Werner Zeh (werner.zeh@siemens.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14505
commit 7e1518dfcdfa1ed03d785637a7c75e7ffe3d5bf5 Author: Werner Zeh werner.zeh@siemens.com Date: Fri Apr 22 14:14:45 2016 +0200
vendorcode/siemens: Add hwilib for Siemens specific info struct
Add a library which unifies access to Siemens specific hardware information data. This library is meant to be used with Siemens platforms and can be selected in Kconfig. The needed source of information has to be present in cbfs. This lib can be used in romstage and ramstage.
Change-Id: I2c6e003b0c123b4cf6a84906c2b133b8c38c8b1a Signed-off-by: Werner Zeh werner.zeh@siemens.com --- src/vendorcode/Makefile.inc | 1 + src/vendorcode/siemens/Kconfig | 20 ++ src/vendorcode/siemens/Makefile.inc | 16 ++ src/vendorcode/siemens/hwilib/Makefile.inc | 19 ++ src/vendorcode/siemens/hwilib/hwilib.c | 321 +++++++++++++++++++++++++++++ src/vendorcode/siemens/hwilib/hwilib.h | 74 +++++++ 6 files changed, 451 insertions(+)
diff --git a/src/vendorcode/Makefile.inc b/src/vendorcode/Makefile.inc index 741a04a..440972f 100644 --- a/src/vendorcode/Makefile.inc +++ b/src/vendorcode/Makefile.inc @@ -1,3 +1,4 @@ subdirs-y += amd subdirs-y += google subdirs-y += intel +subdirs-y += siemens diff --git a/src/vendorcode/siemens/Kconfig b/src/vendorcode/siemens/Kconfig new file mode 100644 index 0000000..8bbab62 --- /dev/null +++ b/src/vendorcode/siemens/Kconfig @@ -0,0 +1,20 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2016 Siemens AG +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +config USE_SIEMENS_HWILIB + bool + default n + +source "src/vendorcode/siemens/*/Kconfig" diff --git a/src/vendorcode/siemens/Makefile.inc b/src/vendorcode/siemens/Makefile.inc new file mode 100644 index 0000000..ece2b4d --- /dev/null +++ b/src/vendorcode/siemens/Makefile.inc @@ -0,0 +1,16 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2016 Siemens AG +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +subdirs-$(CONFIG_USE_SIEMENS_HWILIB) += hwilib diff --git a/src/vendorcode/siemens/hwilib/Makefile.inc b/src/vendorcode/siemens/hwilib/Makefile.inc new file mode 100644 index 0000000..1c6f6c9 --- /dev/null +++ b/src/vendorcode/siemens/hwilib/Makefile.inc @@ -0,0 +1,19 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2016 Siemens AG +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## + +CFLAGS_x86_32 += -Isrc/vendorcode/siemens/hwilib + +romstage-y += hwilib.c +ramstage-y += hwilib.c diff --git a/src/vendorcode/siemens/hwilib/hwilib.c b/src/vendorcode/siemens/hwilib/hwilib.c new file mode 100644 index 0000000..7e1766d --- /dev/null +++ b/src/vendorcode/siemens/hwilib/hwilib.c @@ -0,0 +1,321 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Siemens AG. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <cbfs.h> +#include <string.h> +#include <console/console.h> +#include <arch/io.h> +#include <arch/early_variables.h> +#include "hwilib.h" + + +#define MAX_BLOCK_NUM 3 +#define LEN_HIB 0x1fd +#define LEN_SIB 0x121 +#define LEN_EIB 0x0b5 +#define NEXT_OFFSET_HIB 0x1dc +#define NEXT_OFFSET_SIB 0x104 +#define NEXT_OFFSET_EIB 0x0b0 +#define LEN_UNIQUEL_NUM 0x010 +#define LEN_HW_REV 0x002 +#define LEN_MAC_ADDRESS 0x006 +#define LEN_SPD 0x080 +#define LEN_EDID 0x080 +#define LEN_OFFSET 0x00c +#define EIB_FEATRUE_OFFSET 0x00e +#define LEN_MAGIC_NUM 0x007 +#define BLOCK_MAGIC "H1W2M3I" + +/* Define all supported block types. */ +enum { + BLK_HIB, + BLK_SIB, + BLK_EIB, +}; + +/* This structure holds a valid position for a given field + * Every field can have multiple positions of which the first available + * will be taken by the library. + */ +struct param_pos { + uint8_t blk_type; /* Valid for a specific block type */ + uint32_t offset; /* Offset in given block */ + uint32_t len; /* Length for the field in this block */ +}; + +/* This structure holds all the needed information for a given field type + * and a pointer to a function which is able to extract the desired data. + */ +struct param_info { + struct param_pos pos[MAX_BLOCK_NUM]; + uint64_t mask; + uint8_t mask_offset; + uint32_t (*get_field)(const struct param_info *param, uint8_t *dst, + uint32_t maxlen); +}; + +/* Storage for pointers to the different blocks. The contents will be filled + * in hwilib_find_blocks(). + */ +static uint8_t *all_blocks[MAX_BLOCK_NUM] CAR_GLOBAL; + +static uint32_t hwilib_read_bytes (const struct param_info *param, uint8_t *dst, + uint32_t maxlen); + +/* Add all supported fields to this variable. It is important to use the + * field type of a given field as the array index so that all the information + * is on the appropriate place inside the array. In this way one do not need + * to search for fields but can simply use an index into the array. + */ +static const struct param_info params[] = { + [HIB_VerID] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0x8, .len = 4}, + .get_field = hwilib_read_bytes }, + [SIB_VerID] = { + .pos[0] = {.blk_type = BLK_SIB, .offset = 0x8, .len = 4}, + .get_field = hwilib_read_bytes }, + [EIB_VerID] = { + .pos[0] = {.blk_type = BLK_EIB, .offset = 0x8, .len = 4}, + .get_field = hwilib_read_bytes }, + [HIB_HwRev] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xbe, .len = 2}, + .get_field = hwilib_read_bytes }, + [SIB_HwRev] = { + .pos[0] = {.blk_type = BLK_SIB, .offset = 0xc8, .len = 2}, + .get_field = hwilib_read_bytes }, + [UniqueNum] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xa2, .len = 10}, + .pos[1] = {.blk_type = BLK_SIB, .offset = 0xa2, .len = 10}, + .get_field = hwilib_read_bytes }, + [Mac1] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xc0, .len = 6}, + .get_field = hwilib_read_bytes }, + [Mac1Aux] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xc6, .len = 1}, + .get_field = hwilib_read_bytes }, + [Mac2] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xc8, .len = 6}, + .get_field = hwilib_read_bytes }, + [Mac2Aux] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xce, .len = 1}, + .get_field = hwilib_read_bytes }, + [Mac3] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xd0, .len = 6}, + .get_field = hwilib_read_bytes }, + [Mac3Aux] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xd6, .len = 1}, + .get_field = hwilib_read_bytes }, + [Mac4] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xd8, .len = 6}, + .get_field = hwilib_read_bytes }, + [Mac4Aux] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xde, .len = 1}, + .get_field = hwilib_read_bytes }, + [SPD] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0xe0, .len = 0x80}, + .get_field = hwilib_read_bytes }, + [FF_FreezeDis] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0x1b8, .len = 4}, + .mask = 0x10, + .mask_offset = 4, + .get_field = hwilib_read_bytes }, + [FF_FanReq] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0x1b8, .len = 4}, + .mask = 0x400, + .mask_offset = 10, + .get_field = hwilib_read_bytes }, + [BiosFlags] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0x1c0, .len = 4}, + .get_field = hwilib_read_bytes }, + [MacMapping1] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0x1cc, .len = 4}, + .get_field = hwilib_read_bytes }, + [MacMapping2] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0x1d0, .len = 4}, + .get_field = hwilib_read_bytes }, + [MacMapping3] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0x1d4, .len = 4}, + .get_field = hwilib_read_bytes }, + [MacMapping4] = { + .pos[0] = {.blk_type = BLK_HIB, .offset = 0x1d8, .len = 4}, + .get_field = hwilib_read_bytes }, + [PF_Color_Depth] = { + .pos[0] = {.blk_type = BLK_SIB, .offset = 0xea, .len = 1}, + .mask = 0x03, + .mask_offset = 0, + .get_field = hwilib_read_bytes }, + [PF_DisplType] = { + .pos[0] = {.blk_type = BLK_SIB, .offset = 0xe3, .len = 1}, + .get_field = hwilib_read_bytes }, + [PF_DisplCon] = { + .pos[0] = {.blk_type = BLK_SIB, .offset = 0xf2, .len = 1}, + .get_field = hwilib_read_bytes }, + [Edid] = { + .pos[0] = {.blk_type = BLK_EIB, .offset = 0x10, .len = 0x80}, + .get_field = hwilib_read_bytes }, + [VddRef] = { + .pos[0] = {.blk_type = BLK_EIB, .offset = 0x90, .len = 2}, + .get_field = hwilib_read_bytes }, +}; + +/** \brief This functions reads the given field from the first valid hwinfo + * block + * @param *param Parameter to read from hwinfo + * @param *dst Pointer to memory where the data will be stored in + * @return number of copied bytes on success, 0 on error + */ +static uint32_t hwilib_read_bytes (const struct param_info *param, uint8_t *dst, + uint32_t maxlen) +{ + uint8_t i = 0, *blk = NULL; + uint8_t **blk_ptr = car_get_var_ptr(&all_blocks[0]); + static const uint16_t all_blk_size[MAX_BLOCK_NUM] = + {LEN_HIB, LEN_SIB, LEN_EIB}; + + if (!param || !dst) + return 0; + /* Take the first valid block to get the parameter from */ + do { + if ((param->pos[i].len) && (param->pos[i].offset)) { + blk = blk_ptr[param->pos[i].blk_type]; + break; + } + i++; + } while (i < MAX_BLOCK_NUM); + + /* Ensure there is a valid block available for this parameter and + * the length of the parameter do not exceed maxlen or block len. + */ + if ((!blk) || (param->pos[i].len > maxlen) || + (param->pos[i].len + param->pos[i].offset > + all_blk_size[param->pos[i].blk_type])) + return 0; + /* We can now copy the wanted data. */ + memcpy(dst, (blk + param->pos[i].offset), param->pos[i].len); + /* If there is a mask given, apply it only for parameters with a + * length of 1, 2, 4 or 8 bytes. + */ + if (param->mask) { + switch (param->pos[i].len) { + case 1: + /* Apply a mask on a 8 bit value */ + *dst &= (param->mask & 0xff); + *dst >>= (param->mask_offset); + break; + case 2: + /* Apply mask on a 16 bit value */ + *((uint16_t *)(dst)) &= (param->mask & 0xffff); + *((uint16_t *)(dst)) >>= (param->mask_offset); + break; + case 4: + /* Apply mask on a 32 bit value */ + *((uint32_t *)(dst)) &= (param->mask & 0xffffffff); + *((uint32_t *)(dst)) >>= (param->mask_offset); + break; + case 8: + /* Apply mask on a 64 bit value */ + *((uint64_t *)(dst)) &= (param->mask); + *((uint64_t *)(dst)) >>= (param->mask_offset); + break; + default: + /* Warn if there is a mask for an invalid length. */ + printk(BIOS_WARNING, + "HWILIB: Invalid field length for given mask.\n"); + break; + } + } + return param->pos[i].len; +} + +/** \brief This function finds all available block types in a given cbfs file. + * @param *hwi_filename Name of the cbfs-file to use. + * @return CB_SUCCESS when no error, otherwise error code + */ +enum cb_err hwilib_find_blocks (const char *hwi_filename) +{ + uint8_t *ptr = NULL, *base = NULL; + uint32_t next_offset = 1; + uint8_t **blk_ptr = car_get_var_ptr(&all_blocks[0]); + size_t filesize = 0; + + /* Check for a valid parameter */ + if (!hwi_filename) + return CB_ERR_ARG; + ptr = cbfs_boot_map_with_leak(hwi_filename, CBFS_TYPE_RAW, &filesize); + if (!ptr) { + printk(BIOS_ERR,"HWILIB: Missing file "%s" in cbfs.\n", + hwi_filename); + return CB_ERR; + } + /* Ensure the block has the right magic */ + if (strncmp((char*)ptr, BLOCK_MAGIC, LEN_MAGIC_NUM)) { + printk(BIOS_ERR, "HWILIB: Bad magic at start of block!