Jamie Chen has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38479 )
Change subject: mb/google/puff: Add puff ac/dc loadline configuations ......................................................................
According to VRTT report, add ac/dc loadline configuations in puff device tree.
BUG=b:147206535 BRANCH=None TEST=build and boot up successful on puff.
Change-Id: Ia806de23a1fefcaac3ce9a462a8a04eee5eabcae Signed-off-by: Jamie Chen jamie.chen@intel.com --- M src/mainboard/google/hatch/variants/puff/overridetree.cb 1 file changed, 60 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/38479/1
diff --git a/src/mainboard/google/hatch/variants/puff/overridetree.cb b/src/mainboard/google/hatch/variants/puff/overridetree.cb index 2e40ba9..4bbfc38 100644 --- a/src/mainboard/google/hatch/variants/puff/overridetree.cb +++ b/src/mainboard/google/hatch/variants/puff/overridetree.cb @@ -277,4 +277,64 @@ device pci 1e.3 off end # GSPI #1 end
+ register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = 0, + .voltage_limit = 1520, + .ac_loadline = 1004, + .dc_loadline = 1004, + }" + + register "domain_vr_config[VR_IA_CORE]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = 0, + .voltage_limit = 1520, + .ac_loadline = 181, + .dc_loadline = 181, + }" + + register "domain_vr_config[VR_GT_UNSLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = 0, + .voltage_limit = 1520, + .ac_loadline = 319, + .dc_loadline = 319, + }" + + register "domain_vr_config[VR_GT_SLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = 0, + .voltage_limit = 1520, + .ac_loadline = 319, + .dc_loadline = 319, + }" + end
Jamie Chen has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/38479 )
Change subject: mb/google/puff: Add puff ac/dc loadline configurations ......................................................................
According to VRTT report, add ac/dc loadline configurations in puff device tree.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/38479/2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38479 )
Patch Set 2:
(4 comments)
https://review.coreboot.org/c/coreboot/+/38479/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/38479/2//COMMIT_MSG@7 PS2, Line 7: puff Already in the prefix.
https://review.coreboot.org/c/coreboot/+/38479/2//COMMIT_MSG@9 PS2, Line 9: VRTT What does this stand for?
https://review.coreboot.org/c/coreboot/+/38479/2//COMMIT_MSG@10 PS2, Line 10: in puff device tree. Some words fit on line above (75 characters).
https://review.coreboot.org/c/coreboot/+/38479/2//COMMIT_MSG@11 PS2, Line 11: Did it boot up before also?
Hello Edward O'Callaghan, Tim Wawrzynczak, build bot (Jenkins),
Change subject: mb/google/puff: Add ac/dc loadline configuations ......................................................................
BUG=b:147206535 BRANCH=None TEST=build coreboot and fsp with enabled fw_debug. Flashed to puff and checked the log. All ac/dc loadline configs were set correctly.
Change-Id: Ia806de23a1fefcaac3ce9a462a8a04eee5eabcae Signed-off-by: Jamie Chen jamie.chen@intel.com --- M src/mainboard/google/hatch/variants/puff/overridetree.cb 1 file changed, 76 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/38479/3
Jamie Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38479 )
Patch Set 3:
(4 comments)
Patch Set 2:
(4 comments)
Done
It means VR test tool. VR: voltage regulator.
Done
Add detail steps for test item.
Edward O'Callaghan has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38479 )
Patch Set 3: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/38479 )
Change-Id: Ia806de23a1fefcaac3ce9a462a8a04eee5eabcae Signed-off-by: Jamie Chen jamie.chen@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/38479 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Edward O'Callaghan quasisec@chromium.org --- M src/mainboard/google/hatch/variants/puff/overridetree.cb 1 file changed, 76 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Edward O'Callaghan: Looks good to me, approved
diff --git a/src/mainboard/google/hatch/variants/puff/overridetree.cb b/src/mainboard/google/hatch/variants/puff/overridetree.cb index e7fe907..456e666 100644 --- a/src/mainboard/google/hatch/variants/puff/overridetree.cb +++ b/src/mainboard/google/hatch/variants/puff/overridetree.cb @@ -277,4 +277,80 @@ device pci 1e.3 off end # GSPI #1 end
+ # VR Settings Configuration for 4 Domains + #+----------------+-------+-------+-------+-------+ + #| Domain/Setting | SA | IA | GTUS | GTS | + #+----------------+-------+-------+-------+-------+ + #| Psi1Threshold | 20A | 20A | 20A | 20A | + #| Psi2Threshold | 5A | 5A | 5A | 5A | + #| Psi3Threshold | 1A | 1A | 1A | 1A | + #| Psi3Enable | 1 | 1 | 1 | 1 | + #| Psi4Enable | 1 | 1 | 1 | 1 | + #| ImonSlope | 0 | 0 | 0 | 0 | + #| ImonOffset | 0 | 0 | 0 | 0 | + #| VrVoltageLimit | 1.52V | 1.52V | 1.52V | 1.52V | + #| AcLoadline | 10.04 | 1.81 | 3.19 | 3.19 | + #| DcLoadline | 10.04 | 1.81 | 3.19 | 3.19 | + #+----------------+-------+-------+-------+-------+ + #Note: IccMax settings are moved to SoC code + register "domain_vr_config[VR_SYSTEM_AGENT]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = 0, + .voltage_limit = 1520, + .ac_loadline = 1004, + .dc_loadline = 1004, + }" + + register "domain_vr_config[VR_IA_CORE]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = 0, + .voltage_limit = 1520, + .ac_loadline = 181, + .dc_loadline = 181, + }" + + register "domain_vr_config[VR_GT_UNSLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = 0, + .voltage_limit = 1520, + .ac_loadline = 319, + .dc_loadline = 319, + }" + + register "domain_vr_config[VR_GT_SLICED]" = "{ + .vr_config_enable = 1, + .psi1threshold = VR_CFG_AMP(20), + .psi2threshold = VR_CFG_AMP(5), + .psi3threshold = VR_CFG_AMP(1), + .psi3enable = 1, + .psi4enable = 1, + .imon_slope = 0x0, + .imon_offset = 0x0, + .icc_max = 0, + .voltage_limit = 1520, + .ac_loadline = 319, + .dc_loadline = 319, + }" + end
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38479 )
Patch Set 4:
Automatic boot test returned (PASS/FAIL/TOTAL): 3/0/3 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : https://lava.9esec.io/r/213 EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/212 EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/211
Patch Set 4:
(4 comments)
https://review.coreboot.org/c/coreboot/+/38479/4//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/38479/4//COMMIT_MSG@7 PS4, Line 7: mb/google/puff: Add ac/dc loadline configuations Configure AC/DC loadline
https://review.coreboot.org/c/coreboot/+/38479/4//COMMIT_MSG@7 PS4, Line 7: configuations configurations
https://review.coreboot.org/c/coreboot/+/38479/4//COMMIT_MSG@9 PS4, Line 9: configuations configurations
https://review.coreboot.org/c/coreboot/+/38479/4//COMMIT_MSG@15 PS4, Line 15: log What log? coreboot log?
