Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/5009
commit f8b9d72a35e205470e9368f4f952b8fbd3824776 Author: Aaron Durbin adurbin@chromium.org Date: Tue Dec 10 17:12:44 2013 -0800
baytrail: utilize reg_script_run_on_dev()
The inclusion of reg_script_run_on_dev() allows for removing some of the chained reg_scripts just to set up the device context. Use the new reg_script function in those cases.
BUG=None BRANCH=None TEST=Built and booted. Didn't see any bizarre dmesg or coreboot console output.
Change-Id: I3207449424c1efe92186125004d5aea1bb5ba438 Signed-off-by: Aaron Durbin adurbin@chromium.og Reviewed-on: https://chromium-review.googlesource.com/179541 Tested-by: Aaron Durbin adurbin@chromium.org Reviewed-by: Duncan Laurie dlaurie@chromium.org Commit-Queue: Aaron Durbin adurbin@chromium.org --- src/soc/intel/baytrail/ehci.c | 28 +++++++++++----------------- src/soc/intel/baytrail/emmc.c | 9 ++------- src/soc/intel/baytrail/gfx.c | 15 ++++----------- src/soc/intel/baytrail/lpss.c | 11 ++++------- src/soc/intel/baytrail/pcie.c | 11 ++--------- src/soc/intel/baytrail/scc.c | 3 +-- src/soc/intel/baytrail/xhci.c | 11 ++++------- 7 files changed, 28 insertions(+), 60 deletions(-)
diff --git a/src/soc/intel/baytrail/ehci.c b/src/soc/intel/baytrail/ehci.c index c648415..d4e2986 100644 --- a/src/soc/intel/baytrail/ehci.c +++ b/src/soc/intel/baytrail/ehci.c @@ -34,7 +34,7 @@
#include "chip.h"
-const struct reg_script ehci_init_script[] = { +static const struct reg_script ehci_init_script[] = { /* Enable S0 PLL shutdown * D29:F0:7A[12,10,7,6,4,3,2,1]=11111111b */ REG_PCI_OR16(0x7a, 0x14de), @@ -60,7 +60,7 @@ const struct reg_script ehci_init_script[] = { REG_SCRIPT_END };
-const struct reg_script ehci_clock_gating_script[] = { +static const struct reg_script ehci_clock_gating_script[] = { /* Enable SB local clock gating */ REG_PCI_OR32(0x7c, 0x00004000), /* RCBA + 0x284=0xbe (step B0+) */ @@ -68,7 +68,7 @@ const struct reg_script ehci_clock_gating_script[] = { REG_SCRIPT_END };
-const struct reg_script ehci_disable_script[] = { +static const struct reg_script ehci_disable_script[] = { /* Clear Run/Stop Bit */ REG_RES_RMW32(PCI_BASE_ADDRESS_0, USB2CMD, ~USB2CMD_RS, 0), /* Wait for HC Halted */ @@ -86,6 +86,11 @@ const struct reg_script ehci_disable_script[] = { REG_SCRIPT_END };
+static const struct reg_script ehci_hc_reset[] = { + REG_RES_OR16(PCI_BASE_ADDRESS_0, USB2CMD, USB2CMD_HCRESET), + REG_SCRIPT_END +}; + static void usb2_phy_init(device_t dev) { struct soc_intel_baytrail_config *config = dev->chip_info; @@ -121,18 +126,7 @@ static void usb2_phy_init(device_t dev) static void ehci_init(device_t dev) { struct soc_intel_baytrail_config *config = dev->chip_info; - struct reg_script ehci_hc_reset[] = { - REG_SCRIPT_SET_DEV(dev), - REG_RES_OR16(PCI_BASE_ADDRESS_0, USB2CMD, USB2CMD_HCRESET), - REG_SCRIPT_END - }; - struct reg_script ehci_hc_disable[] = { - REG_SCRIPT_SET_DEV(dev), - REG_SCRIPT_NEXT(ehci_disable_script), - REG_SCRIPT_END - }; struct reg_script ehci_hc_init[] = { - REG_SCRIPT_SET_DEV(dev), /* Controller init */ REG_SCRIPT_NEXT(ehci_init_script), /* Enable clock gating */ @@ -150,19 +144,19 @@ static void ehci_init(device_t dev)
