Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9138
commit c55feac98b61481add52ac7737ba33998450dc96 Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Fri Mar 27 22:49:18 2015 -0500
mainboards/amdfam10: Copy DIMM information to cbmem after romstage
src/northbridge/amd/amdfam10: Add amdmct_cbmem_store_info() function.
Change-Id: I07376e276e3e9e3247d2576a09e58780d32a3a76 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/mainboard/advansus/a785e-i/romstage.c | 2 ++ src/mainboard/amd/bimini_fam10/romstage.c | 2 ++ src/mainboard/amd/mahogany_fam10/romstage.c | 2 ++ .../amd/serengeti_cheetah_fam10/romstage.c | 2 ++ src/mainboard/amd/tilapia_fam10/romstage.c | 2 ++ src/mainboard/asus/kfsn4-dre/romstage.c | 2 ++ src/mainboard/asus/m4a78-em/romstage.c | 2 ++ src/mainboard/asus/m4a785-m/romstage.c | 2 ++ src/mainboard/asus/m5a88-v/romstage.c | 2 ++ src/mainboard/avalue/eax-785e/romstage.c | 2 ++ src/mainboard/gigabyte/ma785gm/romstage.c | 2 ++ src/mainboard/gigabyte/ma785gmt/romstage.c | 2 ++ src/mainboard/gigabyte/ma78gm/romstage.c | 2 ++ src/mainboard/hp/dl165_g6_fam10/romstage.c | 2 ++ src/mainboard/iei/kino-780am2-fam10/romstage.c | 2 ++ src/mainboard/jetway/pa78vm5/romstage.c | 2 ++ src/mainboard/msi/ms9652_fam10/romstage.c | 2 ++ src/mainboard/supermicro/h8dmr_fam10/romstage.c | 2 ++ src/mainboard/supermicro/h8qme_fam10/romstage.c | 2 ++ src/mainboard/supermicro/h8scm_fam10/romstage.c | 2 ++ src/mainboard/tyan/s2912_fam10/romstage.c | 2 ++ src/northbridge/amd/amdfam10/raminit_amdmct.c | 40 ++++++++++++++++++++++ 22 files changed, 82 insertions(+)
diff --git a/src/mainboard/advansus/a785e-i/romstage.c b/src/mainboard/advansus/a785e-i/romstage.c index a70c269..e94d1e1 100644 --- a/src/mainboard/advansus/a785e-i/romstage.c +++ b/src/mainboard/advansus/a785e-i/romstage.c @@ -210,6 +210,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/amd/bimini_fam10/romstage.c b/src/mainboard/amd/bimini_fam10/romstage.c index f4df3a3..299bc5e 100644 --- a/src/mainboard/amd/bimini_fam10/romstage.c +++ b/src/mainboard/amd/bimini_fam10/romstage.c @@ -208,6 +208,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/amd/mahogany_fam10/romstage.c b/src/mainboard/amd/mahogany_fam10/romstage.c index 501c8c3..669e152 100644 --- a/src/mainboard/amd/mahogany_fam10/romstage.c +++ b/src/mainboard/amd/mahogany_fam10/romstage.c @@ -210,6 +210,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/amd/serengeti_cheetah_fam10/romstage.c b/src/mainboard/amd/serengeti_cheetah_fam10/romstage.c index 2932c83..a330ccd 100644 --- a/src/mainboard/amd/serengeti_cheetah_fam10/romstage.c +++ b/src/mainboard/amd/serengeti_cheetah_fam10/romstage.c @@ -322,6 +322,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/amd/tilapia_fam10/romstage.c b/src/mainboard/amd/tilapia_fam10/romstage.c index 97bf51a..8c6a8ce 100644 --- a/src/mainboard/amd/tilapia_fam10/romstage.c +++ b/src/mainboard/amd/tilapia_fam10/romstage.c @@ -210,6 +210,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/asus/kfsn4-dre/romstage.c b/src/mainboard/asus/kfsn4-dre/romstage.c index af6858f..9680174 100644 --- a/src/mainboard/asus/kfsn4-dre/romstage.c +++ b/src/mainboard/asus/kfsn4-dre/romstage.c @@ -353,6 +353,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + printk(BIOS_DEBUG, "disable_spd()\n"); ck804_control(ctrl_conf_disable_spd, ARRAY_SIZE(ctrl_conf_disable_spd), CK804_DEVN_BASE);
