Sumeet R Pawnikar has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/41237 )
Change subject: jasperlake: update processor power limits configuration ......................................................................
Update processor power limit configuration parameters based on common code base support for Intel Jasperlake SoC based platforms.
BRANCH=None BUG=None TEST=Built for jasperlake system
Change-Id: I9b725d041dcb8847f83ec103e58b9571b4c596ac Signed-off-by: Sumeet R Pawnikar sumeet.r.pawnikar@intel.com --- M src/soc/intel/jasperlake/Kconfig M src/soc/intel/jasperlake/chip.h M src/soc/intel/jasperlake/include/soc/cpu.h 3 files changed, 6 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/41237/1
diff --git a/src/soc/intel/jasperlake/Kconfig b/src/soc/intel/jasperlake/Kconfig index 41905c5..47766ed 100644 --- a/src/soc/intel/jasperlake/Kconfig +++ b/src/soc/intel/jasperlake/Kconfig @@ -16,6 +16,7 @@ select BOOT_DEVICE_SUPPORTS_WRITES select CACHE_MRC_SETTINGS select COMMON_FADT + select CPU_INTEL_COMMON select CPU_INTEL_FIRMWARE_INTERFACE_TABLE select FSP_M_XIP select GENERIC_GPIO_LIB @@ -50,6 +51,7 @@ select SOC_INTEL_COMMON_BLOCK_SA select SOC_INTEL_COMMON_BLOCK_SCS select SOC_INTEL_COMMON_BLOCK_SMM + select SOC_INTEL_COMMON_BLOCK_POWER_LIMIT select SOC_INTEL_COMMON_BLOCK_SMM_IO_TRAP select SOC_INTEL_COMMON_PCH_BASE select SOC_INTEL_COMMON_RESET diff --git a/src/soc/intel/jasperlake/chip.h b/src/soc/intel/jasperlake/chip.h index 886f823..c2105d5 100644 --- a/src/soc/intel/jasperlake/chip.h +++ b/src/soc/intel/jasperlake/chip.h @@ -8,6 +8,7 @@ #include <intelblocks/cfg.h> #include <intelblocks/gpio.h> #include <intelblocks/gspi.h> +#include <intelblocks/power_limit.h> #include <soc/gpe.h> #include <soc/gpio.h> #include <soc/gpio_defs.h> @@ -27,6 +28,9 @@ /* Common struct containing soc config data required by common code */ struct soc_intel_common_config common_soc_config;
+ /* Common struct containing power limits configuration information */ + struct soc_power_limits_config power_limits_config; + /* Gpio group routed to each dword of the GPE0 block. Values are * of the form PMC_GPP_[A:U] or GPD. */ uint8_t pmc_gpe0_dw0; /* GPE0_31_0 STS/EN */ @@ -147,8 +151,6 @@ /* HeciEnabled decides the state of Heci1 at end of boot * Setting to 0 (default) disables Heci1 and hides the device from OS */ uint8_t HeciEnabled; - /* PL2 Override value in Watts */ - uint32_t tdp_pl2_override; /* Intel Speed Shift Technology */ uint8_t speed_shift_enable;
diff --git a/src/soc/intel/jasperlake/include/soc/cpu.h b/src/soc/intel/jasperlake/include/soc/cpu.h index 1ab96e5..6aa00bb 100644 --- a/src/soc/intel/jasperlake/include/soc/cpu.h +++ b/src/soc/intel/jasperlake/include/soc/cpu.h @@ -31,7 +31,4 @@ C_STATE_LATENCY_MICRO_SECONDS(C_STATE_LATENCY_CONTROL_ ##reg## _LIMIT, \ (IRTL_1024_NS >> 10))
-/* Configure power limits for turbo mode */ -void set_power_limits(u8 power_limit_1_time); - #endif
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41237 )
Patch Set 1: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/41237 )
Change-Id: I9b725d041dcb8847f83ec103e58b9571b4c596ac Signed-off-by: Sumeet R Pawnikar sumeet.r.pawnikar@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/41237 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/soc/intel/jasperlake/Kconfig M src/soc/intel/jasperlake/chip.h M src/soc/intel/jasperlake/include/soc/cpu.h 3 files changed, 6 insertions(+), 5 deletions(-)
diff --git a/src/soc/intel/jasperlake/Kconfig b/src/soc/intel/jasperlake/Kconfig index 41905c5..47766ed 100644 --- a/src/soc/intel/jasperlake/Kconfig +++ b/src/soc/intel/jasperlake/Kconfig @@ -16,6 +16,7 @@ select BOOT_DEVICE_SUPPORTS_WRITES select CACHE_MRC_SETTINGS select COMMON_FADT + select CPU_INTEL_COMMON select CPU_INTEL_FIRMWARE_INTERFACE_TABLE select FSP_M_XIP select GENERIC_GPIO_LIB @@ -50,6 +51,7 @@ select SOC_INTEL_COMMON_BLOCK_SA select SOC_INTEL_COMMON_BLOCK_SCS select SOC_INTEL_COMMON_BLOCK_SMM + select SOC_INTEL_COMMON_BLOCK_POWER_LIMIT select SOC_INTEL_COMMON_BLOCK_SMM_IO_TRAP select SOC_INTEL_COMMON_PCH_BASE select SOC_INTEL_COMMON_RESET diff --git a/src/soc/intel/jasperlake/chip.h b/src/soc/intel/jasperlake/chip.h index 7a6a7fd..d8ea560 100644 --- a/src/soc/intel/jasperlake/chip.h +++ b/src/soc/intel/jasperlake/chip.h @@ -7,6 +7,7 @@ #include <intelblocks/cfg.h> #include <intelblocks/gpio.h> #include <intelblocks/gspi.h> +#include <intelblocks/power_limit.h> #include <soc/gpe.h> #include <soc/gpio.h> #include <soc/gpio_defs.h> @@ -26,6 +27,9 @@ /* Common struct containing soc config data required by common code */ struct soc_intel_common_config common_soc_config;
+ /* Common struct containing power limits configuration information */ + struct soc_power_limits_config power_limits_config; + /* Gpio group routed to each dword of the GPE0 block. Values are * of the form PMC_GPP_[A:U] or GPD. */ uint8_t pmc_gpe0_dw0; /* GPE0_31_0 STS/EN */ @@ -145,8 +149,6 @@ /* HeciEnabled decides the state of Heci1 at end of boot * Setting to 0 (default) disables Heci1 and hides the device from OS */ uint8_t HeciEnabled; - /* PL2 Override value in Watts */ - uint32_t tdp_pl2_override; /* Intel Speed Shift Technology */ uint8_t speed_shift_enable;
diff --git a/src/soc/intel/jasperlake/include/soc/cpu.h b/src/soc/intel/jasperlake/include/soc/cpu.h index 58e9a8f..1e5332d 100644 --- a/src/soc/intel/jasperlake/include/soc/cpu.h +++ b/src/soc/intel/jasperlake/include/soc/cpu.h @@ -30,7 +30,4 @@ C_STATE_LATENCY_MICRO_SECONDS(C_STATE_LATENCY_CONTROL_ ##reg## _LIMIT, \ (IRTL_1024_NS >> 10))
