Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16641
commit 3c3cdd3ff590e5c8b69c340b338544446d1b1a65 Author: Elyes HAOUAS ehaouas@noos.fr Date: Mon Sep 19 09:47:16 2016 -0600
src/mainboard/lenovo-winent: Add space around operators
Change-Id: Iab2a879ebdea9d93ef5eb7e3abf875036c1e1cb4 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- src/mainboard/lippert/frontrunner-af/mainboard.c | 4 +- src/mainboard/lippert/frontrunner/irq_tables.c | 8 +-- src/mainboard/lippert/hurricane-lx/mainboard.c | 2 +- src/mainboard/lippert/hurricane-lx/romstage.c | 4 +- src/mainboard/lippert/literunner-lx/mainboard.c | 2 +- src/mainboard/lippert/literunner-lx/romstage.c | 6 +- src/mainboard/lippert/roadrunner-lx/mainboard.c | 2 +- src/mainboard/lippert/roadrunner-lx/romstage.c | 6 +- src/mainboard/lippert/spacerunner-lx/devicetree.cb | 2 +- src/mainboard/lippert/spacerunner-lx/mainboard.c | 2 +- src/mainboard/lippert/spacerunner-lx/romstage.c | 6 +- src/mainboard/lippert/toucan-af/mainboard.c | 4 +- src/mainboard/msi/ms6119/irq_tables.c | 16 ++--- src/mainboard/msi/ms6147/irq_tables.c | 18 ++--- src/mainboard/msi/ms6178/irq_tables.c | 10 +-- src/mainboard/msi/ms9185/mptable.c | 40 ++++++------ src/mainboard/msi/ms9185/romstage.c | 10 +-- src/mainboard/msi/ms9282/mptable.c | 10 +-- src/mainboard/msi/ms9282/romstage.c | 14 ++-- src/mainboard/msi/ms9652_fam10/get_bus_conf.c | 10 +-- src/mainboard/msi/ms9652_fam10/mptable.c | 10 +-- src/mainboard/msi/ms9652_fam10/romstage.c | 4 +- src/mainboard/nvidia/l1_2pvv/mptable.c | 4 +- src/mainboard/nvidia/l1_2pvv/romstage.c | 8 +-- src/mainboard/rca/rm4100/irq_tables.c | 18 ++--- src/mainboard/roda/rk886ex/irq_tables.c | 40 ++++++------ src/mainboard/roda/rk886ex/m3885.c | 6 +- src/mainboard/roda/rk886ex/m3885.h | 76 +++++++++++----------- src/mainboard/roda/rk886ex/mainboard.c | 6 +- src/mainboard/roda/rk886ex/romstage.c | 4 +- src/mainboard/samsung/lumpy/gpio.c | 8 +-- src/mainboard/samsung/stumpy/romstage.c | 6 +- src/mainboard/samsung/stumpy/smihandler.c | 12 ++-- src/mainboard/siemens/mc_tcu3/romstage.c | 2 +- src/mainboard/siemens/sitemp_g1p1/fadt.c | 6 +- src/mainboard/siemens/sitemp_g1p1/mainboard.c | 2 +- src/mainboard/siemens/sitemp_g1p1/romstage.c | 4 +- src/mainboard/sunw/ultra40/mptable.c | 32 ++++----- src/mainboard/sunw/ultra40/romstage.c | 18 ++--- src/mainboard/sunw/ultra40m2/mptable.c | 4 +- src/mainboard/sunw/ultra40m2/romstage.c | 8 +-- src/mainboard/supermicro/h8dme/mptable.c | 18 ++--- src/mainboard/supermicro/h8dme/romstage.c | 6 +- src/mainboard/supermicro/h8dmr/mptable.c | 18 ++--- src/mainboard/supermicro/h8dmr/romstage.c | 12 ++-- .../supermicro/h8dmr_fam10/get_bus_conf.c | 6 +- src/mainboard/supermicro/h8dmr_fam10/mptable.c | 10 +-- src/mainboard/supermicro/h8dmr_fam10/romstage.c | 2 +- src/mainboard/supermicro/h8qgi/BiosCallOuts.c | 2 +- src/mainboard/supermicro/h8qgi/fadt.c | 2 +- src/mainboard/supermicro/h8qgi/mptable.c | 2 +- .../supermicro/h8qme_fam10/get_bus_conf.c | 6 +- src/mainboard/supermicro/h8qme_fam10/mptable.c | 10 +-- src/mainboard/supermicro/h8qme_fam10/romstage.c | 10 +-- src/mainboard/supermicro/h8scm/fadt.c | 2 +- src/mainboard/supermicro/h8scm/mptable.c | 2 +- src/mainboard/supermicro/h8scm_fam10/acpi_tables.c | 2 +- src/mainboard/supermicro/h8scm_fam10/mptable.c | 2 +- src/mainboard/supermicro/h8scm_fam10/romstage.c | 2 +- src/mainboard/technexion/tim5690/fadt.c | 6 +- src/mainboard/technexion/tim5690/mptable.c | 2 +- src/mainboard/technexion/tim5690/romstage.c | 4 +- src/mainboard/technexion/tim5690/tn_post_code.c | 68 +++++++++---------- src/mainboard/technexion/tim8690/mainboard.c | 2 +- src/mainboard/technexion/tim8690/mptable.c | 2 +- src/mainboard/technexion/tim8690/romstage.c | 4 +- src/mainboard/thomson/ip1000/irq_tables.c | 18 ++--- src/mainboard/thomson/ip1000/mainboard.c | 2 +- src/mainboard/tyan/s2912/get_bus_conf.c | 6 +- src/mainboard/tyan/s2912/mptable.c | 10 +-- src/mainboard/tyan/s2912/romstage.c | 8 +-- src/mainboard/tyan/s2912_fam10/get_bus_conf.c | 6 +- src/mainboard/tyan/s2912_fam10/mptable.c | 10 +-- src/mainboard/tyan/s2912_fam10/romstage.c | 6 +- src/mainboard/tyan/s8226/fadt.c | 2 +- src/mainboard/tyan/s8226/mptable.c | 2 +- src/mainboard/via/epia-cn/irq_tables.c | 20 +++--- src/mainboard/via/epia-cn/romstage.c | 4 +- src/mainboard/via/pc2500e/irq_tables.c | 22 +++---- src/mainboard/winent/mb6047/mptable.c | 10 +-- src/mainboard/winent/mb6047/romstage.c | 2 +- 81 files changed, 392 insertions(+), 392 deletions(-)
diff --git a/src/mainboard/lippert/frontrunner-af/mainboard.c b/src/mainboard/lippert/frontrunner-af/mainboard.c index 79c093f..a8cf5c5 100644 --- a/src/mainboard/lippert/frontrunner-af/mainboard.c +++ b/src/mainboard/lippert/frontrunner-af/mainboard.c @@ -31,7 +31,7 @@
/* Init SIO GPIOs. */ #define SIO_RUNTIME_BASE 0x0E00 -static const u16 sio_init_table[] = { // hi=offset, lo=value +static const u16 sio_init_table[] = { // hi = offset, lo = value 0x4BA0, // GP1x: COM1/2 control = RS232, no term, max 115200 0x2300, // GP10: COM1 termination = push/pull output 0x2400, // GP11: COM2 termination = push/pull output @@ -70,7 +70,7 @@ static const u16 sio_init_table[] = { // hi=offset, lo=value static int smb_write_blk(u8 slave, u8 command, u8 length, const u8 *data) { __outbyte(SMB0_STATUS, 0x1E); // clear error status - __outbyte(SMB0_ADDRESS, slave & ~1); // slave addr + direction=out + __outbyte(SMB0_ADDRESS, slave & ~1); // slave addr + direction = out __outbyte(SMB0_HOSTCMD, command); // or destination offset __outbyte(SMB0_DATA0, length); // sent before data __inbyte(SMB0_CONTROL); // reset block data array diff --git a/src/mainboard/lippert/frontrunner/irq_tables.c b/src/mainboard/lippert/frontrunner/irq_tables.c index 2e0d9d6..a8f7e36 100644 --- a/src/mainboard/lippert/frontrunner/irq_tables.c +++ b/src/mainboard/lippert/frontrunner/irq_tables.c @@ -23,7 +23,7 @@ static const struct irq_routing_table intel_irq_routing_table = { PIRQ_VERSION, /* u16 version */ 32+16*CONFIG_IRQ_SLOT_COUNT, /* there can be total CONFIG_IRQ_SLOT_COUNT devices on the bus */ 0x00, /* Where the interrupt router lies (bus) */ - (0x12<<3)|0x0, /* Where the interrupt router lies (dev) */ + (0x12 << 3)|0x0, /* Where the interrupt router lies (dev) */ 0x800, /* IRQs devoted exclusively to PCI usage */ 0x1078, /* Vendor */ 0x2, /* Device */ @@ -31,9 +31,9 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0xdf, /* u8 checksum , this hase to set to some value that would give 0 after the sum of all bytes for this structure (including checksum) */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x0e<<3)|0x0, {{0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x04, 0xdeb8}, {0x01, 0x0deb8}}, 0x1, 0x0}, - {0x00,(0x0f<<3)|0x0, {{0x03, 0xdeb8}, {0x04, 0xdeb8}, {0x01, 0xdeb8}, {0x02, 0x0deb8}}, 0x2, 0x0}, + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x0e << 3)|0x0, {{0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x04, 0xdeb8}, {0x01, 0x0deb8}}, 0x1, 0x0}, + {0x00,(0x0f << 3)|0x0, {{0x03, 0xdeb8}, {0x04, 0xdeb8}, {0x01, 0xdeb8}, {0x02, 0x0deb8}}, 0x2, 0x0}, } }; unsigned long write_pirq_routing_table(unsigned long addr) diff --git a/src/mainboard/lippert/hurricane-lx/mainboard.c b/src/mainboard/lippert/hurricane-lx/mainboard.c index ffd20d0..3d32113 100644 --- a/src/mainboard/lippert/hurricane-lx/mainboard.c +++ b/src/mainboard/lippert/hurricane-lx/mainboard.c @@ -31,7 +31,7 @@ #define SIO_GP1X_CONFIG 0x00 #endif
-static const u16 ec_init_table[] = { /* hi=data, lo=index */ +static const u16 ec_init_table[] = { /* hi = data, lo = index */ 0x1900, /* Enable monitoring */ 0x0351, /* TMPIN1,2 diode mode, TMPIN3 off */ 0x805C, /* Unlock zero adjust */ diff --git a/src/mainboard/lippert/hurricane-lx/romstage.c b/src/mainboard/lippert/hurricane-lx/romstage.c index 0c9e03a..7e3288f 100644 --- a/src/mainboard/lippert/hurricane-lx/romstage.c +++ b/src/mainboard/lippert/hurricane-lx/romstage.c @@ -76,7 +76,7 @@ static int smc_send_config(unsigned char config_data) #include "cpu/amd/geode_lx/syspreinit.c" #include "cpu/amd/geode_lx/msrinit.c"
-static const u16 sio_init_table[] = { // hi=data, lo=index +static const u16 sio_init_table[] = { // hi = data, lo = index 0x042C, // disable ATXPG; VIN6 enabled, FAN4/5 disabled, VIN7,VIN3 enabled 0x1423, // don't delay PoWeROK1/2 0x9072, // watchdog triggers PWROK, counts seconds @@ -84,7 +84,7 @@ static const u16 sio_init_table[] = { // hi=data, lo=index 0x0073, 0x0074, // disarm watchdog by changing 56 s timeout to 0 #endif 0xBF25, 0x172A, 0xF326, // select GPIO function for most pins - 0xBF27, 0xFF28, 0x2D29, // (GP36=FAN_CTL3 (PWM), GP23,22,16,15=SPI, GP13=PWROK1) + 0xBF27, 0xFF28, 0x2D29, // (GP36 = FAN_CTL3 (PWM), GP23,22,16,15 = SPI, GP13 = PWROK1) 0x66B8, 0x0CB9, // enable pullups on SPI, RS485_EN 0x07C0, // enable Simple-I/O for GP12-10= RS485_EN2,1, WD_ACTIVE 0x06C8, // config GP12,11 as output, GP10 as input diff --git a/src/mainboard/lippert/literunner-lx/mainboard.c b/src/mainboard/lippert/literunner-lx/mainboard.c index 1a569e2..e4084b5 100644 --- a/src/mainboard/lippert/literunner-lx/mainboard.c +++ b/src/mainboard/lippert/literunner-lx/mainboard.c @@ -34,7 +34,7 @@ /* Bit0 enables COM3's transceiver, bit1 disables the RS485 receiver (e.g. for IR). */ #define SIO_GP2X_CONFIG 0x00
-static const u16 ec_init_table[] = { /* hi=data, lo=index */ +static const u16 ec_init_table[] = { /* hi = data, lo = index */ 0x1900, /* Enable monitoring */ 0x3050, /* VIN4,5 enabled */ 0x0351, /* TMPIN1,2 diode mode, TMPIN3 off */ diff --git a/src/mainboard/lippert/literunner-lx/romstage.c b/src/mainboard/lippert/literunner-lx/romstage.c index efe322c..2f6aa46 100644 --- a/src/mainboard/lippert/literunner-lx/romstage.c +++ b/src/mainboard/lippert/literunner-lx/romstage.c @@ -115,7 +115,7 @@ static int smc_send_config(unsigned char config_data) #include "cpu/amd/geode_lx/syspreinit.c" #include "cpu/amd/geode_lx/msrinit.c"
-static const u16 sio_init_table[] = { // hi=data, lo=index +static const u16 sio_init_table[] = { // hi = data, lo = index 0x072C, // VIN6 enabled, FAN4/5 disabled, VIN7,VIN3 internal 0x1423, // don't delay PoWeROK1/2 0x9072, // watchdog triggers PWROK, counts seconds @@ -123,7 +123,7 @@ static const u16 sio_init_table[] = { // hi=data, lo=index 0x0073, 0x0074, // disarm watchdog by changing 56 s timeout to 0 #endif 0xBF25, 0x172A, 0xF326, // select GPIO function for most pins - 0xFF27, 0xDF28, 0x2729, // (GP45=SUSB, GP23,22,16,15=SPI, GP13=PWROK1) + 0xFF27, 0xDF28, 0x2729, // (GP45 = SUSB, GP23,22,16,15 = SPI, GP13 = PWROK1) 0x66B8, 0x0FB9, // enable pullups on SPI, RS485_EN, COM3_R/TX_EN 0x07C0, // enable Simple-I/O for GP12-10= RS485_EN2,1, LIVE_LED 0x03C1, // enable Simple-I/O for GP21-20= COM3_RX_EN,TX_EN @@ -131,7 +131,7 @@ static const u16 sio_init_table[] = { // hi=data, lo=index 0x07C8, // config GP12-10 as output 0x03C9, // config GP21-20 as output 0x2DF5, // map Hw Monitor Thermal Output to GP55 - 0x08F8, // map GP LED Blinking 1 to GP10=LIVE_LED (deactivate Simple I/O to use) + 0x08F8, // map GP LED Blinking 1 to GP10 = LIVE_LED (deactivate Simple I/O to use) };
/* Early mainboard specific GPIO setup. */ diff --git a/src/mainboard/lippert/roadrunner-lx/mainboard.c b/src/mainboard/lippert/roadrunner-lx/mainboard.c index cd83768..1d35ebe 100644 --- a/src/mainboard/lippert/roadrunner-lx/mainboard.c +++ b/src/mainboard/lippert/roadrunner-lx/mainboard.c @@ -31,7 +31,7 @@ #define SIO_GP1X_CONFIG 0x20 #endif
-static const u16 ec_init_table[] = { /* hi=data, lo=index */ +static const u16 ec_init_table[] = { /* hi = data, lo = index */ 0x1900, /* Enable monitoring */ 0x0351, /* TMPIN1,2 diode mode, TMPIN3 off */ 0x805C, /* Unlock zero adjust */ diff --git a/src/mainboard/lippert/roadrunner-lx/romstage.c b/src/mainboard/lippert/roadrunner-lx/romstage.c index d70e2c1..7e0e2a5 100644 --- a/src/mainboard/lippert/roadrunner-lx/romstage.c +++ b/src/mainboard/lippert/roadrunner-lx/romstage.c @@ -52,7 +52,7 @@ int spd_read_byte(unsigned int device, unsigned int address) #include "cpu/amd/geode_lx/syspreinit.c" #include "cpu/amd/geode_lx/msrinit.c"
