Martin L Roth has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84759?usp=email )
Change subject: mb/google/brya: Create telith variant ......................................................................
Create the telith variant of the nissa reference board by copying the template files to a new directory named for the variant.
(Auto-Generated by create_coreboot_variant.sh version 4.5.0)
BUG=372506691 BRANCH=None TEST=util/abuild/abuild -p none -t google/brya -x -a make sure the build includes GOOGLE_TELITH
Change-Id: I4971b9691d3dd293ca640795967c36472afef9c9 Signed-off-by: Kun Liu liukun11@huaqin.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84759 Reviewed-by: Dinesh Gehlot digehlot@google.com Reviewed-by: Subrata Banik subratabanik@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Jian Tong tongjian@huaqin.corp-partner.google.com Reviewed-by: Eric Lai ericllai@google.com --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/Kconfig.name A src/mainboard/google/brya/variants/telith/Makefile.mk A src/mainboard/google/brya/variants/telith/gpio.c A src/mainboard/google/brya/variants/telith/include/variant/ec.h A src/mainboard/google/brya/variants/telith/include/variant/gpio.h A src/mainboard/google/brya/variants/telith/memory/Makefile.mk A src/mainboard/google/brya/variants/telith/memory/dram_id.generated.txt A src/mainboard/google/brya/variants/telith/memory/mem_parts_used.txt A src/mainboard/google/brya/variants/telith/overridetree.cb A src/mainboard/google/brya/variants/telith/variant.c 11 files changed, 814 insertions(+), 0 deletions(-)
Approvals: Jian Tong: Looks good to me, but someone else must approve Dinesh Gehlot: Looks good to me, approved build bot (Jenkins): Verified Subrata Banik: Looks good to me, approved Eric Lai: Looks good to me, but someone else must approve
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index 4f49df2..d840426 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -542,6 +542,16 @@ select HAVE_WWAN_POWER_SEQUENCE select SOC_INTEL_TWINLAKE
+config BOARD_GOOGLE_TELITH + select BOARD_GOOGLE_BASEBOARD_NISSA + select BOARD_ROMSIZE_KB_16384 + select CHROMEOS_WIFI_SAR if CHROMEOS + select DRIVERS_GENERIC_BAYHUB_LV2 + select DRIVERS_GENERIC_GPIO_KEYS + select DRIVERS_GFX_GENERIC + select DRIVERS_INTEL_MIPI_CAMERA + select SOC_INTEL_TWINLAKE + config BOARD_GOOGLE_TEREID select BOARD_GOOGLE_BASEBOARD_NISSA select BOARD_ROMSIZE_KB_32768 @@ -734,6 +744,7 @@ default 0x0 if BOARD_GOOGLE_YAVIKS default 0x0 if BOARD_GOOGLE_YAVILLA default 0x1 if BOARD_GOOGLE_ZYDRON + default 0x0 if BOARD_GOOGLE_TELITH
config DRIVER_TPM_I2C_ADDR hex @@ -808,6 +819,7 @@ default 13 if BOARD_GOOGLE_YAVIKS default 13 if BOARD_GOOGLE_YAVILLA default 13 if BOARD_GOOGLE_ZYDRON + default 13 if BOARD_GOOGLE_TELITH
config OVERRIDE_DEVICETREE default "variants/$(CONFIG_VARIANT_DIR)/overridetree.cb" @@ -889,6 +901,7 @@ default "Yavista" if BOARD_GOOGLE_YAVISTA default "Zydron" if BOARD_GOOGLE_ZYDRON default "Pujjoga" if BOARD_GOOGLE_PUJJOGA + default "Telith" if BOARD_GOOGLE_TELITH
config VARIANT_DIR default "agah" if BOARD_GOOGLE_AGAH @@ -956,6 +969,7 @@ default "zydron" if BOARD_GOOGLE_ZYDRON default "yavista" if BOARD_GOOGLE_YAVISTA default "pujjoga" if BOARD_GOOGLE_PUJJOGA + default "telith" if BOARD_GOOGLE_TELITH
config VBOOT select VBOOT_EARLY_EC_SYNC if !(BOARD_GOOGLE_BASEBOARD_NISSA || BOARD_GOOGLE_BASEBOARD_TRULO) diff --git a/src/mainboard/google/brya/Kconfig.name b/src/mainboard/google/brya/Kconfig.name index 6167976..b263642 100644 --- a/src/mainboard/google/brya/Kconfig.name +++ b/src/mainboard/google/brya/Kconfig.name @@ -196,3 +196,6 @@
