Tim Wawrzynczak has submitted this change. ( https://review.coreboot.org/c/coreboot/+/62964 )
Change subject: drivers/tpm/cr50: Use cr50_get_firmware_version in get_board_cfg ......................................................................
cr50_get_board_cfg() may be called in ramstage for some mainboards in order to determine the BOARD_CFG register's value. The code was written assuming that the firmware version was already retrieved, but for boards calling this in ramstage, this is not the case. Therefore, instead of using the cached cr50_firmware_version (which is all 0s in ramstage at that time), use the cr50_get_firmware_version function instead.
BUG=b:225206079, b:220685274 BRANCH=firmware-brya-14505.B TEST=boot on brya0 and see: [INFO ] Firmware version: B2-C:0 RO_B:0.0.11/4d655eab RW_B:0.6.93/cr50_v3.94 [INFO ] Enabling GPIO PM b/c CR50 has long IRQ pulse support in the logs.
Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Change-Id: Ia6e5f4965a8852793d2f95e6eb21ea87860335a9 Reviewed-on: https://review.coreboot.org/c/coreboot/+/62964 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Julius Werner jwerner@chromium.org Reviewed-by: Subrata Banik subratabanik@google.com --- M src/drivers/tpm/cr50.c 1 file changed, 13 insertions(+), 5 deletions(-)
Approvals: build bot (Jenkins): Verified Julius Werner: Looks good to me, approved Subrata Banik: Looks good to me, approved
diff --git a/src/drivers/tpm/cr50.c b/src/drivers/tpm/cr50.c index f96e174..1d6c691 100644 --- a/src/drivers/tpm/cr50.c +++ b/src/drivers/tpm/cr50.c @@ -13,8 +13,6 @@ (CONFIG(CR50_USE_LONG_INTERRUPT_PULSES) \ ? CR50_BOARD_CFG_100US_READY_PULSE : 0)
-static struct cr50_firmware_version cr50_firmware_version; - enum cr50_register { CR50_FW_VER_REG, CR50_BOARD_CFG_REG, @@ -74,9 +72,13 @@ */ static uint32_t cr50_get_board_cfg(void) { + struct cr50_firmware_version ver; uint32_t value;
- if (!cr50_fw_supports_board_cfg(&cr50_firmware_version)) + if (cr50_get_firmware_version(&ver) != CB_SUCCESS) + return 0; + + if (!cr50_fw_supports_board_cfg(&ver)) return 0;
const enum cb_err ret = tis_vendor_read(get_reg_addr(CR50_BOARD_CFG_REG), &value, @@ -94,10 +96,14 @@ */ enum cb_err cr50_set_board_cfg(void) { - uint32_t value; + struct cr50_firmware_version ver; enum cb_err ret; + uint32_t value;
- if (!cr50_fw_supports_board_cfg(&cr50_firmware_version)) + if (cr50_get_firmware_version(&ver) != CB_SUCCESS) + return CB_ERR; + + if (!cr50_fw_supports_board_cfg(&ver)) return CB_ERR;
/* Set the CR50_BOARD_CFG register, for e.g. asking cr50 to use longer ready pulses. */ @@ -167,6 +173,8 @@
enum cb_err cr50_get_firmware_version(struct cr50_firmware_version *version) { + static struct cr50_firmware_version cr50_firmware_version; + if (cr50_firmware_version.epoch || cr50_firmware_version.major || cr50_firmware_version.minor) goto success;
