Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/56762 )
Change subject: mb/google/dedede: Create bugzzy variant ......................................................................
Create the bugzzy variant of the waddledoo reference board by copying the template files to a new directory named for the variant.
(Auto-Generated by create_coreboot_variant.sh version 4.5.0).
BUG=b:192521391 BRANCH=None TEST=util/abuild/abuild -p none -t google/dedede -x -a make sure the build includes GOOGLE_BUGZZY
Signed-off-by: Raymond Chung raymondchung@ami.corp-partner.google.com Change-Id: I851b9a75c387586d2fb84b762788e962f33472b5 Reviewed-on: https://review.coreboot.org/c/coreboot/+/56762 Reviewed-by: Karthik Ramasubramanian kramasub@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/dedede/Kconfig M src/mainboard/google/dedede/Kconfig.name A src/mainboard/google/dedede/variants/bugzzy/include/variant/ec.h A src/mainboard/google/dedede/variants/bugzzy/include/variant/gpio.h A src/mainboard/google/dedede/variants/bugzzy/memory/Makefile.inc A src/mainboard/google/dedede/variants/bugzzy/memory/dram_id.generated.txt A src/mainboard/google/dedede/variants/bugzzy/memory/mem_parts_used.txt A src/mainboard/google/dedede/variants/bugzzy/overridetree.cb 8 files changed, 97 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Karthik Ramasubramanian: Looks good to me, approved Raymond Chung: Looks good to me, but someone else must approve
diff --git a/src/mainboard/google/dedede/Kconfig b/src/mainboard/google/dedede/Kconfig index 3cf1a3a..9437ddc 100644 --- a/src/mainboard/google/dedede/Kconfig +++ b/src/mainboard/google/dedede/Kconfig @@ -111,6 +111,7 @@ default "Haboki" if BOARD_GOOGLE_HABOKI default "Cappy" if BOARD_GOOGLE_CAPPY default "Cappy2" if BOARD_GOOGLE_CAPPY2 + default "Bugzzy" if BOARD_GOOGLE_BUGZZY
config MAX_CPUS int @@ -148,6 +149,7 @@ default "haboki" if BOARD_GOOGLE_HABOKI default "cappy" if BOARD_GOOGLE_CAPPY default "cappy2" if BOARD_GOOGLE_CAPPY2 + default "bugzzy" if BOARD_GOOGLE_BUGZZY
endif #BOARD_GOOGLE_BASEBOARD_DEDEDE
diff --git a/src/mainboard/google/dedede/Kconfig.name b/src/mainboard/google/dedede/Kconfig.name index 6cdd4de..98a2298 100644 --- a/src/mainboard/google/dedede/Kconfig.name +++ b/src/mainboard/google/dedede/Kconfig.name @@ -159,3 +159,10 @@ bool "-> Cappy2" select BOARD_GOOGLE_BASEBOARD_DEDEDE_TPM2 select BASEBOARD_DEDEDE_LAPTOP + +config BOARD_GOOGLE_BUGZZY + bool "-> Bugzzy" + select BOARD_GOOGLE_BASEBOARD_DEDEDE_CR50 + select BASEBOARD_DEDEDE_LAPTOP + select DRIVERS_GENERIC_MAX98357A + select DRIVERS_I2C_DA7219 diff --git a/src/mainboard/google/dedede/variants/bugzzy/include/variant/ec.h b/src/mainboard/google/dedede/variants/bugzzy/include/variant/ec.h new file mode 100644 index 0000000..08870e0 --- /dev/null +++ b/src/mainboard/google/dedede/variants/bugzzy/include/variant/ec.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef MAINBOARD_EC_H +#define MAINBOARD_EC_H + +#include <baseboard/ec.h> + +#endif diff --git a/src/mainboard/google/dedede/variants/bugzzy/include/variant/gpio.h b/src/mainboard/google/dedede/variants/bugzzy/include/variant/gpio.h new file mode 100644 index 0000000..9078664 --- /dev/null +++ b/src/mainboard/google/dedede/variants/bugzzy/include/variant/gpio.