Alexandru Gagniuc (mr.nuke.me@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11788
commit 4079a43a2a8b3c3b567124c05c7a2961413ab677 Author: Alexandru Gagniuc mr.nuke.me@gmail.com Date: Mon Sep 28 21:39:12 2015 -0700
WIP: sandy/ivy: Treat native init as first class citizen
The MRC path becomes a second-class citizen and gets the _MRC suffix, while the native path becomes suffixless.
Change-Id: Ic86cee5e00bf7f598716d3d15d1ea81ca673932f Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- src/Kconfig | 8 +- src/cpu/intel/Makefile.inc | 4 +- src/northbridge/intel/sandybridge/Kconfig | 10 +- src/northbridge/intel/sandybridge/Makefile.inc | 6 +- src/northbridge/intel/sandybridge/raminit.c | 293 ------------------------ src/northbridge/intel/sandybridge/raminit_mrc.c | 293 ++++++++++++++++++++++++ src/southbridge/intel/bd82x6x/Makefile.inc | 4 +- 7 files changed, 309 insertions(+), 309 deletions(-)
diff --git a/src/Kconfig b/src/Kconfig index 2c75750..5ea6b9d 100644 --- a/src/Kconfig +++ b/src/Kconfig @@ -246,8 +246,8 @@ config CACHE_RELOCATED_RAMSTAGE_OUTSIDE_CBMEM
config FLASHMAP_OFFSET hex "Flash Map Offset" - default 0x00670000 if NORTHBRIDGE_INTEL_SANDYBRIDGE - default 0x00610000 if NORTHBRIDGE_INTEL_IVYBRIDGE + default 0x00670000 if NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC + default 0x00610000 if NORTHBRIDGE_INTEL_IVYBRIDGE_MRC default CBFS_SIZE if !ARCH_X86 default 0 help @@ -337,8 +337,8 @@ source "src/mainboard/Kconfig" config CBFS_SIZE hex "Size of CBFS filesystem in ROM" default 0x100000 if HAVE_INTEL_FIRMWARE || \ - NORTHBRIDGE_INTEL_GM45 || NORTHBRIDGE_INTEL_SANDYBRIDGE || \ - NORTHBRIDGE_INTEL_IVYBRIDGE || NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE || \ + NORTHBRIDGE_INTEL_GM45 || NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC || \ + NORTHBRIDGE_INTEL_IVYBRIDGE_MRC || NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE || \ NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE || \ NORTHBRIDGE_INTEL_NEHALEM || SOC_INTEL_BRASWELL || \ SOC_INTEL_BROADWELL diff --git a/src/cpu/intel/Makefile.inc b/src/cpu/intel/Makefile.inc index 51451e9..e6a2d6a 100644 --- a/src/cpu/intel/Makefile.inc +++ b/src/cpu/intel/Makefile.inc @@ -17,9 +17,9 @@ subdirs-$(CONFIG_CPU_INTEL_SOCKET_PGA370) += socket_PGA370 subdirs-$(CONFIG_CPU_INTEL_SOCKET_RPGA988B) += socket_rPGA988B subdirs-$(CONFIG_CPU_INTEL_SOCKET_RPGA989) += socket_rPGA989 subdirs-$(CONFIG_NORTHBRIDGE_INTEL_NEHALEM) += model_2065x -subdirs-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE) += model_206ax +subdirs-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC) += model_206ax subdirs-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE) += model_206ax -subdirs-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE) += model_206ax +subdirs-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_MRC) += model_206ax subdirs-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE) += model_206ax subdirs-$(CONFIG_NORTHBRIDGE_INTEL_HASWELL) += haswell subdirs-$(CONFIG_NORTHBRIDGE_INTEL_FSP_SANDYBRIDGE) += fsp_model_206ax diff --git a/src/northbridge/intel/sandybridge/Kconfig b/src/northbridge/intel/sandybridge/Kconfig index 093224f..f8a6263 100644 --- a/src/northbridge/intel/sandybridge/Kconfig +++ b/src/northbridge/intel/sandybridge/Kconfig @@ -17,7 +17,7 @@ ## Foundation, Inc. ##
