Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6081
commit a3a3d5834553e9c5ca76ac7571ac98aef105b2c2 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Jun 19 03:48:42 2014 +0300
AGESA: Move config parameters for non-volatile S3 data
These parameters are not specific to the southbridge device, but the implementation of S3 storage defined by CPU code.
Change-Id: Ic341cc2b7669cf8e3e920c48473826ec03fc7d8d Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/cpu/amd/agesa/Kconfig | 9 +++++++++ src/cpu/amd/agesa/Makefile.inc | 15 +++++++++++++++ src/southbridge/amd/Makefile.inc | 17 ----------------- src/southbridge/amd/agesa/hudson/Kconfig | 16 ---------------- src/southbridge/amd/cimx/sb700/Kconfig | 16 ---------------- src/southbridge/amd/cimx/sb800/Kconfig | 16 ---------------- src/southbridge/amd/cimx/sb900/Kconfig | 16 ---------------- 7 files changed, 24 insertions(+), 81 deletions(-)
diff --git a/src/cpu/amd/agesa/Kconfig b/src/cpu/amd/agesa/Kconfig index 21f0c6f..b53e4b0 100644 --- a/src/cpu/amd/agesa/Kconfig +++ b/src/cpu/amd/agesa/Kconfig @@ -66,6 +66,15 @@ config DCACHE_RAM_BASE config DCACHE_RAM_SIZE hex default 0x10000 + +config S3_DATA_POS + hex + default 0xFFFF0000 + +config S3_DATA_SIZE + int + default 32768 + endif # CPU_AMD_AGESA
source src/cpu/amd/agesa/family10/Kconfig diff --git a/src/cpu/amd/agesa/Makefile.inc b/src/cpu/amd/agesa/Makefile.inc index 4dfb173..f403d30 100644 --- a/src/cpu/amd/agesa/Makefile.inc +++ b/src/cpu/amd/agesa/Makefile.inc @@ -29,3 +29,18 @@ cpu_incs += $(src)/cpu/amd/agesa/cache_as_ram.inc
romstage-y += heapmanager.c ramstage-y += heapmanager.c + +ifeq ($(CONFIG_HAVE_ACPI_RESUME), y) + +$(obj)/coreboot_s3nv.rom: $(obj)/config.h + echo " S3 NVRAM $(CONFIG_S3_DATA_POS) (S3 storage area)" + # force C locale, so cygwin awk doesn't try to interpret the 0xff below as UTF-8 (or worse) + printf %d $(CONFIG_S3_DATA_SIZE) | LC_ALL=C awk '{for (i=0; i<$$1; i++) {printf "%c", 255}}' > $@.tmp + mv $@.tmp $@ + +cbfs-files-y += s3nv +s3nv-file := $(obj)/coreboot_s3nv.rom +s3nv-position := $(CONFIG_S3_DATA_POS) +s3nv-type := raw + +endif # CONFIG_HAVE_ACPI_RESUME == y diff --git a/src/southbridge/amd/Makefile.inc b/src/southbridge/amd/Makefile.inc index 9ec0171..e2f3f9c 100644 --- a/src/southbridge/amd/Makefile.inc +++ b/src/southbridge/amd/Makefile.inc @@ -16,20 +16,3 @@ subdirs-$(CONFIG_SOUTHBRIDGE_AMD_CIMX_SB800) += cimx subdirs-$(CONFIG_SOUTHBRIDGE_AMD_CIMX_SB900) += cimx subdirs-$(CONFIG_SOUTHBRIDGE_AMD_AGESA_HUDSON) += agesa subdirs-$(CONFIG_SOUTHBRIDGE_AMD_AGESA_YANGTZE) += agesa - -ifeq ($(CONFIG_HAVE_ACPI_RESUME), y) -ifeq ($(CONFIG_CPU_AMD_AGESA), y) - -$(obj)/coreboot_s3nv.rom: $(obj)/config.h - echo " S3 NVRAM $(CONFIG_S3_DATA_POS) (S3 storage area)" - # force C locale, so cygwin awk doesn't try to interpret the 0xff below as UTF-8 (or worse) - printf %d $(CONFIG_S3_DATA_SIZE) | LC_ALL=C awk '{for (i=0; i<$$1; i++) {printf "%c", 255}}' > $@.tmp - mv $@.tmp $@ - -cbfs-files-y += s3nv -s3nv-file := $(obj)/coreboot_s3nv.rom -s3nv-position := $(CONFIG_S3_DATA_POS) -s3nv-type := raw - -endif # CONFIG_CPU_AMD_AGESA == y -endif # CONFIG_HAVE_ACPI_RESUME == y diff --git a/src/southbridge/amd/agesa/hudson/Kconfig b/src/southbridge/amd/agesa/hudson/Kconfig index 9e21b84..a0c68a3 100644 --- a/src/southbridge/amd/agesa/hudson/Kconfig +++ b/src/southbridge/amd/agesa/hudson/Kconfig @@ -215,22 +215,6 @@ config RAID_MISC_ROM_POSITION The CONFIG_ROM_SIZE must larger than 0x100000. endif # HUDSON_SATA_RAID
