Richard Spiegel has uploaded this change for review. ( https://review.coreboot.org/22300
Change subject: soc/amd/stoneyridge: Fix SPD code ......................................................................
SPD address should be uint8_t. Remove unused smbus_readSpd prototype from dimmSpd.h.
BUG=b:62200225
Change-Id: Ia11c5994c41849ba01ecae3cee6fa97c527134d0 Signed-off-by: Richard Spiegel richard.spiegel@silverbackltd.com --- M src/soc/amd/common/dimmSpd.h M src/soc/amd/stoneyridge/dimmSpd.c M src/soc/amd/stoneyridge/smbus_spd.c 3 files changed, 5 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/22300/1
diff --git a/src/soc/amd/common/dimmSpd.h b/src/soc/amd/common/dimmSpd.h index cdcdb73..2206b0c 100644 --- a/src/soc/amd/common/dimmSpd.h +++ b/src/soc/amd/common/dimmSpd.h @@ -20,7 +20,6 @@ AmdMemoryReadSPD(IN UINT32 Func, IN UINTN Data, IN OUT AGESA_READ_SPD_PARAMS *SpdData);
-int sb_readSpd(int spdAddress, char *buf, size_t len); -int smbus_readSpd(int spdAddress, char *buf, size_t len); +int sb_readSpd(uint8_t spdAddress, char *buf, size_t len);
#endif diff --git a/src/soc/amd/stoneyridge/dimmSpd.c b/src/soc/amd/stoneyridge/dimmSpd.c index ace22bb..a821036 100644 --- a/src/soc/amd/stoneyridge/dimmSpd.c +++ b/src/soc/amd/stoneyridge/dimmSpd.c @@ -27,7 +27,7 @@ AGESA_STATUS AmdMemoryReadSPD(UINT32 unused1, UINTN unused2, AGESA_READ_SPD_PARAMS *info) { - int spdAddress; + uint8_t spdAddress; DEVTREE_CONST struct device *dev = dev_find_slot(0, PCI_DEVFN(0x18, 2)); DEVTREE_CONST struct soc_amd_stoneyridge_config *conf = dev->chip_info;
diff --git a/src/soc/amd/stoneyridge/smbus_spd.c b/src/soc/amd/stoneyridge/smbus_spd.c index 4e3e293..a8a5b37 100644 --- a/src/soc/amd/stoneyridge/smbus_spd.c +++ b/src/soc/amd/stoneyridge/smbus_spd.c @@ -33,10 +33,10 @@ * sending offset for every byte. * Reads 128 bytes in 7-8 ms at 400 KHz. */ -static int readspd(uint16_t iobase, int SmbusSlaveAddress, +static int readspd(uint16_t iobase, uint8_t SmbusSlaveAddress, char *buffer, size_t count) { - u8 dev_addr; + uint8_t dev_addr; size_t index; int error; char *pbuf = buffer; @@ -93,7 +93,7 @@ outb(SMBSLV_STAT_CLEAR, ioBase + SMBSLVSTAT); }
-int sb_readSpd(int spdAddress, char *buf, size_t len) +int sb_readSpd(uint8_t spdAddress, char *buf, size_t len) { uint16_t ioBase = SMB_BASE_ADDR; setupFch(ioBase);
