Tommie Lin has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/39968 )
Change subject: mb/google/octopus/variants/phaser: Disable xHCI compliance mode ......................................................................
BRANCH=octopus BUG=NONE TEST=Verified usb operation successfully.
Signed-off-by: tong.lin tong.lin@bitland.corp-partner.google.com Change-Id: I3e6ab6ec0c4865cf2467da900f13d18468ff356f --- M src/mainboard/google/octopus/variants/phaser/overridetree.cb 1 file changed, 3 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/39968/1
diff --git a/src/mainboard/google/octopus/variants/phaser/overridetree.cb b/src/mainboard/google/octopus/variants/phaser/overridetree.cb index 625c2a6..3ae365c 100644 --- a/src/mainboard/google/octopus/variants/phaser/overridetree.cb +++ b/src/mainboard/google/octopus/variants/phaser/overridetree.cb @@ -173,4 +173,7 @@ end end # - I2C 7 end + + # Disable compliance mode + register "DisableComplianceMode" = "1" end
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39968 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/39968/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/39968/1//COMMIT_MSG@8 PS1, Line 8: Please mention, why the mode is disabled.
Hello build bot (Jenkins),
Some usb devices exhibits signal loss which causes xHCI entering compliance mode. The resolution is to disable xHCI compliance mode.
BRANCH=octopus BUG=b:149723583 TEST=Verified usb operation successfully.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/39968/2
Tommie Lin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39968 )
Patch Set 2:
Dear Paul, According to the state of dongle to analyze in this issue: 149723583, due to LFPS timeout leading into compliance mode, but the root cause may still need us to use USB Protocol Analyzer to debug. At present, Intel provides a workaround reference, but we need to consider whether to use this CL.
Patch Set 2:
This change is ready for review.
https://review.coreboot.org/c/coreboot/+/39968/1//COMMIT_MSG@10 PS1, Line 10: BUG=NONE
Add the bug?
Yeah, I have added the bug in Patchset 2.
Patch Set 2:
Dear Paul, […]
As the bug is not public, please add a summary (similar to your comment) to the commit message.
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39968 )
Patch Set 2: Code-Review+1
(5 comments)
https://review.coreboot.org/c/coreboot/+/39968/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/39968/2//COMMIT_MSG@9 PS2, Line 9: usb USB
https://review.coreboot.org/c/coreboot/+/39968/2//COMMIT_MSG@9 PS2, Line 9: entering to enter
https://review.coreboot.org/c/coreboot/+/39968/2//COMMIT_MSG@9 PS2, Line 9: exhibits exhibit
https://review.coreboot.org/c/coreboot/+/39968/2//COMMIT_MSG@14 PS2, Line 14: usb USB
https://review.coreboot.org/c/coreboot/+/39968/2/src/mainboard/google/octopu... File src/mainboard/google/octopus/variants/phaser/overridetree.cb:
https://review.coreboot.org/c/coreboot/+/39968/2/src/mainboard/google/octopu... PS2, Line 177: Disable compliance mode Mention that this is for xHCI?
# Disable xHCI compliance mode
Marco Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39968 )
looks good to me and please address reviewer's comments. Thanks.
Hello build bot (Jenkins), Furquan Shaikh, Justin TerAvest, Angel Pons, Marco Chen, Wuxy -, Peichao Li, Karthik Ramasubramanian,
Since the first LFPS timeout causes xHCI to enter compliance mode, the SS hub cannot be enumerated. The resolution is to disable xHCI compliance mode.
BRANCH=octopus BUG=b:149723583 TEST=Verified USB operation successfully.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/39968/3
Patch Set 3:
(7 comments)
Done
Done
USB
Done
exhibit
Done
to enter
Done
USB
Done
Mention that this is for xHCI? […]
Done
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39968 )
Patch Set 3: Code-Review+2
Thanks!
Patch Set 3:
Dear Furquan,
Please kindly cherry-pick it into chromium master branch. Thanks a lot!
Best regards
Furquan Shaikh has submitted this change. ( https://review.coreboot.org/c/coreboot/+/39968 )
Signed-off-by: tong.lin tong.lin@bitland.corp-partner.google.com Change-Id: I3e6ab6ec0c4865cf2467da900f13d18468ff356f Reviewed-on: https://review.coreboot.org/c/coreboot/+/39968 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Furquan Shaikh furquan@google.com Reviewed-by: Angel Pons th3fanbus@gmail.com Reviewed-by: Marco Chen marcochen@google.com --- M src/mainboard/google/octopus/variants/phaser/overridetree.cb 1 file changed, 3 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Marco Chen: Looks good to me, approved Angel Pons: Looks good to me, approved
diff --git a/src/mainboard/google/octopus/variants/phaser/overridetree.cb b/src/mainboard/google/octopus/variants/phaser/overridetree.cb index 625c2a6..b80d031 100644 --- a/src/mainboard/google/octopus/variants/phaser/overridetree.cb +++ b/src/mainboard/google/octopus/variants/phaser/overridetree.cb @@ -173,4 +173,7 @@ end end # - I2C 7 end + + # Disable xHCI compliance mode + register "DisableComplianceMode" = "1" end
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/39968 )
Patch Set 4:
Automatic boot test returned (PASS/FAIL/TOTAL): 3/0/3 Emulation targets: EMULATION_QEMU_X86_Q35 using payload TianoCore : SUCCESS : https://lava.9esec.io/r/2144 EMULATION_QEMU_X86_Q35 using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2143 EMULATION_QEMU_X86_I440FX using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/2142
