Paul Menzel (paulepanter@users.sourceforge.net) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5543
commit ad9142645444284db69836eb15346174e6a20fd6 Author: Paul Menzel paulepanter@users.sourceforge.net Date: Fri Mar 15 10:47:50 2013 +0100
vendorcode/amd/agesa/*/AGESA.h: Correct "ne" to "be" in comment
The typo is not present anymore in Family 16h (Kabini), so fix it for the older families (Family 10h, 12h, 14h, 15h, 15h Trinity) too using the command below.
$ git grep -l ' ne ' src/vendorcode/amd/agesa | xargs sed -i 's/ ne / be /g'
Change-Id: I9cb419251eeec79925f48a5832fac339d40f01d1 Signed-off-by: Paul Menzel paulepanter@users.sourceforge.net --- src/vendorcode/amd/agesa/f10/AGESA.h | 2 +- src/vendorcode/amd/agesa/f12/AGESA.h | 2 +- src/vendorcode/amd/agesa/f14/AGESA.h | 2 +- src/vendorcode/amd/agesa/f15/AGESA.h | 2 +- src/vendorcode/amd/agesa/f15tn/AGESA.h | 2 +- 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/src/vendorcode/amd/agesa/f10/AGESA.h b/src/vendorcode/amd/agesa/f10/AGESA.h index e6f5cfb..d111ae4 100644 --- a/src/vendorcode/amd/agesa/f10/AGESA.h +++ b/src/vendorcode/amd/agesa/f10/AGESA.h @@ -764,7 +764,7 @@ typedef enum { /// GNB configuration info typedef struct { IN PCIe_COMPLEX_DESCRIPTOR *PcieComplexList; /**< Pointer to array of structures describe PCIe topology on each processor package or NULL. - * Last element of array must ne terminated with DESCRIPTOR_TERMINATE_LIST + * Last element of array must be terminated with DESCRIPTOR_TERMINATE_LIST * Example of topology definition for single socket system: * @code * PCIe_PORT_DESCRIPTOR PortList [] = { diff --git a/src/vendorcode/amd/agesa/f12/AGESA.h b/src/vendorcode/amd/agesa/f12/AGESA.h index 9f61807..a240481 100644 --- a/src/vendorcode/amd/agesa/f12/AGESA.h +++ b/src/vendorcode/amd/agesa/f12/AGESA.h @@ -1022,7 +1022,7 @@ typedef struct { /// GNB configuration info typedef struct { IN PCIe_COMPLEX_DESCRIPTOR *PcieComplexList; /**< Pointer to array of structures describe PCIe topology on each processor package or NULL. - * Last element of array must ne terminated with DESCRIPTOR_TERMINATE_LIST + * Last element of array must be terminated with DESCRIPTOR_TERMINATE_LIST * Example of topology definition for single socket system: * @code * PCIe_PORT_DESCRIPTOR PortList [] = { diff --git a/src/vendorcode/amd/agesa/f14/AGESA.h b/src/vendorcode/amd/agesa/f14/AGESA.h index 2a9bed1..4237f86 100644 --- a/src/vendorcode/amd/agesa/f14/AGESA.h +++ b/src/vendorcode/amd/agesa/f14/AGESA.h @@ -877,7 +877,7 @@ typedef struct { /// GNB configuration info typedef struct { IN PCIe_COMPLEX_DESCRIPTOR *PcieComplexList; /**< Pointer to array of structures describe PCIe topology on each processor package or NULL. - * Last element of array must ne terminated with DESCRIPTOR_TERMINATE_LIST + * Last element of array must be terminated with DESCRIPTOR_TERMINATE_LIST * Example of topology definition for single socket system: * @code * PCIe_PORT_DESCRIPTOR PortList [] = { diff --git a/src/vendorcode/amd/agesa/f15/AGESA.h b/src/vendorcode/amd/agesa/f15/AGESA.h index 6b0171b..8b77fd8 100644 --- a/src/vendorcode/amd/agesa/f15/AGESA.h +++ b/src/vendorcode/amd/agesa/f15/AGESA.h @@ -1145,7 +1145,7 @@ typedef struct { /// GNB configuration info typedef struct { IN PCIe_COMPLEX_DESCRIPTOR *PcieComplexList; /**< Pointer to array of structures describe PCIe topology on each processor package or NULL. - * Last element of array must ne terminated with DESCRIPTOR_TERMINATE_LIST + * Last element of array must be terminated with DESCRIPTOR_TERMINATE_LIST * Example of topology definition for single socket system: * @code * PCIe_PORT_DESCRIPTOR PortList [] = { diff --git a/src/vendorcode/amd/agesa/f15tn/AGESA.h b/src/vendorcode/amd/agesa/f15tn/AGESA.h index a709274..1392810 100644 --- a/src/vendorcode/amd/agesa/f15tn/AGESA.h +++ b/src/vendorcode/amd/agesa/f15tn/AGESA.h @@ -1244,7 +1244,7 @@ typedef struct { /// GNB configuration info typedef struct { IN PCIe_COMPLEX_DESCRIPTOR *PcieComplexList; /**< Pointer to array of structures describe PCIe topology on each processor package or NULL. - * Last element of array must ne terminated with DESCRIPTOR_TERMINATE_LIST + * Last element of array must be terminated with DESCRIPTOR_TERMINATE_LIST * Example of topology definition for single socket system: * @code * PCIe_PORT_DESCRIPTOR PortList [] = {