-config NORTHBRIDGE_INTEL_SANDYBRIDGE +config NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC bool select MMCONF_SUPPORT select MMCONF_SUPPORT_DEFAULT @@ -32,7 +32,7 @@ config NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE select HAVE_DEBUG_RAM_SETUP select INTEL_GMA_ACPI
-config NORTHBRIDGE_INTEL_IVYBRIDGE +config NORTHBRIDGE_INTEL_IVYBRIDGE_MRC bool select MMCONF_SUPPORT select MMCONF_SUPPORT_DEFAULT @@ -47,7 +47,7 @@ config NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE select HAVE_DEBUG_RAM_SETUP select INTEL_GMA_ACPI
-if NORTHBRIDGE_INTEL_SANDYBRIDGE || NORTHBRIDGE_INTEL_IVYBRIDGE || NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE || NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE +if NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC || NORTHBRIDGE_INTEL_IVYBRIDGE_MRC || NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE || NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE
config VGA_BIOS_ID string @@ -72,8 +72,8 @@ config MRC_CACHE_SIZE
config DCACHE_RAM_BASE hex - default 0xff7e0000 if NORTHBRIDGE_INTEL_IVYBRIDGE - default 0xff7e0000 if NORTHBRIDGE_INTEL_SANDYBRIDGE + default 0xff7e0000 if NORTHBRIDGE_INTEL_IVYBRIDGE_MRC + default 0xff7e0000 if NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC default 0xfefe0000 if NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE default 0xfefe0000 if NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE
diff --git a/src/northbridge/intel/sandybridge/Makefile.inc b/src/northbridge/intel/sandybridge/Makefile.inc index 52fe23c..fee9457 100644 --- a/src/northbridge/intel/sandybridge/Makefile.inc +++ b/src/northbridge/intel/sandybridge/Makefile.inc @@ -17,7 +17,7 @@ # Foundation, Inc. #
-ifeq ($(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE)$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE)$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE)$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE),y) +ifeq ($(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE)$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC)$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE)$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_MRC),y)
ramstage-y += ram_calc.c ramstage-y += northbridge.c @@ -29,8 +29,8 @@ ramstage-y += acpi.c ramstage-y += mrccache.c
romstage-y += ram_calc.c -romstage-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE) += raminit.c -romstage-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE) += raminit.c +romstage-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_MRC) += raminit_mrc.c +romstage-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC) += raminit_mrc.c romstage-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE) += raminit_native.c romstage-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE) += romstage_native.c