-static const u16 sio_init_table[] = { // hi=data, lo=index +static const u16 sio_init_table[] = { // hi = data, lo = index 0x1E2C, // disable ATXPG; VIN6,FAN4/5,VIN3 enabled, VIN7 internal 0x1423, // don't delay PoWeROK1/2 - triggers 2nd reset 0x9072, // watchdog triggers PWROK, counts seconds @@ -60,13 +60,13 @@ static const u16 sio_init_table[] = { // hi=data, lo=index 0x0073, 0x0074, // disarm watchdog by changing 56 s timeout to 0 #endif 0xBF25, 0x372A, 0xF326, // select GPIO function for most pins - 0xBF27, 0xFF28, 0x2529, // (GP36=FAN_CTL3, GP13=PWROK1) + 0xBF27, 0xFF28, 0x2529, // (GP36 = FAN_CTL3, GP13 = PWROK1) 0x46B8, 0x0CB9, // enable pullups on RS485_EN 0x36C0, // enable Simple-I/O for GP15,14,12,11= LIVE_LED, WD_ACTIVE, RS485_EN2,1 0xFFC3, // enable Simple-I/O for GP47-40 (GPIOs on Supervisory Connector) 0x26C8, // config GP15,12,11 as output; GP14 as input 0x2DF5, // map Hw Monitor Thermal Output to GP55 - 0x0DF8, // map GP LED Blinking 1 to GP15=LIVE_LED (deactivate Simple-I/O to use) + 0x0DF8, // map GP LED Blinking 1 to GP15 = LIVE_LED (deactivate Simple-I/O to use) };
/* Early mainboard specific GPIO setup. */ diff --git a/src/mainboard/lippert/spacerunner-lx/devicetree.cb b/src/mainboard/lippert/spacerunner-lx/devicetree.cb index 8619e84..5f5b15b 100644 --- a/src/mainboard/lippert/spacerunner-lx/devicetree.cb +++ b/src/mainboard/lippert/spacerunner-lx/devicetree.cb @@ -21,7 +21,7 @@ chip northbridge/amd/lx register "com2_enable" = "0" register "com2_address" = "0x2E8" register "com2_irq" = "6" - register "unwanted_vpci[0]" = "0x80007B00" # Audio: 1<<31 + Device 0x0F<<11 + Function 3<<8 + register "unwanted_vpci[0]" = "0x80007B00" # Audio: 1 << 31 + Device 0x0F << 11 + Function 3 << 8 register "unwanted_vpci[1]" = "0" # End of list has a zero device pci 8.0 on end # Slot4 device pci 9.0 on end # Slot3 diff --git a/src/mainboard/lippert/spacerunner-lx/mainboard.c b/src/mainboard/lippert/spacerunner-lx/mainboard.c index 4decd0e..b0bc74e 100644 --- a/src/mainboard/lippert/spacerunner-lx/mainboard.c +++ b/src/mainboard/lippert/spacerunner-lx/mainboard.c @@ -31,7 +31,7 @@ #define SIO_GP1X_CONFIG 0x01 #endif
-static const u16 ec_init_table[] = { /* hi=data, lo=index */ +static const u16 ec_init_table[] = { /* hi = data, lo = index */ 0x1900, /* Enable monitoring */ 0x3050, /* VIN4,5 enabled */ 0x0351, /* TMPIN1,2 diode mode, TMPIN3 off */ diff --git a/src/mainboard/lippert/spacerunner-lx/romstage.c b/src/mainboard/lippert/spacerunner-lx/romstage.c index b3a13ad..85503c5 100644 --- a/src/mainboard/lippert/spacerunner-lx/romstage.c +++ b/src/mainboard/lippert/spacerunner-lx/romstage.c @@ -116,7 +116,7 @@ static int smc_send_config(unsigned char config_data) #include "cpu/amd/geode_lx/syspreinit.c" #include "cpu/amd/geode_lx/msrinit.c"
-static const u16 sio_init_table[] = { // hi=data, lo=index +static const u16 sio_init_table[] = { // hi = data, lo = index 0x072C, // VIN6 enabled, FAN4/5 disabled, VIN7,VIN3 internal 0x1423, // don't delay PoWeROK1/2 0x9072, // watchdog triggers PWROK, counts seconds @@ -124,12 +124,12 @@ static const u16 sio_init_table[] = { // hi=data, lo=index 0x0073, 0x0074, // disarm watchdog by changing 56 s timeout to 0 #endif 0xBF25, 0x172A, 0xF326, // select GPIO function for most pins - 0xFF27, 0xDF28, 0x2729, // (GP45=SUSB, GP23,22,16,15=SPI, GP13=PWROK1) + 0xFF27, 0xDF28, 0x2729, // (GP45 = SUSB, GP23,22,16,15 = SPI, GP13 = PWROK1) 0x66B8, 0x0CB9, // enable pullups on SPI, RS485_EN 0x07C0, // enable Simple-I/O for GP12-10= RS485_EN2,1, LIVE_LED 0x07C8, // config GP12-10 as output 0x2DF5, // map Hw Monitor Thermal Output to GP55 - 0x08F8, // map GP LED Blinking 1 to GP10=LIVE_LED (deactivate Simple I/O to use) + 0x08F8, // map GP LED Blinking 1 to GP10 = LIVE_LED (deactivate Simple I/O to use) };
/* Early mainboard specific GPIO setup. */ diff --git a/src/mainboard/lippert/toucan-af/mainboard.c b/src/mainboard/lippert/toucan-af/mainboard.c index b9c532f..6b51fd2 100644 --- a/src/mainboard/lippert/toucan-af/mainboard.c +++ b/src/mainboard/lippert/toucan-af/mainboard.c @@ -39,7 +39,7 @@ static int smb_write_blk(u8 slave, u8 command, u8 length, const u8 *data) { __outbyte(SMB0_STATUS, 0x1E); // clear error status - __outbyte(SMB0_ADDRESS, slave & ~1); // slave addr + direction=out + __outbyte(SMB0_ADDRESS, slave & ~1); // slave addr + direction = out __outbyte(SMB0_HOSTCMD, command); // or destination offset __outbyte(SMB0_DATA0, length); // sent before data __inbyte(SMB0_CONTROL); // reset block data array @@ -96,7 +96,7 @@ static void init(struct device *dev) * effect a power cycle and switch to the alternate BIOS chip. * Should be done as late as possible. */ printk(BIOS_INFO, "Sending BIOS alive message\n"); - const u8 i_am_alive[] = { 0x03 }; //bit2=SEL_DP0: 0=DDI2, 1=LVDS + const u8 i_am_alive[] = { 0x03 }; //bit2 = SEL_DP0: 0 = DDI2, 1 = LVDS if ((i = smb_write_blk(0x50, 0x25, sizeof(i_am_alive), i_am_alive))) printk(BIOS_ERR, "smb_write_blk failed: %d\n", i);
diff --git a/src/mainboard/msi/ms6119/irq_tables.c b/src/mainboard/msi/ms6119/irq_tables.c index 496c01f..2b9f7f4 100644 --- a/src/mainboard/msi/ms6119/irq_tables.c +++ b/src/mainboard/msi/ms6119/irq_tables.c @@ -29,14 +29,14 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0x9c, /* Checksum */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x0e<<3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x1, 0x0}, - {0x00,(0x10<<3)|0x0, {{0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0x0deb8}}, 0x2, 0x0}, - {0x00,(0x12<<3)|0x0, {{0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0xdeb8}, {0x61, 0x0deb8}}, 0x3, 0x0}, - {0x00,(0x14<<3)|0x0, {{0x63, 0xdeb8}, {0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0x0deb8}}, 0x4, 0x0}, - {0x00,(0x07<<3)|0x1, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0x0deb8}}, 0x0, 0x0}, - {0x00,(0x07<<3)|0x2, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, - {0x00,(0x01<<3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x0e << 3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x1, 0x0}, + {0x00,(0x10 << 3)|0x0, {{0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0x0deb8}}, 0x2, 0x0}, + {0x00,(0x12 << 3)|0x0, {{0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0xdeb8}, {0x61, 0x0deb8}}, 0x3, 0x0}, + {0x00,(0x14 << 3)|0x0, {{0x63, 0xdeb8}, {0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0x0deb8}}, 0x4, 0x0}, + {0x00,(0x07 << 3)|0x1, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0x0deb8}}, 0x0, 0x0}, + {0x00,(0x07 << 3)|0x2, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, + {0x00,(0x01 << 3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, } };
diff --git a/src/mainboard/msi/ms6147/irq_tables.c b/src/mainboard/msi/ms6147/irq_tables.c index 2590bb9..46e3268 100644 --- a/src/mainboard/msi/ms6147/irq_tables.c +++ b/src/mainboard/msi/ms6147/irq_tables.c @@ -29,15 +29,15 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0x20, /* Checksum */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x0e<<3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x1, 0x0}, - {0x00,(0x10<<3)|0x0, {{0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0x0deb8}}, 0x2, 0x0}, - {0x00,(0x12<<3)|0x0, {{0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0xdeb8}, {0x61, 0x0deb8}}, 0x3, 0x0}, - {0x00,(0x14<<3)|0x0, {{0x63, 0xdeb8}, {0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0x0deb8}}, 0x4, 0x0}, - {0x00,(0x00<<3)|0x0, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0x0deb8}}, 0x0, 0x0}, /* North bridge */ - {0x00,(0x07<<3)|0x1, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0x0deb8}}, 0x0, 0x0}, /* IDE */ - {0x00,(0x07<<3)|0x2, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, /* UHCI */ - {0x00,(0x01<<3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, /* AGP bridge */ + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x0e << 3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x1, 0x0}, + {0x00,(0x10 << 3)|0x0, {{0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0x0deb8}}, 0x2, 0x0}, + {0x00,(0x12 << 3)|0x0, {{0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0xdeb8}, {0x61, 0x0deb8}}, 0x3, 0x0}, + {0x00,(0x14 << 3)|0x0, {{0x63, 0xdeb8}, {0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0x0deb8}}, 0x4, 0x0}, + {0x00,(0x00 << 3)|0x0, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0x0deb8}}, 0x0, 0x0}, /* North bridge */ + {0x00,(0x07 << 3)|0x1, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0x0deb8}}, 0x0, 0x0}, /* IDE */ + {0x00,(0x07 << 3)|0x2, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, /* UHCI */ + {0x00,(0x01 << 3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, /* AGP bridge */ } };
diff --git a/src/mainboard/msi/ms6178/irq_tables.c b/src/mainboard/msi/ms6178/irq_tables.c index 2daf255..fae5bcf 100644 --- a/src/mainboard/msi/ms6178/irq_tables.c +++ b/src/mainboard/msi/ms6178/irq_tables.c @@ -29,11 +29,11 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0x1a, /* Checksum */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x1e<<3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x1, 0x0}, - {0x00,(0x10<<3)|0x0, {{0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0x0deb8}}, 0x2, 0x0}, - {0x00,(0x01<<3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, - {0x00,(0x1f<<3)|0x1, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x1e << 3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x1, 0x0}, + {0x00,(0x10 << 3)|0x0, {{0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0xdeb8}, {0x60, 0x0deb8}}, 0x2, 0x0}, + {0x00,(0x01 << 3)|0x0, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, + {0x00,(0x1f << 3)|0x1, {{0x60, 0xdeb8}, {0x61, 0xdeb8}, {0x62, 0xdeb8}, {0x63, 0x0deb8}}, 0x0, 0x0}, } };
diff --git a/src/mainboard/msi/ms9185/mptable.c b/src/mainboard/msi/ms9185/mptable.c index 775fdc6c..fccb200 100644 --- a/src/mainboard/msi/ms9185/mptable.c +++ b/src/mainboard/msi/ms9185/mptable.c @@ -1,7 +1,7 @@ /* * This file is part of the coreboot project. * - * Copyright (C) 2001 Eric W.Biedermanebiderman@lnxi.com + * Copyright (C) 2001 Eric W.Biederman ebiderman@lnxi.com * * Copyright (C) 2006 AMD * Written by Yinghai Lu yinghailu@gmail.com for AMD. @@ -54,7 +54,7 @@ static void *smp_write_config_table(void *v) { device_t dev = 0; struct resource *res; - for(i=0; i<3; i++) { + for(i = 0; i < 3; i++) { dev = dev_find_device(0x1166, 0x0235, dev); if (dev) { res = find_resource(dev, PCI_BASE_ADDRESS_0); @@ -76,11 +76,11 @@ static void *smp_write_config_table(void *v)
//SATA outb(0x07, 0xc00); outb(0x0f, 0xc01); - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_1, (0x0e<<2)|0, m->apicid_bcm5785[0], 0xf); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_1, (0x0e << 2)|0, m->apicid_bcm5785[0], 0xf);
//USB outb(0x01, 0xc00); outb(0x0a, 0xc01); - for(i=0;i<3;i++) { + for(i = 0; i < 3; i++) { smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_0, ((2+sysconf.sbdn)<<2)|i, m->apicid_bcm5785[0], 0xa); // }
@@ -94,52 +94,52 @@ static void *smp_write_config_table(void *v) if(dev) { uint32_t dword; dword = pci_read_config32(dev, 0x6c); - dword |= (1<<4); // enable interrupts + dword |= (1 << 4); // enable interrupts pci_write_config32(dev, 0x6c, dword); } }
//First pci-x slot (on bcm5785) under bus_bcm5785_1:d.0 // AIC 8130 Galileo Technology... - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_1_1, (6<<2)|i, m->apicid_bcm5785[1], 2 + (1+i)%4); // + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_1_1, (6 << 2)|i, m->apicid_bcm5785[1], 2 + (1+i)%4); // }
//pci slot (on bcm5785) - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_0, (5<<2)|i, m->apicid_bcm5785[1], 8+i%4); // + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_0, (5 << 2)|i, m->apicid_bcm5785[1], 8+i%4); // }
//onboard ati - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_0, (4<<2)|0, m->apicid_bcm5785[1], 0x1); + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5785_0, (4 << 2)|0, m->apicid_bcm5785[1], 0x1);
//PCI-X on bcm5780 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[1], (4<<2)|i, m->apicid_bcm5785[1], 2 + (0+i)%4); // + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[1], (4 << 2)|i, m->apicid_bcm5785[1], 2 + (0+i)%4); // }
//onboard Broadcom - for(i=0;i<2;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[2], (4<<2)|i, m->apicid_bcm5785[1], 0xa + (0+i)%4); // + for(i = 0; i < 2; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[2], (4 << 2)|i, m->apicid_bcm5785[1], 0xa + (0+i)%4); // }
