Isaac Christensen (isaac.christensen@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6791
commit dc3353aa289e0d33d04016f29189825aec8efadf Author: David Hendricks dhendrix@chromium.org Date: Thu Oct 3 14:02:45 2013 -0700
arm: Update a stale comment in bootblock .S files
This just updates a comment which refers to "board_init_f". We use bootblock main() in coreboot.
Change-Id: I4cb6b3c11f163b67fe48de495d13dce88710efc0 Reviewed-on: https://chromium-review.googlesource.com/172095 Reviewed-by: Gabe Black gabeblack@chromium.org Commit-Queue: David Hendricks dhendrix@chromium.org Tested-by: David Hendricks dhendrix@chromium.org (cherry picked from commit 65139f29682cedca8dfb58b3dfe67eab64299064) Signed-off-by: Isaac Christensen isaac.christensen@se-eng.com --- src/arch/arm/armv4/bootblock.S | 2 +- src/arch/arm/armv7/bootblock.S | 2 +- src/soc/nvidia/tegra124/bootblock_asm.S | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/src/arch/arm/armv4/bootblock.S b/src/arch/arm/armv4/bootblock.S index 5f7de13..3ba2a88 100644 --- a/src/arch/arm/armv4/bootblock.S +++ b/src/arch/arm/armv4/bootblock.S @@ -65,7 +65,7 @@ init_stack_loop: cmp r0, r1 bne init_stack_loop
-/* Set stackpointer in internal RAM to call board_init_f */ +/* Set stackpointer in internal RAM to call bootblock main() */ call_bootblock: ldr sp, .Stack /* Set up stack pointer */ ldr r0,=0x00000000 diff --git a/src/arch/arm/armv7/bootblock.S b/src/arch/arm/armv7/bootblock.S index f2f528a..f18a355 100644 --- a/src/arch/arm/armv7/bootblock.S +++ b/src/arch/arm/armv7/bootblock.S @@ -76,7 +76,7 @@ init_stack_loop: cmp r0, r1 bne init_stack_loop
-/* Set stackpointer in internal RAM to call board_init_f */ +/* Set stackpointer in internal RAM to call bootblock main() */ call_bootblock: ldr sp, .Stack /* Set up stack pointer */ ldr r0,=0x00000000 diff --git a/src/soc/nvidia/tegra124/bootblock_asm.S b/src/soc/nvidia/tegra124/bootblock_asm.S index 5f7de13..3ba2a88 100644 --- a/src/soc/nvidia/tegra124/bootblock_asm.S +++ b/src/soc/nvidia/tegra124/bootblock_asm.S @@ -65,7 +65,7 @@ init_stack_loop: cmp r0, r1 bne init_stack_loop