/* Don't reset controller in S3 resume path */ if (acpi_slp_type != 3) - reg_script_run(ehci_hc_reset); + reg_script_run_on_dev(dev, ehci_hc_reset);
/* Disable controller if ports are routed to XHCI */ if (config->usb_route_to_xhci) { /* Disable controller */ - reg_script_run(ehci_hc_disable); + reg_script_run_on_dev(dev, ehci_disable_script);
/* Hide device with southcluster function */ dev->enabled = 0; southcluster_enable_dev(dev); } else { /* Initialize EHCI controller */ - reg_script_run(ehci_hc_init); + reg_script_run_on_dev(dev, ehci_hc_init); }
/* Setup USB2 PHY based on board config */ diff --git a/src/soc/intel/baytrail/emmc.c b/src/soc/intel/baytrail/emmc.c index 0a7e9b1..a724c4a 100644 --- a/src/soc/intel/baytrail/emmc.c +++ b/src/soc/intel/baytrail/emmc.c @@ -52,16 +52,11 @@ static const struct reg_script emmc_ops[] = { static void emmc_init(device_t dev) { struct soc_intel_baytrail_config *config = dev->chip_info; - struct reg_script ops[] = { - REG_SCRIPT_SET_DEV(dev), - REG_SCRIPT_NEXT(emmc_ops), - REG_SCRIPT_END, - }; - printk(BIOS_DEBUG, "eMMC init\n"); - reg_script_run(ops);
if (config->scc_acpi_mode) scc_enable_acpi_mode(dev, SCC_MMC_CTL, SCC_NVS_MMC); + printk(BIOS_DEBUG, "eMMC init\n"); + reg_script_run_on_dev(dev, emmc_ops); }
static struct device_operations device_ops = { diff --git a/src/soc/intel/baytrail/gfx.c b/src/soc/intel/baytrail/gfx.c index bf271be..37fdc70 100644 --- a/src/soc/intel/baytrail/gfx.c +++ b/src/soc/intel/baytrail/gfx.c @@ -259,14 +259,9 @@ static const struct reg_script gfx_post_vbios_script[] = { REG_SCRIPT_END };
-static void gfx_run_script(device_t dev, const struct reg_script *ops) +static inline void gfx_run_script(device_t dev, const struct reg_script *ops) { - struct reg_script steps[] = { - REG_SCRIPT_SET_DEV(dev), - REG_SCRIPT_NEXT(ops), - REG_SCRIPT_END, - }; - reg_script_run(&steps[0]); + reg_script_run_on_dev(dev, ops); }
static void gfx_pre_vbios_init(device_t dev) @@ -294,7 +289,6 @@ static void gfx_panel_setup(device_t dev) { struct soc_intel_baytrail_config *config = dev->chip_info; struct reg_script gfx_pipea_init[] = { - REG_SCRIPT_SET_DEV(dev), /* CONTROL */ REG_RES_WRITE32(PCI_BASE_ADDRESS_0, PIPEA_REG(PP_CONTROL), PP_CONTROL_UNLOCK | PP_CONTROL_EDP_FORCE_VDD), @@ -322,7 +316,6 @@ static void gfx_panel_setup(device_t dev) REG_SCRIPT_END }; struct reg_script gfx_pipeb_init[] = { - REG_SCRIPT_SET_DEV(dev), /* CONTROL */ REG_RES_WRITE32(PCI_BASE_ADDRESS_0, PIPEB_REG(PP_CONTROL), PP_CONTROL_UNLOCK | PP_CONTROL_EDP_FORCE_VDD), @@ -352,12 +345,12 @@ static void gfx_panel_setup(device_t dev)
if (config->gpu_pipea_port_select) { printk(BIOS_INFO, "GFX: Initialize PIPEA\n"); - reg_script_run(gfx_pipea_init); + reg_script_run_on_dev(dev, gfx_pipea_init); }