// First PCI-E x8 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[5], (0<<2)|i, m->apicid_bcm5785[1], 0xe); // + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[5], (0 << 2)|i, m->apicid_bcm5785[1], 0xe); // }
// Second PCI-E x8 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[3], (0<<2)|i, m->apicid_bcm5785[1], 0xc); // + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[3], (0 << 2)|i, m->apicid_bcm5785[1], 0xc); // }
// Third PCI-E x1 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[4], (0<<2)|i, m->apicid_bcm5785[1], 0xd); // + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_bcm5780[4], (0 << 2)|i, m->apicid_bcm5785[1], 0xd); // }
/*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN#*/ diff --git a/src/mainboard/msi/ms9185/romstage.c b/src/mainboard/msi/ms9185/romstage.c index f6f6859..16eb36f 100644 --- a/src/mainboard/msi/ms9185/romstage.c +++ b/src/mainboard/msi/ms9185/romstage.c @@ -72,8 +72,8 @@ static inline int spd_read_byte(unsigned device, unsigned address) #include "cpu/amd/model_fxx/fidvid.c" #include "northbridge/amd/amdk8/early_ht.c"
-#define RC0 (0x10<<8) -#define RC1 (0x01<<8) +#define RC0 (0x10 << 8) +#define RC1 (0x01 << 8)
void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) { @@ -148,7 +148,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) #if CONFIG_SET_FIDVID { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "begin msr fid, vid %08x%08x\n", msr.hi, msr.lo); } enable_fid_change(); @@ -157,7 +157,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) // show final fid and vid { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "end msr fid, vid %08x%08x\n", msr.hi, msr.lo); } #endif @@ -181,7 +181,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx)
#if 0 int i; - for(i=0;i<2;i++) { + for(i = 0; i < 2; i++) { activate_spd_rom(sysinfo->ctrl+i); dump_smbus_registers(); } diff --git a/src/mainboard/msi/ms9282/mptable.c b/src/mainboard/msi/ms9282/mptable.c index cbad735..4619737 100644 --- a/src/mainboard/msi/ms9282/mptable.c +++ b/src/mainboard/msi/ms9282/mptable.c @@ -99,15 +99,15 @@ static void *smp_write_config_table(void *v) //NIC2 smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+9)<<2)|0, m->apicid_mcp55, 0x15); // 21
- for(j=7; j>=2; j--) { + for(j = 7; j >= 2; j--) { if(!m->bus_mcp55[j]) continue; - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[j], (0x00<<2)|i, m->apicid_mcp55, 0x10 + (2+j+i+4-sbdn%4)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[j], (0x00 << 2)|i, m->apicid_mcp55, 0x10 + (2+j+i+4-sbdn%4)%4); } }
- for(j=0; j<1; j++) - for(i=0;i<4;i++) { + for(j = 0; j < 1; j++) + for(i = 0; i < 4; i++) { smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[1], ((0x04+j)<<2)|i, m->apicid_mcp55, 0x10 + (2+i+j)%4); }
diff --git a/src/mainboard/msi/ms9282/romstage.c b/src/mainboard/msi/ms9282/romstage.c index 04c5c36..7d360e3 100644 --- a/src/mainboard/msi/ms9282/romstage.c +++ b/src/mainboard/msi/ms9282/romstage.c @@ -70,10 +70,10 @@ static inline int spd_read_byte(unsigned device, unsigned address)
//set GPIO to input mode #define MCP55_MB_SETUP \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+15, ~(0xff), ((0<<4)|(0<<2)|(0<<0)),/* M8,GPIO16, PCIXA_PRSNT2_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+44, ~(0xff), ((0<<4)|(0<<2)|(0<<0)),/* P5,GPIO45, PCIXA_PRSNT1_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+16, ~(0xff), ((0<<4)|(0<<2)|(0<<0)),/* K4,GPIO17, PCIXB_PRSNT1_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+45, ~(0xff), ((0<<4)|(0<<2)|(0<<0)),/* P7,GPIO46, PCIXB_PRSNT2_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+15, ~(0xff), ((0 << 4)|(0 << 2)|(0 << 0)),/* M8,GPIO16, PCIXA_PRSNT2_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+44, ~(0xff), ((0 << 4)|(0 << 2)|(0 << 0)),/* P5,GPIO45, PCIXA_PRSNT1_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+16, ~(0xff), ((0 << 4)|(0 << 2)|(0 << 0)),/* K4,GPIO17, PCIXB_PRSNT1_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+45, ~(0xff), ((0 << 4)|(0 << 2)|(0 << 0)),/* P7,GPIO46, PCIXB_PRSNT2_L*/ \
#include "southbridge/nvidia/mcp55/early_setup_car.c" #include "cpu/amd/model_fxx/init_cpus.c" @@ -98,13 +98,13 @@ static void sio_setup(void) pci_write_config8(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0x7b, byte);
dword = pci_read_config32(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0xa0); - dword |= (1<<0); + dword |= (1 << 0); pci_write_config32(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0xa0, dword); }
//CPU 1 mem is on SMBUS_HUB channel 2, and CPU 2 mem is on channel 1. -#define RC0 (2<<8) -#define RC1 (1<<8) +#define RC0 (2 << 8) +#define RC1 (1 << 8)
void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) { diff --git a/src/mainboard/msi/ms9652_fam10/get_bus_conf.c b/src/mainboard/msi/ms9652_fam10/get_bus_conf.c index 39a24dd..0614e1f 100644 --- a/src/mainboard/msi/ms9652_fam10/get_bus_conf.c +++ b/src/mainboard/msi/ms9652_fam10/get_bus_conf.c @@ -70,7 +70,7 @@ void get_bus_conf(void)
printk(BIOS_SPEW, "get_bus_conf()\n");
- if(get_bus_conf_done==1) return; //do it only once + if(get_bus_conf_done == 1) return; //do it only once
get_bus_conf_done = 1;
@@ -80,7 +80,7 @@ void get_bus_conf(void) memset(m, 0, sizeof(struct mb_sysconf_t));
sysconf.hc_possible_num = ARRAY_SIZE(pci1234x); - for(i=0;i<sysconf.hc_possible_num; i++) { + for(i = 0; i < sysconf.hc_possible_num; i++) { sysconf.pci1234[i] = pci1234x[i]; sysconf.hcdn[i] = hcdnx[i]; } @@ -99,7 +99,7 @@ void get_bus_conf(void) printk(BIOS_DEBUG, "ERROR - could not find PCI 1:%02x.0, using defaults\n", sysconf.sbdn + 0x06); }
- for(i=2; i<8;i++) { + for(i = 2; i < 8; i++) { dev = dev_find_slot(m->bus_mcp55[0], PCI_DEVFN(sysconf.sbdn + 0x0a + i - 2 , 0)); if (dev) { m->bus_mcp55[i] = pci_read_config8(dev, PCI_SECONDARY_BUS); @@ -112,10 +112,10 @@ void get_bus_conf(void) /*I/O APICs: APIC ID Version State Address*/ if (IS_ENABLED(CONFIG_LOGICAL_CPUS)) { apicid_base = get_apicid_base(1); - printk(BIOS_SPEW, "CONFIG_LOGICAL_CPUS==1: apicid_base: %08x\n", apicid_base); + printk(BIOS_SPEW, "CONFIG_LOGICAL_CPUS == 1: apicid_base: %08x\n", apicid_base); } else { apicid_base = CONFIG_MAX_PHYSICAL_CPUS; - printk(BIOS_SPEW, "CONFIG_LOGICAL_CPUS==0: apicid_base: %08x\n", apicid_base); + printk(BIOS_SPEW, "CONFIG_LOGICAL_CPUS == 0: apicid_base: %08x\n", apicid_base); } m->apicid_mcp55 = apicid_base+0; } diff --git a/src/mainboard/msi/ms9652_fam10/mptable.c b/src/mainboard/msi/ms9652_fam10/mptable.c index eff19c7..7d83c46 100644 --- a/src/mainboard/msi/ms9652_fam10/mptable.c +++ b/src/mainboard/msi/ms9652_fam10/mptable.c @@ -88,15 +88,15 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+8)<<2)|0, m->apicid_mcp55, 0x16); // 22 smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+9)<<2)|0, m->apicid_mcp55, 0x15); // 21
diff --git a/src/mainboard/msi/ms9652_fam10/romstage.c b/src/mainboard/msi/ms9652_fam10/romstage.c index 3af4785..e22ec11 100644 --- a/src/mainboard/msi/ms9652_fam10/romstage.c +++ b/src/mainboard/msi/ms9652_fam10/romstage.c @@ -83,7 +83,7 @@ static void sio_setup(void) pci_write_config8(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0x7b, byte);
@@ -200,7 +200,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) post_code(0x3A);
/* show final fid and vid */ - msr=rdmsr(0xc0010071); + msr = rdmsr(0xc0010071); printk(BIOS_DEBUG, "End FIDVIDMSR 0xc0010071 0x%08x 0x%08x\n", msr.hi, msr.lo); #endif init_timer(); /* Need to use TMICT to synchronize FID/VID. */ diff --git a/src/mainboard/nvidia/l1_2pvv/mptable.c b/src/mainboard/nvidia/l1_2pvv/mptable.c index d000b1a..76bb73c 100644 --- a/src/mainboard/nvidia/l1_2pvv/mptable.c +++ b/src/mainboard/nvidia/l1_2pvv/mptable.c @@ -58,8 +58,8 @@ static void *smp_write_config_table(void *v)
/* Initialize interrupt mapping*/ dword = pci_read_config32(dev, 0x74); - dword &= ~(1<<15); - dword |= 1<<2; + dword &= ~(1 << 15); + dword |= 1 << 2; pci_write_config32(dev, 0x74, dword);
dword = 0x43c6c643; diff --git a/src/mainboard/nvidia/l1_2pvv/romstage.c b/src/mainboard/nvidia/l1_2pvv/romstage.c index cfe5beb..d0966ee 100644 --- a/src/mainboard/nvidia/l1_2pvv/romstage.c +++ b/src/mainboard/nvidia/l1_2pvv/romstage.c @@ -81,11 +81,11 @@ static void sio_setup(void) pci_write_config8(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0x7b, byte);
dword = pci_read_config32(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0xa4); - dword |= (1<<16); + dword |= (1 << 16); pci_write_config32(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0xa4, dword); }
@@ -149,7 +149,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) #if CONFIG_SET_FIDVID { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "begin msr fid, vid %08x%08x\n", msr.hi, msr.lo); } enable_fid_change(); @@ -158,7 +158,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) // show final fid and vid { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "end msr fid, vid %08x%08x\n", msr.hi, msr.lo); } #endif diff --git a/src/mainboard/rca/rm4100/irq_tables.c b/src/mainboard/rca/rm4100/irq_tables.c index e8ef598..e99adfc 100644 --- a/src/mainboard/rca/rm4100/irq_tables.c +++ b/src/mainboard/rca/rm4100/irq_tables.c @@ -21,7 +21,7 @@ static const struct irq_routing_table intel_irq_routing_table = { PIRQ_VERSION, /* u16 version */ 32+16*CONFIG_IRQ_SLOT_COUNT, /* there can be total CONFIG_IRQ_SLOT_COUNT devices on the bus */ 0x00, /* Where the interrupt router lies (bus) */ - (0x1f<<3)|0x0, /* Where the interrupt router lies (dev) */ + (0x1f << 3)|0x0, /* Where the interrupt router lies (dev) */ 0, /* IRQs devoted exclusively to PCI usage */ 0x8086, /* Vendor */ 0x24c0, /* Device */ @@ -29,14 +29,14 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0x07, /* u8 checksum , this hase to set to some value that would give 0 after the sum of all bytes for this structure (including checksum) */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x02<<3)|0x0, {{0x60, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] IGD VGA */ - {0x00,(0x1d<<3)|0x0, {{0x60, 0x0ef8}, {0x63, 0x0ef8}, {0x62, 0x0ef8}, {0x6b, 0x00ef8}}, 0x0, 0x0}, /* [A] USB1, [B] USB2, [C] USB3, [D] EHCI */ - {0x00,(0x1f<<3)|0x0, {{0x62, 0x0ef8}, {0x61, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] IDE, [B] SMBUS, [B] AUDIO, [B] MODEM */ - {0x01,(0x08<<3)|0x0, {{0x68, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] ETHERNET */ - {0x01,(0x00<<3)|0x0, {{0x60, 0x0ef8}, {0x61, 0x0ef8}, {0x62, 0x0ef8}, {0x63, 0x00ef8}}, 0x1, 0x0}, /* PCI SLOT 1 */ - {0x01,(0x01<<3)|0x0, {{0x63, 0x0ef8}, {0x60, 0x0ef8}, {0x61, 0x0ef8}, {0x62, 0x00ef8}}, 0x2, 0x0}, /* PCI SLOT 2 */ - {0x01,(0x02<<3)|0x0, {{0x62, 0x0ef8}, {0x63, 0x0ef8}, {0x60, 0x0ef8}, {0x61, 0x00ef8}}, 0x3, 0x0}, /* PCI SLOT 3 */ + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x02 << 3)|0x0, {{0x60, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] IGD VGA */ + {0x00,(0x1d << 3)|0x0, {{0x60, 0x0ef8}, {0x63, 0x0ef8}, {0x62, 0x0ef8}, {0x6b, 0x00ef8}}, 0x0, 0x0}, /* [A] USB1, [B] USB2, [C] USB3, [D] EHCI */ + {0x00,(0x1f << 3)|0x0, {{0x62, 0x0ef8}, {0x61, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] IDE, [B] SMBUS, [B] AUDIO, [B] MODEM */ + {0x01,(0x08 << 3)|0x0, {{0x68, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] ETHERNET */ + {0x01,(0x00 << 3)|0x0, {{0x60, 0x0ef8}, {0x61, 0x0ef8}, {0x62, 0x0ef8}, {0x63, 0x00ef8}}, 0x1, 0x0}, /* PCI SLOT 1 */ + {0x01,(0x01 << 3)|0x0, {{0x63, 0x0ef8}, {0x60, 0x0ef8}, {0x61, 0x0ef8}, {0x62, 0x00ef8}}, 0x2, 0x0}, /* PCI SLOT 2 */ + {0x01,(0x02 << 3)|0x0, {{0x62, 0x0ef8}, {0x63, 0x0ef8}, {0x60, 0x0ef8}, {0x61, 0x00ef8}}, 0x3, 0x0}, /* PCI SLOT 3 */ } };
