Attention is currently required from: Hung-Te Lin, Martin Roth, Paul Menzel, Julius Werner, Marty E. Plummer.
Rex-BC Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/58054 )
Change subject: payloads: Add UefiPayload support to ARM64 platforms
Patch Set 7:
Patchset:
PS6:
modify sys-boot/edk2/edk2-9999.ebuild for this. […]
I have encounter this error:
cros/src/third_party/coreboot$ make -j
toolchain.inc:166: The coreboot toolchain for 'arm64' architecture was not found.
toolchain.inc:176: The coreboot toolchain version of iasl '20210331' was not found
toolchain.inc:202:
toolchain.inc:203: To build the entire coreboot toolchain: run 'make crossgcc'
toolchain.inc:205: To build just IASL: run 'make iasl'
toolchain.inc:207: For more toolchain build targets: run 'make help_toolchain'
toolchain.inc:208:
toolchain.inc:210: To try to use any toolchain in your path, run 'make menuconfig', then select
toolchain.inc:212: the config option: 'General setup', and 'Allow building with any toolchain'
toolchain.inc:214: Note that this is NOT supported. Using it means you're on your own.
toolchain.inc:216:
toolchain.inc:218: *** Halting the build. Stop.
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: I10777a341d46240b91ceeeb1be26c33a0c5db839
Gerrit-Change-Number: 58054
Gerrit-PatchSet: 7
Gerrit-Owner: Rex-BC Chen
rex-bc.chen@mediatek.corp-partner.google.com
Gerrit-Reviewer: Hung-Te Lin
hungte@chromium.org
Gerrit-Reviewer: Julius Werner
jwerner@chromium.org
Gerrit-Reviewer: Martin Roth
martinroth@google.com
Gerrit-Reviewer: Rex-BC Chen
Gerrit-Reviewer: Stefan Reinauer
stefan.reinauer@coreboot.org
Gerrit-Reviewer: Yu-Ping Wu
yupingso@google.com
no-reply@coreboot.org
Gerrit-CC: Marty E. Plummer
hanetzer@startmail.com
Gerrit-CC: Paul Menzel
paulepanter@mailbox.org
Gerrit-Attention: Hung-Te Lin
hungte@chromium.org
Gerrit-Attention: Martin Roth
Gerrit-Attention: Paul Menzel
Gerrit-Attention: Julius Werner
Gerrit-Attention: Marty E. Plummer
Gerrit-Comment-Date: Wed, 06 Oct 2021 03:44:28 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Hung-Te Lin
hungte@chromium.org
Comment-In-Reply-To: Rex-BC Chen
Gerrit-MessageType: comment