config BOARD_GOOGLE_ORISA bool "-> Orisa" + +config BOARD_GOOGLE_TELITH + bool "-> Telith" diff --git a/src/mainboard/google/brya/variants/telith/Makefile.mk b/src/mainboard/google/brya/variants/telith/Makefile.mk new file mode 100644 index 0000000..f41cdfd --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/Makefile.mk @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0-only +bootblock-y += gpio.c + +romstage-y += gpio.c + +ramstage-y += gpio.c + +ramstage-y += variant.c diff --git a/src/mainboard/google/brya/variants/telith/gpio.c b/src/mainboard/google/brya/variants/telith/gpio.c new file mode 100644 index 0000000..7570d51 --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/gpio.c @@ -0,0 +1,125 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#include <baseboard/gpio.h> +#include <baseboard/variants.h> +#include <commonlib/helpers.h> +#include <soc/gpio.h> + +/* Pad configuration in ramstage */ +static const struct pad_config override_gpio_table[] = { + /* A11 : GPP_A11 ==> EN_SPK_PA */ + PAD_CFG_GPO(GPP_A11, 0, DEEP), + /* A18 : NC ==> HDMI_HPD_SRC*/ + PAD_CFG_NF(GPP_A18, NONE, DEEP, NF1), + + /* A20 : DDSP_HPD2 ==> NC */ + PAD_NC_LOCK(GPP_A20, NONE, LOCK_CONFIG), + /* A21 : GPP_A21 ==> NC */ + PAD_NC_LOCK(GPP_A21, NONE, LOCK_CONFIG), + /* A22 : GPP_A22 ==> NC */ + PAD_NC_LOCK(GPP_A22, NONE, LOCK_CONFIG), + + /* B5 : I2C2_SDA ==> MIPI_WCAM_SDA */ + PAD_CFG_NF_LOCK(GPP_B5, NONE, NF2, LOCK_CONFIG), + /* B6 : I2C2_SCL ==> MIPI_WCAM_SCL */ + PAD_CFG_NF_LOCK(GPP_B6, NONE, NF2, LOCK_CONFIG), + + /* B11 : NC ==> EN_PP3300_WLAN_X*/ + PAD_CFG_GPO(GPP_B11, 0, DEEP), + + /* D8 : SRCCLKREQ3# ==> NC */ + PAD_NC_LOCK(GPP_D8, NONE, LOCK_CONFIG), + /* D13 : NC ==> EN_PP1800_WCAM_X */ + PAD_CFG_GPO_LOCK(GPP_D13, 1, LOCK_CONFIG), + + /* E20 : DDP2_CTRLCLK ==> NC */ + PAD_NC_LOCK(GPP_E20, NONE, LOCK_CONFIG), + /* E21 : DDP2_CTRLDATA ==> GPP_E21_STRAP */ + PAD_NC_LOCK(GPP_E21, NONE, LOCK_CONFIG), + + /* H22 : IMGCLKOUT3 ==> WCAM_MCLK_R */ + PAD_CFG_NF(GPP_H22, NONE, DEEP, NF1), + + /* F6 : CNV_PA_BLANKING ==> NC */ + PAD_NC(GPP_F6, NONE), + /* F15 : GSXSRESET# ==> SOC_PEN_DETECT_ODL */ + PAD_CFG_GPI_SCI_HIGH(GPP_F15, NONE, PLTRST, EDGE_BOTH), + /* F18 : THC1_SPI2_INT# ==> NC */ + PAD_NC(GPP_F18, NONE), + /* F23 : V1P05_CTRL ==> NC*/ + PAD_NC_LOCK(GPP_F23, NONE, LOCK_CONFIG), + + /* H8 : CNV_MFUART2_RXD ==> NC */ + PAD_NC(GPP_H8, NONE), + /* H9 : CNV_MFUART2_TXD ==> NC */ + PAD_NC(GPP_H9, NONE), + /* H12 : UART0_RTS# ==> NC*/ + PAD_NC_LOCK(GPP_H12, NONE, LOCK_CONFIG), + /* H13 : UART0_CTS# ==> NC */ + PAD_NC_LOCK(GPP_H13, NONE, LOCK_CONFIG), + /* H15 : DDPB_CTRLCLK ==> HDMI_DDC_SCL */ + PAD_CFG_NF(GPP_H15, NONE, DEEP, NF1), + /* H17 : DDPB_CTRLDATA ==> HDMI_DDC_SDA */ + PAD_CFG_NF(GPP_H17, NONE, DEEP, NF1), + + /* R6 : DMIC_CLK_A_1A ==> NC */ + PAD_NC_LOCK(GPP_R6, NONE, LOCK_CONFIG), + /* R7 : DMIC_DATA_1A ==> NC */ + PAD_NC_LOCK(GPP_R7, NONE, LOCK_CONFIG), + + /* Configure the virtual CNVi Bluetooth I2S GPIO pads */ + /* BT_I2S_BCLK */ + PAD_CFG_NF(GPP_VGPIO_30, NONE, DEEP, NF3), + /* BT_I2S_SYNC */ + PAD_CFG_NF(GPP_VGPIO_31, NONE, DEEP, NF3), + /* BT_I2S_SDO */ + PAD_CFG_NF(GPP_VGPIO_32, NONE, DEEP, NF3), + /* BT_I2S_SDI */ + PAD_CFG_NF(GPP_VGPIO_33, NONE, DEEP, NF3), + /* SSP2_SCLK */ + PAD_CFG_NF(GPP_VGPIO_34, NONE, DEEP, NF1), + /* SSP2_SFRM */ + PAD_CFG_NF(GPP_VGPIO_35, NONE, DEEP, NF1), + /* SSP_TXD */ + PAD_CFG_NF(GPP_VGPIO_36, NONE, DEEP, NF1), + /* SSP_RXD */ + PAD_CFG_NF(GPP_VGPIO_37, NONE, DEEP, NF1), +}; + +/* Early pad configuration in bootblock */ +static const struct pad_config early_gpio_table[] = { + /* C0 : SMBCLK ==> EN_PP3300_TCHSCR_X */ + PAD_CFG_GPO(GPP_C0, 1, DEEP), + /* C1 : SMBDATA ==> TCHSCR_RST_L */ + PAD_CFG_GPO(GPP_C1, 1, DEEP), + + /* H20 : IMGCLKOUT1 ==> WLAN_PERST_L */ + PAD_CFG_GPO(GPP_H20, 0, DEEP), + /* A13 : GPP_A13 ==> GSC_SOC_INT_ODL */ + PAD_CFG_GPI_APIC(GPP_A13, NONE, PLTRST, LEVEL, INVERT), + /* E12 : THC0_SPI1_IO1 ==> SOC_WP_OD */ + PAD_CFG_GPI_GPIO_DRIVER(GPP_E12, NONE, DEEP), + + + /* H4 : I2C0_SDA ==> SOC_I2C_GSC_SDA */ + PAD_CFG_NF(GPP_H4, NONE, DEEP, NF1), + /* H5 : I2C0_SCL ==> SOC_I2C_GSC_SCL */ + PAD_CFG_NF(GPP_H5, NONE, DEEP, NF1), + + /* H10 : UART0_RXD ==> UART_SOC_RX_DBG_TX */ + PAD_CFG_NF(GPP_H10, NONE, DEEP, NF2), + /* H11 : UART0_TXD ==> UART_SOC_TX_DBG_RX */ + PAD_CFG_NF(GPP_H11, NONE, DEEP, NF2), +}; + +const struct pad_config *variant_gpio_override_table(size_t *num) +{ + *num = ARRAY_SIZE(override_gpio_table); + return override_gpio_table; +} + +const struct pad_config *variant_early_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(early_gpio_table); + return early_gpio_table; +} diff --git a/src/mainboard/google/brya/variants/telith/include/variant/ec.h b/src/mainboard/google/brya/variants/telith/include/variant/ec.h new file mode 100644 index 0000000..7a2a6ff --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/include/variant/ec.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __VARIANT_EC_H__ +#define __VARIANT_EC_H__ + +#include <baseboard/ec.h> + +#endif diff --git a/src/mainboard/google/brya/variants/telith/include/variant/gpio.h b/src/mainboard/google/brya/variants/telith/include/variant/gpio.h new file mode 100644 index 0000000..c4fe342 --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/include/variant/gpio.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <baseboard/gpio.h> + +#endif diff --git a/src/mainboard/google/brya/variants/telith/memory/Makefile.mk b/src/mainboard/google/brya/variants/telith/memory/Makefile.mk new file mode 100644 index 0000000..3b7dc39 --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/memory/Makefile.mk @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Generated by: +# util/spd_tools/bin/part_id_gen ADL lp5 src/mainboard/google/brya/variants/teliks/memory src/mainboard/google/brya/variants/teliks/memory/mem_parts_used.txt + +SPD_SOURCES = +SPD_SOURCES += spd/lp5/set-0/spd-1.hex # ID = 0(0b0000) Parts = MT62F512M32D2DR-031 WT:B, H9JCNNNBK3MLYR-N6E +SPD_SOURCES += spd/lp5/set-0/spd-2.hex # ID = 1(0b0001) Parts = H9JCNNNCP3MLYR-N6E, MT62F1G32D4DR-031 WT:B +SPD_SOURCES += spd/lp5/set-0/spd-4.hex # ID = 2(0b0010) Parts = H9JCNNNFA5MLYR-N6E, MT62F2G32D8DR-031 WT:B +SPD_SOURCES += spd/lp5/set-0/spd-9.hex # ID = 3(0b0011) Parts = K3KL6L60GM-MGCT +SPD_SOURCES += spd/lp5/set-0/spd-7.hex # ID = 4(0b0100) Parts = MT62F1G32D2DS-026 WT:B, K3KL8L80CM-MGCT, H58G56BK7BX068 +SPD_SOURCES += spd/lp5/set-0/spd-8.hex # ID = 5(0b0101) Parts = MT62F2G32D4DS-026 WT:B, K3KL9L90CM-MGCT, H58G66BK7BX067 diff --git a/src/mainboard/google/brya/variants/telith/memory/dram_id.generated.txt b/src/mainboard/google/brya/variants/telith/memory/dram_id.generated.txt new file mode 100644 index 0000000..773f11b --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/memory/dram_id.generated.txt @@ -0,0 +1,19 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Generated by: +# util/spd_tools/bin/part_id_gen ADL lp5 src/mainboard/google/brya/variants/teliks/memory src/mainboard/google/brya/variants/teliks/memory/mem_parts_used.txt + +DRAM Part Name ID to assign +MT62F512M32D2DR-031 WT:B 0 (0000) +H9JCNNNBK3MLYR-N6E 0 (0000) +H9JCNNNCP3MLYR-N6E 1 (0001) +MT62F1G32D4DR-031 WT:B 1 (0001) +H9JCNNNFA5MLYR-N6E 2 (0010) +MT62F2G32D8DR-031 WT:B 2 (0010) +K3KL6L60GM-MGCT 3 (0011) +MT62F1G32D2DS-026 WT:B 4 (0100) +K3KL8L80CM-MGCT 4 (0100) +H58G56BK7BX068 4 (0100) +MT62F2G32D4DS-026 WT:B 5 (0101) +K3KL9L90CM-MGCT 5 (0101) +H58G66BK7BX067 5 (0101) diff --git a/src/mainboard/google/brya/variants/telith/memory/mem_parts_used.txt b/src/mainboard/google/brya/variants/telith/memory/mem_parts_used.txt new file mode 100644 index 0000000..8aee4de --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/memory/mem_parts_used.txt @@ -0,0 +1,24 @@ +# This is a CSV file containing a list of memory parts used by this variant. +# One part per line with an optional fixed ID in column 2. +# Only include a fixed ID if it is required for legacy reasons! +# Generated IDs are dependent on the order of parts in this file, +# so new parts must always be added at the end of the file! +# +# Generate an updated Makefile.mk and dram_id.generated.txt by running the +# part_id_gen tool from util/spd_tools. +# See util/spd_tools/README.md for more details and instructions. + +# Part Name +MT62F512M32D2DR-031 WT:B +H9JCNNNBK3MLYR-N6E +H9JCNNNCP3MLYR-N6E +MT62F1G32D4DR-031 WT:B +H9JCNNNFA5MLYR-N6E +MT62F2G32D8DR-031 WT:B +K3KL6L60GM-MGCT +MT62F1G32D2DS-026 WT:B +K3KL8L80CM-MGCT +H58G56BK7BX068 +MT62F2G32D4DS-026 WT:B +K3KL9L90CM-MGCT +H58G66BK7BX067 diff --git a/src/mainboard/google/brya/variants/telith/overridetree.cb b/src/mainboard/google/brya/variants/telith/overridetree.cb new file mode 100644 index 0000000..6ed58f7 --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/overridetree.cb @@ -0,0 +1,537 @@ +fw_config + field WIFI 8 9 + option UNKNOWN 0 + option WIFI_6_7921 1 + option WIFI_6E 2 + option WIFI_6_8852 3 + end + field CAMERA 10 11 + option UF_720P_WF 0 + option UF_1080P 1 + option UF_720P 2 + option UF_1080P_WF 3 + end +end + +chip soc/intel/alderlake + register "sagv" = "SaGv_Enabled" + + # EMMC Tx CMD Delay + # Refer to EDS-Vol2-42.3.7. + # [14:8] steps of delay for DDR mode, each 125ps, range: 0 - 39. + # [6:0] steps of delay for SDR mode, each 125ps, range: 0 - 39. + register "common_soc_config.emmc_dll.emmc_tx_cmd_cntl" = "0x505" + + # EMMC TX DATA Delay 1 + # Refer to EDS-Vol2-42.3.8. + # [14:8] steps of delay for HS400, each 125ps, range: 0 - 78. + # [6:0] steps of delay for SDR104/HS200, each 125ps, range: 0 - 79. + register "common_soc_config.emmc_dll.emmc_tx_data_cntl1" = "0x909" + + # EMMC TX DATA Delay 2 + # Refer to EDS-Vol2-42.3.9. + # [30:24] steps of delay for SDR50, each 125ps, range: 0 - 79. + # [22:16] steps of delay for DDR50, each 125ps, range: 0 - 78. + # [14:8] steps of delay for SDR25/HS50, each 125ps, range: 0 -79. + # [6:0] steps of delay for SDR12, each 125ps. Range: 0 - 79. + register "common_soc_config.emmc_dll.emmc_tx_data_cntl2" = "0x1C2A2828" + + # EMMC RX CMD/DATA Delay 1 + # Refer to EDS-Vol2-42.3.10. + # [30:24] steps of delay for SDR50, each 125ps, range: 0 - 119. + # [22:16] steps of delay for DDR50, each 125ps, range: 0 - 78. + # [14:8] steps of delay for SDR25/HS50, each 125ps, range: 0 - 119. + # [6:0] steps of delay for SDR12, each 125ps, range: 0 - 119. + register "common_soc_config.emmc_dll.emmc_rx_cmd_data_cntl1" = "0x1C1B4F1B" + + # EMMC RX CMD/DATA Delay 2 + # Refer to EDS-Vol2-42.3.12. + # [17:16] stands for Rx Clock before Output Buffer, + # 00: Rx clock after output buffer, + # 01: Rx clock before output buffer, + # 10: Automatic selection based on working mode. + # 11: Reserved + # [14:8] steps of delay for Auto Tuning Mode, each 125ps, range: 0 - 39. + # [6:0] steps of delay for HS200, each 125ps, range: 0 - 79. + register "common_soc_config.emmc_dll.emmc_rx_cmd_data_cntl2" = "0x1004C" + + # EMMC Rx Strobe Delay + # Refer to EDS-Vol2-42.3.11. + # [14:8] Rx Strobe Delay DLL 1(HS400 Mode), each 125ps, range: 0 - 39. + # [6:0] Rx Strobe Delay DLL 2(HS400 Mode), each 125ps, range: 0 - 39. + register "common_soc_config.emmc_dll.emmc_rx_strobe_cntl" = "0x01515" + + # SOC Aux orientation override: + # This is a bitfield that corresponds to up to 4 TCSS ports. + # Bits (0,1) allocated for TCSS Port1 configuration and Bits (2,3)for TCSS Port2. + # TcssAuxOri = 0100b + # Bit0 set to "0" indicates has retimer on USBC Port0, on