diff --git a/src/mainboard/roda/rk886ex/irq_tables.c b/src/mainboard/roda/rk886ex/irq_tables.c index 90ab6b0..f6d02f8 100644 --- a/src/mainboard/roda/rk886ex/irq_tables.c +++ b/src/mainboard/roda/rk886ex/irq_tables.c @@ -21,7 +21,7 @@ static const struct irq_routing_table intel_irq_routing_table = { PIRQ_VERSION, /* u16 version */ 32+16*18, /* There can be total 18 devices on the bus */ 0x00, /* Where the interrupt router lies (bus) */ - (0x1f<<3)|0x0, /* Where the interrupt router lies (dev) */ + (0x1f << 3)|0x0, /* Where the interrupt router lies (dev) */ 0, /* IRQs devoted exclusively to PCI usage */ 0x8086, /* Vendor */ 0x27b0, /* Device */ @@ -29,25 +29,25 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0xf, /* u8 checksum. */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x01<<3)|0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0x0dcd8}}, 0x0, 0x0}, // PCIe? - {0x00,(0x02<<3)|0x0, {{0x60, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // VGA - {0x00,(0x1e<<3)|0x0, {{0x61, 0xdcf8}, {0x68, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // PCI bridge - {0x00,(0x1f<<3)|0x0, {{0x62, 0xdcf8}, {0x63, 0xdcd8}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // LPC - {0x00,(0x1d<<3)|0x0, {{0x6b, 0xdcf8}, {0x63, 0xdcd8}, {0x62, 0xdcf8}, {0x60, 0x0dcf8}}, 0x0, 0x0}, // USB#1 - {0x00,(0x1b<<3)|0x0, {{0x60, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // Audio device - {0x00,(0x1c<<3)|0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0x0dcd8}}, 0x2, 0x0}, // PCIe bridge - {0x04,(0x00<<3)|0x0, {{0x60, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // Firewire - {0x04,(0x01<<3)|0x0, {{0x68, 0xdcf8}, {0x69, 0xdcf8}, {0x6a, 0xdcf8}, {0x6b, 0x0dcf8}}, 0x1, 0x0}, // PCI Bridge - {0x04,(0x02<<3)|0x0, {{0x69, 0xdcf8}, {0x6a, 0xdcf8}, {0x6b, 0xdcf8}, {0x68, 0x0dcf8}}, 0x2, 0x0}, - {0x04,(0x03<<3)|0x0, {{0x6a, 0xdcf8}, {0x6b, 0xdcf8}, {0x68, 0xdcf8}, {0x69, 0x0dcf8}}, 0x3, 0x0}, - {0x04,(0x04<<3)|0x0, {{0x6b, 0xdcf8}, {0x68, 0xdcf8}, {0x69, 0xdcf8}, {0x6a, 0x0dcf8}}, 0x4, 0x0}, - {0x04,(0x05<<3)|0x0, {{0x63, 0xdcd8}, {0x62, 0xdcf8}, {0x61, 0xdcf8}, {0x60, 0x0dcf8}}, 0x5, 0x0}, - {0x04,(0x06<<3)|0x0, {{0x62, 0xdcf8}, {0x61, 0xdcf8}, {0x60, 0xdcf8}, {0x63, 0x0dcd8}}, 0x6, 0x0}, - {0x04,(0x09<<3)|0x0, {{0x69, 0xdcf8}, {0x6a, 0xdcf8}, {0x6b, 0xdcf8}, {0x68, 0x0dcf8}}, 0x9, 0x0}, - {0x01,(0x00<<3)|0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0x0dcd8}}, 0x0, 0x0}, // Ethernet 8168 - {0x02,(0x00<<3)|0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0x0dcd8}}, 0x9, 0x0}, - {0x03,(0x00<<3)|0x0, {{0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0xdcd8}, {0x60, 0x0dcf8}}, 0xa, 0x0}, + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x01 << 3)|0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0x0dcd8}}, 0x0, 0x0}, // PCIe? + {0x00,(0x02 << 3)|0x0, {{0x60, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // VGA + {0x00,(0x1e << 3)|0x0, {{0x61, 0xdcf8}, {0x68, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // PCI bridge + {0x00,(0x1f << 3)|0x0, {{0x62, 0xdcf8}, {0x63, 0xdcd8}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // LPC + {0x00,(0x1d << 3)|0x0, {{0x6b, 0xdcf8}, {0x63, 0xdcd8}, {0x62, 0xdcf8}, {0x60, 0x0dcf8}}, 0x0, 0x0}, // USB#1 + {0x00,(0x1b << 3)|0x0, {{0x60, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // Audio device + {0x00,(0x1c << 3)|0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0x0dcd8}}, 0x2, 0x0}, // PCIe bridge + {0x04,(0x00 << 3)|0x0, {{0x60, 0xdcf8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, // Firewire + {0x04,(0x01 << 3)|0x0, {{0x68, 0xdcf8}, {0x69, 0xdcf8}, {0x6a, 0xdcf8}, {0x6b, 0x0dcf8}}, 0x1, 0x0}, // PCI Bridge + {0x04,(0x02 << 3)|0x0, {{0x69, 0xdcf8}, {0x6a, 0xdcf8}, {0x6b, 0xdcf8}, {0x68, 0x0dcf8}}, 0x2, 0x0}, + {0x04,(0x03 << 3)|0x0, {{0x6a, 0xdcf8}, {0x6b, 0xdcf8}, {0x68, 0xdcf8}, {0x69, 0x0dcf8}}, 0x3, 0x0}, + {0x04,(0x04 << 3)|0x0, {{0x6b, 0xdcf8}, {0x68, 0xdcf8}, {0x69, 0xdcf8}, {0x6a, 0x0dcf8}}, 0x4, 0x0}, + {0x04,(0x05 << 3)|0x0, {{0x63, 0xdcd8}, {0x62, 0xdcf8}, {0x61, 0xdcf8}, {0x60, 0x0dcf8}}, 0x5, 0x0}, + {0x04,(0x06 << 3)|0x0, {{0x62, 0xdcf8}, {0x61, 0xdcf8}, {0x60, 0xdcf8}, {0x63, 0x0dcd8}}, 0x6, 0x0}, + {0x04,(0x09 << 3)|0x0, {{0x69, 0xdcf8}, {0x6a, 0xdcf8}, {0x6b, 0xdcf8}, {0x68, 0x0dcf8}}, 0x9, 0x0}, + {0x01,(0x00 << 3)|0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0x0dcd8}}, 0x0, 0x0}, // Ethernet 8168 + {0x02,(0x00 << 3)|0x0, {{0x60, 0xdcf8}, {0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0x0dcd8}}, 0x9, 0x0}, + {0x03,(0x00 << 3)|0x0, {{0x61, 0xdcf8}, {0x62, 0xdcf8}, {0x63, 0xdcd8}, {0x60, 0x0dcf8}}, 0xa, 0x0}, } };
diff --git a/src/mainboard/roda/rk886ex/m3885.c b/src/mainboard/roda/rk886ex/m3885.c index 6a9b26c..d5a2b70 100644 --- a/src/mainboard/roda/rk886ex/m3885.c +++ b/src/mainboard/roda/rk886ex/m3885.c @@ -240,7 +240,7 @@ void m3885_configure_multikey(void) m3885_set_variable(0x0c, kstate5_flags & ~(7 << 4));
/* Write Matrix to bank 0 */ - for (i=0; i < ARRAY_SIZE(matrix); i++) { + for (i = 0; i < ARRAY_SIZE(matrix); i++) { m3885_set_proc_ram(i + 0x80, matrix[i]); }
@@ -257,7 +257,7 @@ void m3885_configure_multikey(void) printk(BIOS_DEBUG, "M388x does not have a valid RAM offset (0x%x)\n", offs); } else { printk(BIOS_DEBUG, "Writing Fn-Table to M388x RAM offset 0x%x\n", offs); - for (i=0; i < ARRAY_SIZE(function_ram); i++) { + for (i = 0; i < ARRAY_SIZE(function_ram); i++) { m3885_set_proc_ram(i + offs, function_ram[i]); } } @@ -269,7 +269,7 @@ void m3885_configure_multikey(void) m3885_set_variable(0x0c, kstate5_flags); maxvars = m3885_get_variable(0x00); printk(BIOS_DEBUG, "M388x has %d variables in original bank.\n", maxvars); - for (i=0; i<ARRAY_SIZE(variables); i+=3) { + for (i = 0; i < ARRAY_SIZE(variables); i+=3) { if(variables[i + 0] > maxvars) continue; reg8 = m3885_get_variable(variables[i + 0]); diff --git a/src/mainboard/roda/rk886ex/m3885.h b/src/mainboard/roda/rk886ex/m3885.h index 0fb8294..d2dcb14 100644 --- a/src/mainboard/roda/rk886ex/m3885.h +++ b/src/mainboard/roda/rk886ex/m3885.h @@ -21,50 +21,50 @@ #define M3885_CMDAT2 0x06 #define M3885_CMDAT3 0x07
-#define M3885_GPIO_LEVEL (0<<7) -#define M3885_GPIO_PULSE (1<<7) +#define M3885_GPIO_LEVEL (0 << 7) +#define M3885_GPIO_PULSE (1 << 7)
-#define M3885_GPIO_READ (0<<5) -#define M3885_GPIO_SET (1<<5) -#define M3885_GPIO_CLEAR (2<<5) -#define M3885_GPIO_TOGGLE (3<<5) +#define M3885_GPIO_READ (0 << 5) +#define M3885_GPIO_SET (1 << 5) +#define M3885_GPIO_CLEAR (2 << 5) +#define M3885_GPIO_TOGGLE (3 << 5)
-#define M3885_GPIO_P14 (0x00<<0) -#define M3885_GPIO_P15 (0x01<<0) -#define M3885_GPIO_P16 (0x02<<0) -#define M3885_GPIO_P17 (0x03<<0) +#define M3885_GPIO_P14 (0x00 << 0) +#define M3885_GPIO_P15 (0x01 << 0) +#define M3885_GPIO_P16 (0x02 << 0) +#define M3885_GPIO_P17 (0x03 << 0)
-#define M3885_GPIO_P54 (0x04<<0) -#define M3885_GPIO_P55 (0x05<<0) -#define M3885_GPIO_P56 (0x06<<0) -#define M3885_GPIO_P57 (0x07<<0) +#define M3885_GPIO_P54 (0x04 << 0) +#define M3885_GPIO_P55 (0x05 << 0) +#define M3885_GPIO_P56 (0x06 << 0) +#define M3885_GPIO_P57 (0x07 << 0)
-#define M3885_GPIO_P20 (0x08<<0) -#define M3885_GPIO_P21 (0x09<<0) -#define M3885_GPIO_P22 (0x0a<<0) -#define M3885_GPIO_P23 (0x0b<<0) -#define M3885_GPIO_P24 (0x0c<<0) -#define M3885_GPIO_P25 (0x0d<<0) -#define M3885_GPIO_P26 (0x0e<<0) -#define M3885_GPIO_P27 (0x0f<<0) +#define M3885_GPIO_P20 (0x08 << 0) +#define M3885_GPIO_P21 (0x09 << 0) +#define M3885_GPIO_P22 (0x0a << 0) +#define M3885_GPIO_P23 (0x0b << 0) +#define M3885_GPIO_P24 (0x0c << 0) +#define M3885_GPIO_P25 (0x0d << 0) +#define M3885_GPIO_P26 (0x0e << 0) +#define M3885_GPIO_P27 (0x0f << 0)
-#define M3885_GPIO_P40 (0x10<<0) -#define M3885_GPIO_P41 (0x11<<0) -#define M3885_GPIO_P42 (0x12<<0) -#define M3885_GPIO_P43 (0x13<<0) -#define M3885_GPIO_P44 (0x14<<0) -#define M3885_GPIO_P45 (0x15<<0) -#define M3885_GPIO_P46 (0x16<<0) -#define M3885_GPIO_P47 (0x17<<0) +#define M3885_GPIO_P40 (0x10 << 0) +#define M3885_GPIO_P41 (0x11 << 0) +#define M3885_GPIO_P42 (0x12 << 0) +#define M3885_GPIO_P43 (0x13 << 0) +#define M3885_GPIO_P44 (0x14 << 0) +#define M3885_GPIO_P45 (0x15 << 0) +#define M3885_GPIO_P46 (0x16 << 0) +#define M3885_GPIO_P47 (0x17 << 0)
-#define M3885_GPIO_P60 (0x18<<0) -#define M3885_GPIO_P61 (0x19<<0) -#define M3885_GPIO_P62 (0x1a<<0) -#define M3885_GPIO_P63 (0x1b<<0) -#define M3885_GPIO_P64 (0x1c<<0) -#define M3885_GPIO_P65 (0x1d<<0) -#define M3885_GPIO_P66 (0x1e<<0) -#define M3885_GPIO_P67 (0x1f<<0) +#define M3885_GPIO_P60 (0x18 << 0) +#define M3885_GPIO_P61 (0x19 << 0) +#define M3885_GPIO_P62 (0x1a << 0) +#define M3885_GPIO_P63 (0x1b << 0) +#define M3885_GPIO_P64 (0x1c << 0) +#define M3885_GPIO_P65 (0x1d << 0) +#define M3885_GPIO_P66 (0x1e << 0) +#define M3885_GPIO_P67 (0x1f << 0)
void m3885_configure_multikey(void); u8 m3885_gpio(u8 value); diff --git a/src/mainboard/roda/rk886ex/mainboard.c b/src/mainboard/roda/rk886ex/mainboard.c index 1ef2497..1959c32 100644 --- a/src/mainboard/roda/rk886ex/mainboard.c +++ b/src/mainboard/roda/rk886ex/mainboard.c @@ -35,7 +35,7 @@ static void backlight_enable(void) /* P56 is Brightness Up, and it needs a Pulse instead of a * Level */ - for (i=0; i < 28; i++) { + for (i = 0; i < 28; i++) { //m3885_gpio(M3885_GPIO_PULSE|M3885_GPIO_SET|M3885_GPIO_P56); m3885_gpio(M3885_GPIO_PULSE|M3885_GPIO_TOGGLE|M3885_GPIO_P56); } @@ -49,10 +49,10 @@ static void dump_runtime_registers(void) int i;
printk(BIOS_DEBUG, "SuperIO runtime register block:\n"); - for (i=0; i<0x10; i++) + for (i = 0; i < 0x10; i++) printk(BIOS_DEBUG, "%02x ", i); printk(BIOS_DEBUG, "\n"); - for (i=0; i<0x10; i++) + for (i = 0; i < 0x10; i++) printk(BIOS_DEBUG, "%02x ", inb(0x600 +i)); printk(BIOS_DEBUG, "\n"); } diff --git a/src/mainboard/roda/rk886ex/romstage.c b/src/mainboard/roda/rk886ex/romstage.c index f3af5fa..8de4665 100644 --- a/src/mainboard/roda/rk886ex/romstage.c +++ b/src/mainboard/roda/rk886ex/romstage.c @@ -68,7 +68,7 @@ static void ich7_enable_lpc(void) { int lpt_en = 0; if (read_option(lpt, 0) != 0) { - lpt_en = 1<<2; // enable LPT + lpt_en = 1 << 2; // enable LPT } // Enable Serial IRQ pci_write_config8(PCI_DEV(0, 0x1f, 0), 0x64, 0xd0); @@ -113,7 +113,7 @@ static void early_superio_config(void) { device_t dev;
- dev=PNP_DEV(0x2e, 0x00); + dev = PNP_DEV(0x2e, 0x00);
pnp_enter_ext_func_mode(dev); pnp_write_register(dev, 0x01, 0x94); // Extended Parport modes diff --git a/src/mainboard/samsung/lumpy/gpio.c b/src/mainboard/samsung/lumpy/gpio.c index 8e8b936..9d07e64 100644 --- a/src/mainboard/samsung/lumpy/gpio.c +++ b/src/mainboard/samsung/lumpy/gpio.c @@ -233,9 +233,9 @@ const struct pch_gpio_set2 pch_gpio_set2_level = { .gpio41 = GPIO_LEVEL_LOW, .gpio42 = GPIO_LEVEL_LOW, .gpio43 = GPIO_LEVEL_LOW, - .gpio44 = GPIO_LEVEL_HIGH, /* CTL2=1 for USB0 SDP */ - .gpio45 = GPIO_LEVEL_LOW, /* CTL3=0 for USB0 SDP */ - .gpio46 = GPIO_LEVEL_HIGH, /* CTL2=1 for USB1 SDP */ + .gpio44 = GPIO_LEVEL_HIGH, /* CTL2 = 1 for USB0 SDP */ + .gpio45 = GPIO_LEVEL_LOW, /* CTL3 = 0 for USB0 SDP */ + .gpio46 = GPIO_LEVEL_HIGH, /* CTL2 = 1 for USB1 SDP */ .gpio47 = GPIO_LEVEL_HIGH, /* Enable USB0 */ .gpio48 = GPIO_LEVEL_LOW, /* Disable Bluetooth */ .gpio49 = GPIO_LEVEL_LOW, @@ -299,7 +299,7 @@ const struct pch_gpio_set3 pch_gpio_set3_level = { .gpio70 = GPIO_LEVEL_HIGH, /* WLAN out of reset */ .gpio71 = GPIO_LEVEL_HIGH, /* WLAN power on */ .gpio72 = GPIO_LEVEL_LOW, - .gpio73 = GPIO_LEVEL_LOW, /* USB1 CTL3=0 for SDP */ + .gpio73 = GPIO_LEVEL_LOW, /* USB1 CTL3 = 0 for SDP */ .gpio74 = GPIO_LEVEL_LOW, .gpio75 = GPIO_LEVEL_LOW, }; diff --git a/src/mainboard/samsung/stumpy/romstage.c b/src/mainboard/samsung/stumpy/romstage.c index 738f1ff..7f7999c 100644 --- a/src/mainboard/samsung/stumpy/romstage.c +++ b/src/mainboard/samsung/stumpy/romstage.c @@ -144,9 +144,9 @@ static void setup_sio_gpios(void) /* * GPIO45 as LED_POWER# */ - it8772f_gpio_led(DUMMY_DEV, 4 /* set */, (0x1<<5) /* select */, - 0x00 /* polarity: non-inverting */, 0x00 /* 0=pulldown */, - (0x1<<5) /* output */, (0x1<<5) /* 1=Simple IO function */, + it8772f_gpio_led(DUMMY_DEV, 4 /* set */, (0x1 << 5) /* select */, + 0x00 /* polarity: non-inverting */, 0x00 /* 0 = pulldown */, + (0x1 << 5) /* output */, (0x1 << 5) /* 1 = Simple IO function */, SIO_GPIO_BLINK_GPIO45, IT8772F_GPIO_BLINK_FREQUENCY_1_HZ);
/* diff --git a/src/mainboard/samsung/stumpy/smihandler.c b/src/mainboard/samsung/stumpy/smihandler.c index 215af8f..00148f2 100644 --- a/src/mainboard/samsung/stumpy/smihandler.c +++ b/src/mainboard/samsung/stumpy/smihandler.c @@ -36,16 +36,16 @@ void mainboard_smi_sleep(u8 slp_typ) switch (slp_typ) { case ACPI_S3: case ACPI_S4: - it8772f_gpio_led(DUMMY_DEV, 4 /* set */, (0x1<<5) /* select */, - (0x1<<5) /* polarity */, (0x1<<5) /* 1=pullup */, - (0x1<<5) /* output */, 0x00, /* 0=Alternate function */ + it8772f_gpio_led(DUMMY_DEV, 4 /* set */, (0x1 << 5) /* select */, + (0x1 << 5) /* polarity */, (0x1 << 5) /* 1 = pullup */, + (0x1 << 5) /* output */, 0x00, /* 0 = Alternate function */ SIO_GPIO_BLINK_GPIO45, IT8772F_GPIO_BLINK_FREQUENCY_1_HZ); break;