romstage-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE) += ../../../device/dram/ddr3.c diff --git a/src/northbridge/intel/sandybridge/raminit.c b/src/northbridge/intel/sandybridge/raminit.c deleted file mode 100644 index 053a487..0000000 --- a/src/northbridge/intel/sandybridge/raminit.c +++ /dev/null @@ -1,293 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Google Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc. - */ - -#include <console/console.h> -#include <console/usb.h> -#include <bootmode.h> -#include <string.h> -#include <arch/io.h> -#include <cbmem.h> -#include <arch/cbfs.h> -#include <cbfs.h> -#include <ip_checksum.h> -#include <pc80/mc146818rtc.h> -#include <device/pci_def.h> -#include <halt.h> -#include "raminit.h" -#include "pei_data.h" -#include "sandybridge.h" - -/* Management Engine is in the southbridge */ -#include "southbridge/intel/bd82x6x/me.h" - -/* - * MRC scrambler seed offsets should be reserved in - * mainboard cmos.layout and not covered by checksum. - */ -#if CONFIG_USE_OPTION_TABLE -#include "option_table.h" -#define CMOS_OFFSET_MRC_SEED (CMOS_VSTART_mrc_scrambler_seed >> 3) -#define CMOS_OFFSET_MRC_SEED_S3 (CMOS_VSTART_mrc_scrambler_seed_s3 >> 3) -#define CMOS_OFFSET_MRC_SEED_CHK (CMOS_VSTART_mrc_scrambler_seed_chk >> 3) -#else -#define CMOS_OFFSET_MRC_SEED 152 -#define CMOS_OFFSET_MRC_SEED_S3 156 -#define CMOS_OFFSET_MRC_SEED_CHK 160 -#endif - -void save_mrc_data(struct pei_data *pei_data) -{ - u16 c1, c2, checksum; - struct mrc_data_container *mrcdata; - int output_len = ALIGN(pei_data->mrc_output_len, 16); - - /* Save the MRC S3 restore data to cbmem */ - mrcdata = cbmem_add - (CBMEM_ID_MRCDATA, - output_len + sizeof(struct mrc_data_container)); - - if (mrcdata != NULL) { - printk(BIOS_DEBUG, "Relocate MRC DATA from %p to %p (%u bytes)\n", - pei_data->mrc_output, mrcdata, output_len); - - mrcdata->mrc_signature = MRC_DATA_SIGNATURE; - mrcdata->mrc_data_size = output_len; - mrcdata->reserved = 0; - memcpy(mrcdata->mrc_data, pei_data->mrc_output, - pei_data->mrc_output_len); - - /* Zero the unused space in aligned buffer. */ - if (output_len > pei_data->mrc_output_len) - memset(mrcdata->mrc_data+pei_data->mrc_output_len, 0, - output_len - pei_data->mrc_output_len); - - mrcdata->mrc_checksum = compute_ip_checksum(mrcdata->mrc_data, - mrcdata->mrc_data_size); - } - - /* Save the MRC seed values to CMOS */ - cmos_write32(CMOS_OFFSET_MRC_SEED, pei_data->scrambler_seed); - printk(BIOS_DEBUG, "Save scrambler seed 0x%08x to CMOS 0x%02x\n", - pei_data->scrambler_seed, CMOS_OFFSET_MRC_SEED); - - cmos_write32(CMOS_OFFSET_MRC_SEED_S3, pei_data->scrambler_seed_s3); - printk(BIOS_DEBUG, "Save s3 scrambler seed 0x%08x to CMOS 0x%02x\n", - pei_data->scrambler_seed_s3, CMOS_OFFSET_MRC_SEED_S3); - - /* Save a simple checksum of the seed values */ - c1 = compute_ip_checksum((u8*)&pei_data->scrambler_seed, - sizeof(u32)); - c2 = compute_ip_checksum((u8*)&pei_data->scrambler_seed_s3, - sizeof(u32)); - checksum = add_ip_checksums(sizeof(u32), c1, c2); - - cmos_write(checksum & 0xff, CMOS_OFFSET_MRC_SEED_CHK); - cmos_write((checksum >> 8) & 0xff, CMOS_OFFSET_MRC_SEED_CHK+1); -} - -static void prepare_mrc_cache(struct pei_data *pei_data) -{ - struct mrc_data_container *mrc_cache; - u16 c1, c2, checksum, seed_checksum; - - // preset just in case there is an error - pei_data->mrc_input = NULL; - pei_data->mrc_input_len = 0; - - /* Read scrambler seeds from CMOS */ - pei_data->scrambler_seed = cmos_read32(CMOS_OFFSET_MRC_SEED); - printk(BIOS_DEBUG, "Read scrambler seed 0x%08x from CMOS 0x%02x\n", - pei_data->scrambler_seed, CMOS_OFFSET_MRC_SEED); - - pei_data->scrambler_seed_s3 = cmos_read32(CMOS_OFFSET_MRC_SEED_S3); - printk(BIOS_DEBUG, "Read S3 scrambler seed 0x%08x from CMOS 0x%02x\n", - pei_data->scrambler_seed_s3, CMOS_OFFSET_MRC_SEED_S3); - - /* Compute seed checksum and compare */ - c1 = compute_ip_checksum((u8*)&pei_data->scrambler_seed, - sizeof(u32)); - c2 = compute_ip_checksum((u8*)&pei_data->scrambler_seed_s3, - sizeof(u32)); - checksum = add_ip_checksums(sizeof(u32), c1, c2); - - seed_checksum = cmos_read(CMOS_OFFSET_MRC_SEED_CHK); - seed_checksum |= cmos_read(CMOS_OFFSET_MRC_SEED_CHK+1) << 8; - - if (checksum != seed_checksum) { - printk(BIOS_ERR, "%s: invalid seed checksum\n", __func__); - pei_data->scrambler_seed = 0; - pei_data->scrambler_seed_s3 = 0; - return; - } - - if ((mrc_cache = find_current_mrc_cache()) == NULL) { - /* error message printed in find_current_mrc_cache */ - return; - } - - pei_data->mrc_input = mrc_cache->mrc_data; - pei_data->mrc_input_len = mrc_cache->mrc_data_size; - - printk(BIOS_DEBUG, "%s: at %p, size %x checksum %04x\n", - __func__, pei_data->mrc_input, - pei_data->mrc_input_len, mrc_cache->mrc_checksum); -} - -static const char* ecc_decoder[] = { - "inactive", - "active on IO", - "disabled on IO", - "active" -}; - -/* - * Dump in the log memory controller configuration as read from the memory - * controller registers. - */ -static void report_memory_config(void) -{ - u32 addr_decoder_common, addr_decode_ch[2]; - int i; - - addr_decoder_common = MCHBAR32(0x5000); - addr_decode_ch[0] = MCHBAR32(0x5004); - addr_decode_ch[1] = MCHBAR32(0x5008); - - printk(BIOS_DEBUG, "memcfg DDR3 clock %d MHz\n", - (MCHBAR32(0x5e04) * 13333 * 2 + 50)/100); - printk(BIOS_DEBUG, "memcfg channel assignment: A: %d, B % d, C % d\n", - addr_decoder_common & 3, - (addr_decoder_common >> 2) & 3, - (addr_decoder_common >> 4) & 3); - - for (i = 0; i < ARRAY_SIZE(addr_decode_ch); i++) { - u32 ch_conf = addr_decode_ch[i]; - printk(BIOS_DEBUG, "memcfg channel[%d] config (%8.8x):\n", - i, ch_conf); - printk(BIOS_DEBUG, " ECC %s\n", - ecc_decoder[(ch_conf >> 24) & 3]); - printk(BIOS_DEBUG, " enhanced interleave mode %s\n", - ((ch_conf >> 22) & 1) ? "on" : "off"); - printk(BIOS_DEBUG, " rank interleave %s\n", - ((ch_conf >> 21) & 1) ? "on" : "off"); - printk(BIOS_DEBUG, " DIMMA %d MB width x%d %s rank%s\n", - ((ch_conf >> 0) & 0xff) * 256, - ((ch_conf >> 19) & 1) ? 16 : 8, - ((ch_conf >> 17) & 1) ? "dual" : "single", - ((ch_conf >> 16) & 1) ? "" : ", selected"); - printk(BIOS_DEBUG, " DIMMB %d MB width x%d %s rank%s\n", - ((ch_conf >> 8) & 0xff) * 256, - ((ch_conf >> 20) & 1) ? 