Attention is currently required from: Sean Rhodes, Werner Zeh.
Mario Scheithauer has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/75858?usp=email )
Change subject: soc/intel/apollolake: Switch to snake case for DisableSataSalpSupport ......................................................................
For a unification of the naming convension, change from pascal case to snake case style for parameter 'DisableSataSalpSupport'.
Change-Id: I4a68ffd2b68c92434da681b5e5567329c8784c72 Signed-off-by: Mario Scheithauer mario.scheithauer@siemens.com --- M src/mainboard/siemens/mc_apl1/variants/mc_apl1/devicetree.cb M src/mainboard/siemens/mc_apl1/variants/mc_apl2/devicetree.cb M src/mainboard/siemens/mc_apl1/variants/mc_apl3/devicetree.cb M src/mainboard/siemens/mc_apl1/variants/mc_apl4/devicetree.cb M src/mainboard/siemens/mc_apl1/variants/mc_apl5/devicetree.cb M src/mainboard/siemens/mc_apl1/variants/mc_apl6/devicetree.cb M src/mainboard/siemens/mc_apl1/variants/mc_apl7/devicetree.cb M src/soc/intel/apollolake/chip.c M src/soc/intel/apollolake/chip.h 9 files changed, 9 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/58/75858/1
diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl1/devicetree.cb b/src/mainboard/siemens/mc_apl1/variants/mc_apl1/devicetree.cb index 5d4acd8..e5544a1 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl1/devicetree.cb +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl1/devicetree.cb @@ -71,7 +71,7 @@ device pci 12.0 on # - SATA register "sata_ports_enable[0]" = "1" register "sata_ports_enable[1]" = "1" - register "DisableSataSalpSupport" = "1" + register "disable_sata_salp_support" = "1" end device pci 13.0 on # - RP 2 - PCIe A 0 - MACPHY register "pcie_rp_clkreq_pin[2]" = "0" diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl2/devicetree.cb b/src/mainboard/siemens/mc_apl1/variants/mc_apl2/devicetree.cb index 7054413..ae9c3b1 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl2/devicetree.cb +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl2/devicetree.cb @@ -71,7 +71,7 @@ register "sata_ports_enable[1]" = "1" register "sata_ports_ssd[0]" = "1" register "sata_ports_ssd[1]" = "1" - register "DisableSataSalpSupport" = "1" + register "disable_sata_salp_support" = "1" register "sata_speed" = "SATA_GEN2" end device pci 13.0 on # - RP 2 - PCIe A 0 diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl3/devicetree.cb b/src/mainboard/siemens/mc_apl1/variants/mc_apl3/devicetree.cb index 472f5ba..74e30bb 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl3/devicetree.cb +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl3/devicetree.cb @@ -66,7 +66,7 @@ device pci 12.0 on # - SATA register "sata_ports_enable[0]" = "1" register "sata_ports_enable[1]" = "1" - register "DisableSataSalpSupport" = "1" + register "disable_sata_salp_support" = "1" end device pci 13.0 on # - RP 2 - PCIe A 0 register "pcie_rp_clkreq_pin[2]" = "CLKREQ_DISABLED" diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl4/devicetree.cb b/src/mainboard/siemens/mc_apl1/variants/mc_apl4/devicetree.cb index baaff1e..e5d80be 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl4/devicetree.cb +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl4/devicetree.cb @@ -60,7 +60,7 @@ device pci 12.0 on # - SATA register "sata_ports_enable[0]" = "1" register "sata_ports_enable[1]" = "1" - register "DisableSataSalpSupport" = "1" + register "disable_sata_salp_support" = "1" end device pci 13.0 on # - RP 2 - PCIe A 0 register "pcie_rp_clkreq_pin[2]" = "CLKREQ_DISABLED" diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl5/devicetree.cb b/src/mainboard/siemens/mc_apl1/variants/mc_apl5/devicetree.cb index 52fcd49..87e4cc2 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl5/devicetree.cb +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl5/devicetree.cb @@ -71,7 +71,7 @@ register "sata_ports_enable[1]" = "1" register "sata_ports_ssd[0]" = "1" register "sata_ports_ssd[1]" = "1" - register "DisableSataSalpSupport" = "1" + register "disable_sata_salp_support" = "1" register "sata_speed" = "SATA_GEN2" end device pci 13.0 on # - RP 2 - PCIe A 0 diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl6/devicetree.cb b/src/mainboard/siemens/mc_apl1/variants/mc_apl6/devicetree.cb index dc66be6..86e92d5 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl6/devicetree.cb +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl6/devicetree.cb @@ -42,7 +42,7 @@ register "sata_ports_enable[1]" = "1" register "sata_ports_ssd[0]" = "1" register "sata_ports_ssd[1]" = "1" - register "DisableSataSalpSupport" = "1" + register "disable_sata_salp_support" = "1" register "sata_speed" = "SATA_GEN2" end device pci 13.0 on # - RP 2 - PCIe A 0 diff --git a/src/mainboard/siemens/mc_apl1/variants/mc_apl7/devicetree.cb b/src/mainboard/siemens/mc_apl1/variants/mc_apl7/devicetree.cb index 0a080c3..6cf285f 100644 --- a/src/mainboard/siemens/mc_apl1/variants/mc_apl7/devicetree.cb +++ b/src/mainboard/siemens/mc_apl1/variants/mc_apl7/devicetree.cb @@ -58,7 +58,7 @@ device pci 0f.0 on end # - CSE device pci 11.0 on end # - ISH device pci 12.0 on # - SATA - register "DisableSataSalpSupport" = "1" + register "disable_sata_salp_support" = "1" end device pci 13.0 on # - RP 2 - PCIe A 0 register "pcie_rp_clkreq_pin[2]" = "CLKREQ_DISABLED" diff --git a/src/soc/intel/apollolake/chip.c b/src/soc/intel/apollolake/chip.c index 5f9b346..44daa5e 100644 --- a/src/soc/intel/apollolake/chip.c +++ b/src/soc/intel/apollolake/chip.c @@ -736,7 +736,7 @@
/* SATA config */ if (is_devfn_enabled(PCH_DEVFN_SATA)) { - silconfig->SataSalpSupport = !(cfg->DisableSataSalpSupport); + silconfig->SataSalpSupport = !(cfg->disable_sata_salp_support); ahci_set_speed(cfg->sata_speed); memcpy(silconfig->SataPortsEnable, cfg->sata_ports_enable, sizeof(silconfig->SataPortsEnable)); diff --git a/src/soc/intel/apollolake/chip.h b/src/soc/intel/apollolake/chip.h index 2d6b079..d43f3f0 100644 --- a/src/soc/intel/apollolake/chip.h +++ b/src/soc/intel/apollolake/chip.h @@ -221,7 +221,7 @@ uint8_t disable_xhci_lfps_pm;
/* SATA Aggressive Link Power Management */ - uint8_t DisableSataSalpSupport; + uint8_t disable_sata_salp_support;
/* Sata Power Optimisation */ uint8_t SataPwrOptimizeDisable;
