Attention is currently required from: Patrick Rudolph. Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/50169 )
Change subject: soc/intel/broadwell: Use common {DMI,EP,MCH}BAR accessors ......................................................................
Tested with BUILD_TIMELESS=1, Purism Librem 13 v1 remains identical.
Change-Id: I04dbeade44d480301c9f7d336449bc54e56cb7bc Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/soc/intel/broadwell/Kconfig M src/soc/intel/broadwell/acpi/ctdp.asl M src/soc/intel/broadwell/acpi/hostbridge.asl M src/soc/intel/broadwell/early_init.c M src/soc/intel/broadwell/include/soc/iomap.h M src/soc/intel/broadwell/include/soc/systemagent.h 6 files changed, 17 insertions(+), 14 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/69/50169/1
diff --git a/src/soc/intel/broadwell/Kconfig b/src/soc/intel/broadwell/Kconfig index 20254d5..e8919f0 100644 --- a/src/soc/intel/broadwell/Kconfig +++ b/src/soc/intel/broadwell/Kconfig @@ -86,6 +86,15 @@ string default "8086,0406"
+config FIXED_MCHBAR_MMIO_BASE + default 0xfed10000 + +config FIXED_DMIBAR_MMIO_BASE + default 0xfed18000 + +config FIXED_EPBAR_MMIO_BASE + default 0xfed19000 + config DCACHE_RAM_BASE hex default 0xff7c0000 diff --git a/src/soc/intel/broadwell/acpi/ctdp.asl b/src/soc/intel/broadwell/acpi/ctdp.asl index b18ec78..67ceb82 100644 --- a/src/soc/intel/broadwell/acpi/ctdp.asl +++ b/src/soc/intel/broadwell/acpi/ctdp.asl @@ -9,7 +9,7 @@ Name (CTCU, 2) /* CTDP Up Select */ Name (SPL1, 0) /* Saved PL1 value */
- OperationRegion (MCHB, SystemMemory, MCH_BASE_ADDRESS + 0x5000, 0x1000) + OperationRegion (MCHB, SystemMemory, CONFIG_FIXED_MCHBAR_MMIO_BASE + 0x5000, 0x1000) Field (MCHB, DWordAcc, Lock, Preserve) { Offset (0x930), /* PACKAGE_POWER_SKU */ diff --git a/src/soc/intel/broadwell/acpi/hostbridge.asl b/src/soc/intel/broadwell/acpi/hostbridge.asl index 325a736..e36fa47 100644 --- a/src/soc/intel/broadwell/acpi/hostbridge.asl +++ b/src/soc/intel/broadwell/acpi/hostbridge.asl @@ -175,9 +175,9 @@
Name (PDRS, ResourceTemplate() { Memory32Fixed (ReadWrite, RCBA_BASE_ADDRESS, RCBA_BASE_SIZE) - Memory32Fixed (ReadWrite, MCH_BASE_ADDRESS, MCH_BASE_SIZE) - Memory32Fixed (ReadWrite, DMI_BASE_ADDRESS, DMI_BASE_SIZE) - Memory32Fixed (ReadWrite, EP_BASE_ADDRESS, EP_BASE_SIZE) + Memory32Fixed (ReadWrite, CONFIG_FIXED_MCHBAR_MMIO_BASE, MCH_BASE_SIZE) + Memory32Fixed (ReadWrite, CONFIG_FIXED_DMIBAR_MMIO_BASE, DMI_BASE_SIZE) + Memory32Fixed (ReadWrite, CONFIG_FIXED_EPBAR_MMIO_BASE, EP_BASE_SIZE) Memory32Fixed (ReadWrite, CONFIG_MMCONF_BASE_ADDRESS, CONFIG_MMCONF_LENGTH) Memory32Fixed (ReadWrite, EDRAM_BASE_ADDRESS, EDRAM_BASE_SIZE) Memory32Fixed (ReadWrite, GDXC_BASE_ADDRESS, GDXC_BASE_SIZE) diff --git a/src/soc/intel/broadwell/early_init.c b/src/soc/intel/broadwell/early_init.c index 6bf7ba7..6c347f3 100644 --- a/src/soc/intel/broadwell/early_init.c +++ b/src/soc/intel/broadwell/early_init.c @@ -11,9 +11,9 @@ static void broadwell_setup_bars(void) { /* Set up all hardcoded northbridge BARs */ - pci_write_config32(SA_DEV_ROOT, MCHBAR, MCH_BASE_ADDRESS | 1); - pci_write_config32(SA_DEV_ROOT, DMIBAR, DMI_BASE_ADDRESS | 1); - pci_write_config32(SA_DEV_ROOT, EPBAR, EP_BASE_ADDRESS | 1); + pci_write_config32(SA_DEV_ROOT, MCHBAR, CONFIG_FIXED_MCHBAR_MMIO_BASE | 1); + pci_write_config32(SA_DEV_ROOT, DMIBAR, CONFIG_FIXED_DMIBAR_MMIO_BASE | 1); + pci_write_config32(SA_DEV_ROOT, EPBAR, CONFIG_FIXED_EPBAR_MMIO_BASE | 1);
MCHBAR32(EDRAMBAR) = EDRAM_BASE_ADDRESS | 1; MCHBAR32(GDXCBAR) = GDXC_BASE_ADDRESS | 1; diff --git a/src/soc/intel/broadwell/include/soc/iomap.h b/src/soc/intel/broadwell/include/soc/iomap.h index 8f98fd9..61e53fc 100644 --- a/src/soc/intel/broadwell/include/soc/iomap.h +++ b/src/soc/intel/broadwell/include/soc/iomap.h @@ -3,13 +3,10 @@ #ifndef _BROADWELL_IOMAP_H_ #define _BROADWELL_IOMAP_H_
-#define MCH_BASE_ADDRESS 0xfed10000 #define MCH_BASE_SIZE 0x8000
-#define DMI_BASE_ADDRESS 0xfed18000 #define DMI_BASE_SIZE 0x1000
-#define EP_BASE_ADDRESS 0xfed19000 #define EP_BASE_SIZE 0x1000
#define EDRAM_BASE_ADDRESS 0xfed80000 diff --git a/src/soc/intel/broadwell/include/soc/systemagent.h b/src/soc/intel/broadwell/include/soc/systemagent.h index cc0dc4f..331bbc7 100644 --- a/src/soc/intel/broadwell/include/soc/systemagent.h +++ b/src/soc/intel/broadwell/include/soc/systemagent.h @@ -82,10 +82,7 @@ #define PRSCAPDIS (1 << 2)
/* MCHBAR */ - -#define MCHBAR8(x) *((volatile u8 *)(MCH_BASE_ADDRESS + (x))) -#define MCHBAR16(x) *((volatile u16 *)(MCH_BASE_ADDRESS + (x))) -#define MCHBAR32(x) *((volatile u32 *)(MCH_BASE_ADDRESS + (x))) +#include <northbridge/intel/common/fixed_bars.h>
/* Memory controller characteristics */ #define NUM_CHANNELS 2