the DB. + # Bit2 set to "1" indicates no retimer on USBC Port1, on the MB. + # Bit1,Bit3 set to "0" indicates Aux lines are not swapped on the + # motherboard to USBC connector + register "tcss_aux_ori" = "5" + + register "typec_aux_bias_pads[0]" = "{ + .pad_auxp_dc = GPP_A19, + .pad_auxn_dc = GPP_A20 + }" + + register "typec_aux_bias_pads[1]" = "{ + .pad_auxp_dc = GPP_E22, + .pad_auxn_dc = GPP_E23 + }" + + # FIVR configurations for teliks are disabled since the board doesn't have V1p05 and Vnn + # bypass rails implemented. + register "ext_fivr_settings" = "{ + .configure_ext_fivr = 0, + }" + + # Enable the Cnvi BT Audio Offload + register "cnvi_bt_audio_offload" = "1" + + # Intel Common SoC Config + #+-------------+------------------------------+ + #| Field | Value | + #+-------------+------------------------------+ + #| I2C0 | TPM. Early init is | + #| | required to set up a BAR | + #| | for TPM communication | + #| I2C1 | Touchscreen | + #| I2C2 | Sub-board(PSensor)/WCAM | + #| I2C3 | Audio | + #| I2C5 | Trackpad | + #+-------------+------------------------------+ + register "common_soc_config" = "{ + .i2c[0] = { + .early_init = 1, + .speed = I2C_SPEED_FAST_PLUS, + .speed_config[0] = { + .speed = I2C_SPEED_FAST_PLUS, + .scl_lcnt = 55, + .scl_hcnt = 30, + .sda_hold = 7, + } + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + .scl_lcnt = 160, + .scl_hcnt = 79, + .sda_hold = 7, + } + }, + .i2c[2] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + .scl_lcnt = 157, + .scl_hcnt = 79, + .sda_hold = 7, + } + }, + .i2c[3] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + .scl_lcnt = 157, + .scl_hcnt = 79, + .sda_hold = 7, + } + }, + .i2c[5] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + .scl_lcnt = 152, + .scl_hcnt = 79, + .sda_hold = 7, + } + }, + }" + + # Power limit config + register "power_limits_config[ADL_N_041_6W_CORE]" = "{ + .tdp_pl1_override = 15, + .tdp_pl2_override = 25, + .tdp_pl4 = 78, + }" + + device domain 0 on + device ref dtt on + chip drivers/intel/dptf + ## sensor information + register "options.tsr[0].desc" = ""CPU_VR"" + register "options.tsr[1].desc" = ""CPU"" + register "options.tsr[2].desc" = ""Ambient"" + register "options.tsr[3].desc" = ""Charger"" + + # TODO: below values are initial reference values only + ## Passive Policy + register "policies.passive" = "{ + [0] = DPTF_PASSIVE(CPU, CPU, 95, 5000), + [1] = DPTF_PASSIVE(CPU, TEMP_SENSOR_0, 75, 5000), + [2] = DPTF_PASSIVE(CPU, TEMP_SENSOR_1, 75, 5000), + [3] = DPTF_PASSIVE(CPU, TEMP_SENSOR_2, 75, 5000), + [4] = DPTF_PASSIVE(CHARGER, TEMP_SENSOR_3, 75, 5000), + }" + + ## Critical Policy + register "policies.critical" = "{ + [0] = DPTF_CRITICAL(TEMP_SENSOR_1, 100, SHUTDOWN), + [1] = DPTF_CRITICAL(TEMP_SENSOR_2, 80, SHUTDOWN), + }" + + register "controls.power_limits" = "{ + .pl1 = { + .min_power = 6000, + .max_power = 15000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 200 + }, + .pl2 = { + .min_power = 25000, + .max_power = 25000, + .time_window_min = 28 * MSECS_PER_SEC, + .time_window_max = 32 * MSECS_PER_SEC, + .granularity = 1000 + } + }" + + ## Charger Performance Control (Control, mA) + register "controls.charger_perf" = "{ + [0] = { 255, 3000 }, + [1] = { 24, 1500 }, + [2] = { 16, 1000 }, + [3] = { 8, 500 } + }" + + device generic 0 on end + end + end + device ref igpu on + chip drivers/gfx/generic + register "device_count" = "4" + # DDIA for eDP + register "device[0].name" = ""LCD0"" + # Internal panel on the first port of the graphics chip + register "device[0].type" = "panel" + # DDIB for HDMI + # If HDMI is not enumerated in the kernel, then no GFX device should be added for DDIB + register "device[1].name" = ""DD01"" + # TCP0 (DP-1) for port C0 + register "device[2].name" = ""DD02"" + register "device[2].use_pld" = "true" + register "device[2].pld" = "ACPI_PLD_TYPE_C(LEFT, RIGHT, ACPI_PLD_GROUP(1, 1))" + # TCP1 (DP-2) for port C1 + register "device[3].name" = ""DD03"" + register "device[3].use_pld" = "true" + register "device[3].pld" = "ACPI_PLD_TYPE_C(RIGHT, LEFT, ACPI_PLD_GROUP(2, 1))" + device generic 0 on end + end + end + device ref ipu on + chip drivers/intel/mipi_camera + register "acpi_uid" = "0x50000" + register "acpi_name" = ""IPU0"" + register "device_type" = "INTEL_ACPI_CAMERA_CIO2" + + register "cio2_num_ports" = "1" + register "cio2_lanes_used" = "{4}" # 4 CSI Camera lanes are used + register "cio2_lane_endpoint[0]" = ""^I2C2.CAM0"" + register "cio2_prt[0]" = "1" + device generic 0 on + probe CAMERA UF_720P_WF + probe CAMERA UF_1080P_WF + end + end + end + device ref i2c1 on + chip drivers/i2c/hid + register "generic.hid" = ""ILTK0001"" + register "generic.desc" = ""ILITEK Touchscreen"" + register "generic.irq" = "ACPI_IRQ_LEVEL_LOW(GPP_C7_IRQ)" + register "generic.detect" = "1" + register "generic.reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C1)" + register "generic.reset_delay_ms" = "200" + register "generic.enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_C0)" + register "generic.enable_delay_ms" = "12" + register "generic.stop_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_C6)" + register "generic.stop_off_delay_ms" = "200" + register "generic.has_power_resource" = "1" + register "hid_desc_reg_offset" = "0x01" + device i2c 41 on end + end + chip drivers/generic/gpio_keys + register "name" = ""PENH"" + register "gpio" = "ACPI_GPIO_INPUT_ACTIVE_LOW(GPP_F13)" + register "key.wake_gpe" = "GPE0_DW2_15" + register "key.wakeup_route" = "WAKEUP_ROUTE_SCI" + register "key.wakeup_event_action" = "EV_ACT_ANY" + register "key.dev_name" = ""EJCT"" + register "key.linux_code" = "SW_PEN_INSERTED" + register "key.linux_input_type" = "EV_SW" + register "key.label" = ""pen_eject"" + device generic 0 on end + end + end + device ref i2c2 on + chip drivers/intel/mipi_camera + register "acpi_hid" = ""OVTIDB10"" + register "acpi_uid" = "0" + register "acpi_name" = ""CAM0"" + register "chip_name" = ""Ov 13b10 Camera"" + register "device_type" = "INTEL_ACPI_CAMERA_SENSOR" + + register "ssdb.lanes_used" = "4" + register "ssdb.vcm_type" = "0x0C" + register "vcm_name" = ""VCM0"" + register "num_freq_entries" = "1" + register "link_freq[0]" = "560 * MHz" + register "remote_name" = ""IPU0"" + + register "has_power_resource" = "1" + #Controls + register "clk_panel.clks[0].clknum" = "IMGCLKOUT_3" + register "clk_panel.clks[0].freq" = "FREQ_19_2_MHZ" + + register "gpio_panel.gpio[0].gpio_num" = "GPP_D15" # EN_PP2800_WCAM_X + register "gpio_panel.gpio[1].gpio_num" = "GPP_D16" # EN_PP1200_WCAM_X + register "gpio_panel.gpio[2].gpio_num" = "GPP_D3" # WCAM_RST_L + + #_ON + register "on_seq.ops_cnt" = "5" + register "on_seq.ops[0]" = "SEQ_OPS_CLK_ENABLE(0, 0)" + register "on_seq.ops[1]" = "SEQ_OPS_GPIO_ENABLE(0, 5)" + register "on_seq.ops[2]" = "SEQ_OPS_GPIO_ENABLE(1, 5)" + register "on_seq.ops[3]" = "SEQ_OPS_GPIO_DISABLE(2, 5)" + register "on_seq.ops[4]" = "SEQ_OPS_GPIO_ENABLE(2, 5)" + + #_OFF + register "off_seq.ops_cnt" = "4" + register "off_seq.ops[0]" = "SEQ_OPS_CLK_DISABLE(0, 0)" + register "off_seq.ops[1]" = "SEQ_OPS_GPIO_DISABLE(2, 0)" + register "off_seq.ops[2]" = "SEQ_OPS_GPIO_DISABLE(1, 0)" + register "off_seq.ops[3]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 36 on + probe CAMERA UF_720P_WF + probe CAMERA UF_1080P_WF + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "2" + register "acpi_name" = ""VCM0"" + register "chip_name" = ""DW9714 VCM "" + register "device_type" = "INTEL_ACPI_CAMERA_VCM" + + register "vcm_compat" = ""dongwoon,dw9714"" + + register "has_power_resource" = "1" + #Controls + register "gpio_panel.gpio[0].gpio_num" = "GPP_D15" # EN_PP2800_AFVDD + + #_ON + register "on_seq.ops_cnt" = "1" + register "on_seq.ops[0]" = "SEQ_OPS_GPIO_ENABLE(0, 5)" + + #_OFF + register "off_seq.ops_cnt" = "1" + register "off_seq.ops[0]" = "SEQ_OPS_GPIO_DISABLE(0, 0)" + + device i2c 0C on + probe CAMERA UF_720P_WF + probe CAMERA UF_1080P_WF + end + end + chip drivers/intel/mipi_camera + register "acpi_uid" = "1" + register "acpi_name" = ""NVM0"" + register "chip_name" = ""GT24P64E"" + register "device_type" = "INTEL_ACPI_CAMERA_NVM" + + register "nvm_size" = "0x2000" + register "nvm_pagesize" = "1" + register "nvm_readonly" = "1" + register "nvm_width" = "0x10" + register "nvm_compat" = ""atmel,24c64"" + + device i2c 50 on + probe CAMERA UF_720P_WF + probe CAMERA UF_1080P_WF + end + end + end + device ref i2c3 on + chip drivers/i2c/rt5645 + register "hid" = ""10EC5650"" + register "name" = ""RT58"" + register "desc" = ""Realtek RT5650"" + register "irq_gpio" = "ACPI_GPIO_IRQ_EDGE_BOTH(GPP_A23)" + register "cbj_sleeve" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_A11)" + register "jd_mode" = "2" + device i2c 1a on end + end + end + device ref i2c5 on + chip drivers/i2c/hid + register "generic.hid" = ""PNP0C50"" + register "generic.desc" = ""PRIMAX Touchpad"" + register "generic.irq" = "ACPI_IRQ_WAKE_LEVEL_LOW(GPP_F14_IRQ)" + register "generic.wake" = "GPE0_DW2_14" + register "generic.detect" = "1" + register "hid_desc_reg_offset" = "0x01" + device i2c 15 on end + end + end + device ref cnvi_wifi on + chip drivers/wifi/generic + register "wake" = "GPE0_PME_B0" + register "enable_cnvi_ddr_rfim" = "true" + register "add_acpi_dma_property" = "true" + device generic 0 on + probe WIFI WIFI_6E + end + end + end + device ref pcie_rp4 on + # PCIe 4 WLAN + register "pch_pcie_rp[PCH_RP(4)]" = "{ + .clk_src = 2, + .clk_req = 2, + .flags = PCIE_RP_LTR | PCIE_RP_AER, + }" + chip drivers/wifi/generic + register "wake" = "GPE0_DW1_03" + register "add_acpi_dma_property" = "true" + device pci 00.0 on + probe WIFI WIFI_6_7921 + probe WIFI WIFI_6_8852 + end + end + end + device ref pch_espi on + chip ec/google/chromeec + use conn0 as mux_conn[0] + use conn1 as mux_conn[1] + device pnp 0c09.0 on end + end + end + device ref pmc hidden + chip drivers/intel/pmc_mux + device generic 0 on + chip drivers/intel/pmc_mux/conn + use usb2_port1 as usb2_port + use tcss_usb3_port2 as usb3_port + device generic 0 alias conn0 on end + end + chip drivers/intel/pmc_mux/conn + use usb2_port2 as usb2_port + use tcss_usb3_port1 as usb3_port + device generic 1 alias conn1 on end + end + end + end + end + device ref tcss_xhci on + chip drivers/usb/acpi + device ref tcss_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C0 (MLB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_C(LEFT, LEFT, ACPI_PLD_GROUP(1, 1))" + device ref tcss_usb3_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C Port C1 (DB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_C(RIGHT, RIGHT, ACPI_PLD_GROUP(2, 1))" + device ref tcss_usb3_port1 on end + end + end + end + end + device ref xhci on + register "usb2_ports[0]" = "USB2_PORT_TYPE_C(OC_SKIP)" # Type-C MB (7.5 inch) + register "usb2_ports[1]" = "USB2_PORT_TYPE_C(OC_SKIP)" # Type-C DB (7.1 inch) + register "usb2_ports[2]" = "USB2_PORT_MID(OC_SKIP)" # Type-A MB (6.4 inch) + register "usb2_ports[5]" = "USB2_PORT_SHORT(OC_SKIP)" # UFC (3.7 inch) + register "usb2_ports[7]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth port for PCIe WLAN (2.5 inch) + register "usb2_ports[9]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth port for CNVi WLAN + + register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC_SKIP)" # USB3 Type-A port A0(MLB)) + chip