Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/79261?usp=email )
Change subject: cpu/x86/64bit: Turn jumping to long mode into a macro ......................................................................
This makes it easier to reuse, e.g. if you want to do it twice in one assembly file.
Change-Id: Ida861338004187e4e714be41e17c8447fa4cf935 Signed-off-by: Arthur Heymans arthur@aheymans.xyz Reviewed-on: https://review.coreboot.org/c/coreboot/+/79261 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/cpu/intel/car/core2/cache_as_ram.S M src/cpu/intel/car/non-evict/cache_as_ram.S M src/cpu/intel/car/p4-netburst/cache_as_ram.S M src/cpu/qemu-x86/cache_as_ram_bootblock.S M src/cpu/x86/64bit/entry64.inc M src/cpu/x86/64bit/mode_switch.S M src/cpu/x86/64bit/mode_switch2.S M src/cpu/x86/sipi_vector.S M src/cpu/x86/smm/smm_stub.S M src/soc/amd/common/block/cpu/noncar/pre_c.S M src/soc/intel/common/block/cpu/car/cache_as_ram.S 11 files changed, 30 insertions(+), 19 deletions(-)
diff --git a/src/cpu/intel/car/core2/cache_as_ram.S b/src/cpu/intel/car/core2/cache_as_ram.S index e134717..2e4d9c8 100644 --- a/src/cpu/intel/car/core2/cache_as_ram.S +++ b/src/cpu/intel/car/core2/cache_as_ram.S @@ -4,6 +4,7 @@ #include <cpu/x86/mtrr.h> #include <cpu/x86/cache.h> #include <cpu/x86/post_code.h> +#include <cpu/x86/64bit/entry64.inc>
.section .init .global bootblock_pre_c_entry @@ -162,8 +163,7 @@ subl $4, %esp
#if ENV_X86_64 - - #include <cpu/x86/64bit/entry64.inc> + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC)
movd %mm2, %rdi shlq $32, %rdi diff --git a/src/cpu/intel/car/non-evict/cache_as_ram.S b/src/cpu/intel/car/non-evict/cache_as_ram.S index 76986ff..578bf03 100644 --- a/src/cpu/intel/car/non-evict/cache_as_ram.S +++ b/src/cpu/intel/car/non-evict/cache_as_ram.S @@ -4,6 +4,7 @@ #include <cpu/x86/mtrr.h> #include <cpu/x86/cache.h> #include <cpu/x86/post_code.h> +#include <cpu/x86/64bit/entry64.inc>
#define NoEvictMod_MSR 0x2e0 #define BBL_CR_CTL3_MSR 0x11e @@ -213,8 +214,7 @@ andl $0xfffffff0, %esp
movd %mm2, %rdi shlq $32, %rdi diff --git a/src/cpu/intel/car/p4-netburst/cache_as_ram.S b/src/cpu/intel/car/p4-netburst/cache_as_ram.S index f7c023b..32fddd6 100644 --- a/src/cpu/intel/car/p4-netburst/cache_as_ram.S +++ b/src/cpu/intel/car/p4-netburst/cache_as_ram.S @@ -13,6 +13,7 @@ .global bootblock_pre_c_entry
#include <cpu/intel/car/cache_as_ram_symbols.inc> +#include <cpu/x86/64bit/entry64.inc>
.code32 _cache_as_ram_setup: @@ -362,7 +363,7 @@ subl $4, %esp
#if ENV_X86_64 - #include <cpu/x86/64bit/entry64.inc> + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC)
movd %mm2, %rdi shlq $32, %rdi /* BIST */ diff --git a/src/cpu/qemu-x86/cache_as_ram_bootblock.S b/src/cpu/qemu-x86/cache_as_ram_bootblock.S index 859b760..e2662c2 100644 --- a/src/cpu/qemu-x86/cache_as_ram_bootblock.S +++ b/src/cpu/qemu-x86/cache_as_ram_bootblock.S @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#define CBFS_FILE_MAGIC 0 #define CBFS_FILE_LEN (CBFS_FILE_MAGIC + 8) @@ -79,7 +80,7 @@
#if ENV_X86_64 /* entry64.inc preserves ebx. */ -#include <cpu/x86/64bit/entry64.inc> + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC)
/* Restore the BIST result and timestamps. */ movd %mm2, %rdi diff --git a/src/cpu/x86/64bit/entry64.inc b/src/cpu/x86/64bit/entry64.inc index 7da68b4..878f310 100644 --- a/src/cpu/x86/64bit/entry64.inc +++ b/src/cpu/x86/64bit/entry64.inc @@ -22,10 +22,9 @@ #include <arch/rom_segs.h> #endif
- -setup_longmode: +.macro setup_longmode page_table /* Get page table address */ - movl $(CONFIG_ARCH_X86_64_PGTBL_LOC), %eax + movl \page_table, %eax
/* load identity mapped page tables */ movl %eax, %cr3 @@ -48,12 +47,13 @@
