Attention is currently required from: Anjaneya "Reddy" Chagam, Jonathan Zhang, Johnny Lin, Christian Walter, Arthur Heymans, Patrick Rudolph, Tim Chu. Hello build bot (Jenkins), Anjaneya "Reddy" Chagam, Jonathan Zhang, Johnny Lin, Christian Walter, Arthur Heymans, Patrick Rudolph, Tim Chu,
https://review.coreboot.org/c/coreboot/+/60631
Change subject: soc/intel: Remove unused <acpi/acpi.h> ......................................................................
Found using: diff <(git grep -l '#include <acpi/acpi.h>' -- src/) <(git grep -l 'SLP_EN|SLP_TYP_SHIFT|SLP_TYP|SLP_TYP_S|ACPI_TABLE_CREATOR|OEM_ID|ACPI_DSDT_REV_|acpi_device_sleep_states|ACPI_DEVICE_SLEEP|RSDP_SIG|ASLC|ACPI_NAME_BUFFER_SIZE|COREBOOT_ACPI_ID|acpi_tables|acpi_rsdp|acpi_gen_regaddr|ACPI_ADDRESS_SPACE|ACPI_FFIXEDHW_|ACPI_ACCESS_SIZE_|ACPI_REG_MSR|ACPI_REG_UNSUPPORTED|ACPI_HID_|acpi_table_header|MAX_ACPI_TABLES|acpi_rsdt|acpi_xsdt|acpi_hpet|acpi_mcfg|acpi_tcpa|acpi_tpm2|acpi_mcfg_mmconfig|acpi_hmat|acpi_hmat_mpda|acpi_hmat_sllbi|acpi_hmat_msci|acpi_srat|ACPI_SRAT_STRUCTURE_|acpi_srat_lapic|acpi_srat_mem|acpi_srat_gia|CPI_SRAT_GIA_DEV_HANDLE_|acpi_slit|acpi_madt|acpi_lpit|acpi_lpi_flags|acpi_lpi_desc_type|ACPI_LPI_DESC_TYPE_|acpi_lpi_desc_hdr|ACPI_LPIT_CTR_FREQ_TSC|acpi_lpi_desc_ncst|acpi_vfct_image_hdr|acpi_vfct|acpi_ivrs_info|acpi_ivrs_ivhd|acpi_ivrs|acpi_crat_header|ivhd11_iommu_attr|acpi_ivrs_ivhd_11|dev_scope_type|SCOPE_PCI_|SCOPE_IOAPIC|SCOPE_MSI_HPET|SCOPE_ACPI_NAMESPACE_DEVICE|dev_scope|dmar_type|DMAR_|DRHD_INCLUDE_PCI_ALL|ATC_REQUIRED|DMA_CTRL_PLATFORM_OPT_IN_FLAG|dmar_entry|dmar_rmrr_entry|dmar_atsr_entry|dmar_rhsa_entry|dmar_andd_entry|dmar_satc_entry|acpi_dmar|acpi_apic_types|LOCAL_APIC,|IO_APIC|IRQ_SOURCE_OVERRIDE|NMI_TYPE|LOCAL_APIC_NMI|LAPIC_ADDRESS_|IO_SAPIC|LOCAL_SAPIC|PLATFORM_IRQ_SOURCES|LOCAL_X2APIC|GICC|GICD|GIC_MSI_FRAME|GICR|GIC_ITS|acpi_madt_lapic|acpi_madt_lapic_nmi|ACPI_MADT_LAPIC_NMI_ALL_PROCESSORS|acpi_madt_ioapic|acpi_madt_irqoverride|acpi_madt_lx2apic|acpi_madt_lx2apic_nmi|ACPI_DBG2_PORT_|acpi_dbg2_header|acpi_dbg2_device|acpi_fadt|ACPI_FADT_|PM_UNSPECIFIED|PM_DESKTOP|PM_MOBILE|PM_WORKSTATION|PM_ENTERPRISE_SERVER|PM_SOHO_SERVER|PM_APPLIANCE_PC|PM_PERFORMANCE_SERVER|PM_TABLET|acpi_facs|ACPI_FACS_|acpi_ecdt|acpi_hest|acpi_hest_esd|acpi_hest_hen|acpi_bert|acpi_hest_generic_data|acpi_hest_generic_data_v300|HEST_GENERIC_ENTRY_V300|ACPI_GENERROR_|acpi_generic_error_status|GENERIC_ERR_STS_|acpi_cstate|acpi_sw_pstate|acpi_xpss_sw_pstate|acpi_tstate|acpi_lpi_state