\n"); + return CB_ERR; + } + /* Reset all static pointers to blocks as they might have been set + * in prior calls to this function. + * This way the caller do not need to "close" already opened blocks. + */ + memset(blk_ptr, 0, ARRAY_SIZE(all_blocks)); + /* Check which blocks are available by examining the length field. */ + base = ptr; + while(!(strncmp((char *)ptr, BLOCK_MAGIC, LEN_MAGIC_NUM)) && + next_offset) { + uint16_t len = read16(ptr + LEN_OFFSET); + /* Ensure file size boundaries for a given block. */ + if ((ptr - base + len) > filesize) + break; + if (len == LEN_HIB) { + blk_ptr[BLK_HIB] = ptr; + next_offset = read32(ptr + NEXT_OFFSET_HIB); + if (next_offset) + ptr = base + next_offset; + } else if (len == LEN_SIB) { + blk_ptr[BLK_SIB] = ptr; + next_offset = read32(ptr + NEXT_OFFSET_SIB); + if (next_offset) + ptr = base + next_offset; + } else if (len == LEN_EIB) { + /* Skip preliminary blocks */ + if (!(read16(ptr + EIB_FEATRUE_OFFSET) & 0x01)) + blk_ptr[BLK_EIB] = ptr; + next_offset = read32(ptr + NEXT_OFFSET_EIB); + if (next_offset) + ptr = base + next_offset; + } else { + next_offset = 0; + } + } + /* We should have found at least one valid block */ + if (blk_ptr[BLK_HIB] || blk_ptr[BLK_SIB] || blk_ptr[BLK_EIB]) + return CB_SUCCESS; + else + return CB_ERR; +} + +/** \brief This functions is used from caller to get a specific field from + * hwinfo block. + * @param field Field type to read from hwinfo + * @param *dst Pointer to memory where the data will be stored in + * @return number of copied bytes on success, 0 on error + */ +uint32_t hwilib_get_field (hwinfo_field_t field, uint8_t *dst, uint32_t maxlen) +{ + /* Check the boundaries of params-variable */ + if ((uint32_t)field < ARRAY_SIZE(params)) + return params[field].get_field(¶ms[field], dst, maxlen); + else + return 0; +} diff --git a/src/vendorcode/siemens/hwilib/hwilib.h b/src/vendorcode/siemens/hwilib/hwilib.h new file mode 100644 index 0000000..fb0798b --- /dev/null +++ b/src/vendorcode/siemens/hwilib/hwilib.h @@ -0,0 +1,74 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Siemens AG + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef SIEMENS_HWI_LIB_H_ +#define SIEMENS_HWI_LIB_H_ + +#include <types.h> + + +/* Declare all supported fields which can be get with hwilib. */ +typedef enum { + HIB_VerID = 0, + SIB_VerID, + EIB_VerID, + HIB_HwRev, + SIB_HwRev, + UniqueNum, + Mac1, + Mac1Aux, + Mac2, + Mac2Aux, + Mac3, + Mac3Aux, + Mac4, + Mac4Aux, + SPD, + FF_FreezeDis, + FF_FanReq, + BiosFlags, + MacMapping1, + MacMapping2, + MacMapping3, + MacMapping4, + PF_Color_Depth, + PF_DisplType, + PF_DisplCon, + Edid, + VddRef +} hwinfo_field_t; + +/* Define used values in supported fields */ +#define PF_COLOR_DEPTH_6BIT 0x00 +#define PF_COLOR_DEPTH_8BIT 0x01 +#define PF_COLOR_DEPTH_10BIT 0x02 +#define PF_DISPLCON_LVDS_SINGLE 0x00 +#define PF_DISPLCON_LVDS_DUAL 0x05 +#define FF_FREEZE_DISABLE 0x01 +#define FF_FAN_NEEDED 0x01 + +/* Use this function to find all supported blocks in cbfs. It must be called + * once with a valid cbfs file name before hwilib_get_field() can be used. + */ +enum cb_err hwilib_find_blocks (const char *hwi_filename); + +/* Use this function to get fields out of supported info blocks + * This function returns the number of copied bytes or 0 on error. + */ +uint32_t hwilib_get_field (hwinfo_field_t field, uint8_t *data, uint32_t maxlen); + +/* This functions needs to be implemented for every mainboard that uses i210. */ +enum cb_err mainboard_get_mac_address(u16 bus, u8 devfn, u8 mac[6]); +#endif /* SIEMENS_HWI_LIB_H_ */
