Attention is currently required from: Shelley Chen, Ravi kumar, Taniya Das, mturney mturney. mturney mturney has uploaded a new patch set (#4) to the change originally created by Ravi kumar. ( https://review.coreboot.org/c/coreboot/+/56587 )
Change subject: qualcomm/sc7180: Cleanups for drivers with common clock ......................................................................
As we move to use the common clock driver, the sc7180 clock driver, watchdog and display drivers requires few cleanups, thus update the impacted drivers.
Earlier the display client is expected to provide 2n divider value, as the divider value in register is in form "2n-1". mdss_clk_cfg.div = half_divider ? (half_divider - 1) : 0;
The older convention in the upcoming patches would be replaced with the common macro of QCOM_CLOCK_DIV, thus need the divider needs to be updated. mdss_clk_cfg.div = half_divider ? QCOM_CLOCK_DIV(half_divider) : 0;
To accommodate impacting the functionality, the half_divider is taken care in the clock driver.
BUG=b:182963902 TEST=Validated on qualcomm sc7180 development board
Change-Id: Ic334fd0d43e5b4b1e43a27d5db7665f0bc151d66 Signed-off-by: Taniya Das tdas@codeaurora.org --- M src/soc/qualcomm/sc7180/clock.c M src/soc/qualcomm/sc7180/display/dsi_phy.c M src/soc/qualcomm/sc7180/include/soc/clock.h M src/soc/qualcomm/sc7180/watchdog.c 4 files changed, 65 insertions(+), 58 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/56587/4
