Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/74589 )
Change subject: include/cpu/amd/mtrr: rename functions to get top of memory regions ......................................................................
Rename amd_topmem and amd_topmem2 to get_top_of_mem_below_4gb and get_top_of_mem_above_4g to make it clearer what those functions return.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ic6e98d94c731af74aea0ce276a9a7e4867e3986f Reviewed-on: https://review.coreboot.org/c/coreboot/+/74589 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Martin Roth martin.roth@amd.corp-partner.google.com --- M src/cpu/amd/mtrr/amd_mtrr.c M src/include/cpu/amd/mtrr.h M src/northbridge/amd/pi/00730F01/northbridge.c M src/soc/amd/stoneyridge/northbridge.c 4 files changed, 22 insertions(+), 6 deletions(-)
Approvals: build bot (Jenkins): Verified Martin Roth: Looks good to me, approved
diff --git a/src/cpu/amd/mtrr/amd_mtrr.c b/src/cpu/amd/mtrr/amd_mtrr.c index 405e92a..f904df9 100644 --- a/src/cpu/amd/mtrr/amd_mtrr.c +++ b/src/cpu/amd/mtrr/amd_mtrr.c @@ -7,7 +7,7 @@
void add_uma_resource_below_tolm(struct device *nb, int idx) { - uint32_t topmem = amd_topmem(); + uint32_t topmem = get_top_of_mem_below_4gb(); uint32_t top_of_cacheable = restore_top_of_low_cacheable();
if (top_of_cacheable == topmem) diff --git a/src/include/cpu/amd/mtrr.h b/src/include/cpu/amd/mtrr.h index f1b95b6..b8b820c 100644 --- a/src/include/cpu/amd/mtrr.h +++ b/src/include/cpu/amd/mtrr.h @@ -65,12 +65,12 @@ ); }
-static inline uint64_t amd_topmem(void) +static inline uint64_t get_top_of_mem_below_4gb(void) { return rdmsr(TOP_MEM).lo; }
-static inline uint64_t amd_topmem2(void) +static inline uint64_t get_top_of_mem_above_4g(void) { msr_t msr = rdmsr(TOP_MEM2); return (uint64_t)msr.hi << 32 | msr.lo; diff --git a/src/northbridge/amd/pi/00730F01/northbridge.c b/src/northbridge/amd/pi/00730F01/northbridge.c index 5f3b4d9..d963171 100644 --- a/src/northbridge/amd/pi/00730F01/northbridge.c +++ b/src/northbridge/amd/pi/00730F01/northbridge.c @@ -781,7 +781,7 @@ pci_domain_read_resources(dev);
/* TOP_MEM MSR is our boundary between DRAM and MMIO under 4G */ - mmio_basek = amd_topmem() >> 10; + mmio_basek = get_top_of_mem_below_4gb() >> 10;
#if CONFIG_HW_MEM_HOLE_SIZEK != 0 /* if the hw mem hole is already set in raminit stage, here we will compare @@ -837,7 +837,7 @@ sizek = 0; } else { - uint64_t topmem2 = amd_topmem2(); + uint64_t topmem2 = get_top_of_mem_above_4g(); basek = 4 * 1024 * 1024; sizek = topmem2 / 1024 - basek; } diff --git a/src/soc/amd/stoneyridge/northbridge.c b/src/soc/amd/stoneyridge/northbridge.c index 068ba56..ccfa9cb 100644 --- a/src/soc/amd/stoneyridge/northbridge.c +++ b/src/soc/amd/stoneyridge/northbridge.c @@ -276,7 +276,7 @@ */ void amd_initcpuio(void) { - uintptr_t topmem = amd_topmem(); + uintptr_t topmem = get_top_of_mem_below_4gb(); uintptr_t base, limit;
/* Enable legacy video routing: D18F1xF4 VGA Enable */
