Attention is currently required from: Tim Wawrzynczak, Sridhar Siricilla, Patrick Rudolph. Hello build bot (Jenkins), Tim Wawrzynczak, Sridhar Siricilla, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/58157
Change subject: soc/intel/common/cse: Reorganize firmware update checks for CSE Lite ......................................................................
`cse_fw_update()` is currently checking whether an update is required by comparing versions once and then again comparing versions later in `cse_is_downgrade_instance()` to determine if the update is an upgrade or downgrade. Additionally, if CSE RW partition is corrupt (determined based on `cse_is_rw_bp_sign_valid()`), `cse_is_downgrade_instance()` ends up using the corrupted version information to determine if it is a downgrade instance.
This change reorganizes the firmware update checks to return different status values: 1. CSE_UPDATE_NOT_REQUIRED: No update required. Versions match. 2. CSE_UPDATE_UPGRADE: Update required and it is an upgrade. 3. CSE_UPDATE_DOWNGRADE: Update required and it is a downgrade (requires data clear). 4. CSE_UPDATE_CORRUPTED: `cse_is_rw_bp_sign_valid()` failed and hence requires data clear. 5. CSE_UPDATE_METADATA_ERROR: Unable to read CSE metadata from CBFS.
This change also prepares the file for follow up changes which completely drop cse_rw_metadata structure.
BUG=b:184892226
Change-Id: Iabecab8e373e65a11ba7fe1bfc125467571a0588 Signed-off-by: Furquan Shaikh furquan@google.com --- M src/soc/intel/common/block/cse/cse_lite.c 1 file changed, 60 insertions(+), 56 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/57/58157/5
