Attention is currently required from: Tim Wawrzynczak, Patrick Rudolph. Hello build bot (Jenkins), Tim Wawrzynczak, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/61937
Change subject: soc/intel/adl: Select Kconfig to correct TBT port number ......................................................................
Select Kconfig to enable TBT root port index correction code in coreboot. In Alderlake, TBT PCIe root port LCAP registers return index starting from 2 and coreboot needs to correct index to align with index 0.
Selecting Kconfig will allow common code to return correct 0 based index.
Also, added support function which returns whether the slot is TBT PCIe or not.
BUG=b:210933428 BRANCH=None TEST=Check TBT PCIe remap happens correctly on Brya board.
Change-Id: I9c2bd43d7c9ba570fcec8e71a244840160ba81ff Signed-off-by: MAULIK V VAGHELA maulik.v.vaghela@intel.com --- M src/soc/intel/alderlake/Kconfig M src/soc/intel/alderlake/pcie_rp.c 2 files changed, 6 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/61937/3