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef MAINBOARD_GPIO_H +#define MAINBOARD_GPIO_H + +#include <baseboard/gpio.h> + +#endif /* MAINBOARD_GPIO_H */ diff --git a/src/mainboard/google/dedede/variants/bugzzy/memory/Makefile.inc b/src/mainboard/google/dedede/variants/bugzzy/memory/Makefile.inc new file mode 100644 index 0000000..b0ca222 --- /dev/null +++ b/src/mainboard/google/dedede/variants/bugzzy/memory/Makefile.inc @@ -0,0 +1,5 @@ +## SPDX-License-Identifier: GPL-2.0-or-later +## This is an auto-generated file. Do not edit!! +## Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. + +SPD_SOURCES = placeholder.spd.hex diff --git a/src/mainboard/google/dedede/variants/bugzzy/memory/dram_id.generated.txt b/src/mainboard/google/dedede/variants/bugzzy/memory/dram_id.generated.txt new file mode 100644 index 0000000..fa24790 --- /dev/null +++ b/src/mainboard/google/dedede/variants/bugzzy/memory/dram_id.generated.txt @@ -0,0 +1 @@ +DRAM Part Name ID to assign diff --git a/src/mainboard/google/dedede/variants/bugzzy/memory/mem_parts_used.txt b/src/mainboard/google/dedede/variants/bugzzy/memory/mem_parts_used.txt new file mode 100644 index 0000000..e4258b5 --- /dev/null +++ b/src/mainboard/google/dedede/variants/bugzzy/memory/mem_parts_used.txt @@ -0,0 +1,11 @@ +# This is a CSV file containing a list of memory parts used by this variant. +# One part per line with an optional fixed ID in column 2. +# Only include a fixed ID if it is required for legacy reasons! +# Generated IDs are dependent on the order of parts in this file, +# so new parts must always be added at the end of the file! +# +# Generate an updated Makefile.inc and dram_id.generated.txt by running the +# gen_part_id tool from util/spd_tools/{ddr4,lp4x}. +# See util/spd_tools/{ddr4,lp4x}/README.md for more details and instructions. + +# Part Name diff --git a/src/mainboard/google/dedede/variants/bugzzy/overridetree.cb b/src/mainboard/google/dedede/variants/bugzzy/overridetree.cb new file mode 100644 index 0000000..df3fb86 --- /dev/null +++ b/src/mainboard/google/dedede/variants/bugzzy/overridetree.cb @@ -0,0 +1,55 @@ +chip soc/intel/jasperlake + + # USB Port Configuration + register "usb2_ports[5]" = "USB2_PORT_MID(OC_SKIP)" # Camera + + # Intel Common SoC Config + #+-------------------+---------------------------+ + #| Field | Value | + #+-------------------+---------------------------+ + #| GSPI0 | cr50 TPM. Early init is | + #| | required to set up a BAR | + #| | for TPM communication | + #| | before memory is up | + #| I2C0 | Trackpad | + #| I2C1 | Digitizer | + #| I2C2 | Touchscreen | + #| I2C3 | Camera | + #| I2C4 | Audio | + #+-------------------+---------------------------+ + register "common_soc_config" = "{ + .gspi[0] = { + .speed_mhz = 1, + .early_init = 1, + }, + .i2c[0] = { + .speed = I2C_SPEED_FAST, + .rise_time_ns = 66, + .fall_time_ns = 90, + .data_hold_time_ns = 350, + }, + .i2c[1] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[2] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[3] = { + .speed = I2C_SPEED_FAST, + }, + .i2c[4] = { + .speed = I2C_SPEED_FAST, + .speed_config[0] = { + .speed = I2C_SPEED_FAST, + } + }, + }" + device domain 0 on + device pci 14.0 on end + device pci 15.0 on end + device pci 15.2 on end + device pci 1c.7 on end + device pci 19.0 on end + device pci 1f.3 on end + end +end
