Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/61703 )
Change subject: mb/google/var/taniks: Add gpios to lock ......................................................................
Variant should honor locked gpios from baseboard, but not the last. Variant can add more gpios to lock if needed.
BUG=b:216583542 TEST='emerge-brya coreboot chromeos-bootimage', flash and verify that taniks boots successfully to kernel.
Signed-off-by: Eric Lai ericr_lai@compal.corp-partner.google.com Change-Id: Icf6cb0d057f9ad3cbcc1155423ed7efa58a46d0e Reviewed-on: https://review.coreboot.org/c/coreboot/+/61703 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Nick Vaccaro nvaccaro@google.com Reviewed-by: Subrata Banik subratabanik@google.com --- M src/mainboard/google/brya/variants/taniks/gpio.c 1 file changed, 20 insertions(+), 20 deletions(-)
Approvals: build bot (Jenkins): Verified Nick Vaccaro: Looks good to me, approved Subrata Banik: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/taniks/gpio.c b/src/mainboard/google/brya/variants/taniks/gpio.c index 05a68d1..0d36fc2 100644 --- a/src/mainboard/google/brya/variants/taniks/gpio.c +++ b/src/mainboard/google/brya/variants/taniks/gpio.c @@ -33,9 +33,9 @@ /* B2 : VRALERT# ==> NC */ PAD_NC(GPP_B2, NONE), /* B3 : PROC_GP2 ==> NC */ - PAD_NC(GPP_B3, NONE), + PAD_NC_LOCK(GPP_B3, NONE, LOCK_CONFIG), /* B15 : TIME_SYNC0 ==> NC */ - PAD_NC(GPP_B15, NONE), + PAD_NC_LOCK(GPP_B15, NONE, LOCK_CONFIG),
/* C3 : SML0CLK ==> NC */ PAD_NC(GPP_C3, NONE), @@ -45,27 +45,27 @@ PAD_NC(GPP_C6, NONE),
/* D1 : ISH_GP1 ==> NC */ - PAD_NC(GPP_D1, NONE), + PAD_NC_LOCK(GPP_D1, NONE, LOCK_CONFIG), /* D2 : ISH_GP2 ==> NC */ - PAD_NC(GPP_D2, NONE), + PAD_NC_LOCK(GPP_D2, NONE, LOCK_CONFIG), /* D3 : ISH_GP3 ==> NC */ - PAD_NC(GPP_D3, NONE), + PAD_NC_LOCK(GPP_D3, NONE, LOCK_CONFIG), /* D5 : SRCCLKREQ0# ==> SSD_CLKREQ_ODL */ PAD_CFG_NF(GPP_D5, NONE, DEEP, NF1), /* D9 : ISH_SPI_CS# ==> NC */ - PAD_NC(GPP_D9, NONE), + PAD_NC_LOCK(GPP_D9, NONE, LOCK_CONFIG), /* D10 : ISH_SPI_CLK ==> NC */ - PAD_NC(GPP_D10, NONE), + PAD_NC_LOCK(GPP_D10, NONE, LOCK_CONFIG), /* D13 : ISH_UART0_RXD ==> NC */ - PAD_NC(GPP_D13, NONE), + PAD_NC_LOCK(GPP_D13, NONE, LOCK_CONFIG), /* D14 : ISH_UART0_TXD ==> NC */ - PAD_NC(GPP_D14, NONE), + PAD_NC_LOCK(GPP_D14, NONE, LOCK_CONFIG), /* D15 : ISH_UART0_RTS# ==> NC */ - PAD_NC(GPP_D15, NONE), + PAD_NC_LOCK(GPP_D15, NONE, LOCK_CONFIG), /* D16 : ISH_UART0_CTS# ==> NC */ - PAD_NC(GPP_D16, NONE), + PAD_NC_LOCK(GPP_D16, NONE, LOCK_CONFIG), /* D17 : UART1_RXD ==> NC */ - PAD_NC(GPP_D17, NONE), + PAD_NC_LOCK(GPP_D17, NONE, LOCK_CONFIG),
/* E0 : SATAXPCIE0 ==> NC */ PAD_NC(GPP_E0, NONE), @@ -78,11 +78,11 @@ /* E7 : PROC_GP1 ==> NC */ PAD_NC(GPP_E7, NONE), /* E10 : THC0_SPI1_CS# ==> NC */ - PAD_NC(GPP_E10, NONE), + PAD_NC_LOCK(GPP_E10, NONE, LOCK_CONFIG), /* E16 : RSVD_TP ==> NC */ PAD_NC(GPP_E16, NONE), /* E17 : THC0_SPI1_INT# ==> NC */ - PAD_NC(GPP_E17, NONE), + PAD_NC_LOCK(GPP_E17, NONE, LOCK_CONFIG), /* E18 : DDP1_CTRLCLK ==> NC */ PAD_NC(GPP_E18, NONE), /* E19 : DDP1_CTRLDATA ==> NC */ @@ -95,15 +95,15 @@ /* F6 : CNV_PA_BLANKING ==> NC */ PAD_NC(GPP_F6, NONE), /* F11 : THC1_SPI2_CLK ==> NC */ - PAD_NC(GPP_F11, NONE), + PAD_NC_LOCK(GPP_F11, NONE, LOCK_CONFIG), /* F12 : GSXDOUT ==> NC */ - PAD_NC(GPP_F12, NONE), + PAD_NC_LOCK(GPP_F12, NONE, LOCK_CONFIG), /* F13 : GSXDOUT ==> NC */ - PAD_NC(GPP_F13, NONE), + PAD_NC_LOCK(GPP_F13, NONE, LOCK_CONFIG), /* F15 : GSXSRESET# ==> NC */ - PAD_NC(GPP_F15, NONE), + PAD_NC_LOCK(GPP_F15, NONE, LOCK_CONFIG), /* F16 : GSXCLK ==> NC */ - PAD_NC(GPP_F16, NONE), + PAD_NC_LOCK(GPP_F16, NONE, LOCK_CONFIG), /* F19 : SRCCLKREQ6# ==> NC */ PAD_NC(GPP_F19, NONE), /* F20 : EXT_PWR_GATE# ==> NC */ @@ -124,7 +124,7 @@ /* H9 : I2C4_SCL ==> NC */ PAD_NC(GPP_H9, NONE), /* H13 : I2C7_SCL ==> EN_PP3300_SD */ - PAD_CFG_GPO(GPP_H13, 1, DEEP), + PAD_CFG_GPO_LOCK(GPP_H13, 1, LOCK_CONFIG), /* H15 : DDPB_CTRLCLK ==> NC */ PAD_NC(GPP_H15, NONE), /* H17 : DDPB_CTRLDATA ==> NC */
