Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/68770 )
Change subject: mb/google/kahlee/liara/devicetree: move Raydium touchscreen to baseboard ......................................................................
Move the Raydium touchscreen to the baseboard devicetree. Since only the liara variant uses a level IRQ as I2C devices are supposed to, all other board variants still override this to use an edge IRQ which were added as a workaround to make the touchscreen work on the other devices. Right now it's unclear to me if that edge IRQ workaround was only needed temporarily and can now be removed, so I'll keep it as it was for now. If this turns out to be no longer needed on the other variants, the overrides can be dropped in the future.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ic621c1a5856e9e280a25b0668010a1ee5bbb61e4 Reviewed-on: https://review.coreboot.org/c/coreboot/+/68770 Reviewed-by: Matt DeVillier matt.devillier@amd.corp-partner.google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Paul Menzel paulepanter@mailbox.org --- M src/mainboard/google/kahlee/variants/baseboard/devicetree.cb M src/mainboard/google/kahlee/variants/liara/overridetree.cb 2 files changed, 35 insertions(+), 14 deletions(-)
Approvals: build bot (Jenkins): Verified Paul Menzel: Looks good to me, but someone else must approve Matt DeVillier: Looks good to me, approved
diff --git a/src/mainboard/google/kahlee/variants/baseboard/devicetree.cb b/src/mainboard/google/kahlee/variants/baseboard/devicetree.cb index 2f6e0da..fc74d77 100644 --- a/src/mainboard/google/kahlee/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/kahlee/variants/baseboard/devicetree.cb @@ -85,6 +85,18 @@ end device ref i2c_3 on chip drivers/i2c/generic + register "hid" = ""RAYD0001"" + register "desc" = ""Raydium Touchscreen"" + register "probed" = "1" + register "irq_gpio" = "ACPI_GPIO_IRQ_LEVEL_LOW(GPIO_11)" + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_85)" + register "reset_delay_ms" = "20" + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_76)" + register "enable_delay_ms" = "1" + register "has_power_resource" = "1" + device i2c 39 on end + end + chip drivers/i2c/generic register "hid" = ""ELAN0001"" register "desc" = ""ELAN Touchscreen"" register "probed" = "1" diff --git a/src/mainboard/google/kahlee/variants/liara/overridetree.cb b/src/mainboard/google/kahlee/variants/liara/overridetree.cb index 1d750b8..7b1c2d3 100644 --- a/src/mainboard/google/kahlee/variants/liara/overridetree.cb +++ b/src/mainboard/google/kahlee/variants/liara/overridetree.cb @@ -50,18 +50,4 @@ device i2c 2c on end end end - device ref i2c_3 on - chip drivers/i2c/generic - register "hid" = ""RAYD0001"" - register "desc" = ""Raydium Touchscreen"" - register "probed" = "1" - register "irq_gpio" = "ACPI_GPIO_IRQ_LEVEL_LOW(GPIO_11)" - register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_85)" - register "reset_delay_ms" = "20" - register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPIO_76)" - register "enable_delay_ms" = "1" - register "has_power_resource" = "1" - device i2c 39 on end - end - end end #chip soc/amd/stoneyridge