_flags|ACPI_LPI_STATE_|acpi_lpi_state|acpi_upc_type|UPC_TYPE_|acpi_ipmi_interface_type|IPMI_INTERFACE_|ACPI_IPMI_|acpi_spmi|ACPI_EINJ_|ACTION_COUNT|BEGIN_INJECT_OP|GET_TRIGGER_ACTION_TABLE|SET_ERROR_TYPE|GET_ERROR_TYPE|END_INJECT_OP|EXECUTE_INJECT_OP|CHECK_BUSY_STATUS|GET_CMD_STATUS|SET_ERROR_TYPE_WITH_ADDRESS|TRIGGER_ERROR|READ_REGISTER|READ_REGISTER_VALUE|WRITE_REGISTER|WRITE_REGISTER_VALUE|NO_OP|acpi_gen_regaddr1|acpi_einj_action_table|acpi_injection_header|acpi_einj_trigger_table|set_error_type|EINJ_PARAM_NUM|acpi_einj_smi|EINJ_DEF_TRIGGER_PORT|FLAG_PRESERVE|FLAG_IGNORE|EINJ_REG_MEMORY|EINJ_REG_IO|acpi_einj|acpi_create_einj|fw_cfg_acpi_tables|preload_acpi_dsdt|write_acpi_tables|acpi_fill_madt|acpi_fill_ivrs_ioapic|acpi_create_ssdt_generator|acpi_write_bert|acpi_create_fadt|acpi_fill_fadt|arch_fill_fadt|soc_fill_fadt|mainboard_fill_fadt|acpi_fill_gnvs|acpi_fill_cnvs|update_ssdt|update_ssdtx|acpi_fill_lpit|acpi_checksum|acpi_add_table|acpi_create_madt_lapic|acpi_create_madt_ioapic|acpi_create_madt_irqoverride|acpi_create_madt_lapic_nmi|acpi_create_madt|acpi_create_madt_lapics|acpi_create_madt_lapic_nmis|acpi_create_madt_lx2apic|acpi_create_srat_lapic|acpi_create_srat_mem|acpi_create_srat_gia_pci|acpi_create_mcfg_mmconfig|acpi_create_srat_lapics|acpi_create_srat|acpi_create_slit|acpi_create_hmat_mpda|acpi_create_hmat|acpi_create_vfct|acpi_create_ipmi|acpi_create_ivrs|acpi_create_crat|acpi_create_hpet|acpi_write_hpet|generate_cpu_entries|acpi_create_mcfg|acpi_create_facs|acpi_create_dbg2|acpi_write_dbg2_pci_uart|acpi_create_dmar|acpi_create_dmar_drhd|acpi_create_dmar_rmrr|acpi_create_dmar_atsr|acpi_create_dmar_rhsa|acpi_create_dmar_andd|acpi_create_dmar_satc|cpi_dmar_|acpi_create_|acpi_write_hest|acpi_soc_get_bert_region|acpi_resume|mainboard_suspend_resume|acpi_find_wakeup_vector|ACPI_S|acpi_sleep_from_pm1|acpi_get_preferred_pm_profile|acpi_get_sleep_type|acpi_get_gpe|permanent_smi_handler|acpi_s3_resume_allowed|acpi_is_wakeup_s3|acpi_align_current|get_acpi_table_revision' -- src/) |grep "<"
Change-Id: Ibc5d5883d9ec6ee55797bd36178af622d08e4f9b Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/soc/intel/baytrail/ramstage.c M src/soc/intel/baytrail/refcode.c M src/soc/intel/braswell/ramstage.c M src/soc/intel/broadwell/pch/ramstage.c M src/soc/intel/common/block/acpi/acpi_wake_source.c M src/soc/intel/common/block/pmc/pmc.c M src/soc/intel/xeon_sp/cpx/cpu.c 7 files changed, 0 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/31/60631/7