diff --git a/src/mainboard/asus/m4a78-em/romstage.c b/src/mainboard/asus/m4a78-em/romstage.c index da63c66..e2e60ab 100644 --- a/src/mainboard/asus/m4a78-em/romstage.c +++ b/src/mainboard/asus/m4a78-em/romstage.c @@ -212,6 +212,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/asus/m4a785-m/romstage.c b/src/mainboard/asus/m4a785-m/romstage.c index e0c132f..e43dc05 100644 --- a/src/mainboard/asus/m4a785-m/romstage.c +++ b/src/mainboard/asus/m4a785-m/romstage.c @@ -212,6 +212,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/asus/m5a88-v/romstage.c b/src/mainboard/asus/m5a88-v/romstage.c index cc4d04d..23bdb97 100644 --- a/src/mainboard/asus/m5a88-v/romstage.c +++ b/src/mainboard/asus/m5a88-v/romstage.c @@ -207,6 +207,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/avalue/eax-785e/romstage.c b/src/mainboard/avalue/eax-785e/romstage.c index 5cc9fb1..ee83fb5 100644 --- a/src/mainboard/avalue/eax-785e/romstage.c +++ b/src/mainboard/avalue/eax-785e/romstage.c @@ -211,6 +211,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/gigabyte/ma785gm/romstage.c b/src/mainboard/gigabyte/ma785gm/romstage.c index 991531d..f1fdfc0 100644 --- a/src/mainboard/gigabyte/ma785gm/romstage.c +++ b/src/mainboard/gigabyte/ma785gm/romstage.c @@ -207,6 +207,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/gigabyte/ma785gmt/romstage.c b/src/mainboard/gigabyte/ma785gmt/romstage.c index a022a20..cee66fa 100644 --- a/src/mainboard/gigabyte/ma785gmt/romstage.c +++ b/src/mainboard/gigabyte/ma785gmt/romstage.c @@ -207,6 +207,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/gigabyte/ma78gm/romstage.c b/src/mainboard/gigabyte/ma78gm/romstage.c index 7675e25..5ba5f15 100644 --- a/src/mainboard/gigabyte/ma78gm/romstage.c +++ b/src/mainboard/gigabyte/ma78gm/romstage.c @@ -210,6 +210,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/hp/dl165_g6_fam10/romstage.c b/src/mainboard/hp/dl165_g6_fam10/romstage.c index bf054d5..9610dda 100644 --- a/src/mainboard/hp/dl165_g6_fam10/romstage.c +++ b/src/mainboard/hp/dl165_g6_fam10/romstage.c @@ -214,6 +214,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + bcm5785_early_setup();
timestamp_add_now(TS_END_ROMSTAGE); diff --git a/src/mainboard/iei/kino-780am2-fam10/romstage.c b/src/mainboard/iei/kino-780am2-fam10/romstage.c index 5f99df6..0d1fd89 100644 --- a/src/mainboard/iei/kino-780am2-fam10/romstage.c +++ b/src/mainboard/iei/kino-780am2-fam10/romstage.c @@ -210,6 +210,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/jetway/pa78vm5/romstage.c b/src/mainboard/jetway/pa78vm5/romstage.c index 1686988..1467a9e 100644 --- a/src/mainboard/jetway/pa78vm5/romstage.c +++ b/src/mainboard/jetway/pa78vm5/romstage.c @@ -215,6 +215,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/msi/ms9652_fam10/romstage.c b/src/mainboard/msi/ms9652_fam10/romstage.c index b2bfc8b..4231675 100644 --- a/src/mainboard/msi/ms9652_fam10/romstage.c +++ b/src/mainboard/msi/ms9652_fam10/romstage.c @@ -241,6 +241,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + timestamp_add_now(TS_END_ROMSTAGE);
