Patrick Georgi (patrick@georgi-clan.de) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6664
commit 6b8d490b610f1717efa22d18f44bd1e2faf19ce2 Author: Patrick Georgi patrick@georgi-clan.de Date: Thu Aug 14 20:23:51 2014 +0200
exynos5xx0: rename local "main" variable
Change-Id: I9a454c88c65e4e70d351f1ec781e75ba400ceb29 Signed-off-by: Patrick Georgi patrick@georgi-clan.de --- src/cpu/samsung/exynos5250/clock.c | 8 ++++---- src/cpu/samsung/exynos5420/clock.c | 8 ++++---- 2 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/src/cpu/samsung/exynos5250/clock.c b/src/cpu/samsung/exynos5250/clock.c index f012c20..8a731be 100644 --- a/src/cpu/samsung/exynos5250/clock.c +++ b/src/cpu/samsung/exynos5250/clock.c @@ -528,7 +528,7 @@ static int clock_calc_best_scalar(unsigned int main_scaler_bits,
int clock_set_rate(enum periph_id periph_id, unsigned int rate) { - int main; + int main_scalar; unsigned int fine;
switch (periph_id) { @@ -537,13 +537,13 @@ int clock_set_rate(enum periph_id periph_id, unsigned int rate) case PERIPH_ID_SPI2: case PERIPH_ID_SPI3: case PERIPH_ID_SPI4: - main = clock_calc_best_scalar(4, 8, 400000000, rate, &fine); - if (main < 0) { + main_scalar = clock_calc_best_scalar(4, 8, 400000000, rate, &fine); + if (main_scalar < 0) { printk(BIOS_DEBUG, "%s: Cannot set clock rate for periph %d", __func__, periph_id); return -1; } - clock_ll_set_ratio(periph_id, main - 1); + clock_ll_set_ratio(periph_id, main_scalar - 1); clock_ll_set_pre_ratio(periph_id, fine - 1); break; default: diff --git a/src/cpu/samsung/exynos5420/clock.c b/src/cpu/samsung/exynos5420/clock.c index f7436f2..7043310 100644 --- a/src/cpu/samsung/exynos5420/clock.c +++ b/src/cpu/samsung/exynos5420/clock.c @@ -492,7 +492,7 @@ static int clock_calc_best_scalar(unsigned int main_scaler_bits,
switch (periph_id) { @@ -501,13 +501,13 @@ int clock_set_rate(enum periph_id periph_id, unsigned int rate) case PERIPH_ID_SPI2: case PERIPH_ID_SPI3: case PERIPH_ID_SPI4: - main = clock_calc_best_scalar(4, 8, 400000000, rate, &fine); - if (main < 0) { + main_scalar = clock_calc_best_scalar(4, 8, 400000000, rate, &fine); + if (main_scalar < 0) { printk(BIOS_DEBUG, "%s: Cannot set clock rate for periph %d", __func__, periph_id); return -1; } - clock_ll_set_ratio(periph_id, main - 1); + clock_ll_set_ratio(periph_id, main_scalar - 1); clock_ll_set_pre_ratio(periph_id, fine - 1); break; default:
