Attention is currently required from: Tarun Tuli, Subrata Banik, Sridhar Siricilla.
Hello Will Kim, build bot (Jenkins), Tarun Tuli, Subrata Banik, Wonkyu Kim, Kapil Porwal, Sridhar Siricilla, Eric Lai,
https://review.coreboot.org/c/coreboot/+/70819
to look at the new patch set (#20).
Change subject: soc/intel/common: Untie PRMRR from SGX ......................................................................
PRMRR is used by many Intel SOC features, not just Intel SGX. As of now SGX and Key Locker are the features that need PRMRR. Untie it from Intel SGX specific files and move to common cpulib. Also rename PRMRR size config option. Use the renamed PRMRR size config option to set the PRMRR size.
TEST=Able to set PRMRR size using config.
Signed-off-by: Pratikkumar Prajapati pratikkumar.v.prajapati@intel.com Change-Id: I0cd49a87be0293530705802fd9b830201a5863c2 --- M src/soc/intel/common/block/cpu/Kconfig M src/soc/intel/common/block/cpu/cpulib.c M src/soc/intel/common/block/sgx/Kconfig 3 files changed, 85 insertions(+), 43 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/19/70819/20
