Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18001
commit f04cef91813c0a3e01f02e2ae486e4142eb13633 Author: Martin Roth gaumless@gmail.com Date: Fri Dec 30 17:00:19 2016 -0700
util/docker: Update dockerfiles & build method
All files: - Previously, various things were hardcoded into the docker containers that made it necessary to update the Dockerfile files for each new version of the sdk. Turn those into 'Variables" that are updated during the build step. Because the makefile is piping the dockerfile through the sed command and back into the docker build command, the normal docker "COPY" keyword doesn't work.
coreboot-jenkins-node changes: - Run ssh-keygen -A to explicitly generate the ssh keys. This fixes an error: Could not load host key: /etc/ssh/ssh_host_dsa_key
coreboot-sdk changes: - Remove apt-get upgrade command - The Dockerfile guide recommends not to run this. - Change libssl-dev to libssl1.0-dev. libssl-dev's header files won't build the Chrome-EC codebase. - Add libisl-dev, needed to build the riscv toolchain. - Build the toolchain using the -b option - Add environment variables containing the version and commit that the coreboot-sdk was built from.
Makefile: - Update targets to use the version and commit variables
Change-Id: I2c1376fe4b791da2a62fca11bc92c4774cbef1c8 Signed-off-by: Martin Roth gaumless@gmail.com --- util/docker/Makefile | 29 +++++++++++++++++++++------ util/docker/coreboot-jenkins-node/Dockerfile | 30 ++++++++++++++++++++++------ util/docker/coreboot-sdk/Dockerfile | 27 +++++++++++++++++++------ 3 files changed, 68 insertions(+), 18 deletions(-)
diff --git a/util/docker/Makefile b/util/docker/Makefile index f669b93..756dac0 100644 --- a/util/docker/Makefile +++ b/util/docker/Makefile @@ -16,6 +16,12 @@ export top=$(abspath $(CURDIR)/../..) export crossgcc_version=$(shell $(top)/util/crossgcc/buildgcc --version | grep 'cross toolchain' | sed 's/^.*\sv//' | sed 's/\s.*$$//') export DOCKER:=$(shell env sh -c "command -v docker")
+# Version of the jenkins / sdk container +export COREBOOT_CONTAINER_VERSION?=$(crossgcc_version) + +# Commit id to build from +export DOCKER_COMMIT?=$(shell git log -n 1 --pretty=%h) + test-docker: $(if $(DOCKER),,\ $(warning Docker command not found. Please install docker) \ @@ -28,16 +34,23 @@ test-docker-login: test-docker $(error Docker authentication file not found. Run 'docker login'))
coreboot-sdk: test-docker - $(DOCKER) build -t coreboot/coreboot-sdk:$(crossgcc_version) coreboot-sdk + @echo "Building coreboot SDK $(crossgcc_version) from commit $(DOCKER_COMMIT)" + cat coreboot-sdk/Dockerfile | \ + sed "s/{{DOCKER_COMMIT}}/$(DOCKER_COMMIT)/" | \ + sed "s/{{SDK_VERSION}}/$(COREBOOT_CONTAINER_VERSION)/" | \ + $(DOCKER) build -t coreboot/coreboot-sdk:$(COREBOOT_CONTAINER_VERSION) -
upload-coreboot-sdk: test-docker-login - $(DOCKER) push coreboot/coreboot-sdk:$(crossgcc_version) + $(DOCKER) push coreboot/coreboot-sdk:$(COREBOOT_CONTAINER_VERSION)
coreboot-jenkins-node: test-docker - $(DOCKER) build -t coreboot/coreboot-jenkins-node:$(crossgcc_version) coreboot-jenkins-node + cat coreboot-jenkins-node/Dockerfile | \ + sed "s/{{SDK_VERSION}}/$(COREBOOT_CONTAINER_VERSION)/" | \ + sed "s|{{SSH_KEY}}|$$(cat coreboot-jenkins-node/authorized_keys)|" | \ + $(DOCKER) build -t coreboot/coreboot-jenkins-node:$(COREBOOT_CONTAINER_VERSION) -
upload-coreboot-jenkins-node: test-docker-login - $(DOCKER) push coreboot/coreboot-jenkins-node:$(crossgcc_version) + $(DOCKER) push coreboot/coreboot-jenkins-node:$(COREBOOT_CONTAINER_VERSION)
docker-killall: test-docker @if [ -n "$$($(DOCKER) ps | grep 'coreboot')" ]; then \ @@ -52,7 +65,7 @@ clean-coreboot-images: docker-killall
docker-build-coreboot: test-docker $(DOCKER) run -u root -it -v $(top):/home/coreboot/coreboot \ - --rm coreboot/coreboot-sdk:$(crossgcc_version) \ + --rm coreboot/coreboot-sdk:$(COREBOOT_CONTAINER_VERSION) \ /bin/bash -c "cd /home/coreboot/coreboot && \ make clean && \ make $(BUILD_CMD)" @@ -62,7 +75,7 @@ docker-build-coreboot: test-docker
docker-abuild: test-docker $(DOCKER) run -u root -it -v $(top):/home/coreboot/coreboot \ - --rm coreboot/coreboot-sdk:$(crossgcc_version) \ + --rm coreboot/coreboot-sdk:$(COREBOOT_CONTAINER_VERSION) \ /bin/bash -c "cd /home/coreboot/coreboot && \ make clean && \ util/abuild/abuild $(ABUILD_ARGS)" @@ -82,6 +95,10 @@ help: @echo "Commands for using docker images" @echo " docker-build-coreboot <BUILD_CMD=target> - Build coreboot under coreboot-sdk" @echo " docker-abuild <ABUILD_ARGS='-a -B'> - Run abuild under coreboot-sdk" + @echo + @echo "Variables:" + @echo " COREBOOT_CONTAINER_VERSION = $(COREBOOT_CONTAINER_VERSION)" + @echo " DOCKER_COMMIT = $(DOCKER_COMMIT)"
