Aaron Durbin (adurbin@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9130
commit 1f2e3526bb29313ce00a051917f62491d01114b9 Author: Aaron Durbin adurbin@chromium.org Date: Thu Mar 26 14:55:34 2015 -0500
x86: set smbios rom size based on CONFIG_ROM_SIZE
Instead of relying on the CBFS header's romsize field use the CONFIG_ROM_SIZE Kconfig variable. That value is what is used to create the rom file as it is. Therefore, just remove the dependency.
Change-Id: If855d7378df20080061e27e4988e96aee233d1e0 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/arch/x86/boot/smbios.c | 10 +--------- 1 file changed, 1 insertion(+), 9 deletions(-)
diff --git a/src/arch/x86/boot/smbios.c b/src/arch/x86/boot/smbios.c index 4b96d61..4c3490d 100644 --- a/src/arch/x86/boot/smbios.c +++ b/src/arch/x86/boot/smbios.c @@ -28,7 +28,6 @@ #include <device/device.h> #include <arch/cpu.h> #include <cpu/x86/name.h> -#include <cbfs_core.h> #include <arch/byteorder.h> #include <elog.h> #include <memory_info.h> @@ -258,14 +257,7 @@ static int smbios_write_type0(unsigned long *current, int handle) vboot_data->vbt10 = (u32)t->eos + (version_offset - 1); #endif
- { - const struct cbfs_header *header; - u32 romsize = CONFIG_ROM_SIZE; - header = cbfs_get_header(CBFS_DEFAULT_MEDIA); - if (header != CBFS_HEADER_INVALID_ADDRESS) - romsize = ntohl(header->romsize); - t->bios_rom_size = (romsize / 65535) - 1; - } + t->bios_rom_size = (CONFIG_ROM_SIZE / 65535) - 1;
t->system_bios_major_release = 4; t->bios_characteristics =
