Attention is currently required from: Tarun Tuli, Frank Chu.
Hello build bot (Jenkins), Tarun Tuli, Eric Lai,
https://review.coreboot.org/c/coreboot/+/74499
Change subject: mb/google/brya/var/marasov: Add _DSD object for wifi ......................................................................
`is_untrusted` is eventually ended up by adding DMA property _DSD which is similar to what `add_acpi_dma_property` does for WWAN drivers, hence it makes sense to have a unified name across different device drivers.
BUG=b:278310435 BRANCH=firmware-brya-14505.B TEST=Verified that the _DSD object is still present in the SSDT.
Signed-off-by: Frank Chu Frank_Chu@pegatron.corp-partner.google.com Change-Id: I5a69a47e67f6acaad5a5d1b67e437c5a41bebf3e --- M src/mainboard/google/brya/variants/marasov/overridetree.cb 1 file changed, 18 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/99/74499/4