.PHONY: test-docker test-docker-login .PHONY: coreboot-jenkins-node upload-coreboot-jenkins-node diff --git a/util/docker/coreboot-jenkins-node/Dockerfile b/util/docker/coreboot-jenkins-node/Dockerfile index b60466d..230842c 100644 --- a/util/docker/coreboot-jenkins-node/Dockerfile +++ b/util/docker/coreboot-jenkins-node/Dockerfile @@ -1,5 +1,20 @@ -FROM coreboot/coreboot-sdk:1.42 -MAINTAINER Martin Roth gaumless@gmail.com +# This dockerfile is not meant to be used directly by docker. The +# {{}} varibles are replaced with values by the makefile. Please generate +# the docker image for this file by running: +# +# make coreboot-jenkins-node +# +# Variables can be updated on the make command line or left blank to use +# the default values set by the makefile. +# +# SDK_VERSION is used to name the version of the coreboot sdk to use. +# Typically, this corresponds to the toolchain version. +# SSH_KEY is the contents of the file coreboot-jenkins-node/authorized_keys +# Because we're piping the contents of the dockerfile into the +# docker build command, the 'COPY' keyword isn't valid. + +FROM coreboot/coreboot-sdk:{{SDK_VERSION}} +MAINTAINER Martin Roth martin@coreboot.org USER root
# Check to make sure /dev is a tmpfs file system @@ -10,13 +25,17 @@ RUN apt-get -y update && \ lua5.3 liblua5.3-dev openjdk-8-jre-headless openssh-server && \ apt-get clean
-COPY authorized_keys /home/coreboot/.ssh/authorized_keys -RUN chown -R coreboot /home/coreboot/.ssh && \ +# Because of the way that the variables are being replaced, docker's 'COPY' +# command does not work +RUN mkdir -p /home/coreboot/.ssh && \ + echo "{{SSH_KEY}}" > /home/coreboot/.ssh/authorized_keys && \ + chown -R coreboot:coreboot /home/coreboot/.ssh && \ chmod 0700 /home/coreboot/.ssh && \ chmod 0600 /home/coreboot/.ssh/authorized_keys
RUN mkdir /var/run/sshd && \ - chmod 0755 /var/run/sshd + chmod 0755 /var/run/sshd && \ + /usr/bin/ssh-keygen -A
# Build encapsulate tool ADD https://raw.githubusercontent.com/pgeorgi/encapsulate/master/encapsulate.c /tmp/encapsulate.c @@ -24,7 +43,6 @@ RUN gcc -o /usr/sbin/encapsulate /tmp/encapsulate.c && \ chown root /usr/sbin/encapsulate && \ chmod +s /usr/sbin/encapsulate
- VOLUME /data/cache ENTRYPOINT mkdir /dev/cb-build && chown coreboot /dev/cb-build && /usr/sbin/sshd -p 49151 -D EXPOSE 49151 diff --git a/util/docker/coreboot-sdk/Dockerfile b/util/docker/coreboot-sdk/Dockerfile index cb0023c..feaf843 100644 --- a/util/docker/coreboot-sdk/Dockerfile +++ b/util/docker/coreboot-sdk/Dockerfile @@ -1,26 +1,39 @@ +# This dockerfile is not meant to be used directly by docker. The +# {{}} varibles are replaced with values by the makefile. Please generate +# the docker image for this file by running: +# +# make coreboot-sdk +# +# Variables can be updated on the make command line or left blank to use +# the default values set by the makefile. +# +# SDK_VERSION is used to name the version of the coreboot sdk to use. +# Typically, this corresponds to the toolchain version. This +# is used to identify this docker image. +# DOCKER_COMMIT is the coreboot Commit-ID to build the toolchain from. + FROM debian:sid -MAINTAINER Martin Roth gaumless@gmail.com +MAINTAINER Martin Roth martin@coreboot.org
RUN \ useradd -p locked -m coreboot && \ apt-get -qq update && \ - apt-get -qq upgrade && \ apt-get -qqy install gcc g++ make patch python diffutils bison flex \ git doxygen ccache subversion p7zip-full unrar-free \ m4 wget curl bzip2 vim-common cmake xz-utils pkg-config \ dh-autoreconf unifont \ - libssl-dev libgmp-dev zlib1g-dev libpci-dev liblzma-dev \ + libssl1.0-dev libgmp-dev zlib1g-dev libpci-dev liblzma-dev \ libyaml-dev libncurses5-dev uuid-dev libusb-dev libftdi-dev \ libusb-1.0-0-dev libreadline-dev libglib2.0-dev libgmp-dev \ - libelf-dev libxml2-dev libfreetype6-dev && \ + libelf-dev libxml2-dev libfreetype6-dev libisl-dev && \ apt-get clean
RUN \ cd /root && \ git clone http://review.coreboot.org/coreboot && \ cd coreboot/util/crossgcc && \ - git checkout 589ef9de8fa && \ - make all_without_gdb CPUS=$(nproc) DEST=/opt/xgcc && \ + git checkout {{DOCKER_COMMIT}} && \ + make all_without_gdb CPUS=$(nproc) DEST=/opt/xgcc BUILDGCC_OPTIONS=-b && \ cd /root && \ rm -rf coreboot
@@ -31,4 +44,6 @@ RUN mkdir /home/coreboot/.ccache && \ VOLUME /home/coreboot/.ccache
ENV PATH $PATH:/opt/xgcc/bin +ENV SDK_VERSION={{SDK_VERSION}} +ENV SDK_COMMIT={{DOCKER_COMMIT}} USER coreboot