case ACPI_S5: - it8772f_gpio_led(DUMMY_DEV, 4 /* set */, (0x1<<5) /* select */, - 0x00 /* polarity: non-inverting */, 0x00 /* 0=pulldown */, - (0x1<<5) /* output */, (0x1<<5) /* 1=Simple IO function */, + it8772f_gpio_led(DUMMY_DEV, 4 /* set */, (0x1 << 5) /* select */, + 0x00 /* polarity: non-inverting */, 0x00 /* 0 = pulldown */, + (0x1 << 5) /* output */, (0x1 << 5) /* 1 = Simple IO function */, SIO_GPIO_BLINK_GPIO45, IT8772F_GPIO_BLINK_FREQUENCY_1_HZ); break; default: diff --git a/src/mainboard/siemens/mc_tcu3/romstage.c b/src/mainboard/siemens/mc_tcu3/romstage.c index c8cc66b..15d949e 100644 --- a/src/mainboard/siemens/mc_tcu3/romstage.c +++ b/src/mainboard/siemens/mc_tcu3/romstage.c @@ -145,7 +145,7 @@ const PCH_AZALIA_VERB_TABLE mAzaliaVerbTable[] = { { 0x10EC0262, /* Vendor ID/Device IDA */ 0x0000, /* SubSystem ID */ 0xFF, /* Revision IDA */ - 0x01, /* Front panel support (1=yes, 2=no) */ + 0x01, /* Front panel support (1 = yes, 2 = no) */ 0x000B, /* Number of Rear Jacks = 11 */ 0x0002 /* Number of Front Jacks = 2 */ }, diff --git a/src/mainboard/siemens/sitemp_g1p1/fadt.c b/src/mainboard/siemens/sitemp_g1p1/fadt.c index 7d7221d..360a427 100644 --- a/src/mainboard/siemens/sitemp_g1p1/fadt.c +++ b/src/mainboard/siemens/sitemp_g1p1/fadt.c @@ -57,7 +57,7 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt)
fadt->firmware_ctrl = (u32) facs; fadt->dsdt = (u32) dsdt; - /* 3=Workstation,4=Enterprise Server, 7=Performance Server */ + /* 3 = Workstation, 4 = Enterprise Server, 7 = Performance Server */ fadt->preferred_pm_profile = 0x03; fadt->sci_int = 9; /* disable system management mode by setting to 0: */ @@ -86,11 +86,11 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) pm_iowrite(0x2C, ACPI_PMA_CNT_BLK & 0xFF); pm_iowrite(0x2D, ACPI_PMA_CNT_BLK >> 8);
- pm_iowrite(0x0E, 1<<3 | 0<<2); /* AcpiDecodeEnable, When set, SB uses + pm_iowrite(0x0E, 1 << 3 | 0 << 2); /* AcpiDecodeEnable, When set, SB uses * the contents of the PM registers at * index 20-2B to decode ACPI I/O address. * AcpiSmiEn & SmiCmdEn*/ - pm_iowrite(0x10, 1<<1 | 1<<3| 1<<5); /* RTC_En_En, TMR_En_En, GBL_EN_EN */ + pm_iowrite(0x10, 1 << 1 | 1 << 3| 1 << 5); /* RTC_En_En, TMR_En_En, GBL_EN_EN */ outl(0x1, ACPI_PM1_CNT_BLK); /* set SCI_EN */
fadt->pm1a_evt_blk = ACPI_PM_EVT_BLK; diff --git a/src/mainboard/siemens/sitemp_g1p1/mainboard.c b/src/mainboard/siemens/sitemp_g1p1/mainboard.c index 41811e4..8c65972 100644 --- a/src/mainboard/siemens/sitemp_g1p1/mainboard.c +++ b/src/mainboard/siemens/sitemp_g1p1/mainboard.c @@ -657,7 +657,7 @@ static void update_subsystemid( device_t dev ) dev->subsystem_device = 0x4077; // U1P0 = 0x4077 } printk(BIOS_INFO, "%s [%x/%x]\n", dev_name(dev), dev->subsystem_vendor, dev->subsystem_device ); - for( i=0; slot[i].bus < 255; i++) { + for( i = 0; slot[i].bus < 255; i++) { device_t d; d = dev_find_slot(slot[i].bus,slot[i].devfn); if( d ) { diff --git a/src/mainboard/siemens/sitemp_g1p1/romstage.c b/src/mainboard/siemens/sitemp_g1p1/romstage.c index 634f974..a7f2c96 100644 --- a/src/mainboard/siemens/sitemp_g1p1/romstage.c +++ b/src/mainboard/siemens/sitemp_g1p1/romstage.c @@ -141,7 +141,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) if( (cpuid1.edx & 0x6) == 0x6 ) {
/* Read FIDVID_STATUS */ - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); __DEBUG__("begin msr fid, vid: hi=0x%x, lo=0x%x\n", msr.hi, msr.lo);
enable_fid_change(); @@ -149,7 +149,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) init_fidvid_bsp(bsp_apicid);
/* show final fid and vid */ - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); __DEBUG__("end msr fid, vid: hi=0x%x, lo=0x%x\n", msr.hi, msr.lo);
} else { diff --git a/src/mainboard/sunw/ultra40/mptable.c b/src/mainboard/sunw/ultra40/mptable.c index eeae519..d4fdfc1 100644 --- a/src/mainboard/sunw/ultra40/mptable.c +++ b/src/mainboard/sunw/ultra40/mptable.c @@ -139,50 +139,50 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn +0x0a)<<2)|0, apicid_ck804, 0x15); // 21
//Slot 1 PCIE x16 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_5, (0x00<<2)|i, apicid_ck804, 0x10 + (2+i+4-sbdn%4)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_5, (0x00 << 2)|i, apicid_ck804, 0x10 + (2+i+4-sbdn%4)%4); }
//Onboard Firewire - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_1, (0x05<<2)|0, apicid_ck804, 0x13); // 19 + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_1, (0x05 << 2)|0, apicid_ck804, 0x13); // 19
//Slot 2 PCI 32 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_1, (0x04<<2)|i, apicid_ck804, 0x10 + (0+i)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_1, (0x04 << 2)|i, apicid_ck804, 0x10 + (0+i)%4); }
if(pci1234[2] & 0xf) { //Onboard ck804b NIC - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804b_0, ((sbdnb+0x0a)<<2)|0, apicid_ck804b, 0x15);//24+4+4+21=53 + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804b_0, ((sbdnb+0x0a)<<2)|0, apicid_ck804b, 0x15);//24+4+4+21 = 53
//Slot 3 PCIE x16 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804b_5, (0x00<<2)|i, apicid_ck804b, 0x10 + (2+i+4-sbdnb%4)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804b_5, (0x00 << 2)|i, apicid_ck804b, 0x10 + (2+i+4-sbdnb%4)%4); } }
//Channel B of 8131
//Slot 4 PCI-X 100/66 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (4<<2)|i, apicid_8131_2, (0+i)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (4 << 2)|i, apicid_8131_2, (0+i)%4); }
//Slot 5 PCIX 100/66 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (9<<2)|i, apicid_8131_2, (1+i)%4); // 29 + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (9 << 2)|i, apicid_8131_2, (1+i)%4); // 29 }
//OnBoard LSI SCSI - for(i=0;i<2;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (6<<2)|i, apicid_8131_2, (2+i)%4); //30 + for(i = 0; i < 2; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_2, (6 << 2)|i, apicid_8131_2, (2+i)%4); //30 }
//Channel A of 8131
//Slot 6 PCIX 133/100/66 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (4<<2)|i, apicid_8131_1, (0+i)%4); //24 + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_8131_1, (4 << 2)|i, apicid_8131_1, (0+i)%4); //24 }
/*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN#*/ diff --git a/src/mainboard/sunw/ultra40/romstage.c b/src/mainboard/sunw/ultra40/romstage.c index ecb7fe7..d0f569c 100644 --- a/src/mainboard/sunw/ultra40/romstage.c +++ b/src/mainboard/sunw/ultra40/romstage.c @@ -33,9 +33,9 @@ static void sio_gpio_setup(void) unsigned value;
/*Enable onboard scsi*/ - lpc47b397_gpio_offset_out(SUPERIO_GPIO_IO_BASE, 0x2c, (1<<7)|(0<<2)|(0<<1)|(0<<0)); // GP21, offset 0x2c, DISABLE_SCSI_L + lpc47b397_gpio_offset_out(SUPERIO_GPIO_IO_BASE, 0x2c, (1 << 7)|(0 << 2)|(0 << 1)|(0 << 0)); // GP21, offset 0x2c, DISABLE_SCSI_L value = lpc47b397_gpio_offset_in(SUPERIO_GPIO_IO_BASE, 0x4c); - lpc47b397_gpio_offset_out(SUPERIO_GPIO_IO_BASE, 0x4c, (value|(1<<1))); + lpc47b397_gpio_offset_out(SUPERIO_GPIO_IO_BASE, 0x4c, (value|(1 << 1))); } #endif
@@ -55,12 +55,12 @@ static inline int spd_read_byte(unsigned device, unsigned address)
//set GPIO to input mode #define CK804_MB_SETUP \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+ 5, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* M9,GPIO6, PCIXB2_PRSNT1_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+15, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* M8,GPIO16, PCIXB2_PRSNT2_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+44, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* P5,GPIO45, PCIXA_PRSNT1_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+ 7, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* M5,GPIO8, PCIXA_PRSNT2_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+16, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* K4,GPIO17, PCIXB_PRSNT1_L*/ \ - RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+45, ~(0xff),((0<<4)|(0<<2)|(0<<0)),/* P7,GPIO46, PCIXB_PRSNT2_L*/ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+ 5, ~(0xff),((0 << 4)|(0 << 2)|(0 << 0)),/* M9,GPIO6, PCIXB2_PRSNT1_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+15, ~(0xff),((0 << 4)|(0 << 2)|(0 << 0)),/* M8,GPIO16, PCIXB2_PRSNT2_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+44, ~(0xff),((0 << 4)|(0 << 2)|(0 << 0)),/* P5,GPIO45, PCIXA_PRSNT1_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+ 7, ~(0xff),((0 << 4)|(0 << 2)|(0 << 0)),/* M5,GPIO8, PCIXA_PRSNT2_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+16, ~(0xff),((0 << 4)|(0 << 2)|(0 << 0)),/* K4,GPIO17, PCIXB_PRSNT1_L*/ \ + RES_PORT_IO_8, SYSCTRL_IO_BASE + 0xc0+45, ~(0xff),((0 << 4)|(0 << 2)|(0 << 0)),/* P7,GPIO46, PCIXB_PRSNT2_L*/
#include "southbridge/nvidia/ck804/early_setup_car.c" #include "cpu/amd/model_fxx/init_cpus.c" @@ -79,7 +79,7 @@ static void sio_setup(void) pci_write_config8(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0x7b, byte);
dword = pci_read_config32(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0xa0); - dword |= (1<<29)|(1<<0); + dword |= (1 << 29)|(1 << 0); pci_write_config32(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0xa0, dword);
lpc47b397_enable_serial(SUPERIO_GPIO_DEV, SUPERIO_GPIO_IO_BASE); diff --git a/src/mainboard/sunw/ultra40m2/mptable.c b/src/mainboard/sunw/ultra40m2/mptable.c index 89bb9eb..0493d38 100644 --- a/src/mainboard/sunw/ultra40m2/mptable.c +++ b/src/mainboard/sunw/ultra40m2/mptable.c @@ -58,8 +58,8 @@ static void *smp_write_config_table(void *v)
dword = 0x43c6c643; diff --git a/src/mainboard/sunw/ultra40m2/romstage.c b/src/mainboard/sunw/ultra40m2/romstage.c index 7a5ce93..a7489da 100644 --- a/src/mainboard/sunw/ultra40m2/romstage.c +++ b/src/mainboard/sunw/ultra40m2/romstage.c @@ -78,11 +78,11 @@ static void sio_setup(void) pci_write_config8(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0x7b, byte);
@@ -142,7 +142,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) #if CONFIG_SET_FIDVID { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "begin msr fid, vid %08x%08x\n", msr.hi, msr.lo); } enable_fid_change(); @@ -151,7 +151,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) // show final fid and vid { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "end msr fid, vid %08x%08x\n", msr.hi, msr.lo); } #endif diff --git a/src/mainboard/supermicro/h8dme/mptable.c b/src/mainboard/supermicro/h8dme/mptable.c index bf8f0da..a76cf1b 100644 --- a/src/mainboard/supermicro/h8dme/mptable.c +++ b/src/mainboard/supermicro/h8dme/mptable.c @@ -91,25 +91,25 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_mcp55[0], ((sbdn+8)<<2)|0, apicid_mcp55, 0x16); // 22 smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_mcp55[0], ((sbdn+9)<<2)|0, apicid_mcp55, 0x15); // 21
- for(j=7; j>=2; j--) { + for(j = 7; j >= 2; j--) { if(!bus_mcp55[j]) continue; - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_mcp55[j], (0x00<<2)|i, apicid_mcp55, 0x10 + (2+j+i+4-sbdn%4)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_mcp55[j], (0x00 << 2)|i, apicid_mcp55, 0x10 + (2+j+i+4-sbdn%4)%4); } }
- for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_mcp55[1], (0x04<<2)|i, apicid_mcp55, 0x10 + (0+i)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_mcp55[1], (0x04 << 2)|i, apicid_mcp55, 0x10 + (0+i)%4); }
if(bus_pcix[0]) { - for(i=0;i<2;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pcix[2], (4<<2)|i, apicid_mcp55, 0x10 + (0+i+4-sbdn%4)%4); //16, 17 + for(i = 0; i < 2; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pcix[2], (4 << 2)|i, apicid_mcp55, 0x10 + (0+i+4-sbdn%4)%4); //16, 17 }
- for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pcix[1], (4<<2)|i, apicid_mcp55, 0x10 + (2+i+4-sbdn%4)%4); // 18, 19, 16, 17 + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_pcix[1], (4 << 2)|i, apicid_mcp55, 0x10 + (2+i+4-sbdn%4)%4); // 18, 19, 16, 17 } }
diff --git a/src/mainboard/supermicro/h8dme/romstage.c b/src/mainboard/supermicro/h8dme/romstage.c index aeff991..d85ae5b 100644 --- a/src/mainboard/supermicro/h8dme/romstage.c +++ b/src/mainboard/supermicro/h8dme/romstage.c @@ -77,7 +77,7 @@ static void sio_setup(void) uint8_t byte;
enable_smbus(); -// smbusx_write_byte(1, (0x58>>1), 0, 0x80); /* select bank0 */ +// smbusx_write_byte(1, (0x58 >> 1), 0, 0x80); /* select bank0 */ smbusx_write_byte(1, (0x58 >> 1), 0xb1, 0xff); /* set FAN ctrl to DC mode */
