Attention is currently required from: Arthur Heymans, Bill XIE, Jonathan Zhang, Eric Lai, Werner Zeh, Kyösti Mälkki.
Jonathan Zhang has uploaded a new patch set (#14) to the change originally created by Nico Huber. ( https://review.coreboot.org/c/coreboot/+/65420 )
Change subject: allocator_v4: Use memranges only for toplevel ......................................................................
During phase 1 of the resource allocation we gather all the size requirements. Starting from the leafs of our devicetree, we cal- culate the requirements per bus, until we reach the resource do- main.
However, because alignment plays a role, we can't just accumulate the sizes of all resources on a bus. Instead, we already sort all the resources per bus to predict their relative placement, inclu- ding alignment gaps. Then, phase 2 has to perform the final allo- cations with the exact same relative placement.
This patch introduces a very simple mechanism to avoid repeating all the calculations: In phase 1, we note the relative `base` of each resource on a bus. And after we allocated all the resources directly below the domain in phase 2, we add the absolute `base` of bridge resources to the relative `base` of child resources.
This saves most of the computational complexity in phase 2. How- ever, with a shallow devicetree with most devices directly below the domain, this won't have a measurable impact.
Example after phase 1:
domain | `-- bridge #0 | res #0, base 0x000000 (relative), | size 12M, align 8M | |-- device #0 | res #1, base 0x800000 (relative), | size 4M, align 4M | `-- bridge #1 | res #2, base 0x000000 (relative), | size 8M, align 8M | `-- device #1 res #3, base 0x000000 (relative), size 8M, align 8M
After phase 2 allocation at the domain level (assuming res #0 got 0xa000000 assigned):
domain | `-- bridge #0 | res #0, base 0xa000000 (absolute), | size 12M, align 8M | |-- device #0 | res #1, base 0x800000 (relative), | size 4M, align 4M | `-- bridge #1 | res #2, base 0x000000 (relative), | size 8M, align 8M | `-- device #1 res #3, base 0x000000 (relative), size 8M, align 8M
Now, all we need to do is to add the `base` of bridge resources recursively. Starting with resources on the bus below bridge #0:
domain | `-- bridge #0 | res #0, base 0xa000000 (absolute), | size 12M, align 8M | |-- device #0 | res #1, base 0xa800000 (absolute), | size 4M, align 4M | `-- bridge #1 | res #2, base 0xa000000 (absolute), | size 8M, align 8M | `-- device #1 res #3, base 0x000000 (relative), size 8M, align 8M
And finally for resources on the bus below bridge #1:
domain | `-- bridge #0 | res #0, base 0xa000000 (absolute), | size 12M, align 8M | |-- device #0 | res #1, base 0xa800000 (absolute), | size 4M, align 4M | `-- bridge #1 | res #2, base 0xa000000 (absolute), | size 8M, align 8M | `-- device #1 res #3, base 0xa000000 (absolute), size 8M, align 8M
Change-Id: I70c700318a85f6760f27597730bc9c9a86dbe6b3 Signed-off-by: Nico Huber nico.h@gmx.de --- M src/device/resource_allocator_v4.c 1 file changed, 260 insertions(+), 267 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/65420/14
