Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17691
commit 1e91aa905ab1d27ee4cc0b1bb4d9a520f6020e06 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Fri Dec 2 08:06:55 2016 +0200
PCI ops: Remove pci_mmio_xx() in ramstage
MMCONF operations are already the default so these would never be used.
Change-Id: I671f3d2847742e400bc4ecfccc088e3b79d43070 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/device/pci_ops.c | 45 -------------------------------------------- src/include/device/pci_ops.h | 8 -------- 2 files changed, 53 deletions(-)
diff --git a/src/device/pci_ops.c b/src/device/pci_ops.c index ab72405..2f896d2 100644 --- a/src/device/pci_ops.c +++ b/src/device/pci_ops.c @@ -118,48 +118,3 @@ void pci_write_config32(struct device *dev, unsigned int where, u32 val) pci_bus_ops(pbus, dev)->write32(pbus, dev->bus->secondary, dev->path.pci.devfn, where, val); } - -#if CONFIG_MMCONF_SUPPORT -u8 pci_mmio_read_config8(struct device *dev, unsigned int where) -{ - struct bus *pbus = get_pbus(dev); - return pci_ops_mmconf.read8(pbus, dev->bus->secondary, - dev->path.pci.devfn, where); -} - -u16 pci_mmio_read_config16(struct device *dev, unsigned int where) -{ - struct bus *pbus = get_pbus(dev); - return pci_ops_mmconf.read16(pbus, dev->bus->secondary, - dev->path.pci.devfn, where); -} - -u32 pci_mmio_read_config32(struct device *dev, unsigned int where) -{ - struct bus *pbus = get_pbus(dev); - return pci_ops_mmconf.read32(pbus, dev->bus->secondary, - dev->path.pci.devfn, where); -} - -void pci_mmio_write_config8(struct device *dev, unsigned int where, u8 val) -{ - struct bus *pbus = get_pbus(dev); - pci_ops_mmconf.write8(pbus, dev->bus->secondary, dev->path.pci.devfn, - where, val); -} - -void pci_mmio_write_config16(struct device *dev, unsigned int where, u16 val) -{ - struct bus *pbus = get_pbus(dev); - pci_ops_mmconf.write16(pbus, dev->bus->secondary, dev->path.pci.devfn, - where, val); -} - -void pci_mmio_write_config32(struct device *dev, unsigned int where, u32 val) -{ - struct bus *pbus = get_pbus(dev); - pci_ops_mmconf.write32(pbus, dev->bus->secondary, dev->path.pci.devfn, - where, val); -} - -#endif diff --git a/src/include/device/pci_ops.h b/src/include/device/pci_ops.h index 920475a..3310e10 100644 --- a/src/include/device/pci_ops.h +++ b/src/include/device/pci_ops.h @@ -13,14 +13,6 @@ void pci_write_config8(struct device *dev, unsigned int where, u8 val); void pci_write_config16(struct device *dev, unsigned int where, u16 val); void pci_write_config32(struct device *dev, unsigned int where, u32 val);
-#if CONFIG_MMCONF_SUPPORT -u8 pci_mmio_read_config8(struct device *dev, unsigned int where); -u16 pci_mmio_read_config16(struct device *dev, unsigned int where); -u32 pci_mmio_read_config32(struct device *dev, unsigned int where); -void pci_mmio_write_config8(struct device *dev, unsigned int where, u8 val); -void pci_mmio_write_config16(struct device *dev, unsigned int where, u16 val); -void pci_mmio_write_config32(struct device *dev, unsigned int where, u32 val); -#endif #endif
#endif /* PCI_OPS_H */
