(0, 0x15, 0x411111f0), + AZALIA_PIN_CFG(0, 0x16, 0x411111f0), + AZALIA_PIN_CFG(0, 0x18, 0x01a19c30), + AZALIA_PIN_CFG(0, 0x19, 0x02a19c31), + AZALIA_PIN_CFG(0, 0x1a, 0x0181343f), + AZALIA_PIN_CFG(0, 0x1b, 0x02214c1f), + AZALIA_PIN_CFG(0, 0x1c, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1d, 0x4005c603), + AZALIA_PIN_CFG(0, 0x1e, 0x99430120), +}; + +const u32 pc_beep_verbs[] = {}; + +AZALIA_ARRAY_SIZES;
