Paul Menzel has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38435 )
Change subject: autoport: Use HTTPS URLs ......................................................................
Update the two flashrom URLs to use HTTPS. All other URLs are already using HTTPS.
Change-Id: I8e9861b2748289522ab418960a463ae55ab0d2d3 Signed-off-by: Paul Menzel pmenzel@molgen.mpg.de --- M util/autoport/readme.md 1 file changed, 2 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/35/38435/1
diff --git a/util/autoport/readme.md b/util/autoport/readme.md index 6d1c64c..b73b441 100644 --- a/util/autoport/readme.md +++ b/util/autoport/readme.md @@ -63,7 +63,7 @@
Disassemble your computer and find the flash chip(s). Since there could be more than one, this guide will refer to "flash chips" as one or more chips. -Refer to http://flashrom.org/Technology as a reference. The flash chip is +Refer to https://flashrom.org/Technology as a reference. The flash chip is usually in a `SOIC-8` (2x4 pins, 200mil) or `SOIC-16` (2x8 pins) package. As it can be seen on flashrom's wiki, the former package is like any other 8-pin chip on the mainboard, but it is slightly larger. The latter package is much @@ -282,7 +282,7 @@
* `ROM package`, `ROM protocol` and `ROM socketed`: These refer to the flash chips you found earlier. You can visit - http://flashrom.org/Technology for more information. + https://flashrom.org/Technology for more information.
* `Release year`: Use the power of Internet to find that information. * `Category`: This describes the type of mainboard you have.
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38435 )
Patch Set 1: Code-Review+2
Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/38435 )
Change-Id: I8e9861b2748289522ab418960a463ae55ab0d2d3 Signed-off-by: Paul Menzel pmenzel@molgen.mpg.de Reviewed-on: https://review.coreboot.org/c/coreboot/+/38435 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M util/autoport/readme.md 1 file changed, 2 insertions(+), 2 deletions(-)
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38435 )
Patch Set 2:
Automatic boot test returned (PASS/FAIL/TOTAL): 3/0/3 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : No test failed. EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : No test failed. EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : No test failed.
