Subrata Banik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/45688 )
Change subject: soc/intel/{jsl,tgl}: Refactor gpio_op.asl ......................................................................
Also align GPMO ASL function with TGL.
Change-Id: Ia40af2cba9867838a1f99141481a5e78cffa0111 Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/soc/intel/jasperlake/acpi/gpio_op.asl M src/soc/intel/tigerlake/acpi/gpio_op.asl 2 files changed, 14 insertions(+), 15 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/45688/1
diff --git a/src/soc/intel/jasperlake/acpi/gpio_op.asl b/src/soc/intel/jasperlake/acpi/gpio_op.asl index 683686f..0da4696 100644 --- a/src/soc/intel/jasperlake/acpi/gpio_op.asl +++ b/src/soc/intel/jasperlake/acpi/gpio_op.asl @@ -43,7 +43,7 @@ { VAL0, 32 } - VAL0 = PAD_CFG0_TX_STATE | VAL0 + VAL0 |= PAD_CFG0_TX_STATE }
/* @@ -57,7 +57,7 @@ { VAL0, 32 } - VAL0 = ~PAD_CFG0_TX_STATE & VAL0 + VAL0 &= ~PAD_CFG0_TX_STATE }
/* @@ -76,9 +76,8 @@ { VAL0, 32 } - Local0 = VAL0 - Local0 = ~PAD_CFG0_MODE_MASK & Local0 - Arg1 = (Arg1 <<= PAD_CFG0_MODE_SHIFT) & PAD_CFG0_MODE_MASK + Local0 = ~PAD_CFG0_MODE_MASK & VAL0 + Arg1 = (Arg1 << PAD_CFG0_MODE_SHIFT) & PAD_CFG0_MODE_MASK VAL0 = Local0 | Arg1 }
@@ -98,9 +97,9 @@ }
If (Arg1 == 1) { - VAL0 = ~PAD_CFG0_TX_DISABLE & VAL0 + VAL0 &= ~PAD_CFG0_TX_DISABLE } ElseIf (Arg1 == 0){ - VAL0 = PAD_CFG0_TX_DISABLE | VAL0 + VAL0 &= PAD_CFG0_TX_DISABLE } }
@@ -120,8 +119,8 @@ }
If (Arg1 == 1) { - VAL0 = ~PAD_CFG0_RX_DISABLE & VAL0 + VAL0 &= ~PAD_CFG0_RX_DISABLE } ElseIf (Arg1 == 0){ - VAL0 = PAD_CFG0_RX_DISABLE | VAL0 + VAL0 |= PAD_CFG0_RX_DISABL } } diff --git a/src/soc/intel/tigerlake/acpi/gpio_op.asl b/src/soc/intel/tigerlake/acpi/gpio_op.asl index f7332aa..0da4696 100644 --- a/src/soc/intel/tigerlake/acpi/gpio_op.asl +++ b/src/soc/intel/tigerlake/acpi/gpio_op.asl @@ -43,7 +43,7 @@ { VAL0, 32 } - VAL0 = PAD_CFG0_TX_STATE | VAL0 + VAL0 |= PAD_CFG0_TX_STATE }
/* @@ -97,9 +97,9 @@ }
@@ -119,8 +119,8 @@ }
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45688 )
Patch Set 1: Code-Review+1
https://review.coreboot.org/c/coreboot/+/45688/1/src/soc/intel/tigerlake/acp... File src/soc/intel/tigerlake/acpi/gpio_op.asl:
https://review.coreboot.org/c/coreboot/+/45688/1/src/soc/intel/tigerlake/acp... PS1, Line 124: PAD_CFG0_RX_DISABL missing an `E`
Hello Elyes HAOUAS, build bot (Jenkins), Furquan Shaikh, Tim Wawrzynczak, Angel Pons, Patrick Rudolph,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/45688/2
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45688 )
Patch Set 2:
missing an `E`
Ack
HAOUAS Elyes has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45688 )
Patch Set 2: Code-Review+2
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45688 )
Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/45688 )
Change-Id: Ia40af2cba9867838a1f99141481a5e78cffa0111 Signed-off-by: Subrata Banik subrata.banik@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/45688 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: HAOUAS Elyes ehaouas@noos.fr Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Furquan Shaikh furquan@google.com --- M src/soc/intel/jasperlake/acpi/gpio_op.asl M src/soc/intel/tigerlake/acpi/gpio_op.asl 2 files changed, 14 insertions(+), 15 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved HAOUAS Elyes: Looks good to me, approved Angel Pons: Looks good to me, approved
diff --git a/src/soc/intel/jasperlake/acpi/gpio_op.asl b/src/soc/intel/jasperlake/acpi/gpio_op.asl index 683686f..9b9dc44 100644 --- a/src/soc/intel/jasperlake/acpi/gpio_op.asl +++ b/src/soc/intel/jasperlake/acpi/gpio_op.asl @@ -43,7 +43,7 @@ { VAL0, 32 } - VAL0 = PAD_CFG0_TX_STATE | VAL0 + VAL0 |= PAD_CFG0_TX_STATE }
@@ -98,9 +97,9 @@ }
If (Arg1 == 1) { - VAL0 = ~PAD_CFG0_RX_DISABLE & VAL0 + VAL0 &= ~PAD_CFG0_RX_DISABLE } ElseIf (Arg1 == 0){ - VAL0 = PAD_CFG0_RX_DISABLE | VAL0 + VAL0 |= PAD_CFG0_RX_DISABLE } } diff --git a/src/soc/intel/tigerlake/acpi/gpio_op.asl b/src/soc/intel/tigerlake/acpi/gpio_op.asl index f7332aa..9b9dc44 100644 --- a/src/soc/intel/tigerlake/acpi/gpio_op.asl +++ b/src/soc/intel/tigerlake/acpi/gpio_op.asl @@ -43,7 +43,7 @@ { VAL0, 32 } - VAL0 = PAD_CFG0_TX_STATE | VAL0 + VAL0 |= PAD_CFG0_TX_STATE }