if (config->gpu_pipeb_port_select) { printk(BIOS_INFO, "GFX: Initialize PIPEB\n"); - reg_script_run(gfx_pipeb_init); + reg_script_run_on_dev(dev, gfx_pipeb_init); } }
diff --git a/src/soc/intel/baytrail/lpss.c b/src/soc/intel/baytrail/lpss.c index e009c7d..a543fd8 100644 --- a/src/soc/intel/baytrail/lpss.c +++ b/src/soc/intel/baytrail/lpss.c @@ -36,7 +36,6 @@ static void dev_enable_acpi_mode(device_t dev, int iosf_reg, int nvs_index) { struct reg_script ops[] = { - REG_SCRIPT_SET_DEV(dev), /* Disable PCI interrupt, enable Memory and Bus Master */ REG_PCI_OR32(PCI_COMMAND, PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER | (1<<10)), @@ -68,20 +67,19 @@ static void dev_enable_acpi_mode(device_t dev, int iosf_reg, int nvs_index) gnvs->dev.lpss_en[nvs_index] = 1;
/* Put device in ACPI mode */ - reg_script_run(ops); + reg_script_run_on_dev(dev, ops); }
static void dev_enable_snoop_and_pm(device_t dev, int iosf_reg) { struct reg_script ops[] = { - REG_SCRIPT_SET_DEV(dev), REG_IOSF_RMW(IOSF_PORT_LPSS, iosf_reg, ~(LPSS_CTL_SNOOP | LPSS_CTL_NOSNOOP), LPSS_CTL_SNOOP | LPSS_CTL_PM_CAP_PRSNT), REG_SCRIPT_END, };
static void dev_ctl_reg(device_t dev, int *iosf_reg, int *nvs_index) @@ -128,8 +126,7 @@ static void dev_ctl_reg(device_t dev, int *iosf_reg, int *nvs_index) static void i2c_disable_resets(device_t dev) { /* Release the I2C devices from reset. */ - struct reg_script ops[] = { - REG_SCRIPT_SET_DEV(dev), + static const struct reg_script ops[] = { REG_RES_WRITE32(PCI_BASE_ADDRESS_0, 0x804, 0x3), REG_SCRIPT_END, }; @@ -146,7 +143,7 @@ static void i2c_disable_resets(device_t dev) CASE_I2C(I2C6): CASE_I2C(I2C7): printk(BIOS_DEBUG, "Releasing I2C device from reset.\n"); - reg_script_run(ops); + reg_script_run_on_dev(dev, ops); break; default: return; diff --git a/src/soc/intel/baytrail/pcie.c b/src/soc/intel/baytrail/pcie.c index f68304d..ce76d6d 100644 --- a/src/soc/intel/baytrail/pcie.c +++ b/src/soc/intel/baytrail/pcie.c @@ -90,7 +90,6 @@ static const struct reg_script init_static_after_exit_latency[] = { static void byt_pcie_init(device_t dev) { struct reg_script init_script[] = { - REG_SCRIPT_SET_DEV(dev), REG_SCRIPT_NEXT(init_static_before_exit_latency), /* Exit latency configuration based on * PHYCTL2_IOSFBCTL[PLL_OFF_EN] set in root port 1*/ @@ -108,7 +107,7 @@ static void byt_pcie_init(device_t dev) REG_SCRIPT_END, };
- reg_script_run(init_script); + reg_script_run_on_dev(dev, init_script);
if (is_first_port(dev)) { struct soc_intel_baytrail_config *config = dev->chip_info; @@ -157,19 +156,13 @@ static void check_port_enabled(device_t dev)
static void check_device_present(device_t dev) { - struct reg_script no_dev[] = { - REG_SCRIPT_SET_DEV(dev), - REG_SCRIPT_NEXT(no_dev_behind_port), - REG_SCRIPT_END, - }; - /* Set slot implemented. */ pci_write_config32(dev, XCAP, pci_read_config32(dev, XCAP) | SI);
