Paul Menzel (paulepanter@users.sourceforge.net) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3517
commit 9287f38d15781715dc858ef37b23b2127227f105 Author: Rudolf Marek r.marek@assembler.cz Date: Mon May 27 16:12:00 2013 +0200
asus/f2a85-m: Activate IOMMU support
Activate the IOMMU support for the Asus F2A85-M.
Add the device to `devicetree.cb`.
$ lspci -s 0.2 […] 00:00.2 IOMMU: Advanced Micro Devices [AMD] Family 15h (Models 10h-1fh) I/O Memory Management Unit $ dmesg […] [ 0.000000] ACPI: IVRS 00000000bf144e10 00070 (v02 AMD AMDIOMMU 00000001 AMD 00000000) [ 0.000000] ACPI: SSDT 00000000bf144e80 0051F (v02 AMD ALIB 00000001 MSFT 04000000) [ 0.000000] ACPI: SSDT 00000000bf1453a0 006B2 (v01 AMD POWERNOW 00000001 AMD 00000001) [ 0.000000] ACPI: SSDT 00000000bf145a52 00045 (v02 CORE COREBOOT 0000002A CORE 0000002A) […]
Linux 3.10 reported several IO page faults, which could never be explained and which the vendor firmware did not. These errors couldn’t be reproduced with Linux 4.1.
Change-Id: I0aa530be17d31656e65db6113343f2ea7008b843 Signed-off-by: Rudolf Marek r.marek@assembler.cz --- src/mainboard/asus/f2a85-m/buildOpts.c | 2 +- src/mainboard/asus/f2a85-m/devicetree.cb | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/src/mainboard/asus/f2a85-m/buildOpts.c b/src/mainboard/asus/f2a85-m/buildOpts.c index b812cd5..3c9371c 100644 --- a/src/mainboard/asus/f2a85-m/buildOpts.c +++ b/src/mainboard/asus/f2a85-m/buildOpts.c @@ -181,7 +181,7 @@ #define BLDCFG_UMA_ABOVE4G_SUPPORT FALSE #endif
-#define BLDCFG_IOMMU_SUPPORT FALSE +#define BLDCFG_IOMMU_SUPPORT TRUE
#define BLDCFG_CFG_GNB_HD_AUDIO TRUE //#define BLDCFG_IGPU_SUBSYSTEM_ID OEM_IGPU_SSID diff --git a/src/mainboard/asus/f2a85-m/devicetree.cb b/src/mainboard/asus/f2a85-m/devicetree.cb index 4562557..b501dc2 100644 --- a/src/mainboard/asus/f2a85-m/devicetree.cb +++ b/src/mainboard/asus/f2a85-m/devicetree.cb @@ -30,6 +30,7 @@ chip northbridge/amd/agesa/family15tn/root_complex
chip northbridge/amd/agesa/family15tn # PCI side of HT root complex device pci 0.0 on end # Root Complex + device pci 0.2 on end # IOMMU device pci 1.0 on end # Internal Graphics P2P bridge 0x99XX device pci 1.1 on end # Internal Multimedia device pci 2.0 on end # PCIE SLOT0 x16 blue