post_cache_as_ram(); // BSP switch stack to ram, copy then execute LB. diff --git a/src/mainboard/supermicro/h8dmr_fam10/romstage.c b/src/mainboard/supermicro/h8dmr_fam10/romstage.c index 980437b..e1707ac 100644 --- a/src/mainboard/supermicro/h8dmr_fam10/romstage.c +++ b/src/mainboard/supermicro/h8dmr_fam10/romstage.c @@ -238,6 +238,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
post_cache_as_ram(); // BSP switch stack to ram, copy + execute stage 2 diff --git a/src/mainboard/supermicro/h8qme_fam10/romstage.c b/src/mainboard/supermicro/h8qme_fam10/romstage.c index 20522e1..7a75159 100644 --- a/src/mainboard/supermicro/h8qme_fam10/romstage.c +++ b/src/mainboard/supermicro/h8qme_fam10/romstage.c @@ -301,6 +301,8 @@ post_code(0x40); cbmem_initialize_empty(); post_code(0x41);
post_cache_as_ram(); // BSP switch stack to ram, copy then execute LB. diff --git a/src/mainboard/supermicro/h8scm_fam10/romstage.c b/src/mainboard/supermicro/h8scm_fam10/romstage.c index 355cf82..4b6eeb6 100644 --- a/src/mainboard/supermicro/h8scm_fam10/romstage.c +++ b/src/mainboard/supermicro/h8scm_fam10/romstage.c @@ -222,6 +222,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
+ amdmct_cbmem_store_info(sysinfo); + /* dump_pci_device_range(PCI_DEV(0, 0x18, 0), 0, 0x200); dump_pci_device_range(PCI_DEV(0, 0x18, 1), 0, 0x200); diff --git a/src/mainboard/tyan/s2912_fam10/romstage.c b/src/mainboard/tyan/s2912_fam10/romstage.c index 933d709..fef8ecc 100644 --- a/src/mainboard/tyan/s2912_fam10/romstage.c +++ b/src/mainboard/tyan/s2912_fam10/romstage.c @@ -237,6 +237,8 @@ void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) cbmem_initialize_empty(); post_code(0x41);
post_cache_as_ram(); // BSP switch stack to ram, copy then execute LB. diff --git a/src/northbridge/amd/amdfam10/raminit_amdmct.c b/src/northbridge/amd/amdfam10/raminit_amdmct.c index 02dc956..6a71cd5 100644 --- a/src/northbridge/amd/amdfam10/raminit_amdmct.c +++ b/src/northbridge/amd/amdfam10/raminit_amdmct.c @@ -204,3 +204,43 @@ static void raminit_amdmct(struct sys_info *sysinfo)
printk(BIOS_DEBUG, "raminit_amdmct end:\n"); } + +static void amdmct_cbmem_store_info(struct sys_info *sysinfo) +{ + /* Save memory info structures for use in ramstage */ + size_t i; + struct MCTStatStruc *pMCTstat = &(sysinfo->MCTstat); + struct DCTStatStruc *pDCTstatA = NULL; + + if (pMCTstat && sysinfo->DCTstatA) { + /* Allocate memory */ + struct amdmct_memory_info* mem_info; + mem_info = cbmem_add(CBMEM_ID_AMDMCT_MEMINFO, sizeof(struct amdmct_memory_info)); + if (!mem_info) + return; + + printk(BIOS_DEBUG, "%s: Storing AMDMCT configuration in CBMEM\n", __func__); + + /* Initialize memory */ + memset(mem_info, 0, sizeof(struct amdmct_memory_info)); + + /* Copy data */ + memcpy(&mem_info->mct_stat, &(sysinfo->MCTstat), sizeof(struct MCTStatStruc)); + for (i = 0; i < MAX_NODES_SUPPORTED; i++) { + pDCTstatA = sysinfo->DCTstatA + i; + memcpy(&mem_info->dct_stat[i], pDCTstatA, sizeof(struct DCTStatStruc)); + } + mem_info->ecc_enabled = mctGet_NVbits(NV_ECC_CAP); + mem_info->ecc_scrub_rate = mctGet_NVbits(NV_DramBKScrub); + + /* Zero out invalid/unused pointers */ +#if IS_ENABLED(CONFIG_DIMM_DDR3) + + for (i = 0; i < MAX_NODES_SUPPORTED; i++) { + mem_info->dct_stat[i].C_MCTPtr = NULL; + mem_info->dct_stat[i].C_DCTPtr[0] = NULL; + mem_info->dct_stat[i].C_DCTPtr[1] = NULL; + } +#endif + } +}