/* No device present. */ if (!(pci_read_config32(dev, SLCTL_SLSTS) & PDS)) { printk(BIOS_DEBUG, "No PCIe device present.\n"); - reg_script_run(no_dev); + reg_script_run_on_dev(dev, no_dev_behind_port); dev->enabled = 0; } else if(!dev->enabled) { /* Port is disabled, but device present. Disable link. */ diff --git a/src/soc/intel/baytrail/scc.c b/src/soc/intel/baytrail/scc.c index 64792c2..7efb66d 100644 --- a/src/soc/intel/baytrail/scc.c +++ b/src/soc/intel/baytrail/scc.c @@ -90,7 +90,6 @@ void baytrail_init_scc(void) void scc_enable_acpi_mode(device_t dev, int iosf_reg, int nvs_index) { struct reg_script ops[] = { - REG_SCRIPT_SET_DEV(dev), /* Disable PCI interrupt, enable Memory and Bus Master */ REG_PCI_OR32(PCI_COMMAND, PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER | (1<<10)), @@ -122,5 +121,5 @@ void scc_enable_acpi_mode(device_t dev, int iosf_reg, int nvs_index) gnvs->dev.scc_en[nvs_index] = 1;
/* Put device in ACPI mode */ - reg_script_run(ops); + reg_script_run_on_dev(dev, ops); } diff --git a/src/soc/intel/baytrail/xhci.c b/src/soc/intel/baytrail/xhci.c index 1155ca6..b6dc2b2 100644 --- a/src/soc/intel/baytrail/xhci.c +++ b/src/soc/intel/baytrail/xhci.c @@ -132,7 +132,6 @@ const struct reg_script xhci_clock_gating_script[] = { static void xhci_reset_port_usb3(device_t dev, int port) { struct reg_script reset_port_usb3_script[] = { - REG_SCRIPT_SET_DEV(dev), /* Issue Warm Port Rest to the port */ REG_RES_OR32(PCI_BASE_ADDRESS_0, XHCI_USB3_PORTSC(port), XHCI_USB3_PORTSC_WPR), @@ -145,14 +144,13 @@ static void xhci_reset_port_usb3(device_t dev, int port) ~XHCI_USB3_PORTSC_PED, XHCI_USB3_PORTSC_CHST), REG_SCRIPT_END }; - reg_script_run(reset_port_usb3_script); + reg_script_run_on_dev(dev, reset_port_usb3_script); }
/* Prepare ports to be routed to EHCI or XHCI */ static void xhci_route_all(device_t dev) { - struct reg_script xhci_route_all_script[] = { - REG_SCRIPT_SET_DEV(dev), + static const struct reg_script xhci_route_all_script[] = { /* USB3 SuperSpeed Enable */ REG_PCI_WRITE32(XHCI_USB3PR, BYTM_USB3_PORT_MAP), /* USB2 Port Route to XHCI */ @@ -165,7 +163,7 @@ static void xhci_route_all(device_t dev) printk(BIOS_INFO, "USB: Route ports to XHCI controller\n");
/* Route ports to XHCI controller */ - reg_script_run(xhci_route_all_script); + reg_script_run_on_dev(dev, xhci_route_all_script);
/* Reset enabled USB3 ports */ port_disabled = pci_read_config32(dev, XHCI_USB3PDO); @@ -180,7 +178,6 @@ static void xhci_init(device_t dev) { struct soc_intel_baytrail_config *config = dev->chip_info; struct reg_script xhci_hc_init[] = { - REG_SCRIPT_SET_DEV(dev), /* Setup USB3 phy */ REG_SCRIPT_NEXT(usb3_phy_script), /* Initialize host controller */ @@ -207,7 +204,7 @@ static void xhci_init(device_t dev) };
/* Initialize XHCI controller */ - reg_script_run(xhci_hc_init); + reg_script_run_on_dev(dev, xhci_hc_init);
/* Route all ports to XHCI if requested */ if (config->usb_route_to_xhci)
