Vladimir Serbinenko (phcoder@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/4277
commit c1ce71c3332acaaf73bbcd7080a9fb919121deaf Author: Vladimir Serbinenko phcoder@gmail.com Date: Tue Nov 26 01:16:20 2013 +0100
ibexpeak: ensure config compatibility with bd82x6x
Ibexpeak shares few files with bd82x6x. In order for it to work correctly their config structures from chip.h must match, so include bd82x6x/chip.h in ibexpeak/chip.h
Change-Id: Ib56b311b8af04f4e4803d1834724680f604901cd Signed-off-by: Vladimir Serbinenko phcoder@gmail.com --- src/southbridge/intel/ibexpeak/azalia.c | 2 - src/southbridge/intel/ibexpeak/chip.h | 86 ++------------------------------- src/southbridge/intel/ibexpeak/lpc.c | 2 +- src/southbridge/intel/ibexpeak/sata.c | 2 +- 4 files changed, 7 insertions(+), 85 deletions(-)
diff --git a/src/southbridge/intel/ibexpeak/azalia.c b/src/southbridge/intel/ibexpeak/azalia.c index 8a1116a..0e3d365 100644 --- a/src/southbridge/intel/ibexpeak/azalia.c +++ b/src/southbridge/intel/ibexpeak/azalia.c @@ -32,8 +32,6 @@ #define HDA_ICII_BUSY (1 << 0) #define HDA_ICII_VALID (1 << 1)
-typedef struct southbridge_intel_bd82x6x_config config_t; - static int set_bits(u32 port, u32 mask, u32 val) { u32 reg32; diff --git a/src/southbridge/intel/ibexpeak/chip.h b/src/southbridge/intel/ibexpeak/chip.h index 828466c..466ae79 100644 --- a/src/southbridge/intel/ibexpeak/chip.h +++ b/src/southbridge/intel/ibexpeak/chip.h @@ -17,87 +17,11 @@ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */
-#ifndef SOUTHBRIDGE_INTEL_BD82X6X_CHIP_H -#define SOUTHBRIDGE_INTEL_BD82X6X_CHIP_H +#ifndef SOUTHBRIDGE_INTEL_IBEXPEAK_CHIP_H +#define SOUTHBRIDGE_INTEL_IBEXPEAK_CHIP_H
-struct southbridge_intel_bd82x6x_config { - /** - * Interrupt Routing configuration - * If bit7 is 1, the interrupt is disabled. - */ - uint8_t pirqa_routing; - uint8_t pirqb_routing; - uint8_t pirqc_routing; - uint8_t pirqd_routing; - uint8_t pirqe_routing; - uint8_t pirqf_routing; - uint8_t pirqg_routing; - uint8_t pirqh_routing; +#define southbridge_intel_bd82x6x_config southbridge_intel_ibexpeak_config
- /** - * GPI Routing configuration - * - * Only the lower two bits have a meaning: - * 00: No effect - * 01: SMI# (if corresponding ALT_GPI_SMI_EN bit is also set) - * 10: SCI (if corresponding GPIO_EN bit is also set) - * 11: reserved - */ - uint8_t gpi0_routing; - uint8_t gpi1_routing; - uint8_t gpi2_routing; - uint8_t gpi3_routing; - uint8_t gpi4_routing; - uint8_t gpi5_routing; - uint8_t gpi6_routing; - uint8_t gpi7_routing; - uint8_t gpi8_routing; - uint8_t gpi9_routing; - uint8_t gpi10_routing; - uint8_t gpi11_routing; - uint8_t gpi12_routing; - uint8_t gpi13_routing; - uint8_t gpi14_routing; - uint8_t gpi15_routing; +#include "../bd82x6x/chip.h"
- uint32_t gpe0_en; - uint16_t alt_gp_smi_en; - - /* IDE configuration */ - uint32_t ide_legacy_combined; - uint32_t sata_ahci; - uint8_t sata_port_map; - uint32_t sata_port0_gen3_tx; - uint32_t sata_port1_gen3_tx; - - /** - * SATA Interface Speed Support Configuration - * - * Only the lower two bits have a meaning: - * 00 - No effect (leave as chip default) - * 01 - 1.5 Gb/s maximum speed - * 10 - 3.0 Gb/s maximum speed - * 11 - 6.0 Gb/s maximum speed - */ - uint8_t sata_interface_speed_support; - - uint32_t gen1_dec; - uint32_t gen2_dec; - uint32_t gen3_dec; - uint32_t gen4_dec; - - /* Enable linear PCIe Root Port function numbers starting at zero */ - uint8_t pcie_port_coalesce; - - /* Override PCIe ASPM */ - uint8_t pcie_aspm_f0; - uint8_t pcie_aspm_f1; - uint8_t pcie_aspm_f2; - uint8_t pcie_aspm_f3; - uint8_t pcie_aspm_f4; - uint8_t pcie_aspm_f5; - uint8_t pcie_aspm_f6; - uint8_t pcie_aspm_f7; -}; - -#endif /* SOUTHBRIDGE_INTEL_BD82X6X_CHIP_H */ +#endif diff --git a/src/southbridge/intel/ibexpeak/lpc.c b/src/southbridge/intel/ibexpeak/lpc.c index 8417a90..691b139 100644 --- a/src/southbridge/intel/ibexpeak/lpc.c +++ b/src/southbridge/intel/ibexpeak/lpc.c @@ -38,7 +38,7 @@ #define ENABLE_ACPI_MODE_IN_COREBOOT 0 #define TEST_SMM_FLASH_LOCKDOWN 0
-typedef struct southbridge_intel_bd82x6x_config config_t; +typedef struct southbridge_intel_ibexpeak_config config_t;
/** * Set miscellanous static southbridge features. diff --git a/src/southbridge/intel/ibexpeak/sata.c b/src/southbridge/intel/ibexpeak/sata.c index 943d085..9f96d49 100644 --- a/src/southbridge/intel/ibexpeak/sata.c +++ b/src/southbridge/intel/ibexpeak/sata.c @@ -26,7 +26,7 @@ #include <device/pci_ids.h> #include "pch.h"
static inline u32 sir_read(struct device *dev, int idx) {