byte = pci_read_config8(PCI_DEV(0, MCP55_DEVN_BASE + 1, 0), 0x7b); @@ -94,8 +94,8 @@ static void sio_setup(void) }
/* We have no idea where the SMBUS switch is. This doesn't do anything ATM. */ -#define RC0 (2<<8) -#define RC1 (1<<8) +#define RC0 (2 << 8) +#define RC1 (1 << 8)
void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) { diff --git a/src/mainboard/supermicro/h8dmr/mptable.c b/src/mainboard/supermicro/h8dmr/mptable.c index eda7dc6..7ca1091 100644 --- a/src/mainboard/supermicro/h8dmr/mptable.c +++ b/src/mainboard/supermicro/h8dmr/mptable.c @@ -92,25 +92,25 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_mcp55[0], ((sbdn+8)<<2)|0, apicid_mcp55, 0x16); // 22 smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_mcp55[0], ((sbdn+9)<<2)|0, apicid_mcp55, 0x15); // 21
diff --git a/src/mainboard/supermicro/h8dmr/romstage.c b/src/mainboard/supermicro/h8dmr/romstage.c index eb73817..b137b6b 100644 --- a/src/mainboard/supermicro/h8dmr/romstage.c +++ b/src/mainboard/supermicro/h8dmr/romstage.c @@ -69,19 +69,19 @@ static void sio_setup(void) uint8_t byte;
enable_smbus(); -// smbusx_write_byte(1, (0x58>>1), 0, 0x80); /* select bank0 */ - smbusx_write_byte(1, (0x58>>1), 0xb1, 0xff); /* set FAN ctrl to DC mode */ +// smbusx_write_byte(1, (0x58 >> 1), 0, 0x80); /* select bank0 */ + smbusx_write_byte(1, (0x58 >> 1), 0xb1, 0xff); /* set FAN ctrl to DC mode */
byte = pci_read_config8(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0x7b); byte |= 0x20; pci_write_config8(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0x7b, byte);
@@ -144,7 +144,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) #if CONFIG_SET_FIDVID { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "begin msr fid, vid %08x, %08x\n", msr.hi, msr.lo); } enable_fid_change(); @@ -153,7 +153,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) // show final fid and vid { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "end msr fid, vid %08x, %08x\n", msr.hi, msr.lo); } #endif diff --git a/src/mainboard/supermicro/h8dmr_fam10/get_bus_conf.c b/src/mainboard/supermicro/h8dmr_fam10/get_bus_conf.c index 6739105..8a0a6ec 100644 --- a/src/mainboard/supermicro/h8dmr_fam10/get_bus_conf.c +++ b/src/mainboard/supermicro/h8dmr_fam10/get_bus_conf.c @@ -69,7 +69,7 @@ void get_bus_conf(void) device_t dev; int i;
@@ -79,7 +79,7 @@ void get_bus_conf(void) memset(m, 0, sizeof(struct mb_sysconf_t));
sysconf.hc_possible_num = ARRAY_SIZE(pci1234x); - for(i=0;i<sysconf.hc_possible_num; i++) { + for(i = 0; i < sysconf.hc_possible_num; i++) { sysconf.pci1234[i] = pci1234x[i]; sysconf.hcdn[i] = hcdnx[i]; } @@ -98,7 +98,7 @@ void get_bus_conf(void) printk(BIOS_DEBUG, "ERROR - could not find PCI 1:%02x.0, using defaults\n", sysconf.sbdn + 0x06); }
- for(i=2; i<8;i++) { + for(i = 2; i < 8; i++) { dev = dev_find_slot(m->bus_mcp55[0], PCI_DEVFN(sysconf.sbdn + 0x0a + i - 2 , 0)); if (dev) { m->bus_mcp55[i] = pci_read_config8(dev, PCI_SECONDARY_BUS); diff --git a/src/mainboard/supermicro/h8dmr_fam10/mptable.c b/src/mainboard/supermicro/h8dmr_fam10/mptable.c index e1ca607..631ff7d 100644 --- a/src/mainboard/supermicro/h8dmr_fam10/mptable.c +++ b/src/mainboard/supermicro/h8dmr_fam10/mptable.c @@ -88,15 +88,15 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+8)<<2)|0, m->apicid_mcp55, 0x16); // 22 smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+9)<<2)|0, m->apicid_mcp55, 0x15); // 21
diff --git a/src/mainboard/supermicro/h8dmr_fam10/romstage.c b/src/mainboard/supermicro/h8dmr_fam10/romstage.c index 7be3209..7766f3a 100644 --- a/src/mainboard/supermicro/h8dmr_fam10/romstage.c +++ b/src/mainboard/supermicro/h8dmr_fam10/romstage.c @@ -71,7 +71,7 @@ static void sio_setup(void) uint8_t byte;
enable_smbus(); - // smbusx_write_byte(1, (0x58>>1), 0, 0x80); /* select bank0 */ + // smbusx_write_byte(1, (0x58 >> 1), 0, 0x80); /* select bank0 */ /* set FAN ctrl to DC mode */ smbusx_write_byte(1, (0x58 >> 1), 0xb1, 0xff);
diff --git a/src/mainboard/supermicro/h8qgi/BiosCallOuts.c b/src/mainboard/supermicro/h8qgi/BiosCallOuts.c index c568334..ac978a1 100644 --- a/src/mainboard/supermicro/h8qgi/BiosCallOuts.c +++ b/src/mainboard/supermicro/h8qgi/BiosCallOuts.c @@ -53,7 +53,7 @@ static UINT8 select_socket(UINT8 socket_id) gpio56_to_53 = pci_read_config8(sm_dev, PCI_REG_GPIO_56_to_53_CNTRL); value = gpio56_to_53 & (~GPIO_OUT_BIT_GPIO54_to_53_MASK); value |= socket_id; - value &= (~GPIO_OUT_ENABLE_BIT_GPIO54_to_53_MASK); // 0=Output Enabled, 1=Tristate + value &= (~GPIO_OUT_ENABLE_BIT_GPIO54_to_53_MASK); // 0 = Output Enabled, 1 = Tristate pci_write_config8(sm_dev, PCI_REG_GPIO_56_to_53_CNTRL, value);
return gpio56_to_53; diff --git a/src/mainboard/supermicro/h8qgi/fadt.c b/src/mainboard/supermicro/h8qgi/fadt.c index f4fe61e..ae6991f 100644 --- a/src/mainboard/supermicro/h8qgi/fadt.c +++ b/src/mainboard/supermicro/h8qgi/fadt.c @@ -55,7 +55,7 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) else fadt->dsdt = (uintptr_t)dsdt;
- /* 3=Workstation,4=Enterprise Server, 7=Performance Server */ + /* 3 = Workstation, 4 = Enterprise Server, 7 = Performance Server */ fadt->preferred_pm_profile = 0x03; fadt->sci_int = 9; /* disable system management mode by setting to 0: */ diff --git a/src/mainboard/supermicro/h8qgi/mptable.c b/src/mainboard/supermicro/h8qgi/mptable.c index 68af428..7af085d 100644 --- a/src/mainboard/supermicro/h8qgi/mptable.c +++ b/src/mainboard/supermicro/h8qgi/mptable.c @@ -70,7 +70,7 @@ static void *smp_write_config_table(void *v) dword = pci_read_config32(dev, 0xAC); dword = dword & ~(7 << 26); dword = dword | (6 << 26); /* 0: INTA, ...., 7: INTH */ - /* dword |= 1<<22; PIC and APIC co exists */ + /* dword |= 1 << 22; PIC and APIC co exists */ pci_write_config32(dev, 0xAC, dword); #endif
diff --git a/src/mainboard/supermicro/h8qme_fam10/get_bus_conf.c b/src/mainboard/supermicro/h8qme_fam10/get_bus_conf.c index 5a7157b..813fa77 100644 --- a/src/mainboard/supermicro/h8qme_fam10/get_bus_conf.c +++ b/src/mainboard/supermicro/h8qme_fam10/get_bus_conf.c @@ -71,7 +71,7 @@ void get_bus_conf(void) device_t dev; int i;
@@ -81,7 +81,7 @@ void get_bus_conf(void) memset(m, 0, sizeof(struct mb_sysconf_t));
sysconf.hc_possible_num = ARRAY_SIZE(pci1234x); - for(i=0;i<sysconf.hc_possible_num; i++) { + for(i = 0; i < sysconf.hc_possible_num; i++) { sysconf.pci1234[i] = pci1234x[i]; sysconf.hcdn[i] = hcdnx[i]; } @@ -104,7 +104,7 @@ void get_bus_conf(void) printk(BIOS_DEBUG, "ERROR - could not find PCI 1:%02x.0, using defaults\n", sysconf.sbdn + 0x06); }
- for(i=2; i<8;i++) { + for(i = 2; i < 8; i++) { dev = dev_find_slot(m->bus_mcp55[0], PCI_DEVFN(sysconf.sbdn + 0x0a + i - 2 , 0)); if (dev) { m->bus_mcp55[i] = pci_read_config8(dev, PCI_SECONDARY_BUS); diff --git a/src/mainboard/supermicro/h8qme_fam10/mptable.c b/src/mainboard/supermicro/h8qme_fam10/mptable.c index e4dd3a8..9a60194 100644 --- a/src/mainboard/supermicro/h8qme_fam10/mptable.c +++ b/src/mainboard/supermicro/h8qme_fam10/mptable.c @@ -86,15 +86,15 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_8132_2, ((3)<<2)|0, m->apicid_mcp55, 0x5); /* 5 eth0, OK*/ smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_8132_2, ((3)<<2)|1, m->apicid_mcp55, 0xb); /* 11 eth1, OK*/
- for(j=7;j>=2; j--) { + for(j = 7;j >= 2; j--) { if(!m->bus_mcp55[j]) continue; - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[j], (0x00<<2)|i, m->apicid_mcp55, 0x10 + (2+j+i+4-sbdn%4)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[j], (0x00 << 2)|i, m->apicid_mcp55, 0x10 + (2+j+i+4-sbdn%4)%4); } }
diff --git a/src/mainboard/supermicro/h8qme_fam10/romstage.c b/src/mainboard/supermicro/h8qme_fam10/romstage.c index 4661f45..f82ddd1 100644 --- a/src/mainboard/supermicro/h8qme_fam10/romstage.c +++ b/src/mainboard/supermicro/h8qme_fam10/romstage.c @@ -77,19 +77,19 @@ static void sio_setup(void) uint32_t dword; uint8_t byte; enable_smbus(); -// smbusx_write_byte(1, (0x58>>1), 0, 0x80); /* select bank0 */ - smbusx_write_byte(1, (0x58>>1), 0xb1, 0xff); /* set FAN ctrl to DC mode */ +// smbusx_write_byte(1, (0x58 >> 1), 0, 0x80); /* select bank0 */ + smbusx_write_byte(1, (0x58 >> 1), 0xb1, 0xff); /* set FAN ctrl to DC mode */
@@ -260,7 +260,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) post_code(0x3A);
diff --git a/src/mainboard/supermicro/h8scm/fadt.c b/src/mainboard/supermicro/h8scm/fadt.c index 330dc54..fda488f 100644 --- a/src/mainboard/supermicro/h8scm/fadt.c +++ b/src/mainboard/supermicro/h8scm/fadt.c @@ -55,7 +55,7 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) else fadt->dsdt = (uintptr_t)dsdt;
- /* 3=Workstation,4=Enterprise Server, 7=Performance Server */ + /* 3 = Workstation, 4 = Enterprise Server, 7 = Performance Server */ fadt->preferred_pm_profile = 0x03; fadt->sci_int = 9; /* disable system management mode by setting to 0: */ diff --git a/src/mainboard/supermicro/h8scm/mptable.c b/src/mainboard/supermicro/h8scm/mptable.c index 5b809c3..5ef7f3d 100644 --- a/src/mainboard/supermicro/h8scm/mptable.c +++ b/src/mainboard/supermicro/h8scm/mptable.c @@ -70,7 +70,7 @@ static void *smp_write_config_table(void *v) dword = (u32 *)pci_read_config32(dev, 0xAC); dword = dword & ~(7 << 26); dword = dword | (6 << 26); /* 0: INTA, ...., 7: INTH */ - /* dword |= 1<<22; PIC and APIC co exists */ + /* dword |= 1 << 22; PIC and APIC co exists */ pci_write_config32(dev, 0xAC, dword); #endif
diff --git a/src/mainboard/supermicro/h8scm_fam10/acpi_tables.c b/src/mainboard/supermicro/h8scm_fam10/acpi_tables.c index 08910cc..b50410a 100644 --- a/src/mainboard/supermicro/h8scm_fam10/acpi_tables.c +++ b/src/mainboard/supermicro/h8scm_fam10/acpi_tables.c @@ -29,7 +29,7 @@ unsigned long acpi_fill_madt(unsigned long current) { device_t dev; u32 dword; - u32 gsi_base=0; + u32 gsi_base = 0; /* create all subtables for processors */ current = acpi_create_madt_lapics(current);
diff --git a/src/mainboard/supermicro/h8scm_fam10/mptable.c b/src/mainboard/supermicro/h8scm_fam10/mptable.c index 9ae9476..75a4544 100644 --- a/src/mainboard/supermicro/h8scm_fam10/mptable.c +++ b/src/mainboard/supermicro/h8scm_fam10/mptable.c @@ -72,7 +72,7 @@ static void *smp_write_config_table(void *v) dword = (u32 *)((pci_read_config32(dev, 0xac) & ~(7 << 26)) | (6 << 26));
- /* dword |= 1<<22; PIC and APIC co exists */ + /* dword |= 1 << 22; PIC and APIC co exists */ pci_write_config32(dev, 0xac, (u32)dword);
/* diff --git a/src/mainboard/supermicro/h8scm_fam10/romstage.c b/src/mainboard/supermicro/h8scm_fam10/romstage.c index 7312683..f2c79b4 100644 --- a/src/mainboard/supermicro/h8scm_fam10/romstage.c +++ b/src/mainboard/supermicro/h8scm_fam10/romstage.c @@ -188,7 +188,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) post_code(0x3A);
diff --git a/src/mainboard/technexion/tim5690/fadt.c b/src/mainboard/technexion/tim5690/fadt.c index f9768b2..b397f52 100644 --- a/src/mainboard/technexion/tim5690/fadt.c +++ b/src/mainboard/technexion/tim5690/fadt.c @@ -56,7 +56,7 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt)
fadt->firmware_ctrl = (u32) facs; fadt->dsdt = (u32) dsdt; - /* 3=Workstation,4=Enterprise Server, 7=Performance Server */ + /* 3 = Workstation, 4 = Enterprise Server, 7 = Performance Server */ fadt->preferred_pm_profile = 0x03; fadt->sci_int = 9; /* disable system management mode by setting to 0: */ @@ -85,11 +85,11 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) pm_iowrite(0x2C, ACPI_PMA_CNT_BLK & 0xFF); pm_iowrite(0x2D, ACPI_PMA_CNT_BLK >> 8);
fadt->pm1a_evt_blk = ACPI_PM_EVT_BLK; diff --git a/src/mainboard/technexion/tim5690/mptable.c b/src/mainboard/technexion/tim5690/mptable.c index 39192b0..8895163 100644 --- a/src/mainboard/technexion/tim5690/mptable.c +++ b/src/mainboard/technexion/tim5690/mptable.c @@ -69,7 +69,7 @@ static void *smp_write_config_table(void *v) dword = pci_read_config32(dev, 0xac); dword &= ~(7 << 26); dword |= 6 << 26; /* 0: INTA, ...., 7: INTH */ - /* dword |= 1<<22; PIC and APIC co exists */ + /* dword |= 1 << 22; PIC and APIC co exists */ pci_write_config32(dev, 0xac, dword);
/* diff --git a/src/mainboard/technexion/tim5690/romstage.c b/src/mainboard/technexion/tim5690/romstage.c index b94b06c..e534617 100644 --- a/src/mainboard/technexion/tim5690/romstage.c +++ b/src/mainboard/technexion/tim5690/romstage.c @@ -116,7 +116,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cpuid1 = cpuid(0x80000007); if ((cpuid1.edx & 0x6) == 0x6) { /* Read FIDVID_STATUS */ - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "begin msr fid, vid: hi=0x%x, lo=0x%x\n", msr.hi, msr.lo);