-config S3_DATA_POS - hex "S3 volatile storage position" - default 0xFFFF0000 - depends on HAVE_ACPI_RESUME - help - For a system with S3 feature, the BIOS needs to save some data to - non-volatile storage at cold boot stage. - -config S3_DATA_SIZE - int "S3 volatile storage size" - default 32768 - depends on HAVE_ACPI_RESUME - help - For a system with S3 feature, the BIOS needs to save some data to - non-volatile storage at cold boot stage. - config HUDSON_LEGACY_FREE bool "System is legacy free" help diff --git a/src/southbridge/amd/cimx/sb700/Kconfig b/src/southbridge/amd/cimx/sb700/Kconfig index d8bad86..a4f9aa0 100644 --- a/src/southbridge/amd/cimx/sb700/Kconfig +++ b/src/southbridge/amd/cimx/sb700/Kconfig @@ -67,21 +67,5 @@ config REDIRECT_SBCIMX_TRACE_TO_SERIAL
Warning: Only enable this option when debuging or tracing AMD CIMX code.
-config S3_DATA_POS - hex "S3 volatile storage position" - default 0xFFFF0000 - depends on HAVE_ACPI_RESUME - help - For a system with S3 feature, the BIOS needs to save some data to - non-volatile storage at cold boot stage. - -config S3_DATA_SIZE - int "S3 volatile storage size" - default 32768 - depends on HAVE_ACPI_RESUME - help - For a system with S3 feature, the BIOS needs to save some data to - non-volatile storage at cold boot stage. - endif #SOUTHBRIDGE_AMD_CIMX_SB700
diff --git a/src/southbridge/amd/cimx/sb800/Kconfig b/src/southbridge/amd/cimx/sb800/Kconfig index 832655d..ac25e89 100644 --- a/src/southbridge/amd/cimx/sb800/Kconfig +++ b/src/southbridge/amd/cimx/sb800/Kconfig @@ -124,22 +124,6 @@ config RAID_MISC_ROM_POSITION
endif
-config S3_DATA_POS - hex "S3 volatile storage position" - default 0xFFFF0000 - depends on HAVE_ACPI_RESUME - help - For a system with S3 feature, the BIOS needs to save some data to - non-volatile storage at cold boot stage. - -config S3_DATA_SIZE - int "S3 volatile storage size" - default 32768 - depends on HAVE_ACPI_RESUME - help - For a system with S3 feature, the BIOS needs to save some data to - non-volatile storage at cold boot stage. - config SB800_IMC_FWM bool "Add IMC firmware" default n diff --git a/src/southbridge/amd/cimx/sb900/Kconfig b/src/southbridge/amd/cimx/sb900/Kconfig index 5d3b0a1..3bef95a 100644 --- a/src/southbridge/amd/cimx/sb900/Kconfig +++ b/src/southbridge/amd/cimx/sb900/Kconfig @@ -54,21 +54,5 @@ config BOOTBLOCK_SOUTHBRIDGE_INIT string default "southbridge/amd/cimx/sb900/bootblock.c"
-config S3_DATA_POS - hex "S3 volatile storage position" - default 0xFFFF0000 - depends on HAVE_ACPI_RESUME - help - For a system with S3 feature, the BIOS needs to save some data to - non-volatile storage at cold boot stage. - -config S3_DATA_SIZE - int "S3 volatile storage size" - default 32768 - depends on HAVE_ACPI_RESUME - help - For a system with S3 feature, the BIOS needs to save some data to - non-volatile storage at cold boot stage. - endif #SOUTHBRIDGE_AMD_CIMX_SB900
