Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/83960?usp=email )
2 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: soc/intel/jasperlake: Switch to SOC_INTEL_COMMON_DEBUG_CONSENT ......................................................................
This patch drops the SoC-specific config option `SOC_INTEL_JASPERLAKE_DEBUG_CONSENT`.
Additionally, updates the FSP configuration to use the new generic config option.
TEST=Able to build and boot google/dedede without any functional impact while debugging.
Change-Id: I3e7abaf5fb3a0d5528041af5ce767a15fc738870 Signed-off-by: Subrata Banik subratabanik@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/83960 Reviewed-by: Felix Held felix-coreboot@felixheld.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/soc/intel/jasperlake/Kconfig M src/soc/intel/jasperlake/romstage/fsp_params.c 2 files changed, 1 insertion(+), 17 deletions(-)
Approvals: Felix Held: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/soc/intel/jasperlake/Kconfig b/src/soc/intel/jasperlake/Kconfig index 2871508..1502c75 100644 --- a/src/soc/intel/jasperlake/Kconfig +++ b/src/soc/intel/jasperlake/Kconfig @@ -192,22 +192,6 @@ config FSP_FD_PATH default "3rdparty/fsp/JasperLakeFspBinPkg/Fsp.fd"
-config SOC_INTEL_JASPERLAKE_DEBUG_CONSENT - int "Debug Consent for JSL" - # USB DBC is more common for developers so make this default to 3 if - # SOC_INTEL_DEBUG_CONSENT=y - default 3 if SOC_INTEL_DEBUG_CONSENT - default 0 - help - This is to control debug interface on SOC. - Setting non-zero value will allow to use DBC or DCI to debug SOC. - PlatformDebugConsent in FspmUpd.h has the details. - - Desired platform debug type are - 0:Disabled, 1:Enabled (DCI OOB+[DbC]), 2:Enabled (DCI OOB), - 3:Enabled (USB3 DbC), 4:Enabled (XDP/MIPI60), 5:Enabled (USB2 DbC), - 6:Enable (2-wire DCI OOB), 7:Manual - config PRERAM_CBMEM_CONSOLE_SIZE hex default 0x1400 diff --git a/src/soc/intel/jasperlake/romstage/fsp_params.c b/src/soc/intel/jasperlake/romstage/fsp_params.c index 0132906..0299860 100644 --- a/src/soc/intel/jasperlake/romstage/fsp_params.c +++ b/src/soc/intel/jasperlake/romstage/fsp_params.c @@ -96,7 +96,7 @@ m_cfg->SmbusEnable = config->SmbusEnable;
/* Set debug probe type */ - m_cfg->PlatformDebugConsent = CONFIG_SOC_INTEL_JASPERLAKE_DEBUG_CONSENT; + m_cfg->PlatformDebugConsent = CONFIG_SOC_INTEL_COMMON_DEBUG_CONSENT;
/* VT-d config */ m_cfg->VtdDisable = 0;