enable_fid_change(); @@ -124,7 +124,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) init_fidvid_bsp(bsp_apicid);
/* show final fid and vid */ - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "end msr fid, vid: hi=0x%x, lo=0x%x\n", msr.hi, msr.lo); } else { printk(BIOS_DEBUG, "Changing FIDVID not supported\n"); diff --git a/src/mainboard/technexion/tim5690/tn_post_code.c b/src/mainboard/technexion/tim5690/tn_post_code.c index 1fa4935..213034a 100644 --- a/src/mainboard/technexion/tim5690/tn_post_code.c +++ b/src/mainboard/technexion/tim5690/tn_post_code.c @@ -36,7 +36,7 @@ void technexion_post_code_init(void) { uint8_t reg8_data; - device_t dev=0; + device_t dev = 0;
// SMBus Module and ACPI Block (Device 20, Function 0) dev = pci_locate_device(PCI_ID(PCI_VENDOR_ID_ATI, PCI_DEVICE_ID_ATI_SB600_SM), 0); @@ -44,80 +44,80 @@ void technexion_post_code_init(void) // LED[bit0]:GPIO0 // This is reference SB600 RRG 4.1.1 GPIO reg8_data = pmio_read(0x60); - reg8_data |= (1<<7); // 1: GPIO if not used by SATA + reg8_data |= (1 << 7); // 1: GPIO if not used by SATA pmio_write(0x60, reg8_data);
reg8_data = pci_read_config8(dev, 0x80); - reg8_data = ((reg8_data | (1<<0)) & ~(1<<4)); + reg8_data = ((reg8_data | (1 << 0)) & ~(1 << 4)); pci_write_config8(dev, 0x80, reg8_data);
// LED[bit1]:GPIO1 // This is reference SB600 RRG 4.1.1 GPIO reg8_data = pci_read_config8(dev, 0x80); - reg8_data = ((reg8_data | (1<<1)) & ~(1<<5)); + reg8_data = ((reg8_data | (1 << 1)) & ~(1 << 5)); pci_write_config8(dev, 0x80, reg8_data);
// LED[bit2]:GPIO4 // This is reference SB600 RRG 4.1.1 GPIO reg8_data = pmio_read(0x5e); - reg8_data &= ~(1<<7); // 0: GPIO if not used by SATA + reg8_data &= ~(1 << 7); // 0: GPIO if not used by SATA pmio_write(0x5e, reg8_data);
reg8_data = pci_read_config8(dev, 0xa8); - reg8_data |= (1<<0); + reg8_data |= (1 << 0); pci_write_config8(dev, 0xa8, reg8_data);
reg8_data = pci_read_config8(dev, 0xa9); - reg8_data &= ~(1<<0); + reg8_data &= ~(1 << 0); pci_write_config8(dev, 0xa9, reg8_data);
// LED[bit3]:GPIO6 // This is reference SB600 RRG 4.1.1 GPIO reg8_data = pmio_read(0x60); - reg8_data |= (1<<7); // 1: GPIO if not used by SATA + reg8_data |= (1 << 7); // 1: GPIO if not used by SATA pmio_write(0x60, reg8_data);
reg8_data = pci_read_config8(dev, 0xa8); - reg8_data |= (1<<2); + reg8_data |= (1 << 2); pci_write_config8(dev, 0xa8, reg8_data);
reg8_data = pci_read_config8(dev, 0xa9); - reg8_data &= ~(1<<2); + reg8_data &= ~(1 << 2); pci_write_config8(dev, 0xa9, reg8_data); // LED[bit4]:GPIO7 // This is reference SB600 RRG 4.1.1 GPIO reg8_data = pci_read_config8(dev, 0xa8); - reg8_data |= (1<<3); + reg8_data |= (1 << 3); pci_write_config8(dev, 0xa8, reg8_data);
reg8_data = pci_read_config8(dev, 0xa9); - reg8_data &= ~(1<<3); + reg8_data &= ~(1 << 3); pci_write_config8(dev, 0xa9, reg8_data);
// LED[bit5]:GPIO8 // This is reference SB600 RRG 4.1.1 GPIO reg8_data = pci_read_config8(dev, 0xa8); - reg8_data |= (1<<4); + reg8_data |= (1 << 4); pci_write_config8(dev, 0xa8, reg8_data);
reg8_data = pci_read_config8(dev, 0xa9); - reg8_data &= ~(1<<4); + reg8_data &= ~(1 << 4); pci_write_config8(dev, 0xa9, reg8_data);
// LED[bit6]:GPIO10 // This is reference SB600 RRG 4.1.1 GPIO reg8_data = pci_read_config8(dev, 0xab); - reg8_data = ((reg8_data | (1<<0)) & ~(1<<1)); + reg8_data = ((reg8_data | (1 << 0)) & ~(1 << 1)); pci_write_config8(dev, 0xab, reg8_data);
// LED[bit7]:GPIO66 // This is reference SB600 RRG 4.1.1 GPIO reg8_data = pmio_read(0x68); - reg8_data &= ~(1<<5); // 0: GPIO + reg8_data &= ~(1 << 5); // 0: GPIO pmio_write(0x68, reg8_data);
reg8_data = pci_read_config8(dev, 0x7e); - reg8_data = ((reg8_data | (1<<1)) & ~(1<<5)); + reg8_data = ((reg8_data | (1 << 1)) & ~(1 << 5)); pci_write_config8(dev, 0x7e, reg8_data);
} @@ -129,7 +129,7 @@ void technexion_post_code_init(void) void technexion_post_code(uint8_t udata8) { uint8_t u8_data; - device_t dev=0; + device_t dev = 0;
// SMBus Module and ACPI Block (Device 20, Function 0) #ifdef __PRE_RAM__ @@ -143,80 +143,80 @@ void technexion_post_code(uint8_t udata8) // LED[bit0]:GPIO0 u8_data = pci_read_config8(dev, 0x80); if (udata8 & 0x1) { - u8_data |= (1<<0); + u8_data |= (1 << 0); } else { - u8_data &= ~(1<<0); + u8_data &= ~(1 << 0); } pci_write_config8(dev, 0x80, u8_data);
// LED[bit1]:GPIO1 u8_data = pci_read_config8(dev, 0x80); if (udata8 & 0x2) { - u8_data |= (1<<1); + u8_data |= (1 << 1); } else { - u8_data &= ~(1<<1); + u8_data &= ~(1 << 1); } pci_write_config8(dev, 0x80, u8_data);
// LED[bit2]:GPIO4 u8_data = pci_read_config8(dev, 0xa8); if (udata8 & 0x4) { - u8_data |= (1<<0); + u8_data |= (1 << 0); } else { - u8_data &= ~(1<<0); + u8_data &= ~(1 << 0); } pci_write_config8(dev, 0xa8, u8_data);
// LED[bit3]:GPIO6 u8_data = pci_read_config8(dev, 0xa8); if (udata8 & 0x8) { - u8_data |= (1<<2); + u8_data |= (1 << 2); } else { - u8_data &= ~(1<<2); + u8_data &= ~(1 << 2); } pci_write_config8(dev, 0xa8, u8_data);
// LED[bit4]:GPIO7 u8_data = pci_read_config8(dev, 0xa8); if (udata8 & 0x10) { - u8_data |= (1<<3); + u8_data |= (1 << 3); } else { - u8_data &= ~(1<<3); + u8_data &= ~(1 << 3); } pci_write_config8(dev, 0xa8, u8_data);
// LED[bit5]:GPIO8 u8_data = pci_read_config8(dev, 0xa8); if (udata8 & 0x20) { - u8_data |= (1<<4); + u8_data |= (1 << 4); } else { - u8_data &= ~(1<<4); + u8_data &= ~(1 << 4); } pci_write_config8(dev, 0xa8, u8_data);
// LED[bit6]:GPIO10 u8_data = pci_read_config8(dev, 0xab); if (udata8 & 0x40) { - u8_data |= (1<<0); + u8_data |= (1 << 0); } else { - u8_data &= ~(1<<0); + u8_data &= ~(1 << 0); } pci_write_config8(dev, 0xab, u8_data);
// LED[bit7]:GPIO66 u8_data = pci_read_config8(dev, 0x7e); if (udata8 & 0x80) { - u8_data |= (1<<1); + u8_data |= (1 << 1); } else { - u8_data &= ~(1<<1); + u8_data &= ~(1 << 1); } pci_write_config8(dev, 0x7e, u8_data);
diff --git a/src/mainboard/technexion/tim8690/mainboard.c b/src/mainboard/technexion/tim8690/mainboard.c index 939becf..9e1c58d 100644 --- a/src/mainboard/technexion/tim8690/mainboard.c +++ b/src/mainboard/technexion/tim8690/mainboard.c @@ -59,7 +59,7 @@ static void enable_onboard_nic(void) byte |= ( 1 << 7); pci_write_config8(sm_dev, 0x9a, byte);
- byte=pm_ioread(0x59); + byte = pm_ioread(0x59); byte &= ~( 1<< 5); pm_iowrite(0x59,byte);
diff --git a/src/mainboard/technexion/tim8690/mptable.c b/src/mainboard/technexion/tim8690/mptable.c index 39192b0..8895163 100644 --- a/src/mainboard/technexion/tim8690/mptable.c +++ b/src/mainboard/technexion/tim8690/mptable.c @@ -69,7 +69,7 @@ static void *smp_write_config_table(void *v) dword = pci_read_config32(dev, 0xac); dword &= ~(7 << 26); dword |= 6 << 26; /* 0: INTA, ...., 7: INTH */ - /* dword |= 1<<22; PIC and APIC co exists */ + /* dword |= 1 << 22; PIC and APIC co exists */ pci_write_config32(dev, 0xac, dword);
/* diff --git a/src/mainboard/technexion/tim8690/romstage.c b/src/mainboard/technexion/tim8690/romstage.c index e052d92..b1805a9 100644 --- a/src/mainboard/technexion/tim8690/romstage.c +++ b/src/mainboard/technexion/tim8690/romstage.c @@ -111,7 +111,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cpuid1 = cpuid(0x80000007); if ((cpuid1.edx & 0x6) == 0x6 ) { /* Read FIDVID_STATUS */ - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "begin msr fid, vid: hi=0x%x, lo=0x%x\n", msr.hi, msr.lo);
enable_fid_change(); @@ -119,7 +119,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) init_fidvid_bsp(bsp_apicid);
/* show final fid and vid */ - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "end msr fid, vid: hi=0x%x, lo=0x%x\n", msr.hi, msr.lo); } else { printk(BIOS_DEBUG, "Changing FIDVID not supported\n"); diff --git a/src/mainboard/thomson/ip1000/irq_tables.c b/src/mainboard/thomson/ip1000/irq_tables.c index e8ef598..e99adfc 100644 --- a/src/mainboard/thomson/ip1000/irq_tables.c +++ b/src/mainboard/thomson/ip1000/irq_tables.c @@ -21,7 +21,7 @@ static const struct irq_routing_table intel_irq_routing_table = { PIRQ_VERSION, /* u16 version */ 32+16*CONFIG_IRQ_SLOT_COUNT, /* there can be total CONFIG_IRQ_SLOT_COUNT devices on the bus */ 0x00, /* Where the interrupt router lies (bus) */ - (0x1f<<3)|0x0, /* Where the interrupt router lies (dev) */ + (0x1f << 3)|0x0, /* Where the interrupt router lies (dev) */ 0, /* IRQs devoted exclusively to PCI usage */ 0x8086, /* Vendor */ 0x24c0, /* Device */ @@ -29,14 +29,14 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0x07, /* u8 checksum , this hase to set to some value that would give 0 after the sum of all bytes for this structure (including checksum) */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x02<<3)|0x0, {{0x60, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] IGD VGA */ - {0x00,(0x1d<<3)|0x0, {{0x60, 0x0ef8}, {0x63, 0x0ef8}, {0x62, 0x0ef8}, {0x6b, 0x00ef8}}, 0x0, 0x0}, /* [A] USB1, [B] USB2, [C] USB3, [D] EHCI */ - {0x00,(0x1f<<3)|0x0, {{0x62, 0x0ef8}, {0x61, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] IDE, [B] SMBUS, [B] AUDIO, [B] MODEM */ - {0x01,(0x08<<3)|0x0, {{0x68, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] ETHERNET */ - {0x01,(0x00<<3)|0x0, {{0x60, 0x0ef8}, {0x61, 0x0ef8}, {0x62, 0x0ef8}, {0x63, 0x00ef8}}, 0x1, 0x0}, /* PCI SLOT 1 */ - {0x01,(0x01<<3)|0x0, {{0x63, 0x0ef8}, {0x60, 0x0ef8}, {0x61, 0x0ef8}, {0x62, 0x00ef8}}, 0x2, 0x0}, /* PCI SLOT 2 */ - {0x01,(0x02<<3)|0x0, {{0x62, 0x0ef8}, {0x63, 0x0ef8}, {0x60, 0x0ef8}, {0x61, 0x00ef8}}, 0x3, 0x0}, /* PCI SLOT 3 */ + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x02 << 3)|0x0, {{0x60, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] IGD VGA */ + {0x00,(0x1d << 3)|0x0, {{0x60, 0x0ef8}, {0x63, 0x0ef8}, {0x62, 0x0ef8}, {0x6b, 0x00ef8}}, 0x0, 0x0}, /* [A] USB1, [B] USB2, [C] USB3, [D] EHCI */ + {0x00,(0x1f << 3)|0x0, {{0x62, 0x0ef8}, {0x61, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] IDE, [B] SMBUS, [B] AUDIO, [B] MODEM */ + {0x01,(0x08 << 3)|0x0, {{0x68, 0x0ef8}, {0x00, 0x0000}, {0x00, 0x0000}, {0x00, 0x00000}}, 0x0, 0x0}, /* [A] ETHERNET */ + {0x01,(0x00 << 3)|0x0, {{0x60, 0x0ef8}, {0x61, 0x0ef8}, {0x62, 0x0ef8}, {0x63, 0x00ef8}}, 0x1, 0x0}, /* PCI SLOT 1 */ + {0x01,(0x01 << 3)|0x0, {{0x63, 0x0ef8}, {0x60, 0x0ef8}, {0x61, 0x0ef8}, {0x62, 0x00ef8}}, 0x2, 0x0}, /* PCI SLOT 2 */ + {0x01,(0x02 << 3)|0x0, {{0x62, 0x0ef8}, {0x63, 0x0ef8}, {0x60, 0x0ef8}, {0x61, 0x00ef8}}, 0x3, 0x0}, /* PCI SLOT 3 */ } };
diff --git a/src/mainboard/thomson/ip1000/mainboard.c b/src/mainboard/thomson/ip1000/mainboard.c index c387ac6..bdcc1fa 100644 --- a/src/mainboard/thomson/ip1000/mainboard.c +++ b/src/mainboard/thomson/ip1000/mainboard.c @@ -67,7 +67,7 @@ static void flash_gpios(void) if ((manufacturer_id == 0x20) && ((device_id == 0x2c) || (device_id == 0x2d))) { printk(BIOS_DEBUG, "Detected ST M50FW0%c0 flash:\n", - (device_id==0x2c)?'4':'8'); + (device_id == 0x2c)?'4':'8'); u8 fgpi = read8((u8 *)0xffbc0100); printk(BIOS_DEBUG, " FGPI0 [%c] FGPI1 [%c] FGPI2 [%c] FGPI3 [%c] FGPI4 [%c]\n", (fgpi & (1 << 0)) ? 'X' : ' ', diff --git a/src/mainboard/tyan/s2912/get_bus_conf.c b/src/mainboard/tyan/s2912/get_bus_conf.c index 0bc852e..d13f737 100644 --- a/src/mainboard/tyan/s2912/get_bus_conf.c +++ b/src/mainboard/tyan/s2912/get_bus_conf.c @@ -67,7 +67,7 @@ void get_bus_conf(void) device_t dev; int i;
@@ -77,7 +77,7 @@ void get_bus_conf(void) memset(m, 0, sizeof(struct mb_sysconf_t));
sysconf.hc_possible_num = ARRAY_SIZE(pci1234x); - for(i=0;i<sysconf.hc_possible_num; i++) { + for(i = 0; i < sysconf.hc_possible_num; i++) { sysconf.pci1234[i] = pci1234x[i]; sysconf.hcdn[i] = hcdnx[i]; } @@ -96,7 +96,7 @@ void get_bus_conf(void) printk(BIOS_DEBUG, "ERROR - could not find PCI 1:%02x.0, using defaults\n", sysconf.sbdn + 0x06); }
- for(i=2; i<8;i++) { + for(i = 2; i < 8; i++) { dev = dev_find_slot(m->bus_mcp55[0], PCI_DEVFN(sysconf.sbdn + 0x0a + i - 2 , 0)); if (dev) { m->bus_mcp55[i] = pci_read_config8(dev, PCI_SECONDARY_BUS); diff --git a/src/mainboard/tyan/s2912/mptable.c b/src/mainboard/tyan/s2912/mptable.c index c878160..9b46ad6 100644 --- a/src/mainboard/tyan/s2912/mptable.c +++ b/src/mainboard/tyan/s2912/mptable.c @@ -86,15 +86,15 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+8)<<2)|0, m->apicid_mcp55, 0x16); // 22 smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+9)<<2)|0, m->apicid_mcp55, 0x15); // 21
