Attention is currently required from: Arthur Heymans, Christian Walter, Dinesh Gehlot, Eran Mitrani, Jakub Czapiga, Jeff Daly, Johnny Lin, Jonathan Zhang, Kapil Porwal, Lean Sheng Tan, Nick Vaccaro, Sean Rhodes, Subrata Banik, Tarun, Tim Chu, Vanessa Eusebio, Werner Zeh.
Felix Singer has uploaded a new patch set (#2) to the change originally created by Martin L Roth. ( https://review.coreboot.org/c/coreboot/+/80073?usp=email )
Change subject: soc/intel: Rename Makefiles from .inc to .mk ......................................................................
The .inc suffix is confusing to various tools as it's not specific to Makefiles. This means that editors don't recognize the files, and don't open them with highlighting and any other specific editor functionality.
This issue is also seen in the release notes generation script where Makefiles get renamed before running cloc.
Signed-off-by: Martin Roth gaumless@gmail.com Change-Id: Ib479b93b7d0b2e790d0495b6a6b4b4298a515d9a --- R src/soc/intel/Makefile.mk R src/soc/intel/alderlake/Makefile.mk R src/soc/intel/alderlake/romstage/Makefile.mk R src/soc/intel/apollolake/Makefile.mk R src/soc/intel/baytrail/Makefile.mk R src/soc/intel/baytrail/romstage/Makefile.mk R src/soc/intel/braswell/Makefile.mk R src/soc/intel/braswell/romstage/Makefile.mk R src/soc/intel/broadwell/Makefile.mk R src/soc/intel/broadwell/pch/Makefile.mk R src/soc/intel/cannonlake/Makefile.mk M src/soc/intel/cannonlake/cnl_memcfg_init.c R src/soc/intel/cannonlake/romstage/Makefile.mk R src/soc/intel/common/Makefile.mk R src/soc/intel/common/basecode/Makefile.mk R src/soc/intel/common/basecode/debug/Makefile.mk R src/soc/intel/common/basecode/ramtop/Makefile.mk R src/soc/intel/common/block/Makefile.mk R src/soc/intel/common/block/acpi/Makefile.mk R src/soc/intel/common/block/chip/Makefile.mk R src/soc/intel/common/block/cnvi/Makefile.mk R src/soc/intel/common/block/cpu/Makefile.mk R src/soc/intel/common/block/crashlog/Makefile.mk R src/soc/intel/common/block/cse/Makefile.mk R src/soc/intel/common/block/dsp/Makefile.mk R src/soc/intel/common/block/dtt/Makefile.mk R src/soc/intel/common/block/fast_spi/Makefile.mk R src/soc/intel/common/block/gpio/Makefile.mk R src/soc/intel/common/block/gpmr/Makefile.mk R src/soc/intel/common/block/graphics/Makefile.mk R src/soc/intel/common/block/gspi/Makefile.mk R src/soc/intel/common/block/hda/Makefile.mk R src/soc/intel/common/block/i2c/Makefile.mk R src/soc/intel/common/block/ioc/Makefile.mk R src/soc/intel/common/block/ipu/Makefile.mk R src/soc/intel/common/block/irq/Makefile.mk R src/soc/intel/common/block/itss/Makefile.mk R src/soc/intel/common/block/lpc/Makefile.mk R src/soc/intel/common/block/lpss/Makefile.mk R src/soc/intel/common/block/memory/Makefile.mk R src/soc/intel/common/block/oc_wdt/Makefile.mk R src/soc/intel/common/block/p2sb/Makefile.mk R src/soc/intel/common/block/pcie/Makefile.mk R src/soc/intel/common/block/pcie/rtd3/Makefile.mk R src/soc/intel/common/block/pcr/Makefile.mk R src/soc/intel/common/block/pmc/Makefile.mk R src/soc/intel/common/block/power_limit/Makefile.mk R src/soc/intel/common/block/rtc/Makefile.mk R src/soc/intel/common/block/sata/Makefile.mk R src/soc/intel/common/block/scs/Makefile.mk R src/soc/intel/common/block/sgx/Makefile.mk R src/soc/intel/common/block/smbus/Makefile.mk R src/soc/intel/common/block/smm/Makefile.mk R src/soc/intel/common/block/spi/Makefile.mk R src/soc/intel/common/block/sram/Makefile.mk R src/soc/intel/common/block/systemagent/Makefile.mk R src/soc/intel/common/block/tcss/Makefile.mk R src/soc/intel/common/block/thermal/Makefile.mk R src/soc/intel/common/block/timer/Makefile.mk R src/soc/intel/common/block/tracehub/Makefile.mk R src/soc/intel/common/block/uart/Makefile.mk R src/soc/intel/common/block/usb4/Makefile.mk R src/soc/intel/common/block/vtd/Makefile.mk R src/soc/intel/common/block/xdci/Makefile.mk R src/soc/intel/common/block/xhci/Makefile.mk R src/soc/intel/common/pch/Makefile.mk R src/soc/intel/common/pch/lockdown/Makefile.mk R src/soc/intel/denverton_ns/Makefile.mk R src/soc/intel/elkhartlake/Makefile.mk R src/soc/intel/elkhartlake/romstage/Makefile.mk R src/soc/intel/jasperlake/Makefile.mk R src/soc/intel/jasperlake/romstage/Makefile.mk R src/soc/intel/meteorlake/Makefile.mk R src/soc/intel/meteorlake/romstage/Makefile.mk R src/soc/intel/skylake/Makefile.mk R src/soc/intel/skylake/nhlt/Makefile.mk R src/soc/intel/skylake/romstage/Makefile.mk R src/soc/intel/tigerlake/Makefile.mk R src/soc/intel/tigerlake/romstage/Makefile.mk R src/soc/intel/xeon_sp/Makefile.mk R src/soc/intel/xeon_sp/cpx/Makefile.mk R src/soc/intel/xeon_sp/ebg/Makefile.mk R src/soc/intel/xeon_sp/lbg/Makefile.mk R src/soc/intel/xeon_sp/ras/Makefile.mk R src/soc/intel/xeon_sp/skx/Makefile.mk R src/soc/intel/xeon_sp/spr/Makefile.mk 86 files changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/73/80073/2