/* use long jump to switch to 64-bit code segment */ #if defined(__RAMSTAGE__) - ljmp $RAM_CODE_SEG64, $__longmode_start + ljmp $RAM_CODE_SEG64, $jmp_addr@ #else - ljmp $ROM_CODE_SEG64, $__longmode_start + ljmp $ROM_CODE_SEG64, $jmp_addr@
#endif .code64 -__longmode_start: +jmp_addr@: +.endm
#endif diff --git a/src/cpu/x86/64bit/mode_switch.S b/src/cpu/x86/64bit/mode_switch.S index c4198f3..01fe003 100644 --- a/src/cpu/x86/64bit/mode_switch.S +++ b/src/cpu/x86/64bit/mode_switch.S @@ -1,4 +1,5 @@ /* SPDX-License-Identifier: GPL-2.0-only */ +#include <cpu/x86/64bit/entry64.inc>
/* Calls a x86_32 function from x86_64 context */ .text @@ -42,8 +43,8 @@ call *%ebx movl %eax, %ebx
- /* Jump to long mode. Preserves ebx */ - #include <cpu/x86/64bit/entry64.inc> + /* Preserves ebx */ + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC)
/* Place return value in rax */ movl %ebx, %eax diff --git a/src/cpu/x86/64bit/mode_switch2.S b/src/cpu/x86/64bit/mode_switch2.S index 65e9d94..1807d2e 100644 --- a/src/cpu/x86/64bit/mode_switch2.S +++ b/src/cpu/x86/64bit/mode_switch2.S @@ -4,6 +4,8 @@ * Must not be directly invoked from C code! */
+#include <cpu/x86/64bit/entry64.inc> + .text .code32 .section ".text.long_mode_call_3arg", "ax", @progbits @@ -19,7 +21,7 @@ mov %esp, %ebp
/* Enter long mode, preserves ebx */ - #include <cpu/x86/64bit/entry64.inc> + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC)
/* Align stack */ movabs $0xfffffffffffffff0, %rax diff --git a/src/cpu/x86/sipi_vector.S b/src/cpu/x86/sipi_vector.S index 39973db..923e398 100644 --- a/src/cpu/x86/sipi_vector.S +++ b/src/cpu/x86/sipi_vector.S @@ -6,6 +6,7 @@ #include <arch/ram_segs.h>
#define __RAMSTAGE__ +#include <cpu/x86/64bit/entry64.inc>
/* The SIPI vector is responsible for initializing the APs in the system. It * loads microcode, sets up MSRs, and enables caching before calling into @@ -223,7 +224,8 @@
#if ENV_X86_64 /* entry64.inc preserves ebx, esi, edi, ebp */ -#include <cpu/x86/64bit/entry64.inc> + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC) + movabs c_handler, %eax call *%rax #else diff --git a/src/cpu/x86/smm/smm_stub.S b/src/cpu/x86/smm/smm_stub.S index f97ab59..9f1f21d 100644 --- a/src/cpu/x86/smm/smm_stub.S +++ b/src/cpu/x86/smm/smm_stub.S @@ -12,6 +12,7 @@ #include <cpu/x86/cr.h> #include <cpu/x86/msr.h> #include <cpu/x86/lapic_def.h> +#include <cpu/x86/64bit/entry64.inc>
.code32 .section ".module_parameters", "aw", @progbits @@ -195,7 +196,7 @@ #if ENV_X86_64 mov %ecx, %edi /* entry64.inc preserves ebx, esi, edi, ebp */ -#include <cpu/x86/64bit/entry64.inc> + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC) mov %edi, %ecx
diff --git a/src/soc/amd/common/block/cpu/noncar/pre_c.S b/src/soc/amd/common/block/cpu/noncar/pre_c.S index eb556fa..bb2203b 100644 --- a/src/soc/amd/common/block/cpu/noncar/pre_c.S +++ b/src/soc/amd/common/block/cpu/noncar/pre_c.S @@ -1,6 +1,7 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <amdblocks/post_codes.h> +#include <cpu/x86/64bit/entry64.inc> #include <cpu/x86/post_code.h>
.section .init, "ax", @progbits @@ -27,7 +28,7 @@ post_code(POSTCODE_BOOTBLOCK_PRE_C_ENTRY)
#if ENV_X86_64 - #include <cpu/x86/64bit/entry64.inc> + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC) #endif
/* Clear .bss section */ diff --git a/src/soc/intel/common/block/cpu/car/cache_as_ram.S b/src/soc/intel/common/block/cpu/car/cache_as_ram.S index 61cbe307..c22e7d9 100644 --- a/src/soc/intel/common/block/cpu/car/cache_as_ram.S +++ b/src/soc/intel/common/block/cpu/car/cache_as_ram.S @@ -9,6 +9,7 @@ #include <cpu/x86/post_code.h> #include <intelblocks/msr.h> #include <intelblocks/post_codes.h> +#include <cpu/x86/64bit/entry64.inc>
@@ -279,7 +280,8 @@ andl $0xfffffff0, %esp
#if ENV_X86_64 - #include <cpu/x86/64bit/entry64.inc> + setup_longmode $(CONFIG_ARCH_X86_64_PGTBL_LOC) + movd %mm2, %rdi shlq $32, %rdi movd %mm1, %rsi