drivers/usb/acpi + device ref xhci_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C0 (MLB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_C(LEFT, LEFT, ACPI_PLD_GROUP(1, 1))" + device ref usb2_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C Port C1 (DB)"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_C(RIGHT, RIGHT, ACPI_PLD_GROUP(2, 1))" + device ref usb2_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Port A0 (MLB)"" + register "type" = "UPC_TYPE_A" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_A(LEFT, RIGHT, ACPI_PLD_GROUP(3, 1))" + device ref usb2_port3 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 UFC"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb2_port6 on end + end + chip drivers/usb/acpi + register "desc" = ""PCIe Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D4)" + device ref usb2_port8 on + probe WIFI WIFI_6_7921 + probe WIFI WIFI_6_8852 + end + end + chip drivers/usb/acpi + register "desc" = ""CNVi Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_D4)" + device ref usb2_port10 on + probe WIFI WIFI_6E + end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Port A0 (MLB)"" + register "type" = "UPC_TYPE_USB3_A" + register "use_custom_pld" = "true" + register "custom_pld" = "ACPI_PLD_TYPE_A(LEFT, RIGHT, ACPI_PLD_GROUP(3, 1))" + device ref usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 WLAN"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb3_port4 on end + end + end + end + end + device ref pcie_rp7 off end # SDCard + device ref hda on + chip drivers/sof + register "spkr_tplg" = "rt5650_sp" + register "jack_tplg" = "rt5650_hp" + register "mic_tplg" = "_2ch_pdm0" + device generic 0 on end + end + end + end +end diff --git a/src/mainboard/google/brya/variants/telith/variant.c b/src/mainboard/google/brya/variants/telith/variant.c new file mode 100644 index 0000000..fbfe76c --- /dev/null +++ b/src/mainboard/google/brya/variants/telith/variant.c @@ -0,0 +1,56 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <baseboard/variants.h> +#include <fw_config.h> +#include <sar.h> +#include <soc/gpio_soc_defs.h> +#include <intelblocks/graphics.h> + +/* Per-pipe DDI Function Control 2 */ +#define TRANS_DDI_FUNC_CTL2_A 0x60404 +#define TRANS_DDI_AUDIO_MUTE_OVERRIDE_BITS_FIELDS (3 << 6) + +const char *get_wifi_sar_cbfs_filename(void) +{ + return get_wifi_sar_fw_config_filename(FW_CONFIG_FIELD(WIFI)); +} + +static const struct pad_config wifi_pcie_enable_pad[] = { + /* H20 : IMGCLKOUT1 ==> WLAN_PERST_L */ + PAD_CFG_GPO(GPP_H20, 1, DEEP), + /* B11 : NC ==> EN_PP3300_WLAN_X*/ + PAD_CFG_GPO(GPP_B11, 1, DEEP), +}; + +void variant_update_soc_chip_config(struct soc_intel_alderlake_config *config) +{ + if (!fw_config_probe(FW_CONFIG(WIFI, WIFI_6E))) { + printk(BIOS_INFO, "CNVi bluetooth disabled by fw_config\n"); + config->cnvi_bt_core = false; + printk(BIOS_INFO, "CNVi bluetooth audio offload disabled by fw_config\n"); + config->cnvi_bt_audio_offload = false; + } +} + +void fw_config_gpio_padbased_override(struct pad_config *padbased_table) +{ + if (fw_config_probe(FW_CONFIG(WIFI, WIFI_6_7921)) + || fw_config_probe(FW_CONFIG(WIFI, WIFI_6_8852))) { + printk(BIOS_INFO, "Enable PCie based Wifi GPIO pins.\n"); + gpio_padbased_override(padbased_table, wifi_pcie_enable_pad, + ARRAY_SIZE(wifi_pcie_enable_pad)); + } +} + +void variant_finalize(void) +{ + /* + * Panel CSOT MNB601LS1-3 will flicker once during enter Chrome login screen, + * it is because it inserts 12 blank frames if it receives the unmute in VB-ID. + * + * Always override the mute in VB-ID to avoid Tcon EC detected the + * audiomute_flag change. + */ + graphics_gtt_rmw(TRANS_DDI_FUNC_CTL2_A, ~TRANS_DDI_AUDIO_MUTE_OVERRIDE_BITS_FIELDS, + TRANS_DDI_AUDIO_MUTE_OVERRIDE_BITS_FIELDS); +}