- for(j=7; j>=2; j--) { + for(j = 7; j >= 2; j--) { if(!m->bus_mcp55[j]) continue; - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[j], (0x00<<2)|i, m->apicid_mcp55, 0x10 + (2+j+i+4-sbdn%4)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[j], (0x00 << 2)|i, m->apicid_mcp55, 0x10 + (2+j+i+4-sbdn%4)%4); } }
- for(j=0; j<1; j++) - for(i=0;i<4;i++) { + for(j = 0; j < 1; j++) + for(i = 0; i < 4; i++) { smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[1], ((0x04+j)<<2)|i, m->apicid_mcp55, 0x10 + (2+i+j)%4); }
diff --git a/src/mainboard/tyan/s2912/romstage.c b/src/mainboard/tyan/s2912/romstage.c index c80e2d6..8c01272 100644 --- a/src/mainboard/tyan/s2912/romstage.c +++ b/src/mainboard/tyan/s2912/romstage.c @@ -82,11 +82,11 @@ static void sio_setup(void)
dword = pci_read_config32(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0xa0); /*serial 0 */ - dword |= (1<<0); + dword |= (1 << 0); pci_write_config32(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0xa0, dword);
@@ -147,7 +147,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) #if CONFIG_SET_FIDVID { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "begin msr fid, vid %08x%08x\n", msr.hi, msr.lo); } enable_fid_change(); @@ -156,7 +156,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) // show final fid and vid { msr_t msr; - msr=rdmsr(0xc0010042); + msr = rdmsr(0xc0010042); printk(BIOS_DEBUG, "end msr fid, vid %08x%08x\n", msr.hi, msr.lo); } #endif diff --git a/src/mainboard/tyan/s2912_fam10/get_bus_conf.c b/src/mainboard/tyan/s2912_fam10/get_bus_conf.c index 9d633a3..29ab03d 100644 --- a/src/mainboard/tyan/s2912_fam10/get_bus_conf.c +++ b/src/mainboard/tyan/s2912_fam10/get_bus_conf.c @@ -68,7 +68,7 @@ void get_bus_conf(void) device_t dev; int i;
- if(get_bus_conf_done==1) return; //do it only once + if(get_bus_conf_done == 1) return; //do it only once
get_bus_conf_done = 1;
@@ -78,7 +78,7 @@ void get_bus_conf(void) memset(m, 0, sizeof(struct mb_sysconf_t));
sysconf.hc_possible_num = ARRAY_SIZE(pci1234x); - for(i=0;i<sysconf.hc_possible_num; i++) { + for(i = 0; i < sysconf.hc_possible_num; i++) { sysconf.pci1234[i] = pci1234x[i]; sysconf.hcdn[i] = hcdnx[i]; } @@ -97,7 +97,7 @@ void get_bus_conf(void) printk(BIOS_DEBUG, "ERROR - could not find PCI 1:%02x.0, using defaults\n", sysconf.sbdn + 0x06); }
- for(i=2; i<8;i++) { + for(i = 2; i < 8; i++) { dev = dev_find_slot(m->bus_mcp55[0], PCI_DEVFN(sysconf.sbdn + 0x0a + i - 2 , 0)); if (dev) { m->bus_mcp55[i] = pci_read_config8(dev, PCI_SECONDARY_BUS); diff --git a/src/mainboard/tyan/s2912_fam10/mptable.c b/src/mainboard/tyan/s2912_fam10/mptable.c index 157b363..87d06b8 100644 --- a/src/mainboard/tyan/s2912_fam10/mptable.c +++ b/src/mainboard/tyan/s2912_fam10/mptable.c @@ -86,15 +86,15 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+8)<<2)|0, m->apicid_mcp55, 0x16); // 22 smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, m->bus_mcp55[0], ((sbdn+9)<<2)|0, m->apicid_mcp55, 0x15); // 21
diff --git a/src/mainboard/tyan/s2912_fam10/romstage.c b/src/mainboard/tyan/s2912_fam10/romstage.c index bd64cab..e095b79 100644 --- a/src/mainboard/tyan/s2912_fam10/romstage.c +++ b/src/mainboard/tyan/s2912_fam10/romstage.c @@ -84,11 +84,11 @@ static void sio_setup(void)
dword = pci_read_config32(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0xa4); - dword |= (1<<16); + dword |= (1 << 16); pci_write_config32(PCI_DEV(0, MCP55_DEVN_BASE+1 , 0), 0xa4, dword); }
@@ -195,7 +195,7 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) post_code(0x3A);
/* show final fid and vid */ - msr=rdmsr(0xc0010071); + msr = rdmsr(0xc0010071); printk(BIOS_DEBUG, "End FIDVIDMSR 0xc0010071 0x%08x 0x%08x\n", msr.hi, msr.lo); #endif
diff --git a/src/mainboard/tyan/s8226/fadt.c b/src/mainboard/tyan/s8226/fadt.c index 330dc54..fda488f 100644 --- a/src/mainboard/tyan/s8226/fadt.c +++ b/src/mainboard/tyan/s8226/fadt.c @@ -55,7 +55,7 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) else fadt->dsdt = (uintptr_t)dsdt;
- /* 3=Workstation,4=Enterprise Server, 7=Performance Server */ + /* 3 = Workstation, 4 = Enterprise Server, 7 = Performance Server */ fadt->preferred_pm_profile = 0x03; fadt->sci_int = 9; /* disable system management mode by setting to 0: */ diff --git a/src/mainboard/tyan/s8226/mptable.c b/src/mainboard/tyan/s8226/mptable.c index 68af428..7af085d 100644 --- a/src/mainboard/tyan/s8226/mptable.c +++ b/src/mainboard/tyan/s8226/mptable.c @@ -70,7 +70,7 @@ static void *smp_write_config_table(void *v) dword = pci_read_config32(dev, 0xAC); dword = dword & ~(7 << 26); dword = dword | (6 << 26); /* 0: INTA, ...., 7: INTH */ - /* dword |= 1<<22; PIC and APIC co exists */ + /* dword |= 1 << 22; PIC and APIC co exists */ pci_write_config32(dev, 0xAC, dword); #endif
diff --git a/src/mainboard/via/epia-cn/irq_tables.c b/src/mainboard/via/epia-cn/irq_tables.c index 13c7b66..ee8d488 100644 --- a/src/mainboard/via/epia-cn/irq_tables.c +++ b/src/mainboard/via/epia-cn/irq_tables.c @@ -30,16 +30,16 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0x66, /* Checksum */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x14<<3)|0x0, {{0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0xdeb8}, {0x01, 0x0deb8}}, 0x1, 0x0}, - {0x00,(0x0d<<3)|0x0, {{0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0xdeb8}, {0x01, 0x0deb8}}, 0x2, 0x0}, - {0x00,(0x0e<<3)|0x0, {{0x03, 0xdeb8}, {0x05, 0xdeb8}, {0x01, 0xdeb8}, {0x02, 0x0deb8}}, 0x3, 0x0}, - {0x00,(0x13<<3)|0x0, {{0x01, 0xdeb8}, {0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x4, 0x0}, - {0x00,(0x11<<3)|0x0, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x0, 0x0}, - {0x00,(0x0f<<3)|0x0, {{0x01, 0xdeb8}, {0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x0, 0x0}, - {0x00,(0x01<<3)|0x0, {{0x01, 0xdeb8}, {0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x0, 0x0}, - {0x00,(0x10<<3)|0x0, {{0x01, 0xdeb8}, {0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x0, 0x0}, - {0x00,(0x12<<3)|0x0, {{0x01, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0x0deb8}}, 0x0, 0x0}, + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x14 << 3)|0x0, {{0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0xdeb8}, {0x01, 0x0deb8}}, 0x1, 0x0}, + {0x00,(0x0d << 3)|0x0, {{0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0xdeb8}, {0x01, 0x0deb8}}, 0x2, 0x0}, + {0x00,(0x0e << 3)|0x0, {{0x03, 0xdeb8}, {0x05, 0xdeb8}, {0x01, 0xdeb8}, {0x02, 0x0deb8}}, 0x3, 0x0}, + {0x00,(0x13 << 3)|0x0, {{0x01, 0xdeb8}, {0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x4, 0x0}, + {0x00,(0x11 << 3)|0x0, {{0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x0, 0x0}, + {0x00,(0x0f << 3)|0x0, {{0x01, 0xdeb8}, {0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x0, 0x0}, + {0x00,(0x01 << 3)|0x0, {{0x01, 0xdeb8}, {0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x0, 0x0}, + {0x00,(0x10 << 3)|0x0, {{0x01, 0xdeb8}, {0x02, 0xdeb8}, {0x03, 0xdeb8}, {0x05, 0x0deb8}}, 0x0, 0x0}, + {0x00,(0x12 << 3)|0x0, {{0x01, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0xdeb8}, {0x00, 0x0deb8}}, 0x0, 0x0}, } };
diff --git a/src/mainboard/via/epia-cn/romstage.c b/src/mainboard/via/epia-cn/romstage.c index a28bf78..39dd3fc 100644 --- a/src/mainboard/via/epia-cn/romstage.c +++ b/src/mainboard/via/epia-cn/romstage.c @@ -46,7 +46,7 @@ static void enable_mainboard_devices(void) if (dev == PCI_DEV_INVALID) die("Southbridge not found!!!\n");
- /* bit=0 means enable function (per CX700 datasheet) + /* bit = 0 means enable function (per CX700 datasheet) * 5 16.1 USB 2 * 4 16.0 USB 1 * 3 15.0 SATA and PATA @@ -55,7 +55,7 @@ static void enable_mainboard_devices(void) */ pci_write_config8(dev, 0x50, 0x80);
- /* bit=1 means enable internal function (per CX700 datasheet) + /* bit = 1 means enable internal function (per CX700 datasheet) * 3 Internal RTC * 2 Internal PS2 Mouse * 1 Internal KBC Configuration diff --git a/src/mainboard/via/pc2500e/irq_tables.c b/src/mainboard/via/pc2500e/irq_tables.c index 53a4d79..e514df4 100644 --- a/src/mainboard/via/pc2500e/irq_tables.c +++ b/src/mainboard/via/pc2500e/irq_tables.c @@ -29,17 +29,17 @@ static const struct irq_routing_table intel_irq_routing_table = { { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }, /* u8 rfu[11] */ 0x3e, /* Checksum */ { - /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ - {0x00,(0x08<<3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x1, 0x0}, - {0x00,(0x09<<3)|0x0, {{0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0xdef8}, {0x01, 0x0def8}}, 0x2, 0x0}, - {0x00,(0x0a<<3)|0x0, {{0x03, 0xdef8}, {0x05, 0xdef8}, {0x01, 0xdef8}, {0x02, 0x0def8}}, 0x3, 0x0}, - {0x00,(0x0b<<3)|0x0, {{0x05, 0xdef8}, {0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0x0def8}}, 0x4, 0x0}, - {0x00,(0x0c<<3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x5, 0x0}, - {0x00,(0x11<<3)|0x0, {{0x00, 0xdef8}, {0x00, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x0, 0x0}, - {0x00,(0x0f<<3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x0, 0x0}, - {0x00,(0x01<<3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x0, 0x0}, - {0x00,(0x10<<3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x0, 0x0}, - {0x00,(0x12<<3)|0x0, {{0x01, 0xdef8}, {0x00, 0xdef8}, {0x00, 0xdef8}, {0x00, 0x0def8}}, 0x0, 0x0}, + /* bus, dev|fn, {link, bitmap}, {link, bitmap}, {link, bitmap}, {link, bitmap}, slot, rfu */ + {0x00,(0x08 << 3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x1, 0x0}, + {0x00,(0x09 << 3)|0x0, {{0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0xdef8}, {0x01, 0x0def8}}, 0x2, 0x0}, + {0x00,(0x0a << 3)|0x0, {{0x03, 0xdef8}, {0x05, 0xdef8}, {0x01, 0xdef8}, {0x02, 0x0def8}}, 0x3, 0x0}, + {0x00,(0x0b << 3)|0x0, {{0x05, 0xdef8}, {0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0x0def8}}, 0x4, 0x0}, + {0x00,(0x0c << 3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x5, 0x0}, + {0x00,(0x11 << 3)|0x0, {{0x00, 0xdef8}, {0x00, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x0, 0x0}, + {0x00,(0x0f << 3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x0, 0x0}, + {0x00,(0x01 << 3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x0, 0x0}, + {0x00,(0x10 << 3)|0x0, {{0x01, 0xdef8}, {0x02, 0xdef8}, {0x03, 0xdef8}, {0x05, 0x0def8}}, 0x0, 0x0}, + {0x00,(0x12 << 3)|0x0, {{0x01, 0xdef8}, {0x00, 0xdef8}, {0x00, 0xdef8}, {0x00, 0x0def8}}, 0x0, 0x0}, } };
diff --git a/src/mainboard/winent/mb6047/mptable.c b/src/mainboard/winent/mb6047/mptable.c index 1a5685f..3d9ffb5 100644 --- a/src/mainboard/winent/mb6047/mptable.c +++ b/src/mainboard/winent/mb6047/mptable.c @@ -77,17 +77,17 @@ static void *smp_write_config_table(void *v) smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_0, ((sbdn +8)<<2)|0, apicid_ck804, 0x16); // 22
//Slot PCIE x16 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_5, (0x00<<2)|i, apicid_ck804, 0x10 + (2+i+4-sbdn%4)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_5, (0x00 << 2)|i, apicid_ck804, 0x10 + (2+i+4-sbdn%4)%4); }
//Slot PCIE x4 - for(i=0;i<4;i++) { - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_4, (0x00<<2)|i, apicid_ck804, 0x10 + (1+i+4-sbdn%4)%4); + for(i = 0; i < 4; i++) { + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_4, (0x00 << 2)|i, apicid_ck804, 0x10 + (1+i+4-sbdn%4)%4); }
//Onboard SM720 VGA - smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_1, (6<<2)|0, apicid_ck804, 0x13); // 19 + smp_write_intsrc(mc, mp_INT, MP_IRQ_TRIGGER_LEVEL|MP_IRQ_POLARITY_LOW, bus_ck804_1, (6 << 2)|0, apicid_ck804, 0x13); // 19
/*Local Ints: Type Polarity Trigger Bus ID IRQ APIC ID PIN#*/ mptable_lintsrc(mc, bus_isa); diff --git a/src/mainboard/winent/mb6047/romstage.c b/src/mainboard/winent/mb6047/romstage.c index 20eb92e..3372f32 100644 --- a/src/mainboard/winent/mb6047/romstage.c +++ b/src/mainboard/winent/mb6047/romstage.c @@ -57,7 +57,7 @@ static void sio_setup(void) /* LPC Positive Decode 0 */ dword = pci_read_config32(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0xa0); /* Serial 0, Serial 1 */ - dword |= (1<<0) | (1<<1); + dword |= (1 << 0) | (1 << 1); pci_write_config32(PCI_DEV(0, CK804_DEVN_BASE+1 , 0), 0xa0, dword);