16 : 8, - ((ch_conf >> 18) & 1) ? "dual" : "single", - ((ch_conf >> 16) & 1) ? ", selected" : ""); - } -} - -static void post_system_agent_init(struct pei_data *pei_data) -{ - /* If PCIe init is skipped, set the PEG clock gating */ - if (!pei_data->pcie_init) - MCHBAR32(0x7010) = MCHBAR32(0x7010) | 0x01; -} - -/** - * Find PEI executable in coreboot filesystem and execute it. - * - * @param pei_data: configuration data for UEFI PEI reference code - */ -void sdram_initialize(struct pei_data *pei_data) -{ - struct sys_info sysinfo; - int (*entry) (struct pei_data *pei_data) __attribute__ ((regparm(1))); - - report_platform_info(); - - /* Wait for ME to be ready */ - intel_early_me_init(); - intel_early_me_uma_size(); - - printk(BIOS_DEBUG, "Starting UEFI PEI System Agent\n"); - - memset(&sysinfo, 0, sizeof(sysinfo)); - - sysinfo.boot_path = pei_data->boot_mode; - - /* - * Do not pass MRC data in for recovery mode boot, - * Always pass it in for S3 resume. - */ - if (!recovery_mode_enabled() || pei_data->boot_mode == 2) - prepare_mrc_cache(pei_data); - - /* If MRC data is not found we cannot continue S3 resume. */ - if (pei_data->boot_mode == 2 && !pei_data->mrc_input) { - printk(BIOS_DEBUG, "Giving up in sdram_initialize: No MRC data\n"); - outb(0x6, 0xcf9); - halt(); - } - - /* Pass console handler in pei_data */ - pei_data->tx_byte = do_putchar; - - /* Locate and call UEFI System Agent binary. */ - entry = cbfs_boot_map_with_leak("mrc.bin", CBFS_TYPE_MRC, NULL); - if (entry) { - int rv; - rv = entry (pei_data); - if (rv) { - switch (rv) { - case -1: - printk(BIOS_ERR, "PEI version mismatch.\n"); - break; - case -2: - printk(BIOS_ERR, "Invalid memory frequency.\n"); - break; - default: - printk(BIOS_ERR, "MRC returned %x.\n", rv); - } - die("Nonzero MRC return value.\n"); - } - } else { - die("UEFI PEI System Agent not found.\n"); - } - -#if CONFIG_USBDEBUG_IN_ROMSTAGE - /* mrc.bin reconfigures USB, so reinit it to have debug */ - usbdebug_init(); -#endif - - /* For reference print the System Agent version - * after executing the UEFI PEI stage. - */ - u32 version = MCHBAR32(0x5034); - printk(BIOS_DEBUG, "System Agent Version %d.%d.%d Build %d\n", - version >> 24 , (version >> 16) & 0xff, - (version >> 8) & 0xff, version & 0xff); - - /* Send ME init done for SandyBridge here. This is done - * inside the SystemAgent binary on IvyBridge. */ - if (BASE_REV_SNB == - (pci_read_config16(PCI_CPU_DEVICE, PCI_DEVICE_ID) & BASE_REV_MASK)) - intel_early_me_init_done(ME_INIT_STATUS_SUCCESS); - else - intel_early_me_status(); - - post_system_agent_init(pei_data); - report_memory_config(); -} diff --git a/src/northbridge/intel/sandybridge/raminit_mrc.c b/src/northbridge/intel/sandybridge/raminit_mrc.c new file mode 100644 index 0000000..053a487 --- /dev/null +++ b/src/northbridge/intel/sandybridge/raminit_mrc.c @@ -0,0 +1,293 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2011 Google Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#include <console/console.h> +#include <console/usb.h> +#include <bootmode.h> +#include <string.h> +#include <arch/io.h> +#include <cbmem.h> +#include <arch/cbfs.h> +#include <cbfs.h> +#include <ip_checksum.h> +#include <pc80/mc146818rtc.h> +#include <device/pci_def.h> +#include <halt.h> +#include "raminit.h" +#include "pei_data.h" +#include "sandybridge.h" + +/* Management Engine is in the southbridge */ +#include "southbridge/intel/bd82x6x/me.h" + +/* + * MRC scrambler seed offsets should be reserved in + * mainboard cmos.layout and not covered by checksum. + */ +#if CONFIG_USE_OPTION_TABLE +#include "option_table.h" +#define CMOS_OFFSET_MRC_SEED (CMOS_VSTART_mrc_scrambler_seed >> 3) +#define CMOS_OFFSET_MRC_SEED_S3 (CMOS_VSTART_mrc_scrambler_seed_s3 >> 3) +#define CMOS_OFFSET_MRC_SEED_CHK (CMOS_VSTART_mrc_scrambler_seed_chk >> 3) +#else +#define CMOS_OFFSET_MRC_SEED 152 +#define CMOS_OFFSET_MRC_SEED_S3 156 +#define CMOS_OFFSET_MRC_SEED_CHK 160 +#endif + +void save_mrc_data(struct pei_data *pei_data) +{ + u16 c1, c2, checksum; + struct mrc_data_container *mrcdata; + int output_len = ALIGN(pei_data->mrc_output_len, 16); + + /* Save the MRC S3 restore data to cbmem */ + mrcdata = cbmem_add + (CBMEM_ID_MRCDATA, + output_len + sizeof(struct mrc_data_container)); + + if (mrcdata != NULL) { + printk(BIOS_DEBUG, "Relocate MRC DATA from %p to %p (%u bytes)\n", + pei_data->mrc_output, mrcdata, output_len); + + mrcdata->mrc_signature = MRC_DATA_SIGNATURE; + mrcdata->mrc_data_size = output_len; + mrcdata->reserved = 0; + memcpy(mrcdata->mrc_data, pei_data->mrc_output, + pei_data->mrc_output_len); + + /* Zero the unused space in aligned buffer. */ + if (output_len > pei_data->mrc_output_len) + memset(mrcdata->mrc_data+pei_data->mrc_output_len, 0, + output_len - pei_data->mrc_output_len); + + mrcdata->mrc_checksum = compute_ip_checksum(mrcdata->mrc_data, + mrcdata->mrc_data_size); + } + + /* Save the MRC seed values to CMOS */ + cmos_write32(CMOS_OFFSET_MRC_SEED, pei_data->scrambler_seed); + printk(BIOS_DEBUG, "Save scrambler seed 0x%08x to CMOS 0x%02x\n", + pei_data->scrambler_seed, CMOS_OFFSET_MRC_SEED); + + cmos_write32(CMOS_OFFSET_MRC_SEED_S3, pei_data->scrambler_seed_s3); + printk(BIOS_DEBUG, "Save s3 scrambler seed 0x%08x to CMOS 0x%02x\n", + pei_data->scrambler_seed_s3, CMOS_OFFSET_MRC_SEED_S3); + + /* Save a simple checksum of the seed values */ + c1 = compute_ip_checksum((u8*)&pei_data->scrambler_seed, + sizeof(u32)); + c2 = compute_ip_checksum((u8*)&pei_data->scrambler_seed_s3, + sizeof(u32)); + checksum = add_ip_checksums(sizeof(u32), c1, c2); + + cmos_write(checksum & 0xff, CMOS_OFFSET_MRC_SEED_CHK); + cmos_write((checksum >> 8) & 0xff, CMOS_OFFSET_MRC_SEED_CHK+1); +} + +static void prepare_mrc_cache(struct pei_data *pei_data) +{ + struct mrc_data_container *mrc_cache; + u16 c1, c2, checksum, seed_checksum; + + // preset just in case there is an error + pei_data->mrc_input = NULL; + pei_data->mrc_input_len = 0; + + /* Read scrambler seeds from CMOS */ + pei_data->scrambler_seed = cmos_read32(CMOS_OFFSET_MRC_SEED); + printk(BIOS_DEBUG, "Read scrambler seed 0x%08x from CMOS 0x%02x\n", + pei_data->scrambler_seed, CMOS_OFFSET_MRC_SEED); + + pei_data->scrambler_seed_s3 = cmos_read32(CMOS_OFFSET_MRC_SEED_S3); + printk(BIOS_DEBUG, "Read S3 scrambler seed 0x%08x from CMOS 0x%02x\n", + pei_data->scrambler_seed_s3, CMOS_OFFSET_MRC_SEED_S3); + + /* Compute seed checksum and compare */ + c1 = compute_ip_checksum((u8*)&pei_data->scrambler_seed, + sizeof(u32)); + c2 = compute_ip_checksum((u8*)&pei_data->scrambler_seed_s3, + sizeof(u32)); + checksum = add_ip_checksums(sizeof(u32), c1, c2); + + seed_checksum = cmos_read(CMOS_OFFSET_MRC_SEED_CHK); + seed_checksum |= cmos_read(CMOS_OFFSET_MRC_SEED_CHK+1) << 8; + + if (checksum != seed_checksum) { + printk(BIOS_ERR, "%s: invalid seed checksum\n", __func__); + pei_data->scrambler_seed = 0; + pei_data->scrambler_seed_s3 = 0; + return; + } + + if ((mrc_cache = find_current_mrc_cache()) == NULL) { + /* error message printed in find_current_mrc_cache */ + return; + } + + pei_data->mrc_input = mrc_cache->mrc_data; + pei_data->mrc_input_len = mrc_cache->mrc_data_size; + + printk(BIOS_DEBUG, "%s: at %p, size %x checksum %04x\n", + __func__, pei_data->mrc_input, + pei_data->mrc_input_len, mrc_cache->mrc_checksum); +} + +static const char* ecc_decoder[] = { + "inactive", + "active on IO", + "disabled on IO", + "active" +}; + +/* + * Dump in the log memory controller configuration as read from the memory + * controller registers. + */ +static void report_memory_config(void) +{ + u32 addr_decoder_common, addr_decode_ch[2]; + int i; + + addr_decoder_common = MCHBAR32(0x5000); + addr_decode_ch[0] = MCHBAR32(0x5004); + addr_decode_ch[1] = MCHBAR32(0x5008); + + printk(BIOS_DEBUG, "memcfg DDR3 clock %d MHz\n", + (MCHBAR32(0x5e04) * 13333 * 2 + 50)/100); + printk(BIOS_DEBUG, "memcfg channel assignment: A: %d, B % d, C % d\n", + addr_decoder_common & 3, + (addr_decoder_common >> 2) & 3, + (addr_decoder_common >> 4) & 3); + + for (i = 0; i < ARRAY_SIZE(addr_decode_ch); i++) { + u32 ch_conf = addr_decode_ch[i]; + printk(BIOS_DEBUG, "memcfg channel[%d] config (%8.8x):\n", + i, ch_conf); + printk(BIOS_DEBUG, " ECC %s\n", + ecc_decoder[(ch_conf >> 24) & 3]); + printk(BIOS_DEBUG, " enhanced interleave mode %s\n", + ((ch_conf >> 22) & 1) ? "on" : "off"); + printk(BIOS_DEBUG, " rank interleave %s\n", + ((ch_conf >> 21) & 1) ? "on" : "off"); + printk(BIOS_DEBUG, " DIMMA %d MB width x%d %s rank%s\n", + ((ch_conf >> 0) & 0xff) * 256, + ((ch_conf >> 19) & 1) ? 16 : 8, + ((ch_conf >> 17) & 1) ? "dual" : "single", + ((ch_conf >> 16) & 1) ? "" : ", selected"); + printk(BIOS_DEBUG, " DIMMB %d MB width x%d %s rank%s\n", + ((ch_conf >> 8) & 0xff) * 256, + ((ch_conf >> 20) & 1) ? 16 : 8, + ((ch_conf >> 18) & 1) ? "dual" : "single", + ((ch_conf >> 16) & 1) ? ", selected" : ""); + } +} + +static void post_system_agent_init(struct pei_data *pei_data) +{ + /* If PCIe init is skipped, set the PEG clock gating */ + if (!pei_data->pcie_init) + MCHBAR32(0x7010) = MCHBAR32(0x7010) | 0x01; +} + +/** + * Find PEI executable in coreboot filesystem and execute it. + * + * @param pei_data: configuration data for UEFI PEI reference code + */ +void sdram_initialize(struct pei_data *pei_data) +{ + struct sys_info sysinfo; + int (*entry) (struct pei_data *pei_data) __attribute__ ((regparm(1))); + + report_platform_info(); + + /* Wait for ME to be ready */ + intel_early_me_init(); + intel_early_me_uma_size(); + + printk(BIOS_DEBUG, "Starting UEFI PEI System Agent\n"); + + memset(&sysinfo, 0, sizeof(sysinfo)); + + sysinfo.boot_path = pei_data->boot_mode; + + /* + * Do not pass MRC data in for recovery mode boot, + * Always pass it in for S3 resume. + */ + if (!recovery_mode_enabled() || pei_data->boot_mode == 2) + prepare_mrc_cache(pei_data); + + /* If MRC data is not found we cannot continue S3 resume. */ + if (pei_data->boot_mode == 2 && !pei_data->mrc_input) { + printk(BIOS_DEBUG, "Giving up in sdram_initialize: No MRC data\n"); + outb(0x6, 0xcf9); + halt(); + } + + /* Pass console handler in pei_data */ + pei_data->tx_byte = do_putchar; + + /* Locate and call UEFI System Agent binary. */ + entry = cbfs_boot_map_with_leak("mrc.bin", CBFS_TYPE_MRC, NULL); + if (entry) { + int rv; + rv = entry (pei_data); + if (rv) { + switch (rv) { + case -1: + printk(BIOS_ERR, "PEI version mismatch.\n"); + break; + case -2: + printk(BIOS_ERR, "Invalid memory frequency.\n"); + break; + default: + printk(BIOS_ERR, "MRC returned %x.\n", rv); + } + die("Nonzero MRC return value.\n"); + } + } else { + die("UEFI PEI System Agent not found.\n"); + } + +#if CONFIG_USBDEBUG_IN_ROMSTAGE + /* mrc.bin reconfigures USB, so reinit it to have debug */ + usbdebug_init(); +#endif + + /* For reference print the System Agent version + * after executing the UEFI PEI stage. + */ + u32 version = MCHBAR32(0x5034); + printk(BIOS_DEBUG, "System Agent Version %d.%d.%d Build %d\n", + version >> 24 , (version >> 16) & 0xff, + (version >> 8) & 0xff, version & 0xff); + + /* Send ME init done for SandyBridge here. This is done + * inside the SystemAgent binary on IvyBridge. */ + if (BASE_REV_SNB == + (pci_read_config16(PCI_CPU_DEVICE, PCI_DEVICE_ID) & BASE_REV_MASK)) + intel_early_me_init_done(ME_INIT_STATUS_SUCCESS); + else + intel_early_me_status(); + + post_system_agent_init(pei_data); + report_memory_config(); +} diff --git a/src/southbridge/intel/bd82x6x/Makefile.inc b/src/southbridge/intel/bd82x6x/Makefile.inc index a1256df..1e7225d 100644 --- a/src/southbridge/intel/bd82x6x/Makefile.inc +++ b/src/southbridge/intel/bd82x6x/Makefile.inc @@ -50,8 +50,8 @@ romstage-y += reset.c romstage-y += early_spi.c early_pch.c romstage-y += early_rcba.c
-romstage-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE) += early_me.c early_usb.c -romstage-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE) += early_me.c early_usb.c +romstage-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_MRC) += early_me.c early_usb.c +romstage-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE_MRC) += early_me.c early_usb.c romstage-$(CONFIG_NORTHBRIDGE_INTEL_IVYBRIDGE_NATIVE) += early_thermal.c early_pch_native.c early_me_native.c early_usb_native.c romstage-$(CONFIG_NORTHBRIDGE_INTEL_SANDYBRIDGE_NATIVE) += early_thermal.c early_pch_native.c early_me_native.c early_usb_native.c
