Attention is currently required from: Furquan Shaikh, Caveh Jalali, Tim Wawrzynczak. Hello build bot (Jenkins), Furquan Shaikh, Caveh Jalali, Tim Wawrzynczak, Paul Menzel,
https://review.coreboot.org/c/coreboot/+/56928
Change subject: mb/google/poppy/variants/atlas: stop setting touchscreen probed=1 ......................................................................
This allows the touchscreen ACPI device in Linux to re-enumerate when rebinding its I2C adapter device.
Without this change, after rebinding the touchscreen's I2C adapter device using sysfs, the touchscreen ACPI and HID devices are absent, and the touchscreen is unresponsive.
With this change, the touchscreen ACPI and HID devices are re-created after rebinding its I2C adapter device, and the touchscreen becomes responsive again.
BUG=b:177350937 TEST=Tested on 2 Atlas DUTs running CrOS top-of-tree builds with Linux 4.4 and 5.4.
Built new AP FW with this change applied in Atlas CrOS firmware branch. Tested shipping RO + new RW, and tested new RO + new RW.
Test sequence:
1) Boot DUT, verify basic touchscreen functionality.
2) $ cd /sys/bus/platform/drivers/i2c_designware
3) $ ls -ld i2c_designware.0{,/i2c-6{,/i2c-ACPI0C50:00{,/0018:0483:1058.*{,/hidraw{,/hidraw*}}}}} lrwxrwxrwx. 1 root root 0 Aug 12 01:07 i2c_designware.0 -> ../../../../devices/pci0000:00/0000:00:15.0/i2c_designware.0 drwxr-xr-x. 5 root root 0 Aug 12 01:07 i2c_designware.0/i2c-6 drwxr-xr-x. 4 root root 0 Aug 12 01:07 i2c_designware.0/i2c-6/i2c-ACPI0C50:00 drwxr-xr-x. 5 root root 0 Aug 12 01:07 i2c_designware.0/i2c-6/i2c-ACPI0C50:00/0018:0483:1058.0002 drwxr-xr-x. 3 root root 0 Aug 12 01:07 i2c_designware.0/i2c-6/i2c-ACPI0C50:00/0018:0483:1058.0002/hidraw drwxr-xr-x. 3 root root 0 Aug 12 01:07 i2c_designware.0/i2c-6/i2c-ACPI0C50:00/0018:0483:1058.0002/hidraw/hidraw1
4) $ echo i2c_designware.0 > unbind
5) Verify touchscreen is unresponsive.
6) $ ls -ld i2c_designware.0 ls: cannot access 'i2c_designware.0': No such file or directory
7) $ echo i2c_designware.0 > bind
*** Without this change: ***
8) Touchscreen remains unresponsive.
9) $ ls -ld i2c_designware.0{,/i2c-6{,/i2c-ACPI0C50:00}} ls: cannot access 'i2c_designware.0/i2c-6/i2c-ACPI0C50:00': No such file or directory lrwxrwxrwx. 1 root root 0 Aug 12 01:18 i2c_designware.0 -> ../../../../devices/pci0000:00/0000:00:15.0/i2c_designware.0 drwxr-xr-x. 4 root root 0 Aug 12 01:18 i2c_designware.0/i2c-6
*** With this change: ***
8) Touchscreen is functional again.
9) $ ls -ld i2c_designware.0{,/i2c-6{,/i2c-ACPI0C50:00{,/0018:0483:1058.*{,/hidraw{,/hidraw*}}}}} lrwxrwxrwx. 1 root root 0 Aug 12 01:09 i2c_designware.0 -> ../../../../devices/pci0000:00/0000:00:15.0/i2c_designware.0 drwxr-xr-x. 5 root root 0 Aug 12 01:09 i2c_designware.0/i2c-6 drwxr-xr-x. 4 root root 0 Aug 12 01:09 i2c_designware.0/i2c-6/i2c-ACPI0C50:00 drwxr-xr-x. 5 root root 0 Aug 12 01:09 i2c_designware.0/i2c-6/i2c-ACPI0C50:00/0018:0483:1058.0003 drwxr-xr-x. 3 root root 0 Aug 12 01:09 i2c_designware.0/i2c-6/i2c-ACPI0C50:00/0018:0483:1058.0003/hidraw drwxr-xr-x. 3 root root 0 Aug 12 01:09 i2c_designware.0/i2c-6/i2c-ACPI0C50:00/0018:0483:1058.0003/hidraw/hidraw1
Signed-off-by: Matthew Blecker matthewb@chromium.org Change-Id: I7b90690b0591e8748d7a007f8cc9688d393e59db --- M src/mainboard/google/poppy/variants/atlas/devicetree.cb 1 file changed, 0 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/56928/5
